DF3-4S-2C
DF3-4S-2C
    HRS(广濑)
    Housings
    4Pins 250VAC 3A 10.00 x 6.80mm Black
DF3-4S-2C 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 2mm Pitch Connector for Discrete Wire Connection(Product approved by UL CSA Standard) DF3 Series ■Features Correspond to Board Design in Wide Variation ●ID Socket (1) Low profile design with the mounting height of 6.8mm (2) Achieves the multi-harness by the full automatic ID machine in combination with the DF11 series ID type. (DF11 series represents the 2mm pitch single-row product.Please refer to page B220 to B233.) ●Crimp Socket (1) Low profile design with mounting height 7.5mm. (2) Provide the contact crimping area with the sufficient space, and secures the stable crimping operation. ●Receptacle (1) The board can be connected horizontally or vertically in combination with the straight header with the right angle header. (2) For horizontal connection, the board to board size is the low profile of 6.6mm. (3) Compatibility with the in-line plug allows the receptacle to set the board side to the receptacle and the cable side to the plug in the board to cable connection. ●Pin Header (1) The board pre-fixed kink is treated with the post pin. (2) The style employs a scoop-proof and sturborn box type. (3) The type corresponding to SMT is avilable, using the heat-proof resin. This SMT header is equipped with the metal tab to prevent peeling in the solder joint area. ●In-line Plug (1) The crimping in-line plug consits of two types, one type, which has pursued after space merits, and the other employs the panel lock type, which can be fixed to the panel. (2) The in-line adapter is available to insert and in-line the ID socket from both sides. ■Applications Business equipment such as copy machine and printer B207 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) ■Product Specifications Crimping Current rating Rating Wire size Note 1 IDC Voltage rating AC100V Crimping AWG#22 to 24 :3A Operating Temperature Range -30ç to +85ç Note 2. AWG#26 :2A Operating Humidity Range AWG#28 :1A Wire size AWG 26, 28:1A Press-fit: 250V AC IDC Storage Temperature Range -10ç to +60ç Note 3. Press-connect: 100V AC Storagg Humidity Range UL-CSA Safety Standard and Approved specification Rated Current Wire size Rating Rated Voltage AWG 24 to 28: 1A 30V AC Item 40% to 70% Note 3. ■UL CSA Safety Standard File No. UL :E52653 CSA :LR95109 ■UL CSA Acquisition Objective Item 1DF3-*S-2C 2DF3/3A-*P-2DSA/DS 3DF3/DF3AA-*EP-2C 4DF3-*S-2R26/28 5DF3-*P-2H Specification Condition 1. Insulation Resistance 1000M ohms min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 30m ohms max 100mA 4. Single Insertor/Extraction Force MIN0.3N (30gf), MAX4.4N(450gf) 5. Vibration 40% to 80% Measure by the square steel pin with 0.5±0.002mm No electrical discontinuity of 1µs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 6. Humidity (Steady state) Contact resistance: 30m ohms max.Insulation resistance: 500M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 7. Temperature Cycle (-55ç: 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10minutes) 5 cycles Contact resistance: 30m ohms max.:Insulation resistance: 1000M ohms min. 8. Durability (Mating/un-mating) Contact resistance: 30m ohms max. Tin plating: 30 cycles Gold plating: 50 cycles 9. Resistance to Soldering Heat No deformation of components affecting performance. Flow: 260ç for 10 seconds Manual soldering: 300ç for 2 seconds Reflow: At the recommended temperature profile Manual soldering: 300ç for 3 seconds Note 1: Current rating of header is 3A. Note 2: Includes temperature rise caused by current flow. Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Crimping Socket Insulator IDC Contact for Socket Contact ID Socket Receptacle Pin Header SMT Pin Header Finish Remarks Polyamide Black UL94V-0 Phosphor bronze Tin plated or gold plated ––––––– Insulator Polyamide Black UL94V-0 Contact Phosphor bronze Tin plated or gold plated ––––––– Insulator Polyamide Black UL94V-0 Contact Phosphor bronze Tin plated or gold plated ––––––– Insulator Polyamide Black UL94V-0 Contact Brass Tin plated or gold plated ––––––– Insulator Polyamide Beige UL94V-0 Contact Brass Tin plated or gold plated ––––––– Metal tab Brass Tin plated ––––––– In-line Plug Insulator Polyamide Black UL94V-0 In-line IDC Contact Contact Phosphor bronze Tin plated or gold plated ––––––– Insulator Polyamide Black UL94V-0 Contact Brass Tin plated ––––––– In-line Adapter B208 Materia The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) ■Ordering Information ●Connector DF3 - * S - 2C q w e rt : DF3, 3A, 3AA t Connection Form/Contact Style q Series Name w Number of Contacts : 2~15 C e Connector Type R26 : ID socket for AWG26 : Crimp socket S : Socket R28 : ID socket for AWG28 P : Pin Header DSA : Straight through hole EP : In-line Plug DS : Right angle through hole : 2mm V : Straight SMT H : Right angle SMT A : Adapter r Contact Pitch ●Contact DF3 - EP2428PCFA q q Contact Type w e r e Contact Type/Packaging Type Blank : For socket SCF : Socket contact, Reel EP SC : Socket contact, Bag PCF : Plug contact, Reel PC : Plug contact, Bag : For in-line plug w Applicable Wire Size 22 : AWG#22 2428 : AWG#24 to#28 r Plating Type Blank : Tin plated A : Gold plated (Plug contact) C : Gold plated (Socket contact) ■Application pattern DF3-πS-2R**(05) DF3Z-πP-2H DF3-πS-2R**(05) DF3Z-πP-2V DF3Z-πP-2H DF3Z-πP-2V DF3-πS-2DSA(25) DF3Z-πP-2H DF3Z-πP-2V B209 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) ■ID Socket [Specific No.]–* *, (* *) (01) : Gold plated, 100 pieces per bag (05) : Tin plated, 100 pieces per bag (25) : Tin plated, Tube packaging This picture shows the cable assembled status. Note 1. Mark to determine the socket name Mark6: R26, Mark8: R28 ●AWG#28 Unit: mm Unit: mm Number of Tube packaging Number of Tube packaging Part Number CL No. A B RoHS Part Number CL No. A B RoHS Contacts Quantity Contacts Quantity DF3- 2S-2R26(**) 543-0078-7-** 2 6 2 190 pieces DF3- 2S-2R28(**) 543-0092-8-** 2 6 2 190 pieces DF3- 3S-2R26(**) 543-0079-0-** 3 8 4 142 DF3- 3S-2R28(**) 543-0093-0-** 3 8 4 142 DF3- 4S-2R26(**) 543-0080-9-** 4 10 6 114 DF3- 4S-2R28(**) 543-0094-3-** 4 10 6 114 DF3- 5S-2R26(**) 543-0081-1-** 5 12 8 94 DF3- 5S-2R28(**) 543-0095-6-** 5 12 8 94 DF3- 6S-2R26(**) 543-0082-4-** 6 14 10 80 DF3- 6S-2R28(**) 543-0096-9-** 6 14 10 80 DF3- 7S-2R26(**) 543-0083-7-** 7 16 12 70 DF3- 7S-2R28(**) 543-0097-1-** 7 16 12 70 DF3- 8S-2R26(**) 543-0084-0-** 8 18 14 62 DF3- 8S-2R28(**) 543-0098-4-** 8 18 14 62 YES YES DF3- 9S-2R26(**) 543-0085-2-** 9 20 16 56 DF3- 9S-2R28(**) 543-0099-7-** 9 20 16 56 DF3-10S-2R26(**) 543-0086-5-** 10 22 18 52 DF3-10S-2R28(**) 543-0100-4-** 10 22 18 52 DF3-11S-2R26(**) 543-0087-8-** 11 24 20 46 DF3-11S-2R28(**) 543-0101-7-** 11 24 20 46 DF3-12S-2R26(**) 543-0088-0-** 12 26 22 44 DF3-12S-2R28(**) 543-0102-0-** 12 26 22 44 DF3-13S-2R26(**) 543-0089-3-** 13 28 24 40 DF3-13S-2R28(**) 543-0103-2-** 13 28 24 40 DF3-14S-2R26(**) 543-0090-2-** 14 30 26 38 DF3-14S-2R28(**) 543-0104-5-** 14 30 26 38 DF3-15S-2R26(**) 543-0091-5-** 15 32 28 34 DF3-15S-2R28(**) 543-0105-8-** 15 32 28 34 Note 2.The quantity for delivery of the specific No. (01) and (05) is determined per bag (100pcs.). If needed, please order the productsper bag. Note 3.If the Full automatic IDC machine to hit the DF11 single core,the (25) tube packaging specification will be applied. Note 4.Order the tube packaging product, multiplying the tube packaging quantity (pieces). ●AWG#26 ■Applicable Cable Part Number Applicable Cable Jacket Diameter DF3-*S-2R26(**) UL1061 AWG#26 (7/0.16) Ø0.9 to 1mm DF3-*S-2R28(**) UL1061 AWG#28 (7/0.127) Ø0.9 to 1mm ■Applicable ID Connection Tool B210 Type Part Number DF11 Single Contact Punching Full Automatic ID Machine AM700/DF11 DF3 DF4 Desktop ID Machine SA701/DF3 Connection Type ■ Effective Harness Form 1DF11-Both ended, single ended 2DF11-DF11, Separation 3DF11-DF3, Separation ■ Effective Harness Length 100 to 2,000mm ■ Conduction Inspection Mechanism Installed DF3 No restriction DF4 No restriction Remarks Connector is the specification (25). Tube packaging applied Desktop machine for small lot The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) ■Crimping Socket [Specific No.] –* *, (* *) Blank: 100 pieces per pack This picture shows the Contact crimped status. Unit: mm Number of Contacts A B DF3-2S-2C(**) 543-0003-8-** 2 06 02 DF3-3S-2C(**) 543-0004-0-** 3 08 DF3-4S-2C(**) 543-0005-3-** 4 10 DF3-5S-2C(**) 543-0006-6-** 5 12 08 DF3-6S-2C(**) 543-0007-9-** 6 14 10 DF3-7S-2C(**) 543-0008-1-** 7 16 12 Part Number CL No. Number of Contacts A B DF3-19S-2C(**) 543-0010-3-** 09 20 16 04 DF3-10S-2C(**) 543-0011-6-** 10 22 18 06 DF3-11S-2C(**) 543-0012-9-** 11 24 20 DF3-12S-2C(**) 543-0013-1-** 12 26 22 DF3-13S-2C(**) 543-0014-4-** 13 28 24 DF3-14S-2C(**) 543-0015-7-** 14 30 26 RoHS YES Part Number CL No. RoHS YES 14 28 18 32 8 15 DF3-8S-2C(**) 543-0009-4-** DF3-15S-2C(**) 543-0016-0-** Note1: The product's contact number indicated. Note2: The quantity for delivery of the specification No. "None" is determined per bag (100 pcs.). If needed, please order the products per bag. Note3: A quantity of "500 pieces package" and "1000 pieces package" for delivery is dealt with pieces. Order example: 500, 1000, and 1500 pieces... ■Receptacle [Specific No.] –* *, (* *) (25) :Tin plated, Tube packaging (55) :Gold plated, Tube packaging Note1: The product's contact number indicated ●Board Through-hole Diameter: Ø0.8++0.1 0 Unit: mm Part Number CL No. Number of Contacts A B Tube Package RoHS Quantity Part Number CL No. Number of Contacts A B Tube Package RoHS Quantity DF3-2S-2DSA(**) 543-0048-6-** 2 06 02 80 pieces DF3- 9S-2DSA(**) 543-0055-1-** 09 20 16 24 pieces DF3-3S-2DSA(**) 543-0049-9-** 3 08 04 60 DF3-10S-2DSA(**) 543-0056-4-** 10 22 18 21 DF3-4S-2DSA(**) 543-0050-8-** 4 10 06 48 DF3-11S-2DSA(**) 543-0057-7-** 11 24 20 20 DF3-5S-2DSA(**) 543-0051-0-** 5 12 08 40 DF3-12S-2DSA(**) 543-0058-0-** 12 26 22 18 DF3-6S-2DSA(**) 543-0052-3-** 6 14 10 34 DF3-13S-2DSA(**) 543-0059-2-** 13 28 24 17 DF3-7S-2DSA(**) 543-0053-6-** 7 16 12 30 DF3-14S-2DSA(**) 543-0060-1-** 14 30 26 16 18 14 27 8 DF3-8S-2DSA(**) 543-0054-9-** DF3-15S-2DSA(**) 543-0061-4-** Note2: Please order the tube packaging at the multiplied tube packaging quantity (pieces). 15 32 28 15 YES YES B211 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) ■Straight Pin Header ●Board Through-hole Diameter: Ø0.8++0.1 0 ●Kink Pre-fixed Effective Diameter: Ø0.8++0.05 0 Unit: mm Tin Plating Gold Plating Part Number CL No. Part Number CL No. 543-0017-2-01 543-0165-0 DF3A- 2P-2DSA DF3- 2P-2DSA(01) 543-0018-5-01 543-0166-2 DF3A- 3P-2DSA DF3- 3P-2DSA(01) 543-0019-8-01 543-0167-5 DF3A- 4P-2DSA DF3- 4P-2DSA(01) 543-0020-7-01 543-0168-8 DF3A- 5P-2DSA DF3- 5P-2DSA(01) 543-0021-0-01 543-0169-0 DF3A- 6P-2DSA DF3- 6P-2DSA(01) 543-0022-2-01 543-0170-0 DF3A- 7P-2DSA DF3- 7P-2DSA(01) 543-0023-5-01 543-0171-2 DF3A- 8P-2DSA DF3- 8P-2DSA(01) 543-0024-8-01 543-0172-5 DF3A- 9P-2DSA DF3- 9P-2DSA(01) 543-0025-0-01 543-0173-8 DF3A-10P-2DSA DF3-10P-2DSA(01) 543-0026-3-01 543-0174-0 DF3A-11P-2DSA DF3-11P-2DSA(01) 543-0027-6-01 543-0175-3 DF3A-12P-2DSA DF3-12P-2DSA(01) 543-0028-9-01 543-0176-6 DF3A-13P-2DSA DF3-13P-2DSA(01) 543-0029-1-01 543-0177-9 DF3A-14P-2DSA DF3-14P-2DSA(01) 543-0030-0-01 543-0178-1 DF3A-15P-2DSA DF3-15P-2DSA(01) Note : The quantity for delivery is determined per bag (100 pcs.). If needed, please order the products per bag. Number of Contacts A 2 3 4 5 6 7 8 9 10 11 12 13 14 15 06 08 10 12 14 16 18 20 22 24 26 28 30 32 B RoHS 02 04 06 08 10 12 14 YES 16 18 20 22 24 26 28 ■Right Angle Pin Header ●Board Through-hole Diameter: Ø0.8++0.1 0 ●Kink Pre-fixed Effective Diameter: Ø0.8++0.05 0 Unit: mm Tin Plating Gold Plating Part Number CL No. Part Number CL No. 543-0179-4 543-0031-3-01 DF3A- 2P-2DS DF3- 2P-2DS(01) 543-0180-3 543-0032-6-01 DF3A- 3P-2DS DF3 -3P-2DS(01) 543-0181-6 543-0033-9-01 DF3A- 4P-2DS DF3- 4P-2DS(01) 543-0182-9 543-0034-1-01 DF3A- 5P-2DS DF3- 5P-2DS(01) 543-0183-1 543-0035-4-01 DF3A- 6P-2DS DF3- 6P-2DS(01) 543-0184-4 543-0036-7-01 DF3A- 7P-2DS DF3- 7P-2DS(01) 543-0185-7 543-0037-0-01 DF3A- 8P-2DS DF3- 8P-2DS(01) 543-0186-0 543-0038-2-01 DF3A- 9P-2DS DF3- 9P-2DS(01) 543-0187-2 543-0039-5-01 DF3A-10P-2DS DF3-10P-2DS(01) 543-0188-5 543-0040-4-01 DF3A-11P-2DS DF3-11P-2DS(01) 543-0189-8 543-0041-7-01 DF3A-12P-2DS DF3-12P-2DS(01) 543-0190-7 543-0042-0-01 DF3A-13P-2DS DF3-13P-2DS(01) 543-0191-0 543-0043-2-01 DF3A-14P-2DS DF3-14P-2DS(01) 543-0192-2 543-0044-5-01 DF3A-15P-2DS DF3-15P-2DS(01) Note : The quantity for delivery is determined per bag(100 pcs.). If needed, please order the products per bag. B212 Number of Contacts A 2 3 4 5 6 7 8 9 10 11 12 13 14 15 06 08 10 12 14 16 18 20 22 24 26 28 30 32 B RoHS 02 04 06 08 10 12 14 YES 16 18 20 22 24 26 28 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) ■Straight Pin Header (SMT) BPCB mounting pattern C Note : If a pattern is included in the shaded area and is not treated with resist, it could touch the connector contact. [Specific No.] –* *, (* *) (21) :Tin plated packaging (51) :Gold plated packaging Unit: mm Without Boss Part Number CL No. Number of Contacts A DF3DZ- 2P-2V(**) 0543-1056-0-** 2 02 08.5 08.74 DF3DZ- 3P-2V(**) 0543-1057-2-** 3 04 10.5 10.74 DF3DZ- 4P-2V(**) 0543-1058-5-** 4 06 12.5 12.74 DF3DZ- 5P-2V(**) 0543-1059-8-** 5 08 14.5 14.74 DF3DZ- 6P-2V(**) 0543-1060-7-** 6 10 16.5 16.74 DF3DZ- 7P-2V(**) 0543-1061-0-** 7 12 18.5 18.74 DF3DZ- 8P-2V(**) 0543-1062-2-** 8 14 20.5 20.74 DF3DZ- 9P-2V(**) 0543-1063-5-** 9 16 22.5 22.74 DF3DZ-10P-2V(**) 0543-1064-8-** 10 18 24.5 24.74 DF3DZ-11P-2V(**) 0543-1065-0-** 11 20 26.5 26.74 DF3DZ-12P-2V(**) 0543-1066-3-** 12 22 28.5 28.74 DF3DZ-13P-2V(**) 0543-1067-6-** 13 24 30.5 30.74 DF3DZ-14P-2V(**) 0543-1068-9-** 14 26 32.5 32.74 B C RoHS YES 15 0543-1069-1-** DF3DZ-15P-2V(**) 28 34.5 34.74 Note1: Please order the emboss packaging product by the reel number. (1 reel : 1000 pcs.) Note2: Embossed packaging products have the reel wrapped in polyethylene and include a desiccant. Note3: Small blisters of the molding compounds in small areas will not affect from,fit or function. B213 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) ■Right Angle Pin Header (SMT) BPCB mounting pattern D [Specific No.] –* *, (* *) (21) :Tin plated embossed packaging (Note the number of contacts for marchandization.) (51) :Gold plated embossded packaging Unit: mm Without Boss Part Number CL No. Number of Contacts A DF3DZ- 2P-2H(**) 0543-1070-0-** 2 02 08.5 08.74 DF3DZ- 3P-2H(**) 0543-1071-3-** 3 04 10.5 10.74 DF3DZ- 4P-2H(**) 0543-1072-6-** 4 06 12.5 12.74 DF3DZ- 5P-2H(**) 0543-1073-9-** 5 08 14.5 14.74 DF3DZ- 6P-2H(**) 0543-1074-1-** 6 10 16.5 16.74 DF3DZ- 7P-2H(**) 0543-1075-4-** 7 12 18.5 18.74 DF3DZ- 8P-2H(**) 0543-1076-7-** 8 14 20.5 20.74 DF3DZ- 9P-2H(**) 0543-1077-0-** 9 16 22.5 22.74 DF3DZ-10P-2H(**) 0543-1078-2-** 10 18 24.5 24.74 DF3DZ-11P-2H(**) 0543-1079-5-** 11 20 26.5 26.74 DF3DZ-12P-2H(**) 0543-1080-4-** 12 22 28.5 28.74 DF3DZ-13P-2H(**) 0543-1081-7-** 13 24 30.5 30.74 DF3DZ-14P-2H(**) 0543-1082-0-** 14 26 32.5 32.74 B C RoHS YES 15 28 34.5 34.74 0543-1083-2-** DF3DZ-15P-2H(**) Note1: Please order the emboss packaging product by the reel number. (1 reel : 1000 pcs.) Note2: Embossed packaging products have the reel wrapped in polyethylene and include a desiccant. Note3: Small blisters of the molding compounds in small areas will not affect from,fit or function. B214 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) ■In-line Plug Photo: Contact inserted status Number of Contacts Part Number CL No. 543-0064-2 2 DF3- 2EP-2C 3 543-0065-5 DF3- 3EP-2C 4 543-0066-8 DF3- 4EP-2C 5 543-0067-0 DF3- 5EP-2C 6 543-0068-3 DF3- 6EP-2C 7 543-0069-6 DF3- 7EP-2C 8 543-0070-5 DF3- 8EP-2C Note : The specific No."None" item is delivered Number of Contacts A B RoHS Part Number CL No. 02 06 543-0071-8 09 DF3- 9EP-2C 04 08 10 543-0072-0 DF3-10EP-2C 06 10 11 543-0073-3 DF3-11EP-2C 08 YES 12 12 543-0074-6 DF3-12EP-2C 10 14 13 543-0075-9 DF3-13EP-2C 12 16 14 543-0076-1 DF3-14EP-2C 14 18 15 543-0077-4 DF3-15EP-2C per bag (100 pcs.). Please order products per bag unit. ■In-line Plug with Panel Lock A 20 22 24 26 28 30 32 B 16 18 20 22 24 26 28 Unit: mm RoHS YES BPanel Cutouts Photo: Contact insertion status Number of Contacts A Part Number CL No. B 2 06 DF3AA- 2EP-2C 543-0151-5 11 3 08 DF3AA- 3EP-2C 543-0152-8 13 4 10 DF3AA- 4EP-2C 543-0153-0 15 5 12 DF3AA- 5EP-2C 543-0154-3 17 6 14 DF3AA- 6EP-2C 543-0155-6 19 7 16 DF3AA- 7EP-2C 543-0156-9 21 8 18 DF3AA- 8EP-2C 543-0157-1 23 9 20 DF3AA- 9EP-2C 543-0158-4 25 10 22 DF3AA-10EP-2C 543-0159-7 27 11 24 DF3AA-11EP-2C 543-0160-6 29 12 26 DF3AA-12EP-2C 543-0161-9 31 13 28 DF3AA-13EP-2C 543-0162-1 33 14 30 DF3AA-14EP-2C 543-0163-4 35 15 32 DF3AA-15EP-2C 543-0164-7 37 Note : Delivered per bag (100 pcs.). Please order products C 02 04 06 08 10 12 14 16 18 20 22 24 26 28 per Unit: mm D E RoHS 9.4 6.3 11.4 8.3 13.4 10.3 15.4 12.3 17.4 14.3 19.4 16.3 21.4 18.3 YES 23.4 20.3 25.4 22.3 27.4 24.3 29.4 26.3 31.4 28.3 33.4 30.3 35.4 32.3 bag unit. Note1: Applicable panel thickness is 1.6 to 1.0mm. (However, a slight backlash is considered for the thickness other than 1.6 and 1.2mm.) Note2: Use the non-radius surface at the hooking panel edge. Note3: Contact No. indicates 1, 4, 8, 12, and 15. [Specific No.] –* *, (* *) Blank : 100 pcs. per bag B215 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) ■In-line Adapter with Panel Lock BPanel Cutouts Adapter to in-line by pushing 2 pcs. of socket from both sides No.1-No.1 connection circuit type Unit: mm Part Number CL No. Number of Contacts A B C D E DF3- 2EP-2A 543-0267-0 2 11 06 02 9.4 6.3 DF3- 3EP-2A 543-0268-2 3 13 08 04 11.4 8.3 DF3- 4EP-2A 543-0269-5 4 15 10 06 13.4 10.3 DF3- 5EP-2A 543-0270-4 5 17 12 08 15.4 12.3 DF3- 6EP-2A 543-0271-7 6 19 14 10 17.4 14.3 DF3- 7EP-2A 543-0272-0 7 21 16 12 19.4 16.3 DF3- 8EP-2A 543-0273-2 8 23 18 14 21.4 18.3 DF3- 9EP-2A 543-0274-5 9 25 20 16 23.4 20.3 DF3-10EP-2A 543-0275-8 10 27 22 18 25.4 22.3 DF3-11EP-2A 543-0276-0 11 29 24 20 27.4 24.3 DF3-12EP-2A 543-0277-3 12 31 26 22 29.4 26.3 DF3-13EP-2A 543-0278-6 13 33 28 24 31.4 28.3 DF3-14EP-2A 543-0279-9 14 35 30 26 33.4 30.3 DF3-15EP-2A 543-0280-8 15 37 32 28 35.4 32.3 Note : Delivered per bag (100 pcs.). Please order products per bag unit. B216 RoHS Note1: Applicable panel thickness is 1.6 to 1.0mm.(However,backlash will occur except for 1.6, 1.2mm thickness.) Note2: Please use the non-radius surface at the hooking panel edge. YES The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) ■Crimping Contact for Socket Part Number CL No. Type Quantity Finish DF3-22SCF 543-0235-3 Reel contact 10000 pcs. per reel DF3-22SC 543-0236-6 Bulk contact 100 pcs. DF3-22SCFC 543-0861-0 Reel contact 10000 pcs. per reel DF3-22SCC 543-0862-3 Bulk contact 100 pcs. DF3-2428SCF 543-0001-2 Reel contact 10000 pcs. per reel DF3-2428SC 543-0002-5 Bulk contact 100 pcs. DF3-2428SCFC 543-0046-0 Reel contact 10000 pcs. per reel DF3-2428SCC 543-0047-3 Bulk contact 100 pcs. per pack per pack per pack per pack ●Applicable Wire (Tin Plating Annealed Copper Wire) Conductor Size (Wire Configuration) Jacket Diameter AWG#22 (17pcs./0.16mm) Ø1.2 to Ø1.45mm RoHS Tin plated Gold plated YES Tin plated Gold plated ●Recommended Wire UL1061, UL1007 (Note 2.) ●Strip Length 1.8 to 2.3mm AWG#24 (11pcs./0.16mm) AWG#26 (7pcs./0.16mm) Ø0.75 to Ø1.45mm AWG#28 (7pcs./0.127mm) Note1: If other wires are used instead of the applicable cable, please contact HRS company. Note2: DF3-22SCF is applicable to UL1061. ■Crimping Contact for In-line Plug Part Number CL No. Type Quantity Finish DF3-EP2428PCF 543-0062-7 Reel contact 10000 pcs. per reel DF3-EP2428PC 543-0063-0 Bulk contact 100 pcs. per pack DF3-EP2428PCFA 543-0149-3 Reel contact 10000 pcs. per reel DF3-EP2428PCA 100 pcs. 543-0150-2 Bulk contact per pack ●Applicable Wire (Tin Plating Annealed Copper Wire) Conductor Size (Wire Configuration) Jacket Diameter Tin plated YES Gold plated ●Recommended Wire UL1061, UL1007 ●Strip Length 1.9 to 2.5mm AWG#24 (11pcs./0.16mm) AWG#26 (7pcs./0.16mm) RoHS Ø0.75 to Ø1.45mm AWG#28 (7pcs./0.127mm) Note1: If other wires are used instead of the applicable cable, please contact HRS company. BApplicable Crimping Tool Type Applicator Press Unit Hand Crimping Tool Extraction Tool Part Number CL No. Applicable Contact AP105-DF3-2428S 901-4503-3 DF3-2428SCF/SCFC AP105-DF3-22S 901-4549-4 DF3-22SCF AP105-DF3-EP2428P 901-4508-7 DF3-EP2428PCF/PCFA CM-105 901-0005-4 ––––––––––––––––––– DF3-TA2428HC 550-0164-5 DF3-2428SC/SCC DF3EP-TA2428HC 550-0184-2 DF3-EP2428PC/PCA DF3-TA22HC 550-0257-4 DF3-22SC DF-C-PO (A) 550-0170-8 DF3-****SCF DF3-EP****PCF Note : If any trouble has occurred due to tools other than designated tool, Hirose bears no respoisibility for any trouble. B217 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. PleaseWire checkConnection(Product the products status on the Hirose website RoHS at www.hirose-connectors.com, or contact your Hirose sales representative. DF3 Series●2mm Pitch Connector for Discrete approved bysearch UL CSA Standard) BEmbossed Carrier Tape Dimensions ●Straight Pin Header 1. 1 0. + 0 5 4±0.1 12±0.1 E 6.4±0.3 1.5±0.3 0.4±0.1 0.2 φ 2 ±0.1 1.75 ±0.1 E-E .8 φ370±2 C±0.3 B±0.1 φ21±0 (φ80 ) A±0.1 φ 13 ± 2±0.5 D +20 0.2 E .75 R0 1.7 +0.05 0 (D+6) MAX Unreeling direction 1.5 +0.1 0 Unit: mm Product Type Size Number of Contacts A B C D 2 to 4 24.0 ––– 11.5 24.4 5 to 7 32.0 28.4 14.2 32.4 8 to 10 44.0 40.4 20.2 44.4 11 to 15 56.0 52.4 26.2 56.4 DF3DZ-*P-2V ●Right Angle Pin Header 12±0.1 4±0.1 1 0. + 0 E 5 1. Ø 1.75±0.1 2±0.1 2±0.5 E–E Ø80 B±0.1 A±0.3 Ø13±0.2 Ø370±2 C±0.1 Carrier hole length E Unreeling direction 0 1.5 +0.1 0.2 0 1.7 +0.01 .75 R0 0 D+0.2 0.4±0.1 (D+6)MAX 6.1±0.3 1.6±0.3 Unit: mm Product Type DF3DZ-*P-2H B218 Size Number of Contacts A B C D 2 to 4 24.0 ––– 11.5 24.4 5 to 7 32.0 28.4 14.2 32.4 8 to 10 44.0 40.4 20.2 44.4 11 to 15 56.0 52.4 26.2 56.4 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please checkPitch the products status on for the Hirose websiteWire RoHS search at www.hirose-connectors.com, or contact representative. DF3 Series●2mm Connector Discrete Connection(Product approved by your UL Hirose CSA sales Standard) BPrecautions 1. Recommended Temperature Profile (SMT) temperature (ç) 10s max 250 230 200 180±10 60s max Soldering 150 100 to 120s Preheating 100 Time (S) Note1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note2: The temperature profile indicates the board surface temperature at the point of cintacts with the connector terminals. 2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 290±10ç, Soldering time: Within 3 seconds 3. Recommended Screen Thickness (SMT) 0.15 to 0.2mm 4. Board Warpage (SMT) 5. Recommended Soldering Condition (DIP) Based on both connector edges, 0.03mm max. in the connector center portion ■Flow Condition with Automatic Soldering Tool. Soldering temperature: 250±5ç, Soldering time: Within 10 seconds ■Manual Soldering Condition. Soldering iron temperature: 290±10ç, Soldering time: Within 2 seconds 6. Cleaning Condition Refer to the "Nylon Connector Use Hand book". 7. Connection Condition Refer to the "Nylon Connector Use Hand book". 8. Precations Refer to the "Nylon Connector Use Hand book". B219
DF3-4S-2C 价格&库存
很抱歉,暂时无法提供与“DF3-4S-2C”相匹配的价格&库存,您可以联系我们找货
DF3-4S-2C
  • 1+1.259501+0.15220
  • 10+0.7393010+0.08940
  • 100+0.61340100+0.07410
  • 500+0.58770500+0.07100
  • 1000+0.511901000+0.06190
  • 2500+0.461802500+0.05580
  • 50000+0.4280050000+0.05170
库存:27314
DF3-4S-2C
    • 10+0.29631
    • 100+0.23749
    • 300+0.20808
    库存:19
    DF3-4S-2C
    • 1+0.19759
    • 100+0.18459
    • 300+0.17159
    • 500+0.15859
    • 2000+0.15209
    • 5000+0.14819
    库存:92740
    DF3-4S-2C
      • 100+0.20150
      库存:4400
      DF3-4S-2C
        • 100+0.19712
        库存:27900
