HTC321XT5/R6
HTC321XT5/R6
    HUATECH(华泰)
    SOT23-5
    1MHZ通用RRIO CMOS放大器
HTC321XT5/R6 数据手册
HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers General Description The HTC321 (single), HTC358 (dual) and HTC324 (quad) are general purpose, low offset, high frequency response and micro power operational amplifiers. With an excellent bandwidth of 1MHz, a slew rate of 1V/μs, and a quiescent current of 65μA per amplifier at 5V, the HTC321/358/324 family can be designed into a wide range of applications. The HTC321/358/324 op-amps are designed to provide optimal performance in low voltage and low power systems. The input common-mode voltage range includes ground, and the maximum input offset voltage are 4.0mV. These parts provide rail-to-rail output swing into heavy loads. The HTC321/358/324 family is specified for single or dual power supplies of of +2.3V to +5.5V. All models are specified over the extended industrial temperature range of −40℃ to +125℃. The HTC321 is available in 5-lead SOT-23 package. The HTC358 is available in 8-lead SOIC package. The HTC324 is available in 14-lead SOIC package. Features and Benefits            General Purpose 1 MHz Amplifiers, Low Cost High Slew Rate: 1 V/μs Low Offset Voltage: 4.8 mV Maximum Low Power: 65 μA per Amplifier Supply Current Settling Time to 0.1% with 2V Step: 4.1 μs Unit Gain Stable Rail-to-Rail Input and Output – Input Voltage Range: -0.1 to +5.1 V at 5V Supply Operating Power Supply: +2.3 V to +5.5 V Operating Temperature Range: −40℃ to +125℃ ESD Rating: HBM – 4kV, CDM – 2kV Upgrade to LMV321/LMV358/LMV324 Family         Smoke/Gas/Environment Sensors Audio Outputs Battery and Power Supply Control Portable Equipments and Mobile Devices Active Filters Sensor Interfaces Battery-Powered Instrumentation Medical instrumentation Applications Pin Configurations (Top View) ﹢IN 1 ﹣VS 2 ﹣IN 3 HTC321 HTC358 HTC324 SOT23-5 SO-8 SO-14 5 4 ﹢VS OUT OUT A 1 ﹣IN A 2 ﹢IN A 3 ﹣VS 4 A B 8 ﹢VS OUT A 1 7 OUT B ﹣IN A 2 6 ﹣IN B ﹢IN A ﹢IN B ﹢VS ﹢IN B 5 5 14 OUT D 13 ﹣IN D 3 12 ﹢IN D 4 11 ﹣VS 10 ﹢IN C A B 1 HUATECH SEMICONDUCTOR D C ﹣IN B 6 9 ﹣IN C OUT B 7 8 OUT C CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Pin Description Symbol Description –IN Inverting Input of the Amplifier. The Voltage range can go from (VS– – 0.1V) to (VS+ + 0.1V). +IN Non-Inverting Input of Amplifier. This pin has the same voltage range as –IN. +VS Positive Power Supply. The voltage is from 2.3V to 5.5V. Split supplies are possible as long as the voltage between VS+ and VS– is between 2.3V and 5.5V. A bypass capacitor of 0.1μF as close to the part as possible should be used between power supply pins or between supply pins and ground. –VS Negative Power Supply. It is normally tied to ground. It can also be tied to a voltage other than ground as long as the voltage between VS+ and VS– is from 2.3V to 5.5V. If it is not connected to ground, bypass it with a capacitor of 0.1μF as close to the part as possible. OUT Amplifier Output. N/C No Connection. Ordering Information Type Number Package Name Package Quantity Marking Code HTC321XT5/R6 SOT23-5 Tape and Reel, 3 000 C41B HTC358XS8/R8 SO-8 Tape and Reel, 4 000 C42X HTC324XS14/R5 SO-14 Tape and Reel, 2 500 C44X Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 7.0V Common-Mode Input Voltage VS– – 0.5V to VS+ + 0.5V Storage Temperature Range –65℃ to +150℃(TJ) Junction Temperature 160℃ Lead Temperature Range (Soldering 10 sec) 260℃ HBM ±4 000V Electrostatic Discharge Voltage CDM ±2 000V MM ±400V NOTE 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 2: Provided device does not exceed maximum junction temperature (TJ) at any time. 2 HUATECH SEMICONDUCTOR CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Electrical Characteristics VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. ±1.0 +4.5 Unit INPUT CHARACTERISTICS VOS Input offset voltage -4.5 over Temperature -4.8 VOS TC Offset voltage drift over Temperature 1 over Temperature IOS Input offset current VCM Common-mode voltage range Common-mode rejection ratio over Temperature over Temperature AVOL Open-loop voltage gain over Temperature RIN Input resistance CIN Input capacitance 800 1 VS––0.1 VCM = 0.05V to 3.5V 74 VCM = VS––0.1 to VS++0.1 V VO = 0.05 to 3.5 V pA pA VS++0.1 V 90 69 66 mV μV/℃ 2.3 Input bias current IB CMRR +4.8 dB 80 60 96 112 86 dB GΩ 100 Differential 2.0 Common mode 3.5 pF OUTPUT CHARACTERISTICS VOH High output voltage swing VS+–8 mV VOL Low output voltage swing 8 mV ZOUT ISC Closed-loop output impedance f = 200kHz, G = +1 0.4 Open-loop output impedance f = 1MHz, IO = 0 2.6 Source current through 10Ω 50 Sink current through 10Ω 40 Short-circuit current Ω mA DYNAMIC PERFORMANCE GBW Gain bandwidth product f = 1kHz 1.0 MHz ΦM Phase margin CL = 100pF 66 ° SR Slew rate G = +1, CL = 100pF, VO = 1.5V to 3.5V 1.0 V/μs tS Settling time tOR Overload recovery time THD+N Total harmonic distortion + f = 1kHz, G = +1, VO = 3VPP noise 0.5 To 0.1%, G = +1, 2V step 4.1 To 0.01%, G = +1, 2V step 5.1 VIN * Gain > VS μs 2 μs 0.0023 % 10 μVP-P NOISE PERFORMANCE Vn Input voltage noise 3 f = 0.1 to 10 Hz HUATECH SEMICONDUCTOR CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions en Input voltage noise density f = 1kHz In Input current noise density f = 10kHz Min. Typ. Max. Unit 30 nV/√Hz 4 fA/√Hz POWER SUPPLY VS Operating supply voltage PSRR Power supply rejection ratio over Temperature IQ 2.3 VS = 2.7V to 5.5V, VCM < VS+ − 2V 80 5.5 98 V dB 70 Quiescent current (per amplifier) 65 over Temperature 90 μA 95 THERMAL CHARACTERISTICS TA Operating temperature range θJA Package Thermal Resistance -40 +125 SOT23-5 190 SO-8 125 SO-14 115 ℃ ℃/W Specifications subject to changes without notice. 4 HUATECH SEMICONDUCTOR CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Typical Performance Characteristics At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 120 2,000 Samples VS = 5V VCM = 0.05V 500 Quiescent Current (μA) Number of Amplifiers 600 400 300 200 100 0 110 100 90 80 70 60 50 40 30 -3.5 -3 -2.5 -2 -1.5 -1 -0.5 0 0.5 1 1.5 2 2.5 3 3.5 20 1.5 2.5 Input Offset Voltage (mV) 4.5 5.5 6.5 Supply Voltage (V) Input Offset Voltage Production Distribution. Quiescent Current as a function of Supply Voltage. 60 Short-circuit Current (mA) 90 Quiescent current (μA) 3.5 85 80 75 70 65 60 -50 0 50 100 150 Temperature (℃) 50 +ISC 40 30 -ISC 20 10 0 2 2.5 3 3.5 4 4.5 5 Supply Voltage (V) Quiescent Current as a function of Temperature. Short-circuit Current as a function of Supply Voltage. Short-circuit Current (mA) 70 65 +ISC 60 55 50 45 -ISC 40 35 30 25 20 -50 -25 0 25 50 75 100 125 150 Temperature (℃) Short-circuit Current as a function of Temperature. 5 HUATECH SEMICONDUCTOR Output Voltage Swing as a function of Output Current. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Typical Performance Characteristics (continued) 120 180 100 150 80 120 60 90 40 60 20 30 0 0 -20 Phase (deg) AVOL (dB) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. -30 -40 1 10 100 1k -60 10k 100k 1M 10M Frequency (Hz) Open-loop Gain and Phase as a function of Frequency. Input Bias Current as a function of Temperature. 200 100 CMRR Voltage Noise (nV/√Hz) PSRR and CMRR (dB) 120 80 60 PSRR 40 20 0 -20 180 160 140 120 100 80 60 40 20 1 10 100 1k 10k 100k 1M 10M 10 Frequency (Hz) 100 1k 10k 100k Frequency (Hz) Power Supply and Common-mode Rejection Ratio as a function of Frequency. Input Voltage Noise Spectral Density as a function of Frequency. 1V/div 0.5V/div CL=100pF 5μs/div Large Signal Step Response. 6 HUATECH SEMICONDUCTOR 5μs/div Small Signal Step Response. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Application Notes LOW INPUT BIAS CURRENT 6.0 PCB SURFACE LEAKAGE In applications where low input bias current is critical, Printed Circuit Board (PCB) surface leakage effects need to be considered. Surface leakage is caused by humidity, dust or other contamination on the board. Under low humidity conditions, a typical resistance between nearby traces is 1012Ω. A 5V difference would cause 5pA of current to flow, which is greater than the HTC321/358/324’s input bias current at +25℃ (±1fA, typical). It is recommended to use multi-layer PCB layout and route the op-amp’s –IN and +IN signal under the PCB surface. The effective way to reduce surface leakage is to use a guard ring around sensitive pins (or traces). The guard ring is biased at the same voltage as the sensitive pin. An example of this type of layout is shown in Figure 1 for Inverting Gain application. 1. For Non-Inverting Gain and Unity-Gain Buffer: a) Connect the non-inverting pin (+IN) to the input with a wire that does not touch the PCB surface. b) Connect the guard ring to the inverting input pin (– IN). This biases the guard ring to the Common Mode input voltage. 2. For Inverting Gain and Trans-impedance Gain Amplifiers (convert current to voltage, such as photo detectors): a) Connect the guard ring to the non-inverting input pin (+IN). This biases the guard ring to the same reference voltage as the op-amp (e.g., VS/2 or ground). b) Connect the inverting pin (–IN) to the input with a wire that does not touch the PCB surface. Guard Ring +IN –IN +VS Figure 1. Use a guard ring around sensitive pins GROUND SENSING AND RAIL TO RAIL The input common-mode voltage range of the HTC321/358 /324 series extends 100mV beyond the supply rails. This is achieved with a complementary input stage—an N-channel input differential pair in parallel with a P-channel differential pair. For normal operation, inputs should be limited to this range. The absolute maximum input voltage is 500mV beyond the supplies. Inputs greater than the input commonmode range but less than the maximum input voltage, while not valid, will not cause any damage to the op-amp. Unlike some other op-amps, if input current is limited, the inputs may go beyond the supplies without phase inversion, as shown in Figure 2. Since the input common-mode range extends from (VS− − 0.1V) to (VS+ + 0.1V), the HTC321/358 /324 op-amps can easily perform ‘true ground’ sensing. 7 HUATECH SEMICONDUCTOR 5.0 AMPLITUDE (V) The HTC321/358/324 family is a CMOS op-amp family and features very low input bias current in pA range. The low input bias current allows the amplifiers to be used in applications with high resistance sources. Care must be taken to minimize PCB Surface Leakage. See below section on “PCB Surface Leakage” for more details. 4.0 3.0 2.0 1.0 0.0 -1.0 0 10 20 30 40 50 60 TIME (ms) Figure 2. No Phase Inversion with Inputs Greater Than the Power-Supply Voltage A topology of class AB output stage with common-source transistors is used to achieve rail-to-rail output. For light resistive loads (e.g. 100kΩ), the output voltage can typically swing to within 5mV from the supply rails. With moderate resistive loads (e.g. 10kΩ), the output can typically swing to within 10mV from the supply rails and maintain high openloop gain. See the Typical Characteristic curve, Output Voltage Swing as a function of Output Current, for more information. The maximum output current is a function of total supply voltage. As the supply voltage to the amplifier increases, the output current capability also increases. Attention must be paid to keep the junction temperature of the IC below 150℃ when the output is in continuous short-circuit. The output of the amplifier has reverse-biased ESD diodes connected to each supply. The output should not be forced more than 0.5V beyond either supply, otherwise current will flow through these diodes. CAPACITIVE LOAD AND STABILITY The HTC321/358/324 can directly drive 1nF in unity-gain without oscillation. The unity-gain follower (buffer) is the most sensitive configuration to capacitive loading. Direct capacitive loading reduces the phase margin of amplifiers and this results in ringing or even oscillation. Applications that require greater capacitive drive capability should use an isolation resistor between the output and the capacitive load like the circuit in Figure 3. The isolation resistor RISO and the load capacitor CL form a zero to increase stability. The bigger the RISO resistor value, the more stable VOUT will be. Note that this method results in a loss of gain accuracy because RISO forms a voltage divider with the RL. RISO VOUT VIN CL Figure 3. Indirectly Driving Heavy Capacitive Load An improvement circuit is shown in Figure 4. It provides DC accuracy as well as AC stability. The RF provides the DC accuracy by connecting the inverting signal with the output. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Application Notes (continued) The CF and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop. CF RF RISO VOUT VIN RL CL Figure 4. Indirectly Driving Heavy Capacitive Load with DC Accuracy For no-buffer configuration, there are two others ways to increase the phase margin: (a) by increasing the amplifier’s gain, or (b) by placing a capacitor in parallel with the feedback resistor to counteract the parasitic capacitance associated with inverting node. POWER SUPPLY LAYOUT AND BYPASS The HTC321/358/324 family operates from either a single of +2.3V to +5.5V supply or dual ±1.15V to ±3.00V supplies. For single-supply operation, bypass the power supply VS with a ceramic capacitor (i.e. 0.01μF to 0.1μF) which should be placed close (within 2mm for good high frequency performance) to the VS pin. For dual-supply operation, both the VS+ and the VS– supplies should be bypassed to ground with separate 0.1μF ceramic capacitors. A bulk capacitor (i.e. 2.2μF or larger tantalum capacitor) within 100mm to provide large, slow currents and better performance. This bulk capacitor can be shared with other analog parts. Good PC board layout techniques optimize performance by decreasing the amount of stray capacitance at the op-amp’s inputs and output. To decrease stray capacitance, minimize trace lengths and widths by placing external components as close to the device as possible. Use surface-mount components whenever possible. For the op-amp, soldering the part to the board directly is strongly recommended. Try to keep the high frequency big current loop area small to minimize the EMI (electromagnetic interfacing). GROUNDING A ground plane layer is important for the HTC321/358/324 circuit design. The length of the current path speed currents in an inductive ground return will create an unwanted voltage noise. Broad ground plane areas will reduce the parasitic inductance. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. Typical Application Circuits The HTC321/358/324 family is well suited for conditioning sensor signals in battery-powered applications. Figure 6 shows a two op-amp instrumentation amplifier, using the HTC358 op-amps. The circuit works well for applications requiring rejection of common-mode noise at higher gains. The reference voltage (VREF) is supplied by a lowimpedance source. In single voltage supply applications, the VREF is typically VS/2. DIFFERENTIAL AMPLIFIER R2 R1 Vn VOUT Vp R3 BUFFERED CHEMICAL SENSORS R4 VREF Coax Figure 5. Differential Amplifier The circuit shown in Figure 5 performs the difference function. If the resistors ratios are equal R4/R3 = R2/R1, then: VOUT = (Vp – Vn) × R2/R1 + VREF 3V R1 10MΩ To ADC, AFE or MCU pH PROBE INSTRUMENTATION AMPLIFIER R2 10MΩ RG VREF R1 R2 R2 R1 All components contained within the pH probe V1 HTC358 Figure 7. Buffered pH Probe HTC358 VOUT V2 VOUT =(V1 − V2 )(1 + R1 2 R1 + ) + VREF R2 RG Figure 6. Instrumentation Amplifier 8 HUATECH SEMICONDUCTOR The HTC321/358/324 family has input bias current in the pA range. This is ideal in buffering high impedance chemical sensors, such as pH probes. As an example, the circuit in Figure 7 eliminates expansive low-leakage cables that that is required to connect a pH probe (general purpose combination pH probes, e.g Corning 476540) to metering ICs such as ADC, AFE and/or MCU. An HTC321/358/324 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Typical Application Circuits (continued) op-amp and a lithium battery are housed in the probe assembly. A conventional low-cost coaxial cable can be used to carry the op-amp’s output signal to subsequent ICs for pH reading. At the same time, the op-amp’s bandwidth should be much greater than the PWM frequency, like 10 time at least. SHUNT-BASED CURRENT SENSING AMPLIFIER The current sensing amplification shown in Figure 8 has a slew rate of 2πfVPP for the output of sine wave signal, and has a slew rate of 2fVPP for the output of triangular wave signal. In most of motor control systems, the PWM frequency is at 10kHz to 20kHz, and one cycle time is 100μs for a 10kHz of PWM frequency. In current shunt monitoring for a motor phase, the phase current is converted to a phase voltage signal for ADC sampling. This sampling voltage signal must be settled before entering the ADC. As the Figure 8 shown, the total settling time of a current shunt monitor circuit includes: the rising edge delay time (tSR) due to the op-amp’s slew rate, and the measurement settling time (tSET). For a 3-shunt solution in motor phase current sensing, if the smaller duty cycle of the PWM is defined at 45% (In fact, the phase with minimum PWM duty cycle, such as 5%, is not detected current directly, and it can be calculated from the other two phase currents), and the tSR is required at 20% of a total time window for a phase current monitoring, in case of a 3.3V motor control system (3.3V MCU with 12-bit ADC), the opamp’s slew rate should be more than: 3.3V / (100μs× 45% × 20%) = 0.37 V/μs 9 HUATECH SEMICONDUCTOR tSMP tSR VBUS tSET High side switch tSR – Time delay due to op-amp slew rate tSET – Measurement settling time tSMP – Sampling time window To Motor Phase VM Low side switch R2 R1 C1 RSHUNT HTC358 R3 R4 To MCU ADC pin R5 C2 Filter Offset Amplification Figure 8. Current Shunt Monitor Circuit CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Package Outlines SOT23-5 A2 A A1 D e1 Symbol A A1 A2 b c D E E1 e e1 L L1 θ θ L E1 E L1 b e Dimensions In Millimeters Min Max 1.040 1.350 0.040 0.150 1.000 1.200 0.380 0.480 0.110 0.210 2.720 3.120 1.400 1.800 2.600 3.000 0.950 typ. 1.900 typ. 0.700 ref. 0.300 0.600 0° 8° Dimensions In Inches Min Max 0.042 0.055 0.002 0.006 0.041 0.049 0.015 0.020 0.004 0.009 0.111 0.127 0.057 0.073 0.106 0.122 0.037 typ. 0.078 typ. 0.028 ref. 0.012 0.024 0° 8° Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 typ. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 typ. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.056 0.068 0.003 0.007 0.053 0.061 0.013 0.021 0.008 typ. 0.192 0.208 0.156 0.164 0.237 0.253 0.050 typ. 0.018 0.306 0° 8° C SO-8 A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ 10 HUATECH SEMICONDUCTOR C CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b) HTC321, HTC358, HTC324 1MHz General Purpose, RRIO CMOS Amplifiers Package Outlines SO-14 A3 A2 A A1 D C e b Symbol L1 L E E1 θ A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.450 1.850 0.100 0.300 1.350 1.550 0.550 0.750 0.406 typ. 0.203 typ. 8.630 8.830 5.840 6.240 3.850 4.050 1.270 typ. 1.040 ref. 0.350 0.750 2° 8° Dimensions In Inches Min Max 0.059 0.076 0.004 0.012 0.055 0.063 0.022 0.031 0.017 typ. 0.008 typ. 0.352 0.360 0.238 0.255 0.157 0.165 0.050 typ. 0.041 ref. 0.014 0.031 2° 8° Important Notice Huatech Semiconductor Inc and its subsidiaries (Huatech) reserve the right to make corrections, enhancement,amelioration or other changes for them. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete.This condition is also applied to the process of sales contract. Huatech promises that functions of its products match the scope of application described in the product datasheet, Huatech promises that functions of its products match the scope of application described in the product datasheet, and performs strict tests for all parameters to guarantee the quality of products. 11 HUATECH SEMICONDUCTOR CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Huatech (and design) is a registered trademark of Huatech Semiconductor Inc. Copyright Huatech Semiconductor Inc. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-32 (v.2.b)
HTC321XT5/R6 价格&库存
很抱歉,暂时无法提供与“HTC321XT5/R6”相匹配的价格&库存,您可以联系我们找货
HTC321XT5/R6
