YSX146GA/YSX306GA
Features
. External dimensions: 7.0 x 1.5 x 1.4 mm / 8.0 x 3.8 x 2.54 mm.
. Frequency range: 32.768KHz.
reference clocks.
.portable consumer products
.High reliable environmental performance.
.RoHS compliant /Pb Free.
.Measurement Instrument : S&A 250B(Measured FL).
Electrical Specifications
Item / Type
YSX146GA/YSX306GA
Nominal Frequency Range
32.768 KHz
AT Fundamental
12.5pF, or specify
Frequency Tolerance (at 25 ℃)
± 20 ppm , or specify
Operating Temperature
– 40 ~ + 85 ℃
Storage Temperature
– 55 ~ + 125 ℃
Re ar
m rk :
: Sp
Vibration Mode
Load Capacitance
Shunt Capacitance
2.0pF typical
Level Of Drive
1.0 μW Max.
Frequency Aging (at 25 ℃)
± 5 ppm / year Max.
Turnover Temperature
25 ℃ ± 5 ℃
Temperature Coefficient
± 0.006ppm/
℃2
–0.036
Motional Resistance
50KΩ Max.
Motional Capacitance
3.0pF typical
Mode of Vibration
+2
X-cut
o
Fundameneta
Dimensions
Y SX 306G A
#1
6.7
7.0 Max.
#3
Y X C32X X X
#1
0.4
#4
0.25
#1
0.2
0.15
0.4
0.2
内部连接
(TOP VIEW)
#3
#2
0.1
Max.
#4
#3
#1
#2
#2
#2
#1
2.38
1.4
0.1
#4
8.0
#4
3.8 Max.
0.3
Y X C32X X X
内部连接
(TOP VIEW)
2.54 Max.
1.5 Max.
#3
3.2
#4
0.55
0.3
Y SX 146G A
0.5
5.5
1.9
(0.9)
#2
#3
0.2
Units: mm
come visit our site http://www.yxc.hk
1/5
YSX146GA/YSX306GA
【Components】
1. Crystal blank(SiO 2)
Electrode (Cr ,Cu,Ag)
2. Cup( Nickel silver)
Finish(Nickel plating)
3. Base(Glass,KV,Fe‐Ni(42%))
Finish(Nickel under plating 4μ, Tin plating 10 μ(Cu 2wt%)
4. Solder of a junction
RX307‐207BHO (NIHON HANDA SHANGHAI)
Pb 93.5%, Sn 5%, Ag 1.5% (Melting points 260℃)
5 .MOLD
Epoxy compound
KL-G100
【Physical and environmental characteristics 】
1. Humidity
Subject the crystal at 40℃2℃ and 90%-95% RH for 96 4 hours. Then release the crystal
into the room conditions for 2 hours prior to the measurement﹒
2. High Temperature Exposure
Subject the crystal to 85℃ 5℃ for 964 hours﹒ Then release the crystal into the room
3. Low Temperature
Subject the crystal to -20℃ 5℃ for 96 4 hours﹒Then release the crystal into the room
conditions for 2 hours prior to the measurement.
4. Mechanical Shock
Drop the crystal randomly onto a concrete floor from the height of 75cm 3 times﹒ Then
release the crystal into the room temperature for 15 minutes prior to the measurement﹒
5. Temperature Cycling
Subject the crystal to -30℃ for 30 min. followed by a high temperature of +85℃ for 30 min.
Cycling shall be repeated 5times with a transfer time of 15sec. at the room condition﹒
Then release the resonator into the room temperature for 2 hours prior to the measurement﹒
6. Vibration
Subject the crystal to vibration for 2 hours each in x, y, and z axes with the amplitude of
1.5mm, the frequency shall be varied uniformly between the limits of 10-55 Hz﹒Then release
2/5
YSX146GA/YSX306GA
7. Resistance to Solder Heat
Dip the crystal terminals no closer than 2mm into the solder bath 260℃5℃ for 51 sec;
Then release the crystal into the room temperature for 2 hour prior to the measurement﹒
8. Solder Ability
Dip the crystal terminals no closer than 2mm into the solder bath at 235℃ 5℃ for 30.5
sec.more than 95% of the erminal surface of the crystal shall be covered with fresh solder.
Then release the crystal into the room temperature for 2hour prior to the measurement﹒
9. Lead Fatigue
(1) Pulling Test
Weight along with the direction of terminals without any shock 0.5kg for 10±1sec.; The crystal
shall no evidence of damage and shall fulfill all the initial electric characteristics.
(2) Bending Test
Lead shall be subject to withstand against 90 degrees bending at its stem•This operation shall
be done towards both directions; The crystal shall no evidence of damage and shall fulfill all
【 Handling Notice for Standard Tuning Fork Crystal (Cylindrical Type) 】
1. Shock resistance
It may deteriorate the characteristics or cause of no oscillation if excess physical shock given.
Please be careful not to drop. Please use under condition to minimize the shocks as much as
possible. Please review the conditions if it is used by auto mounting or after the conditions are
changed.
2. Heat and humidity resistance in storage
Storing the crystal products under higher or lower temperature or high humidity for a long period
may deteriorate the characteristics of crystal units. Please store and use the crystal products at
the normal temperature and humidity.
3. Solder heat resistance
Standard type crystal products use Material have a 280℃ melting point. Heating up the package
more than 270ºC may deteriorate the characteristics or cause of no oscillation the products.
3/5
YSX146GA/YSX306GA
4. Mounting method to PCB
When the crystal products need to be lay down please fix to PCB securely. If the crystal is used with
mechanical vibration location, please put cushion in between PCB or fix with elasticity glue (Silicon
etc) as shown in below figure. Please don’t gluing hermetic seal grass.
Y SX 146G A
1.3
0.6
1.9
0.6
0.3
Y SX 306G A
1.2
5.1
1.9
1.2
1.3
4.2
1.3
5. Ultrasonic cleaning and ultrasonic soldering
Soldered by ultrasonic cannot be guaranteed, because crystal maybe sympathetic vibrated and
may damage. Please study at your side about ultrasonic cleaning.
6. Drive level
Applying excessive drive level to the crystal units may cause deterioration of characteristics or
damage. Less then 1.0μW is recommended to this products. More than 2.0μW cannot be
guaranteed.
REVIEW OF SPECIFICATION
When something get doubtful with this specifications ,we shall jointly work to get an agreement.
4/5
YSX146GA/YSX306GA
★ PART NUMBER GUIDE 部件号示例
Quartz Crystal Resonator Dimensions Frequency Load Capacitance
(Hz)
(Pf)
X
7015
32768K
YSX14 6G A =7 .0×1.5 SMD SEAM TYPE
e.g. X7 015327 68 K SD4 G I
S
Frequency
Stability
Overall
(ppm)
Pin
Material
Operating Temp.
Range
D
4
G
I
5/5
很抱歉,暂时无法提供与“X701532768KGD4GI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.00459
- 50+1.58512
- 150+1.40541
- 500+1.18120
- 国内价格
- 5+1.45310
- 50+1.19120
- 150+1.00910
- 500+0.93160
- 1000+0.87540
- 3000+0.82570
- 6000+0.78840
- 国内价格
- 1+1.44740
- 100+1.11190
- 750+0.92680
- 1500+0.84270
- 3000+0.78100
- 国内价格
- 100+0.70441
- 500+0.69248
- 国内价格
- 10+6.31210
- 100+4.72080
- 800+3.66000
- 3000+2.65210
- 6000+2.51960
- 30000+2.33390
