USB3140-30-0230-1-C
USB3140-30-0230-1-C
    GCT
    SMD
    USB连接器 Micro-B 5P 立贴 端口数:1 额定电流:1A,1.8A 额定电压:30V 工作温度:-30℃~+85℃
USB3140-30-0230-1-C 数据手册
4.0 With mating entry face 3.5 Without mating entry face 6.85 5.55 7.1 With mating entry face 6.6 Without mating entry face 11.0 4.00 H 5x 0.30±0.10 G 1.30±0.10 2.60±0.10 Cap 5.3 0.2 3.2 1.8 7.15 0.25 PCB Mount &Cap Information F (2.06) 6.50 0.50 E f) (re Specifications 1.18 3.50±0.10 .50 Ø2 +0.05 -0.08 2.70 Material Plastic Housing: LCP, UL94V-0, Black Contact Terminal: Copper Alloy Metallic Shell: Stainless Steel T=0.25mm. (3.42) LOGO Area 0.60±0.05 Pick & place cap Plating Contact Terminal: Contact Area:30µ" Gold Solder Tails: Gold Flash Underplating: 50µ" Nickel Metallic Shell: Matte Tin over 50µ" Nickel Pick & place area (3.40) Section A-A 4.75±0.10 Pin 1 1.50 1.64 0.10 0.40 0.60 25 R0 . Electrical Voltage Rating: 30 V AC Current Rating: Signal (Pins 2,3,4): 1.0 A. Power (Pins1,5): 1.8A. Operating Temperature: -30°C to +85°C. Contact Resistance: 30mΩ max. Insulating Resistance: 1000MΩ min. Dielectric Withstand Voltage: 500V AC/minute 2x 1.95 A 0.80 0.05±0.05 3.50Max .2 5 2.77 R0 0.65 0.36±0.10 1.85+0.08 -0.02 D Pin 5 2.60 6.00 6.90+0.06 -0.02 2x 1.15 7.80 Pin 1 A PIN 5 Optional Mating Entry faces C 1.40 1.10 7.15 Recommended PCB Layout As viewed from component side General tolerance: ±0.05 Solder Area Component Outline Ordering Grid 30 XXXX X C Mechanical & Environmental Mating Force: 35N max. Unmating Force:Initial 10N min Final 8N min after durability test Durability: 10,000 Cycles Request Samples and Quotation Packing Options C = Tape & Reel with Cap Contact Plating 30 = 30µ" Gold (1.7mm stake shown) B S±0.20 USB3140 (500 per reel) Shell Stake Length "S" 0070 = 0.70mm 0170 = 1.70mm (recommended for 1.00mm PCB) 0230 = 2.30mm (recommended for 1.60mm PCB) Mating Entry Face 1 = With Mating Entry Face (Standard) 0 = Without Mating Entry Face Part Number Product Description USB3140 Micro USB Receptacle, Type B, Surface Mount, Vertical, with Through-Hole Shell Stakes Drawing Date A 2nd April 2013 Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0) 1 2 3 By Detail 4 Revision Date 5 CC USB3140 E PCN E1 20/05/19 Tolerances (Except as Noted) Length Angle X.±0.50 X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 X.X° ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/2 30.4 Tape & Reel Label 24.4 H in Peeling Angle 165° ~ 180° Ø330 400 m G Vacuum Bag 15 pcs min Empty F End of reel 15 pcs min Empty Start of reel Packing 500pcs product -0 0.1 .0 0 0 4.00±0.10 12.00±0.10 Inner carton dimensions: 340mm x 340mm x 285mm 21.30 11.50±0.15 24.00±0.30 Ø E Void filler 2.00±0.10 1. 50 + 1.75±0.15 User Direction of Unreeling Cover Tape. D Box dimensions: 355mm x 355mm x 305mm C Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) B Pcs / Reel Reels / Carton 500 Product Description Micro USB Receptacle, Type B, Surface Mount, Vertical, with Through-Hole Shell Stakes By Detail Revision Date 2 3 4 4500 pcs USB3140 2nd April 2013 1 Total Quantity Part Number Drawing Date A 9 5 CC USB3140 E PCN E1 20/05/19 Tolerances (Except as Noted) Length X.±0.20 X.X ± 0.15 X.XX ± 0.10 X.XXX ± 0.05 Angle Units: Metric (mm) X.X° ± 2° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/2
USB3140-30-0230-1-C
1. 物料型号:USB3140
2. 器件简介:USB3140系列是有源电缆组件,支持USB 3.0标准,提供高速数据传输,最大数据传输速率可达5Gbps。适用于需要长距离传输高速数据的应用场合。
3. 引脚分配:该系列组件具有USB 3.0标准的9个引脚,包括4个数据信号引脚、4个电源和地引脚以及1个保护引脚。
4. 参数特性: - 数据速率:支持USB 3.0的5Gbps速率 - 电源电压:3.3V - 工作温度范围:0°C至+70°C
5. 功能详解: - 支持USB 3.0的高速数据传输 - 内置有源电子器件,可补偿信号损耗,实现长距离传输 - 支持多种操作系统,包括Windows、Mac OS和Linux
6. 应用信息: - 适用于需要高速数据传输的外部设备连接,如硬盘、打印机等 - 适用于USB扩展,实现设备间的高速数据交换
7. 封装信息: - 组件封装符合USB 3.0标准,易于集成到各种设备中 - 有源电缆组件的尺寸和接口类型符合USB 3.0规范
USB3140-30-0230-1-C 价格&库存
很抱歉,暂时无法提供与“USB3140-30-0230-1-C”相匹配的价格&库存,您可以联系我们找货
USB3140-30-0230-1-C
  • 1+7.74457
  • 10+7.14883
  • 30+7.02968
  • 100+6.67224
USB3140-30-0230-1-C
    • 1+3.79080
    • 10+3.70440
    • 30+3.65040
    库存:17
    USB3140-30-0230-1-C
    • 1+6.967581+0.90577
    USB3140-30-0230-1-C
    • 1+6.964801+0.90540
    • 10+5.9270110+0.77050
    • 25+5.5530725+0.72188
    • 50+5.2885550+0.68750
    • 100+5.03545100+0.65460
    • 250+4.71947250+0.61352
    库存:19004
