HTS3005XV10/R6
HTS3005XV10/R6
    HUATECH(华泰)
    MSOP-10
    1.8V~5.5V 0.5Ω(TYP)超低导通电阻 低电压 2通道 SPDT模拟开关
HTS3005XV10/R6 数据手册
HTS3005 Data Sheet Ultra Low ON-Resistance, Low Voltage, Dual, SPDT Analog Switch General Description The HTS3005 is a dual, low on-resistance, low voltage, bidirectional, single-pole/doublethrow (SPDT) CMOS analog switch designed to operate from a single 1.8V to 5.5V power  supply.  Targeted  applications  include  battery  powered  equipment  that  benefit  from  low  RON (0.5Ω) and fast switching speeds (tON = 50ns, tOFF = 15ns).  The  on  resistance  profile  is  very  flat  over  the  full  analog  signal  range.  This  ensures  excellent linearity and low distortion when switching audio signals. The HTS3005 is a committed dual single-pole/double- throw (SPDT) that consist of two  normally  open  (NO)  and  two  normally  close  (NC)  switches.  This  configuration  can  be  used as a dual 2-to-1 multiplexer. HTS3005 is available in Green TDFN-3×3-10L and MSOP-10 packages.  Features n n n n n n n n n Low Voltage Operation: 1.8V to 5.5V Low On-Resistance: 0.5Ω (TYP) Low On-Resistance Flatness -3dB Bandwidth: 15MHz Fast Switching Times: Ø tON 50ns Ø tOFF 15ns Rail-to-Rail Operation Typical Power Consumption (
HTS3005XV10/R6 价格&库存
很抱歉,暂时无法提供与“HTS3005XV10/R6”相匹配的价格&库存,您可以联系我们找货
