Ap
pplications Noote: AN
N_SY80
032E
Hiigh Efficiiency 1M
MHz, 2.5A
A Contin
nuous,
3A Peaak, Syncchronouss Step Doown Reg
gulator
Generral Descrription
Feeatures
The SY88032E is a high-efficiency
h
y, high frequuency
synchronoous step-down DC-DC regullator IC capabble of
deliveringg up to 2.5A output curreent. The SY80032E
operates over
o
a wide innput voltage raange from 2.77V to
5.5V andd integrate maain switch and
a
synchroonous
switch with
w
very loow RDS(ON) to
t minimize the
conduction loss.
Low outpput voltage rippple and smalll external induuctor
and capaccitor sizes aree achieved wiith greater than
1MHz swiitching frequenncy.
Orderring Infoormation
n
SY8032 □(□□)□
Ap
pplicationns
Temperature Coode
T
P
Package
Code
O
Optional
Spec Code
C
Orderinng Number
SY80332EABC
Low
L RDS(ON) foor internal swittches
(top/bottom):100mΩ/80mΩ
Ω,2.5A
2.7-5.5V
2
inputt voltage rangee
2.5A
2
continuous, 3A peak looad current cap
pability
High
H
switchingg frequency m
minimizes the ex
xternal
components:
c
1
1MHz
CCM
C
only opeeration
Internal
I
softstaart limits the innrush current
100% dropout operation
RoHS
R
Compliant and Halogeen Free
Compact
C
packkage: SOT23-6. Other packag
ges are
available
a
uponn requests
①
Note
Package type
SOT23-6
LCD
L
TV
Set Top Box
Net
N PC
Mini-Noteboo
M
k PC
Access
A
Point Router
R
Typiccal Applications
ON/ OFF
O
EN
VOU
LX
IN
R1
CIN
C1(op
pt.)
COUT
FB
GND
R2
Efficiency (%)
L
VIN
PG
F
Figure
1.Schem
matic diagram
SY8032E Rev. 0.9A
A
Figure 2. Efficiency
E
vs L
Load Current
Silerggy Corp. Coonfidential- Prepared
P
forr Customer U
Use Only
1
AN
N_SY8032E
Pinou
ut (top vieew)
SOT23-6
Pin Name
N
EN
N
GN
ND
LX
X
IN
N
PG
G
FB
B
Top Mark:
M
MBxyzz (device code:: MB, x=year code,
c
y=week code,
c
z= lot nu
umber code)
Pinn Number
Pin Descripption
1
E
Enable
control. Pull high to tu
urn on. Do nott float.
2
G
Ground
pin
3
Innductor pin. Connect
C
this pin
n to the switchiing node of indductor.
4
Innput pin. Decoouple this pin to GND pin wiith at least 10uF
F ceramic cap..
5
P
Power
good inddicator (Open drain
d
output). Low
L if the outpput < 90% of
reegulation voltaage; High otheerwise. Connecct a pull-up resiistor to the inp
put.
6
O
Output
Feedbacck Pin. Connecct this pin to thhe center point of the output
reesistor divider (as shown in Figure
F
1) to prrogram the outpput voltage:
V
Vout=0.6*(1+R
R1/R2).
Absollute Maxximum Ratings
R
(N
Note 1)
Supply Innput Voltage --------------------------------------------------------------------------------------------------------------- -- 6.0V
Enable, FB
F Voltage ------------------------------------------------------------------------------------------------------------ VINN + 0.6V
LX Voltagge ----------------------------------------------------------------------------------------------------------- - -0.3V *1 to 6V *2
Power Dissipation, PD @ TA = 25°C,
S
SOT23-6
-------------------------------------------------------------------------------------------------------------------- -- 0.6W
Package Thermal
T
Resisttance (Note 2)
θ JA ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------140°C/W
1
θ JC---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 70°C/W
7
Junction Temperature
T
R
Range
------------------------------------------------------------------------------------------------------ 150°C
Lead Tem
mperature (Solddering, 10 sec.) ---------------------------------------------------------------------------------------- 260°C
Storage Temperature
T
Range -------------------------------------------------------------------------------------------- 65°C to
o 150°C
(*1)
LX Vooltage tested doown to -3V
很抱歉,暂时无法提供与“SY8032EABC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.66947
- 50+1.29924
- 150+1.14070
- 500+0.94274
- 3000+0.85461
- 6000+0.80169
- 国内价格
- 5+1.51488
- 50+1.17894
- 600+0.85544
- 国内价格
- 1+1.56200
- 100+1.21000
- 750+1.00540
- 1500+0.91410
- 3000+0.84810
- 国内价格
- 1+1.59150
- 10+1.17730
- 100+1.00900
- 1000+0.84090
