MM1Z6V8
MM1Z6V8
    BLUECOLOUR(蓝彩电子)
    SOD123
    Vz=6.8V Izt=5mA P=500mW
MM1Z6V8 数据手册
MM1Z2V0~MM1Z75 Silicon Planar Zener Diodes PINNING Features • Total power dissipation: max. 500 mW • Small plastic package suitable for surface mounted design • Tolerance approximately ± 5% DESCRIPTION PIN 1 Cathode 2 Anode 2 1 Top View Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Power Dissipation Junction Temperature Thermal Resistance Junction to Ambient Air bl Page 1 f 4 Ptot 500 mW TJ 150 O TStg - 55 to + 150 O Symbol Max. RthA 340 VF 0.9 C C co ue Parameter Forward Voltage at IF = 10 mA Unit lo Storage Temperature Range Characteristics at Ta = 25 OC Value ur Symbol Unit C/W O V REV01: 09/2011 Characteristics at Ta = 25 OC 1) Ω at I Z mA 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 2 2 2 2 2 2 2 2 2 2 2 ur 100 100 100 110 120 130 130 130 130 130 130 80 50 30 30 30 30 30 30 35 35 40 40 45 50 55 60 70 80 80 90 100 130 150 180 180 200 250 300 lo 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 ZZT (Max.) co 4A 4B 4C 4D 4E 4F 4H 4J 4K 4M 4N 4P 4R 4X 4Y 4Z 5A 5B 5C 5D 5E 5F 5H 5J 5K 5M 5N 5P 5R 5X 5Y 5Z 6A 6B 6C 6D 6E 6F 6H V znom V l ZT for V ZT mA V 5 1.8...2.15 5 2.08...2.33 5 2.28...2.56 5 2.5...2.9 5 2.8...3.2 5 3.1...3.5 5 3.4...3.8 5 3.7...4.1 5 4...4.6 5 4.4...5 5 4.8...5.4 5 5.2...6 5 5.8...6.6 5 6.4...7.2 5 7...7.9 5 7.7...8.7 5 8.5...9.6 5 9.4...10.6 5 10.4...11.6 5 11.4...12.7 5 12.4...14.1 5 13.8...15.6 5 15.3...17.1 5 16.8...19.1 5 18.8...21.2 5 20.8...23.3 5 22.8...25.6 5 25.1...28.9 5 28...32 5 31...35 5 34...38 2.5 37...41 2.5 40...46 2.5 44...50 2.5 48...54 2.5 52...60 2.5 58...66 2.5 64...72 2.5 70...79 Dynamic Impedance 2) ue MM1Z2V0 MM1Z2V2 MM1Z2V4 MM1Z2V7 MM1Z3V0 MM1Z3V3 MM1Z3V6 MM1Z3V9 MM1Z4V3 MM1Z4V7 MM1Z5V1 MM1Z5V6 MM1Z6V2 MM1Z6V8 MM1Z7V5 MM1Z8V2 MM1Z9V1 MM1Z10 MM1Z11 MM1Z12 MM1Z13 MM1Z15 MM1Z16 MM1Z18 MM1Z20 MM1Z22 MM1Z24 MM1Z27 MM1Z30 MM1Z33 MM1Z36 MM1Z39 MM1Z43 MM1Z47 MM1Z51 MM1Z56 MM1Z62 MM1Z68 MM1Z75 Zener Voltage Range 1) bl Type Marking Code Reverse Leakage Current I R (Max.) μA 120 120 120 120 50 20 10 5 5 2 2 1 1 0.5 0.5 0.5 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 2 2 2 1 1 0.2 0.2 0.2 at VR V 0.5 0.7 1 1 1 1 1 1 1 1 1.5 2.5 3 3.5 4 5 6 7 8 9 10 11 12 13 15 17 19 21 23 25 27 30 33 36 39 43 47 52 57 VZ is tested with pulses (20 ms). ZZT is measured at IZ by given a very small A.C. current signal. 2) Page 2 f 4 REV01: 09/2011 Typical Characteristics Breakdown characteristics Tj = constant (pulsed) mA 50 Tj=25o C 3V9 2V7 6V8 4V7 Iz 3V3 40 8V2 5V6 30 ur 20 0 1 3 2 4 5 co 0 lo Test current Iz 5mA 10 8 7 6 9 10 V Vz Breakdown characteristics ue Tj = constant (pulsed) mA 30 Tj=25 oC 10 12 bl Iz 15 20 18 22 27 Test current Iz 5mA 10 33 0 0 10 20 30 40 V Vz Page 3 f 4 REV01: 09/2011 PACKAGE OUTLINE SOD-123 bl ue co lo ur Plastic surface mounted package; 2 leads Page 4 f 4 REV01: 09/2011
MM1Z6V8 价格&库存
很抱歉,暂时无法提供与“MM1Z6V8”相匹配的价格&库存,您可以联系我们找货
MM1Z6V8
    • 1+0.07890
    库存:50
    MM1Z6V8
      • 10+0.06048
      • 50+0.05594
      • 200+0.05216
      • 600+0.04838
      • 1500+0.04536
      • 3000+0.04347
