A1006H-10P
A1006H-10P
    CJT(长江连接器)
    P=1mm
    胶壳 间距P=1mm 10Pin(1x10)
A1006H-10P 数据手册
A1006 SERIES 1.00mm pitch wire to board connector Specifications Current rating:1A AC,DC Voltage rating:50V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m Max. Insulation resistance:100M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* 1.85 1.75 7.00 REF CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-27 A1006 SERIES A1006-T 1.00mm pitch wire to board connector 1.00mm pitch Crimp Terminal 1.42±0.25 Reference Informations: *Used in CJT A1006H-XP,A1006H-2xXP series Housing 1.40±0.25 0.12 0.55±0.25 C SEC: B-B 0.25±0.20 2.20±0.20 C B 2.00±0.20 0.50 1.00±0.25 0.80 B 2.35±0.20 A 4.80±0.20 A 0.90±0.25 SEC: A-A 0.80±0.25 SEC: C-C 0.55±0.20 Ordering information & Specifications: Unit:mm Wire Range Insulation O.D. Material A1006-TP AWG#28-#32 0.80mm(max) Phosphor Bronze Tin over Nickel 20,000 PCS A1006-GP AWG#28-#32 0.80mm(max) Phosphor Bronze Gold over Nickel 20,000 PCS Part NO. Qty/reel Finish Optional Gold plating available but MOQ requested A1006H-XP 1.00mm pitch Single Row Housing Ordering Information: A1006H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Reference Informations: *Material: Insulator:Nylon 66,UL94V-0 *Suitable CJT A1006-T series Terminal *Mates with CJT A1006WR-S-XP series Single Row Wafer *Color:White B±0.20 1.15 C±0.15 Ordering Information & Dimensions: Circuit 1 2.90 1.00 5.70±0.20 PART NO. 1.75 A±0.10 1.00±0.05 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 20P 22P 26P 30P A 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 19.00 21.00 25.00 29.00 Dimensions B 4.60 5.60 6.60 7.60 8.60 9.60 10.60 11.60 12.60 13.60 14.60 15.60 16.60 17.60 18.60 22.60 24.60 28.60 32.60 C 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 16.00 17.00 21.00 23.00 27.00 31.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-28 A1006 SERIES A1006H-2xXP 1.00mm pitch wire to board connector 1.00mm pitch Dual Row Housing Ordering Information: A1006H-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Reference Informations: *Material: PBT,UL94V-0 *Suitable CJT A1006-T series Terminal *Mates with CJT A1006WV-S-2xXP series Dual Row Wafer *Color:Natural B±0.25 A±0.25 6.00±0.25 1.00 1.00±0.10 5.40±0.25 3.98±0.20 C±0.25 Ordering Information & Dimensions: PART NO. 2x10P 2x15P 2x20P 2x25P A 9.00 14.00 19.00 24.00 Dimensions B 14.70 19.70 24.70 29.70 C 15.70 20.70 25.70 30.70 Unit: mm A1006WR-S-XP 1.00mm pitch 90° Single Row Wafer-SMT TYPE Ordering Information: A1006WR-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A1006H-XP series Single Row Housing *Color:Ivory A 1.00 1.00 0.60 1.70 3.35 4.60 C±0.20 1.00±0.10 0.90 A±0.15 P.C.B LAYOUT B±0.20 5.00±0.20 4.30±0.20 4.10±0.20 0.20 1.75±0.20 1.85±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P A 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 16.00 17.00 18.00 19.00 20.00 21.00 22.00 23.00 24.00 25.00 26.00 27.00 28.00 29.00 Dimensions B 4.80 5.80 6.80 7.80 8.80 9.80 10.80 11.80 12.80 13.80 14.80 15.80 16.80 17.80 18.80 19.80 20.80 21.80 22.80 23.80 24.80 25.80 26.80 27.80 28.80 29.80 30.80 31.80 32.80 C 3.10 4.10 5.10 6.10 7.10 8.10 9.10 10.10 11.10 12.10 13.10 14.10 15.10 16.10 17.10 18.10 19.10 20.10 21.10 22.10 23.10 24.10 25.10 26.10 27.10 28.10 29.10 30.10 31.10 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-29 A1006 SERIES A1006WV-S-2xXP 1.00mm pitch wire to board connector 1.00mm pitch 180° Dual Row Wafer-SMT TYPE Ordering Information: A1006WV-S-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A1006H-2xXP series Dual Row Housing *Color:Ivory A±0.20 A±0.20 0.60 1.00±0.10 Circuit 2 4.00±0.10 1.80±0.10 Circuit 1 7.20±0.10 1.00±0.10 0.85±0.10 0.90±0.10 P.C.B LAYOUT B±0.25 5.45±0.25 CAP 0.20 0.30 4.65±0.25 Ordering Information & Dimensions: 4.20±0.25 6.50±0.20 6.65±0.25 PART NO. 2x10P 2x15P 2x20P 2x25P Dimensions A B 9.00 13.00 14.00 18.00 19.00 23.00 24.00 28.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-30
A1006H-10P 价格&库存
很抱歉,暂时无法提供与“A1006H-10P”相匹配的价格&库存,您可以联系我们找货
