CC1206KKX7RBBB103
CC1206KKX7RBBB103
    YAGEO(国巨)
    贴片电容(MLCC) 1206 10nF ±10% 500V X7R
CC1206KKX7RBBB103 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Mid-voltage: NP0/X7R (Pb Free & RoHS compliant) 100 V TO 500 V Product specification – Sep 08, 2005 V. 0 10 pF to 470 nF Product specification Surface-Mount Ceramic Multilayer Capacitors SCOPE ` This specification describes Midvoltage NP0/X7R series chip capacitors with lead-free terminations. NP0/X7R 100 V to 500 V 2 16 ORDERING INFORMATION Part number is identified by the series, size, tolerance, packing style, TC material, rated voltage and capacitance value. YAGEO ORDERING CODE CC XXXX X X XXX X (1) APPLICATIONS PCs, hard disk, game PCs Power supplies LCD panel ADSL, modem Mid-voltage (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) FEATURES Supplied in tape on reel Nickel-barrier end termination 1808 (4520) 1812 (4532) (2) TOLERANCE J = ±5% K = ±10% (3) PACKING STYLE R = 7” paper tape K = 7” blister tape P = 13” paper tape F = 13” blister tape C = Bulk case (4) TC MATERIAL NP0 X7R (5) RATED VOLTAGE 0 = 100 V A = 200 V Y = 250 V B = 500 V (6) PROCESS B = BME N = NME (7) CAPACITANCE VALUE: First two for significant figures and 3rd for number of zero Letter “R” for decimal point www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 3 16 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION Table 1 For dimension see Table 1 W T L2 L4 L1 L3 TYPE CC0603 CC0805 CC1206 CC1210 CC1808 CC1812 L1 (mm) 1.6 ±0.10 2.0 ±0.20 3.2±0.20 3.2 ±0.20 4.5 ±0.30 4.5 ±0.30 W (mm) 0.8 ±0.07 1.25 ±0.20 1.6±0.20 2.5 ±0.20 2.0 ±0.30 3.2 ±0.30 T (mm) MBB211 Fig. 2 Surface mounted multilayer ceramic capacitor dimension L2/L3 (mm) L4 (mm) Refer to table 2 to 7 min. 0.20 0.25 0.25 0.25 0.25 0.25 max. 0.50 0.75 0.75 0.75 0.75 0.75 min. 0.60 0.55 1.40 1.40 2.20 2.20 www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 4 16 CAPACITANCE RANGE & THICKNESS FOR NP0 100V Table 2 For NP0 100 V sizes from 0603 to 1812 CAPACITANCE (pF) 100 V 0603 0805 0.8 ±0.10 0.6 ±0.10 1206 1210 1808 1812 0.6 ±0.10 1.25 ±0.20 1.25 ±0.20 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 0.6 ±0.10 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 0.85 ±0.10 1,800 2,200 2,700 3,300 3,900 1.25 ±0.20 0.85 ±0.10 4,700 5,600 1.15±0.15 0.85 ±0.10 www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 5 16 Table 2 For NP0 100 V sizes from 0603 to 1812 (continued) CAPACITANCE (pF) 100 V 0603 0805 6,800 1206 1210 1808 1812 1.15±0.15 8,200 1.25 ±0.20 10,000 12,000 15,000 0.85 ±0.10 1.25 ±0.20 1.25 ±0.20 0.85 ±0.10 18,000 1.15±0.15 22,000 27,000 33,000 39,000 47,000 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. Capacitance range < 10 pF is on request. CAPACITANCE RANGE & THICKNESS FOR NP0 200/250 V Table 3 For NP0 200/250 V sizes from 0603 to 1812 CAPACITANCE (pF) 200/250 V 0603 0805 1206 0.8 ±0.10 0.6 ±0.10 0.6 ±0.10 1210 1808 1812 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Table 3 Mid-voltage NP0/X7R 100 V to 500 V 6 16 For NP0 200/250 V sizes from 0603 to 1812 (continued) CAPACITANCE (pF) 200/250 V 0603 0805 0.8 ±0.10 0.85 ±0.10 1206 1210 1808 1812 220 270 330 390 0.6 ±0.10 470 560 1.25 ±0.20 680 820 0.8 ±0.10 1,000 0.85 ±0.10 1,200 1.25 ±0.20 1,500 1.25 ±0.20 1.15±0.15 1,800 0.8 ±0.10 2,200 1.25 ±0.20 0.85 ±0.10 1.25 ±0.20 2,700 1.25 ±0.20 3,300 1.15±0.15 3,900 0.85 ±0.10 4,700 1.25 ±0.20 1.15±0.15 5,600 6,800 8,200 10,000 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. Capacitance range < 10 pF is on request. CAPACITANCE RANGE & THICKNESS FOR NP0 500 V Table 4 For NP0 500 V sizes from 0805 to 1812 CAPACITANCE (pF) 500 V 0805 1206 0.6 ±0.10 0.6 ±0.10 1210 1808 1812 10 12 15 18 22 27 www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 7 16 Table 4 For NP0 500 V sizes from 0805 to 1812 (continued) CAPACITANCE 500 V (pF) 0805 1206 0.6 ±0.10 0.6 ±0.10 1210 1808 1812 33 39 47 56 68 82 100 120 150 180 0.85 ±0.10 220 270 330 0.85 ±0.10 390 470 0.85 ±0.10 560 680 820 1.25 ±0.20 1.15±0.15 1,000 1,200 0.8 ±0.10 1,500 1,800 2,200 2,700 1.15±0.15 1.25 ±0.20 1.25 ±0.20 1.25 ±0.20 1.25 ±0.20 1.15±0.15 3,300 3,900 4,700 1.25 ±0.20 5,600 6,800 8,200 10,000 NOTE 1. Values in shaded cells indicate thickness class in mm. 2. Capacitance range < 10 pF is on request. www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 8 16 CAPACITANCE RANGE & THICKNESS FOR X7R 100V Table 5 For X7R 100 V sizes from 0805 to 1812 CAPACITANCE (pF) 100 V 0603 0805 1206 0.6 ±0.10 0.85 ±0.10 1210 1808 1812 100 150 220 330 470 680 1,000 0.8 ±0.10 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 0.85 ±0.10 1.25 ±0.20 68,000 100,000 0.85 ±0.10 1.15±0.15 0.85 ±0.10 150,000 1.15±0.15 220,000 1.6 ±0.20 1.25 ±0.20 1.15±0.15 330,000 470,000 1.6 ±0.20 680,000 1,000,000 NOTE 1. Values in shaded cells indicate thickness class in mm. www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 9 16 CAPACITANCE RANGE & THICKNESS FOR X7R 200/250 V Table 6 For X7R 200/250 V sizes from 0805 to 1812 CAPACITANCE (pF) 200/250 V 0805 1206 1210 1808 1812 100 150 220 330 470 680 1,000 0.85 ±0.10 1,500 2,200 3,300 0.85 ±0.10 4,700 6,800 10,000 1.25 ±0.20 15,000 0.8 ±0.10 22,000 1.25 ±0.20 33,000 47,000 68,000 100,000 0.85 ±0.10 1.15±0.15 1.15±0.15 1.25 ±0.20 1.25 ±0.20 1.25 ±0.20 1.15±0.15 150,000 220,000 1.6 ±0.20 330,000 2.0 ±0.20 470,000 680,000 1,000,000 NOTE 1. Values in shaded cells indicate thickness class in mm. www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 10 16 CAPACITANCE RANGE & THICKNESS FOR X7R 500 V Table 7 For X7R 500 V sizes from 0805 to 1812 CAPACITANCE (pF) 500 V 0805 1206 1210 1808 1812 100 150 220 330 470 680 1,000 0.8 ±0.10 1,500 1.15±0.15 2,200 3,300 4,700 1.15±0.15 0.85 ±0.10 6,800 10,000 1.25 ±0.20 1.25 ±0.20 15,000 1.25 ±0.20 22,000 33,000 47,000 1.15±0.15 1.25 ±0.20 1.6 ±0.20 1.25 ±0.20 68,000 100,000 1.6 ±0.20 150,000 220,000 330,000 470,000 680,000 1,000,000 NOTE 1. Values in shaded cells indicate thickness class in mm. www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors NP0/X7R Mid-voltage 100 V to 500 V 11 16 THICKNESS CLASSES AND PACKING QUANTITY Table 8 DESCRIPTION SIZE CODE THICKNESS CLASSIFICATION (mm) 8 mm TAPE WIDTH/AMOUNT PER REEL Ø180 mm, 7” Ø330 mm, 13” 12 mm TAPE WIDTH /AMOUNT PER REEL Paper Blister Paper Blister Ø180 mm, 7” Blister 0603 0.8 ±0.10 4,000 --- --- --- --- 0805 0.6 ±0.10 4,000 --- --- --- --- 0.8 ±0.10 4,000 --- --- --- --- 0.85 ±0.1 4,000 --- --- --- --- 1.25 ±0.20 --- 3,000 --- --- --- 0.6 ±0.10 4,000 --- 20,000 --- --- 0.8 ±0.10 4,000 --- --- --- --- 0.85 ±0.10 4,000 --- 15,000 --- --- 1.00 ±0.10 --- 3,000 --- 10,000 --- 1.15 ±0.15 --- 3,000 --- 10,000 --- 1.25 ±0.20 --- 3,000 --- --- --- 0.6 ±0.10 --- 4,000 --- 15,000 --- 0.85 ±0.10 --- 4,000 --- 10,000 --- 1.15 ±0.15 --- 3,000 --- 10,000 --- 1.25 ±0.20 --- 3,000 --- --- --- 1.6 ±0.20 --- 2,000 --- --- --- 1.15 ±0.15 --- --- --- --- 1,500 1.25 ±0.20 --- --- --- --- 3,000 1.35 ±0.15 --- --- --- --- 1,000 1.5 ±0.10 --- --- --- --- 1,000 1.6 ±0.20 --- --- --- --- 2,000 2.0 ±0.20 --- --- --- --- 2,000 0.85 ±0.10 --- --- --- --- 2,000 1.15 ±0.15 --- --- --- --- 1,500 1.25 ±0.20 --- --- --- --- 1,000 1.35 ±0.15 --- --- --- --- 1,000 1.5 ±0.1 --- --- --- --- 1,000 1.6 ±0.2 --- --- --- --- 1,000 2.0 ±0.20 --- --- --- --- 2,000 1206 1210 Mid / High voltage 1808 1812 www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 12 16 100 V to 500 V ELECTRICAL CHARACTERISTICS NP0/X7R DIELECTRIC CAPACITORS; NISN TERMINATIONS Unless otherwise stated all electrical values apply at an ambient temperature of 20±1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. Table 9 VALUE DESCRIPTION Capacitance range (1) Capacitance tolerance (1) 10 pF to 470 nF : NP0 X7R Dissipation factor NP0 X7R ±5% ±10% (D.F.) (1): Insulation resistance after 1 minute at Ur (DC) ≤ 0.1% ≤ 2.5% Rins ≥ 10 GΩ or Rins × C ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): NP0 X7R Operating temperature range: NP0/X7R ±30 ppm/°C ±15% –55 °C to +125 °C NOTE 1. NP0: frequency = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms; frequency = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms X7R: frequency = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms. www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 13 16 TESTS AND REQUIREMENTS Table 10 Test condition, procedure and requirements TEST Mounting Visual inspection and dimension check Capacitance TEST METHOD PROCEDURE REQUIREMENTS IEC 6038421/22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage 4.4 Any applicable method using × 10 magnification In accordance with specification 4.5.1 NP0: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C; f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Within specified tolerance X7R: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C Dissipation factor (D.F.) 4.5.2 NP0: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C; f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C In accordance with specification X7R: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C Insulation resistance Voltage proof 4.5.3 At Ur (DC) for 1 minute In accordance with specification 4.5.4.2 Test voltage (DC) applied for 1 minute No breakdown or flashover Ur ≤ 100 V: 2.5 × Ur applied to NP0/X7R series 100 V < Ur ≤ 200 V: 1.5 × Ur +100 V applied to NP0/X7R series 200 V < Ur ≤ 500 V: 1.3 × Ur +100 V applied to NP0/X7R series Ur > 500 V: 1.3 × Ur applied to NP0/X7R series I: 7.5 mA Temperature characteristic Adhesion 4.6 Between minimum and maximum temperature NP0: l∆C/Cl: 30 ppm/°C X7R: l∆C/Cl: 15% 4.15 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate for size ≥ 0603: a force of 5 N applied for size 0402: a force of 2.5 N applied No visible damage www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 14 16 Table 10 Test condition, procedure and requirements (continued) TEST Bond strength of plating on end face TEST METHOD PROCEDURE REQUIREMENTS IEC 6038421/22 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 340 mm NP0: l∆C/Cl: ≤ 1% or 0.5 pF whichever is greater 4.8 X7R: l∆C/Cl: ≤ 10% Resistance to soldering heat 4.9 Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature Preheating: for size ≤ 1206: 120 to 150 °C for 1 minute Preheating: for size >1206: 100 to 120 °C for 1 minute and 170 to 200 °C for 1 minute Solder bath temperature: 260 ±5 °C Dipping time: 10 ±0.5 seconds The termination shall be well tinned NP0: l∆C/Cl: ≤ 0.5% or 0.5 pF whichever is greater X7R: l∆C/Cl: ≤ 10% D.F.: within initial specified value Rins: within initial specified value Recovery time: 24 ±2 hours. Solderability 4.10 Unmounted chips completely immersed in a solder bath at 235 ±5 °C The termination shall be well tinned. Dipping time: 2 ±0.5 seconds Depth of immersion: 10 mm Rapid change of temperature 4.11 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature No visual damage 5 cycles with following detail: 30 minutes at lower category temperature; 30 minutes at upper category temperature X7R: l∆C/Cl: ≤ 15% NP0: l∆C/Cl: ≤ 1% or 1 pF whichever is greater D.F.: within initial specified value Rins: within initial specified value Recovery time 24 ±2 hours. Damp heat, with Ur load 4.13 Initial measurements; after 150 +0/-10 °C for 1 hour, then keep for 24 ±1 hours at room temperature NP0: l∆C/Cl: ≤ 2% or 1 pF whichever is greater Duration and conditions: 500 ±12 hours at 40 ±2 °C; 90 to 95% RH; Ur applied X7R: l∆C/Cl: ≤ 15% Final measurement: perform a heat treatment at 150 +0/–10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load. NP0: D.F.: 2 × initial value max. X7R ≥ 100 V: D.F. ≤ 5% NP0: Rins ≥ 2,500 MΩ or Rins × Cr ≥ 25 seconds, whichever is less X7R: Rins ≥ 500 MΩ or Rins × Cr ≥ 25 seconds, whichever is less www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 15 16 Table 10 Test condition, procedure and requirements (continued) TEST Endurance TEST METHOD PROCEDURE REQUIREMENTS IEC 6038421/22 Preconditioning; Initial measurements; after 150 +0/-10 °C for 1 hour, then keep for 24 ±1 hours at room temperature NP0: l∆C/Cl: ≤ 2% or 1 pF whichever is greater 4.14 X7R: l∆C/Cl: ≤ 15% Duration and conditions: 1,000 ±12 hours at upper category temperature with 1.5 × Ur voltage applied NP0: D.F.: 2 × initial value max. Final measurement: perform a heat treatment at 150 +0/–10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load. NP0: Rins ≥ 4,000 MΩ or Rins × Cr ≥ 40 seconds, whichever is less X7R ≥ 100 V: D.F. ≤ 5% X7R: Rins ≥ 1,000 MΩ or Rins × Cr ≥ 50 seconds, whichever is less www.yageo.com Sep 08, 2005 V.0 Product specification Surface-Mount Ceramic Multilayer Capacitors Mid-voltage NP0/X7R 100 V to 500 V 16 16 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 - - New Sep 08, 2005 www.yageo.com Sep 08, 2005 V.0
CC1206KKX7RBBB103 价格&库存
很抱歉,暂时无法提供与“CC1206KKX7RBBB103”相匹配的价格&库存,您可以联系我们找货
CC1206KKX7RBBB103
  • 1+0.14846
  • 100+0.13793
  • 300+0.12740
  • 500+0.11688
  • 2000+0.11161
  • 5000+0.10845
