X201624MMD4SI
X201624MMD4SI
    YXC(扬兴科技)
    SMD2016_4P
    无源晶振 24MHz 100Ω 10pF ±20ppm -40℃~+85℃ SMD2016_4P
X201624MMD4SI 数据手册
【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX211SL Features C Y X A C AQ . External dimensions: 2.05 x 1.65 x 0.50 mm. . Standard Frequency: 16~54MHz. . High precision and high frequency stability. .Excellent heat resistance and environmental characteristics. .Applications: mobile phone, Bluetooth, Bluetooth, W-LAN ISM band radio, clock for MPU GPS, smart phone. Electrical Specifications Item / Type YSX211SL Standard Frequency 16~54 M Hz Vibration Mode AT Fundamental Load Capacitance pF , or specify 9pF, 12 8pF, Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 1 5 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 3 pF Max. Level Of Drive 1 0 ~200 μW Max. (10uW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) Fundamental 20 ~ 30 MHz 100 Ω Max. 30 ~ 50 MHz 80 Ω Max. Dimensions YXC AAQC Units: mm come visit our site http://www.yxc.hk 1/2 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX211SL ★ PART NUMBER GUIDE 部件号示例 e.g. X201612MO B4 SC Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 2016 Frequency Stability Pin Overall (ppm) O ★ TAPING SPECIFICATION (Unit: mm) 4.0 YSX211SL =2.00×1.60 SMD SEAM TYPE 4 B Material Operating Temp. Range S C 编带规格 φ2.0 1.75 12 0° φ13 2.0 C B D SMD2016 G A F E A B C 180±2.0 8.0 ±0.2 D 2.30±0.01 1.90±0.01 E F G 4.0±0.1 0.90±0.01 60.0±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ come visit our site http://www.yxc.hk 2/2 120sec. max
X201624MMD4SI 价格&库存
很抱歉,暂时无法提供与“X201624MMD4SI”相匹配的价格&库存,您可以联系我们找货
X201624MMD4SI
  • 1+0.78210
  • 100+0.73000
  • 300+0.67790
  • 500+0.62570
  • 2000+0.57360
  • 5000+0.52140
库存:2041
X201624MMD4SI
  • 10+0.57494
  • 100+0.53785
  • 500+0.50075
  • 2000+0.44511
  • 5000+0.42657
  • 10000+0.41544
库存:2041
