X252024MSD4SI
X252024MSD4SI
    YXC(扬兴科技)
    SMD2520_4P
    无源晶振 24MHz 100Ω 20pF ±20ppm -40℃~+85℃ SMD2520_4P
X252024MSD4SI 数据手册
【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX221SL Features . External dimensions: 2.55 x 2.05 x 0.55 mm. C Y X A . Frequency range: 12MHz ~ 54MHz. C AQ . High precision and high frequency stability. .Excellent heat resistance and environmental characteristics. .Applications: mobile phone, Bluetooth, Bluetooth, W-LAN ISM band radio, clock for MPU GPS, smart phone. Electrical Specifications Item / Type YSX221SL Nominal Frequency Range 12 ~ 54 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 3 pF Max. Level Of Drive 1 ~200 μW Max. (100uW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) Fundamental 12 ~ 14 MHz 150 Ω Max. 14 ~ 30 MHz 100 Ω Max. 30 ~ 48 MHz 60 Ω Max. 48 ~ 54 MHz 50 Ω Max. Dimensions YXC AAQC Units: mm come visit our site http://www.yxc.hk 1/2 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSX221SL ★ PART NUMBER GUIDE 部件号示例 e.g. X252012MSB4 SC Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 2520 Frequency Stability Pin Overall (ppm) S ★ TAPING SPECIFICATION (Unit: mm) 4.0 YSX221SL =2.55×2.05 SMD SEAM TYPE 4 B Material Operating Temp. Range S C 编带规格 φ1.5 1.75 12 0° φ13 2.0 C B D SMD2520 G A F E A B C 178±2.0 8.0 ±0.3 D 2.70±0.05 2.25±0.05 E F G 4.0±0.1 1.05±0.05 60.5±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ come visit our site http://www.yxc.hk 2/2 120sec. max
X252024MSD4SI
1. 物料型号: YSX221SL 2. 器件简介: - 外部尺寸: 2.55 x 2.05 x 0.55mm - 频率范围: 12MHz ~54MHz - 高精度和高频率稳定性 - 出色的耐热性和环境特性 - 应用: 手机、蓝牙、W-LAN波段无线电、MPU时钟、GPS、智能手机 3. 引脚分配: 未提供具体的引脚分配图或描述 4. 参数特性: - 标称频率范围: 12-54MHz - 振动模式: AT基础 - 负载电容: 12pF, 20pF, 或指定 - 频率容差(25°C): ±10ppm, 20ppm, 或指定 - 频率与温度特性: ±20ppm, 或指定 - 工作温度: -20~+70°C, -40~+85°C, 或指定 - 存储温度: -40~+85°C, 或指定 - 并联电容: 最大3pF - 驱动水平: 最大1-200mW(典型100μW) - 频率老化(25°C): ±3ppm/年 5. 功能详解: 未提供详细的功能详解 6. 应用信息: 适用于手机、蓝牙设备、W-LAN波段无线电、MPU时钟、GPS模块、智能手机等 7. 封装信息: 提供了尺寸图,但没有提供封装类型
X252024MSD4SI 价格&库存
很抱歉,暂时无法提供与“X252024MSD4SI”相匹配的价格&库存,您可以联系我们找货
X252024MSD4SI
  • 1+0.73500
  • 100+0.68600
  • 300+0.63700
  • 500+0.58800
  • 2000+0.56350
  • 5000+0.54880
