SS-10-15SP-LE
SS-10-15SP-LE
    NIDEC(尼得科)
    SW8_10X10MM_TM
    旋转开关 SW8_10X10MM_TM SP5T 100mA 5V 500Cycles
SS-10-15SP-LE 数据手册
COPAL ELECTRONICS ROTARY SELECTOR SWITCHES RoHS compliant SS-10/S-2050 INTERNAL STRUCTURE SS-10 series 1 7 2 6 3 5 Part name ■FEATURES ● RoHS compliant ● Compact-size DIP pin configuration ● Protected against dust and washable after soldering ● Self-cleaning mechanism 4 Material Flammability ① Rotor ② “O” ring ③ Base ④ Terminal pin ⑤ Contact Copper alloy, Gold-plated ⑥ P.C.B. Gold-plated epoxy board ⑦ Housing POM(Polyoxymethylene) UL-94HB Silicone rubber PBT(Polybutyleneterephthalate) Copper alloy, Gold-plated PBT(Polybutyleneterephthalate) — UL-94HB ■PART NUMBER DESIGNATION SS-10 - 1 6 S P - L - A E W Series name Form of packaging No. of poles W:Tray packaging Blank:Plastic bag 1:1 pole 2:2 poles Terminal pin No. of contacts E:Au (Lead-free) 3:3 contacts (2 poles only) 5:5 contacts (1 pole only) 6:6 contacts (1 pole only) Schematic Contact timing ※1 A:Without OFF position Blank:With OFF position N:Non-shorting (1pole 6 contacts with OFF, 2 poles 3 contacts) S:Shorting (1 pole 5 contacts, 1 pole 6 contacts without OFF) Shape of rotor L:With knob (extended shaft) Blank:Without knob Setting position P:Top setting ※1:The designation for schematic is only aplicable to SS-10-16 □□. The other partnumbers (ex. S-2050, SS-10-15SPEW) are without OFF position. ※Please refer to the LIST OF PART NUMBERS when placing orders. ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. COPAL ELECTRONICS SS-10/S-2050 ROTARY SELECTOR SWITCHES ■LIST OF PART NUMBERS Contact timing Circuit type Form of packaging Shape Non-shorting Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob Top setting With knob 1 pole 4 contacts Without knob Side setting With knob Without knob 1 pole 5 contacts With knob Without knob With OFF 1 pole 6 contacts With knob Top setting Without knob Without OFF With knob Without knob 2 poles 3 contacts With knob Pieces in package Shorting 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack S-2050W S-2050 S-2150W S-2150 S-2051W S-2051 S-2151W S-2151 SS-10-15SPEW SS-10-15SPE SS-10-15SP-LEW SS-10-15SP-LE SS-10-16NPEW SS-10-16NPE SS-10-16NP-LEW SS-10-16NP-LE SS-10-16SP-AEW SS-10-16SP-AE SS-10-16SP-L-AEW SS-10-16SP-L-AE SS-10-23NPEW SS-10-23NPE SS-10-23NP-LEW SS-10-23NP-LE : Not manufactured ※ Verify the above part numbers when placing orders. Tray version can be supplied only in tray nuits. ■SCHEMATIC DIAGRAMS ● 1 pole 4 contacts ● 2 poles 3 contacts Switching specifications Series Schematic Schematic  2  1 3 5 1 1 1 S-2051 3 C C 2 SS-10-15SPE 2 S-2150 SS-10-15SP-LE C 4 1 1 C 3 C 4 ON SS-10-23NP-LE Schematic 3 Switching specifications 1 C 4 6 3 2 SS-10-16SP-AE SS-10-16SP-L-AE C 1 5 6 1 5 6 C Schematic 2 3 4 5 1 Series 2 ON 2 1 ON 1 SS-10-16NPE 1 1 C (OFF) 2 3 4 C 1 C ●1 pole 6 contacts (Without OFF) Switching specifications SS-10-16NP-LE 3 C ON ● 1 pole 6 contacts (With OFF) 2 C SS-10-23NPE 5 S-2151 Series Switching specifications Series 2 3 4 3 1 2 Schematic 4 S-2050 Switching specifications 1 Series ● 1 pole 5 contacts ON C 3 C 4 5 6 ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. COPAL ELECTRONICS SS-10/S-2050 ROTARY SELECTOR SWITCHES ■TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS SS-10-15 SS-10-16 S-2050 S-2150 SS-10-23 (Unit: mm) S-2051 S-2151 Operating face NC C 5 4 6 C 5 4 1 C 2 3 SS-10-23 series. C 8 – φ 0.8 hole 2.54±0.1 Dimension is common to SS-10-15, SS-10-16 and 2.54±0.1 SS – 10 case ■STANDARD SPECIFICATIONS Circuit type Contact rating Non-switching Switching Minimum − 25 ~ 70 °C Contact timing Storage temperature range Net weight Contact resistance Washable by “O” ring Insulation resistance Approx. 0.84 g (without knob) Approx. 0.94 g (with knob) ■MECHANICAL CHARACTERISTICS No. of positions 40 mN·m {408 gf·cm} maximum Stopper strength 50 mN·m {510 gf·cm} minimum 1 pole 4 contacts 2 poles 3 contacts 30° (1 pole 5 contacts) 22.5° (1 pole 6 contacts, with OFF) 28° (1 pole 6 contacts, without OFF) 36° Terminal strength Solderability Soldering heat 2.54±0.1 S – 2050 case S – 2150 case  Operating face 5 – φ 0.8 hole S – 2051 case S – 2151 case Dielectric strength DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μA Shorting Non-shorting 100 mΩ maximum 100 MΩ (DC100 V) minimum AC300 V, 60 s ■ENVIRONMENTAL CHARACTERISTICS 3, 4, 5, 6 Adjustment torque Stepping angle 5 – φ 0.8 hole 2.54±0.1 ■ELECTRICAL CHARACTERISTICS 1 pole 4 contacts 1 pole 5 contacts 1 pole 6 contacts 2 poles 3 contacts Operating temperature range Sealing C 7.62±0.1 P.C.B. dimensions (Bottom view) 4 3 2 1 4 3 2 1 5.08±0.1 3 2 C 1 2.54±0.1 3 2 C 1 7.62±0.1 3 2 C 1 2.54±0.1 Terminal pin layout (Bottom view) ( ) 15 N {1.53 kgf} minimum 245 ± 3 °C, 2 ~ 3 s Flow soldering 260 ± 3 °C, 5 ~ 6 s, two times maximum Manual soldering 380 ± 10 °C, 3 ~ 4 s Vibration Shock Humidity (Steady state) Load life Amplitude 1.5 mm or Acceleration 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each 490 m/s2, 11 ms 6 directions for 3 times each 40 °C, Relative humidity 90 ~ 95 %, 240 h 500 cycles minimum DC5 V, 100 mA High temperature exposure 70 °C, 240 h Low temperature exposure − 25 °C, 96 h Thermal shock − 25 (0.5 h) ~ 70 °C (0.5 h), 5 cycles { } : Reference only ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. COPAL ELECTRONICS SS-10/S-2050 ROTARY SELECTOR SWITCHES ■OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● SS-10-15SP-LE ● SS-10-15SPE Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 5 2 C 3 NC 2.54 1 2.54 4 ˚ 30 Straight knurl M = 0.2 0.7 W × 1 D ● SS-10-16SP-AE 6.6 4.5±0.5 3 6 NC 7.62 2.54 28 ˚ Straight knurl M = 0.2 0.7 W × 1 D 4 C 5 2 C 3 6 ● SS-10-16NP-LE ● SS-10-16NPE Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 6.6 4.5±0.5 2.54 2.54 6 ˚ 2.5 2 Straight knurl M = 0.2 0.7 W × 1 D 4 C 5 2 C 3 6 2.54 3 7.62 1 8 – 0.5±0.1 t = 0.2 C 3.9 2 10 2.54 2.54 5 8 – 0.5±0.1 t = 0.2 2.54 4 345 ● SS-10-23NP-LE ● SS-10-23NPE Part No., Production date code & Lead-free Identification mark Part No., Production date code & Lead-free Identification mark 4.5 ± 0.5 6.6 1 2.54 2.54 3 0.7 W × 1 D Straight knurl M = 0.2 3 C 2 2 C 3 1 2.54 C 7.62 1 8 – 0.5±0.1 t = 0.2 2 3.9 2 ˚ 3 36 2.54 8 – 0.5±0.1 t = 0.2 2.54 4.5±0.5 123 1 C SS –1 0 123 SS –1 0 36˚ 7 10 7.62 2.54 7 10 6 0.7 W × 3.2 L × 1 D 4.5±0.5 12 345 1 C SS–1 0 12 SS–1 0 ˚ 2.5 7 10 7.62 6 7 10 10 3 1 2.54 C 1 8 – 0.5±0.1 t = 0.2 2.54 2 3.9 5 10 2.54 2.54 4 8 – 0.5±0.1 t = 0.2 2.54 6 ˚ 28 10 C 4.5±0.5 23 4 5 1 C SS–1 0 23 4 5 SS–1 0 10 1 7 10 7.62 6 7 10 10 5 2 Part No., Production date code & Lead-free Identification mark 0.7 W × 3.2 L × 1 D 0.7 W × 3.2 L × 1 D 4 C ● SS-10-16SP-L-AE Part No., Production date code & Lead-free Identification mark 2 7.62 8 – 0.5±0.1 t = 0.2 2.54 0.7 W × 3.2 L × 1 D 4.5±0.5 3.9 2.54 2.54 1 C 8 – 0.5±0.1 t = 0.2 2.54 ˚ 30 7 10 7.62 SS–1 0 SS–1 0 10 6.6 4.5±0.5 10 7 10 ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. COPAL ELECTRONICS SS-10/S-2050 ROTARY SELECTOR SWITCHES ■OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● S-2050 ● S-2150 0.7 W × 3.2 L × 1 D Part No. & Production date code 0.7 W × 1 D Part No. & Production date code 4.5±0.5 7 6.6 10 7.62 4.5±0.5 10 2.54 2.54 7.62 4 Part No. & Production date code 2 5–0.5±0.1 t = 0.2 36 ˚ 1 Straight knurl M = 0.2 Part No. & Production date code 0.7 W × 3.2 L × 1 D 0.7 W × 1 D 11.5 36 36 ˚ 10 3 2 1 C 5 – 0.5±0.1 t = 0.2 2.54 2.54 6 3.5±0.5 φ 3.9 10 10 1 4 1 6.6 23 4 4 18.1 ˚ 10 23 3.5 ± 0.5 3 C ● S-2151 ● S-2051 2.54 2.54 10 2.54 1 2.54 ˚ 5–0.5±0.1 t = 0.2 4 36 2 4 C 4 23 23 10 1 3 φ 3.9 1 2.54 7 4 3 2 1 C 5 – 0.5±0.1 t = 0.2 5.08 2.54 2.54 2.54 12.6 5.08 Straight knurl M = 0.2 ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. COPAL ELECTRONICS SS-10/S-2050 ROTARY SELECTOR SWITCHES ■SWITCHES WITH KNOB AS EXTENDED SHAFT (Unit: mm) 10 φ 5.5 1 φ 9.5 0.7 The large knob is common to S-1000A, S-2000A, SA-5000, and SS-10 series. ※ Knob can’t be dettached due to being fixed. Simple knob can’t be sold. ■PACKAGING SPECIFICATIONS ● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box. : The switch with a large knob for manual adjustment is available as a semi-standard item. ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request.
SS-10-15SP-LE 价格&库存
很抱歉,暂时无法提供与“SS-10-15SP-LE”相匹配的价格&库存,您可以联系我们找货
SS-10-15SP-LE
  • 5+28.52350
  • 10+27.45713
  • 20+26.96559
  • 30+26.47823
  • 40+26.00127
库存:60
SS-10-15SP-LE
  • 1+35.612991+4.62958
