RS2253XTSS16
RS2253XTSS16
    RUNIC(润石)
    TSSOP-16
    CMOS三路2通道模拟多路复用器/解复用器
RS2253XTSS16 数据手册
RS2253 CMOS Triple 2-Channel Analog Multiplexer/Demultiplexer FEATURES • -3dB Bandwidth: 180MHz • Single Supply Operation +2.5V to +5.5V • Low ON Resistance, 48Ω(TYP) With 5V Supply High Off-Isolation: -83dB (RL = 50Ω, f = 1MHz) • • • Break-Before-Make Switching Binary Address Decoding on Chip • Operating Temperature Range: -40°C to +125°C • PACKAGES: SOIC-16(SOP16), SSOP-16, TSSOP-16 and QFN-3×3-16L DESCRIPTION The RS2253 is a CMOS analog IC configured as three single-pole/double-throw (SPDT) switches. This CMOS device can operate from 2.5 V to 5.5 V. The RS2253 device are digitally-controlled analog switches. It has low on-resistance (48Ω TYP) and very low off-leakage current (1nA TYP). The RS2253 is available in Green SOIC-16, SSOP16, TSSOP-16 and QFN-3×3-16L packages. It operates over an ambient temperature range of -40°C to +125°C. Functional Diagrams of RS2253 APPLICATIONS • Sensors • • Analog and Digital Multiplexing and Demultiplexing A/D and D/A Conversion • Signal Gating • Battery-Operated Equipment • • Factory Automation Appliances • Communications Circuits EN AB LE X Y Z R S2 25 3 RevC.1 1 A X0 A X1 B Y0 B Y1 C Z0 C Z1 www.run-ic.com RS2253 PIN CONFIGURATIONS (TOP VIEW) (TOP VIEW) 1 16 VCC Y0 2 15 Y Z1 3 Z 4 Z0 5 ENABLE 6 NC 7 GND RS2253 Y1 8 14 X 13 X1 12 X0 11 A 10 B 9 Z1 Y0 Y1 VCC 16 15 14 Y 13 X 1 12 X 11 X1 10 X0 9 A X7 Z 2 Z0 3 ENABLE 4 RS2253 EP C SOIC-16(SOP16)/SSOP-16/ TSSOP-16 5 6 7 8 NC GND C B QFN-3×3-16L PIN DESCRIPTION Y1 Y0 Z1 Z Z0 PIN SOIC-16/SSOP-16/ TSSOP-16 1 2 3 4 5 ENABLE 6 4 NC GND C B A X0 X1 X Y 7 8 9 10 11 12 13 14 15 5 6 7 8 9 10 11 12 13 VCC 16 14 EP — Exposed Pad NAME PIN QFN-3×3-16L FUNCTION 15 16 1 2 3 2 Analog Switch “Y” Normally Open Input. Analog Switch “Y” Normally Closed Input. Analog Switch “Z” Normally Open Input. Analog Switch “Z” Output. Analog Switch “Z” Normally Closed Input. Digital Enable Input. Normally connected to GND. No Connect. Ground. Connect to digital ground. Digital Address “C” Input. Digital Address “B” Input. Digital Address “A” Input. Analog Switch “X” Normally Closed Input. Analog Switch “X” Normally Open Input. Analog Switch “X” Output. Analog Switch “Y” Output. Positive Analog and Digital Supply Voltage Input Exposed Pad. Connect EP to GND. www.run-ic.com RS2253 FUNCTION TABLE ENABLE INPUT 1 0 0 0 0 0 0 0 0 INPUT STATES C B X X 0 0 0 0 0 1 0 1 1 0 1 0 1 1 1 1 A X 0 1 0 1 0 1 0 1 ON CHANNEL(S) NONE X0, Y0, Z0 X1, Y0, Z0 X0, Y1, Z0 X1, Y1, Z0 X0, Y0, Z1 X1, Y0, Z1 X0, Y1, Z1 X1, Y1, Z1 X=Don’t care NOTE: Input and output pins are identical and inter-changeable. Either may be considered an input or output; signals pass equally well in either direction. 3 www.run-ic.com RS2253 ABSOLUTE MAXIMUM RATINGS (1) VCC to GND..........................................................−0.3 to 6V Input Terminals, Voltage. (2) .................– 0.3 to (V+) + 0.3V Continuous Current into Any Terminal......................±20mA Peak Current, X_ (Pulsed at 1ms,10% duty cycle)…………………….. ±40mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….…….…… −40°C to +125°C Junction Temperature...............................................+150°C Package Thermal Resistance @ TA = +25°C ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. QFN-3×3-16L………………….………..……………. 80°C/W SSOP-16……….…………........................................64°C/W SOIC-16, TSSOP-16………….……….…………….100°C/W Lead Temperature (Soldering, 10s) …………….........260°C ESD Susceptibility HBM ….......................................................................1000V MM ……………………….........………………...……….100V (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.3V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION PRODUCT TEMPERATURE RANGE PACKAGE LEAD PACKAGE MARKING RS2253XS16 -40°C ~+125°C SOIC-16(SOP16) RS2253 Tape and Reel,3000 RS2253XSS16 -40°C ~+125°C SSOP-16 RS2253 Tape and Reel,3000 RS2253XTSS16 -40°C ~+125°C TSSOP-16 RS2253 Tape and Reel,3000 RS2253XTQC16 -40°C ~+125°C QFN-3×3 -16L RS2253 Tape and Reel,3000 ORDERING NUMBER PACKAGE OPTION RS2253 4 www.run-ic.com RS2253 ELECTRICAL CHARACTERISTICS VCC = 5.0 V or 3.3V, FULL= –40°C to +125°C, Typical values are at TA = +25°C. (unless otherwise noted) PARAMETER SYMBOL CONDITIONS VCC TA MIN TYP MAX UNITS ANALOG SWITCH Analog Signal Range VX_, VY_, VZ_ VX, VY, VZ FULL VCC=5V, IX, IY, IZ =1mA On-Resistance RON VCC=3.3V, IX, IY, IZ =1mA On-Resistance Match Between Channels On-Resistance Flatness X_, Y_, Z_ Off Leakage Current X, Y, Z Off Leakage Current X, Y, Z On Leakage Current 5V 3.3V ∆RON VCC=5V, IX, IY, IZ =1mA 5V RFLAT(ON) VCC=5V, IX, IY, IZ =1mA 5V VX_, VY_, VZ_=1V, 4.5V IX_(OFF) IY_(OFF) VX, VY, VZ =4.5V, 1V IZ_(OFF) VX_, VY_, VZ_=1V, 3V VX, VY, VZ =3V, 1V VX_, VY_, VZ_=1V, 4.5V IX(OFF) IY(OFF) VX, VY, VZ =4.5V, 1V IZ(OFF) VX_, VY_, VZ_=1V, 3V VX, VY, VZ =3V, 1V GND +25°C 48 FULL +25°C 100 FULL +25°C 1.5 FULL +25°C 17 FULL VCC V 65 Ω 70 Ω 130 Ω 140 Ω 5 Ω 5.3 Ω 25 Ω 28 Ω 5V +25°C 1 100 nA 3.3V +25°C 1 100 nA 5V +25°C 1 100 nA 3.3V +25°C 1 100 nA VCC=5V, VX, VY, VZ =4.5V, 1V 5V +25°C 1 100 nA VCC=3.3V, VX, VY, VZ =3V, 1V 3.3V +25°C 1 100 nA 5V +25°C 1.7 V 3.3V +25°C 1.7 V 5V +25°C 0.5 V 3.3V +25°C 0.5 V IX(ON) IY(ON) IZ(ON) DIGITAL CONTROL INPUTS(1) Logic Input Logic Threshold High VAH, VBH, VCH, V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE Logic Input Logic Threshold Low VAL, VBL, VCL V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE Input-Current High IAH, IBH, ICH I̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE VA, VB, VC, V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE = VCC 3.3V to 5V +25°C 1 100 nA Input-Current Low IAL, IBL, ICL I̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE VA, VB, VC, V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE = 0V 3.3V to 5V +25°C 1 100 nA (1) All unused digital inputs of the device must be held at VIO or GND to ensure proper device operation. 5 www.run-ic.com RS2253 ELECTRICAL CHARACTERISTICS (continued) VCC= 5.0 V or 3.3V, FULL= –40°C to +125°C Typical values are at TA = +25°C (unless otherwise noted) PARAMETER SYMBOL CONDITIONS tTRANS VX_, VY_, VZ_= 3V/0V, RL = 300Ω, CL = 35pF, Test Circuit 1 VX_, VY_, VZ_= 3V/0V, RL = 300Ω, CL = 35pF, Test Circuit 1 VCC TEMP MIN TYP MAX UNITS 5V +25°C 160 ns 3.3V +25°C 240 ns DYNAMIC CHARACTERISTICS Address Transition Time ENABLE Turn-On Time tON VX_, VY_, VZ_= 3V, RL = 300Ω, CL = 35pF, Test Circuit 2 ENABLE Turn-Off Time tOFF VX_, VY_, VZ_= 3V, RL = 300Ω, CL = 35pF, Test Circuit 2 Internal A, B, C Rise Time tR Internal A, B, C Fall Time tF Break-Before-Make Time Delay tD Charge Injection Q 5V 3.3V 5V 3.3V 5V 3.3V 5V 3.3V VX_, VY_, VZ_= 3V, RL = 300Ω, CL = 35pF, Test Circuit 3 5V 3.3V RS = 0Ω, CL = 1nF, Test Circuit 4 5V RS = 0Ω, CL = 1nF, Test Circuit 4 3.3V 90 140 70 100 +25°C +25°C ns ns 50 +25°C ns 80 +25°C +25°C +25°C 60 85 ns ns 60 ns 90 ns 6 pC 4 pC Off Isolation OISO RL = 50Ω, f = 1MHz, Test Circuit 5 5V +25°C -83 dB Channel-to-Channel Crosstalk XTALK RL = 50Ω, f = 1MHz, Test Circuit 5 5V +25°C -110 dB 180 MHz 180 MHz -3dB Bandwidth Input Off-Capacitance Output Off-Capacitance Output On- Capacitance Total Harmonic Distortion BW CX_(OFF) CY_(OFF) CZ_(OFF) CX(OFF) CY(OFF) CZ(OFF) CX(ON) CY(ON) CZ(ON) THD 5V RL = 50Ω 3.3V VX_, VY_, VZ_= 0V, f = 1MHz, Test Circuit 6 VX_, VY_, VZ_= 0V, f = 1MHz, Test Circuit 6 VX_, VY_, VZ_= 0V, f = 1MHz, Test Circuit 6 RL = 600Ω,5VP-P, f = 20Hz to 20kHz +25°C 5V +25°C 4.7 pF 5V +25°C 12.7 pF 5V +25°C 16 pF 5V +25°C 0.7 % POWER REQUIREMENTS Power Supply Range Power Supply Current VCC ICC FULL VCC = 5.0V, VA, VB, VC, V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE = VCC or 0 VCC = 3.3V, VA, VB, VC, V̅̅̅̅̅̅̅̅̅̅̅̅ ENABLE = VCC or 0 6 2.5 5.5 V 5V +25°C 0.001 2 μA 3.3V +25°C 0.001 1 μA www.run-ic.com RS2253 TYPICAL CHARACTERISTICS Typical ron as a Function of Input Voltage (VI ) for VI = 0 to V+ 400 Ron(Ω) 200 100 50 25 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 VI(V) V+=5.5V V+=4.5V V+=3.3V 7 V+=2.5V www.run-ic.com RS2253 Parameter Measurement Information Test Circuit 1. Address Transition Times (tTRANS) Test Circuit 2. Switching Times (tON, tOFF) Test Circuit 3. Break-Before-Make Time Delay (tD) 8 www.run-ic.com RS2253 Parameter Measurement Information (continued) Test Circuit 4. Charge Injection (Q) Test Circuit 5. Off Isolation, On Loss Test Circuit 6. Capacitance 9 www.run-ic.com RS2253 APPLICATION NOTES The RS2253 device is a triple 2-channel multiplexer having three separate digital control inputs, A, B, and C, and an inhibit input. Each control input selects one of a pair of channels which are connected in a single-pole, double-throw configuration. When the devices are used as demultiplexers, the CHANNEL IN/OUT terminals are the outputs and the COMMON OUT/IN terminals are the inputs. LOGIC LEVEL CONVERSION 16 VCC BINARY TO 1 OF 2 DECODERS WITH INHIBIT IN/OUT Z1 Z0 Y1 Y0 X1 X0 3 5 1 2 13 12 TG COMMON OUT/IN X 14 A 11 TG TG COMMON OUT/IN Y 15 B 10 C TG TG 9 COMMON OUT/IN Z 4 TG ENABLE 6 VCC 8 GND 7 NC Figure 1. The RS2253 Functional Block Diagram 10 www.run-ic.com RS2253 PACKAGE OUTLINE DIMENSIONS SOIC-16 e b 5.2 1.27 E1 E 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 A c θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.006 0.010 D 9.800 10.200 0.386 0.402 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 1.27(BSC) 0.050(BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 11 www.run-ic.com RS2253 SSOP-16 e b 5.588 E1 E 1.651 D 0.635 0.406 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.200 0.300 0.008 0.012 c 0.170 0.250 0.007 0.010 D 4.700 5.100 0.185 0.200 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 0.635(BSC) 0.025(BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 12 www.run-ic.com RS2253 TSSOP-16 e b 5.94 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.200 6.600 0.244 0.260 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.02 0.25TYP 1° 0.028 0.01TYP 7° 13 1° 7° www.run-ic.com RS2253 QFN-3x3-16L E e L b E1 D D1 N16 N5 N1 TOP VIEW BOTTOM VIEW 0.50 1.70 A1 A2 3.60 A 0.70 0.24 SIDE VIEW 1.70 RECOMMENDED LAND PATTERN (Unit: mm) Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.700 0.800 0.028 0.031 A1 0.000 0.050 0.000 0.002 A2 0.203 0.008 b 0.180 0.300 0.007 0.012 D 2.900 3.100 0.114 0.122 D1 1.600 1.800 0.063 0.071 E 2.900 3.100 0.114 0.122 E1 1.600 1.800 0.063 0.071 e L 0.500 TYP 0.300 0.020 TYP 0.500 14 0.012 0.020 www.run-ic.com
RS2253XTSS16 价格&库存
很抱歉,暂时无法提供与“RS2253XTSS16”相匹配的价格&库存,您可以联系我们找货
RS2253XTSS16
  • 5+1.82639
  • 50+1.36372
  • 150+1.16543
  • 500+0.91800
库存:2075
