C1815
C1815
    BLUECOLOUR(蓝彩电子)
    SOT-23
    NPN Ic=150mA Vceo=50V hfe=200~400 fT=80MHz P=200mW SOT-23
C1815 数据手册
TRANSISTOR (NPN) C1815 FEATURE SOT-23 Power dissipation 1.BASE 2.EMITTER 3.COLLECTOR MARKING : HF r MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Collector-Base Voltage VCEO Collector-Emitter Voltage VEBO Emitter-Base Voltage IC Collector Current -Continuous PC Collector Power Dissipation Tj Junction Temperature Tstg Storage Temperature bl u ec ol VCBO ou Parameter Symbol Value Units 60 V 50 V 5 V 150 mA 200 mW 150 ℃ ℃ -55-150 ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Parameter Symbol Test conditions MIN TYP MAX UNIT Collector-base breakdown voltage V(BR)CBO IC= 100µA, IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC= 0.1mA, 50 V IB=0 Collector cut-off current ICBO VCB=60V, IE=0 0.1 µA Collector cut-off current ICEO VCE=50V, IB=0 0.1 µA Emitter cut-off current IEBO VEB= 5V, IC=0 0.1 µA DC current gain hFE VCE= 6V, IC= 2mA 200 400 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB= 10mA 0.25 V Base-emitter saturation voltage VBE(sat) IC=100mA, IB= 10mA 1 V VCE=10V, IC= 1mA, Transition frequency Page 1 f 3 fT f=30MHz 80 MHz REV01: 09/2011 Typical Characteristics IC —— COMMON EMITTER Ta=25℃ 14uA hFE 12uA 8uA 2 6uA 4uA 1 Ta=25℃ 100 2 4 6 8 COLLECTOR-EMITTER VOLTAGE —— 10 VCE (V) IC BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) 100 bl u (mA) IC 1 0 300 T= a 25 ℃ T= a 10 0℃ 10 0.1 VBE 600 900 1 COLLECTOR CURREMT fT 1000 Cob/Cib —— 1200 VCB/VEB COMMON EMITTER VCE=10V Ta=25℃ 10 0.1 1 COLLECTOR POWER DISSIPATION PC (mW) (pF) Cib CAPACITANCE Cob 0.1 0.1 10 1 REVERSE VOLTAGE V (V) 10 PC 250 C 10 20 100 150 (mA) IC COLLECTOR CURRENT f=1MHz IE=0/IC=0 Ta=25 ℃ IC 100 BASE-EMMITER VOLTAGE VBE (mV) 50 —— 10 (MHz) —— COMMON EMITTER VCE= 6V (mA) Ta=100 ℃ fT IC 150 100 IC ec COLLECTOR CURREMT IC β=10 100 0.1 150 (mA) Ta=25℃ ou β=10 10 IC 1000 ol Ta=25℃ 100 150 10 VBEsat —— 2000 Ta=100 ℃ 1 1 COLLECTOR CURRENT 100 10 COMMON EMITTER VCE= 6V 10 0.1 r 0 VCEsat Page 2 f 3 IC IB=2uA 500 COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) DC CURRENT GAIN 10uA 3 —— Ta=100℃ 4 0 COLLECTOR CURRENT hFE 1000 TRANSITION FREQUENCY COLLECTOR CURRENT VCE 16uA IC (mA) 5 —— IC 100 (mA) Ta 200 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃ ) REV01: 09/2011 PACKAGE OUTLINE SOT-23 bl u ec ol ou r Plastic surface mounted package; 3 leads Page 3 f 3 REV01: 09/2011
C1815 价格&库存
很抱歉,暂时无法提供与“C1815”相匹配的价格&库存,您可以联系我们找货
C1815
  • 50+0.03300
  • 500+0.02970
  • 5000+0.02750
  • 10000+0.02640
  • 30000+0.02530
  • 50000+0.02464
