A1201H-2P
A1201H-2P
    CJT(长江连接器)
    P=1.2mm
    胶壳 间距P=1.2mm 2Pin(1x2)
A1201H-2P 数据手册
A1201 SERIES 1.20mm pitch wire to board connector Specifications Current rating:2A AC,DC Voltage rating:50V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:100MΩMin. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* 3 3 Standards E326732 E326732 1.40 4.30 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-36 A1201 SERIES A1201-T 1.20mm pitch wire to board connector 1.20mm pitch Crimp Terminal Reference Informations: *Used in CJT A1201 series Housing 0.32 1.11±0.25 0.12 0.06±0.03 0.84±0.05 2.42±0.25 0.90±0.25 1.74 B 0.60 B SEC:A-A 0.74 0.80 A 3.16±0.25 0.40±0.10 A 1.20±0.25 0.96 1.02±0.25 SEC:B-B 0.36±0.05 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1201-GP AWG#28-#30 0.63mm(max) Phosphor Bronze Gold over Nickel 30,000 PCS A1201-T-A 1.20mm pitch Crimp Terminal Reference Informations: *Used in CJT A1201HA series Housing 1.00±0.15 0.12 0.85±0.15 1.00±0.15 0.60±0.10 0.80±0.08 1.15±0.05 0.14±0.05 0.58±0.08 0.85±0.15 0.28±0.05 1.20 B 1.17 B 1.45 A 0.70 A 2.95±0.20 SEC: A-A SEC: B-B Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1201-GP-A AWG#28-#32 0.63mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-37 A1201 SERIES A1201-T-B 1.20mm pitch wire to board connector 0.12 1.10±0.10 0.40±0.10 SEC:A-A A C 0.36 0.68±0.10 C 0.88±0.10 0.88±0.10 B 0.70±0.10 B SEC:B-B 3.10±0.20 A 1.05±0.10 1.00±0.10 Reference Informations: *Used in CJT A1201HB,HC-XP series Housing 1.00±0.10 1.20mm pitch Crimp Terminal 0.95±0.10 SEC:C-C Ordering information & Specifications: Unit:mm Wire Range Insulation O.D. Material A1201-TP-B AWG#28-#32 0.63mm(max) A1201-GP-B AWG#28-#32 0.63mm(max) Part NO. A1201-T-D Finish Qty/reel Phosphor Bronze Tin over Nickel 30,000 PCS Phosphor Bronze Gold over Nickel 30,000 PCS 1.20mm pitch Crimp Terminal 1.10±0.15 Reference Informations: *Used in CJT A1201HD-XP series Housing 0.12 1.20±0.15 B B C 0.85±0.15 0.95±0.15 0.70 A 3.55±0.20 A 1.45±0.10 SEC: A-A SEC: B-B C 0.85 0.50 0.48 1.20±0.10 0.85 0.30 SEC: C-C Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1201-GP-D AWG#28-#30 0.63mm(max) Phosphor Bronze Gold over Nickel 40,000 PCS CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-38 A1201 SERIES 1.20mm pitch Crimp Terminal Reference Informations: *Used in CJT A1201 series Housing 0.94±0.20 A1201M-GP 1.20mm pitch wire to board connector 1.15±0.20 0.12 0.77±0.20 SEC:A-A 0.40 0.93±0.20 0.24±0.03 0.80±0.10 0.90±0.05 0.25±0.10 2.25±0.10 C 1.25±0.05 C 0.46 B 0.68 B 0.80±0.10 SEC:B-B A 3.98±0.20 A 0.40±0.10 SEC:C-C Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1201M-GP AWG#28-#32 0.50mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS A1201H-XP 1.20mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1201-T series Terminal *Mates with CJT A1201WR-S-XP series Wafer *Color:Black Ordering Information: A1201H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Circuit 1 D±0.15 Ordering Information & Dimensions: C±0.15 3.80±0.15 1.20±0.15 1.20±0.05 A±0.10 B±0.15 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 1.20 2.40 3.60 4.80 6.00 7.20 8.40 9.60 10.80 12.00 13.20 14.40 15.60 16.80 Dimensions B C 3.10 2.60 4.30 3.80 5.50 5.00 6.70 6.20 7.90 7.40 9.10 8.60 10.30 9.80 11.50 11.00 12.70 12.20 13.90 13.40 15.10 14.60 16.30 15.80 17.50 17.00 18.70 18.20 D 3.60 4.80 6.00 7.20 8.40 9.60 10.80 12.00 13.20 14.40 15.60 16.80 18.00 19.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-39 A1201 SERIES A1201HA-XP 1.20mm pitch wire to board connector 1.20mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1201-T-A series Terminal *Mates with CJT A1201WRA-S-XP series Wafer *Color:White Ordering Information: A1201HA-XP - ** - *** 1 2 3 1.Part No. 2.Color: (blank):White BK:Black 3.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ PUSH 4 2 2Pin 0.30 4Pin 3.50±0.20 1.05 1.20 PUSH PUSH 3 C±0.20 Ordering Information & Dimensions: 1.20±0.20 B±0.30 Circuit 1 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 0.25 1.20±0.10 A±0.20 A 1.20 2.40 3.60 4.80 6.00 7.20 8.40 9.60 10.80 Dimensions B 3.35 4.55 5.75 6.95 8.15 9.35 10.55 11.75 12.95 C 2.60 3.80 5.00 6.20 7.40 8.60 9.80 11.00 12.20 Unit: mm A1201HB-XP 1.20mm pitch Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A1201-T-B series Terminal *Color:Natural B±0.25 1.20±0.20 Ordering Information: A1201HB-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 4.60±0.20 C±0.25 Circuit 1 Ordering Information & Dimensions: PART NO. 1.20±0.10 2P 3P 4P 5P 6P A±0.20 D±0.25 E±0.25 Dimensions A 1.20 2.40 3.60 4.80 6.00 B 2.98 4.18 5.38 6.58 7.78 C 2.60 3.80 5.00 6.20 7.40 D 3.20 4.40 5.60 6.80 8.00 E 3.50 4.70 5.90 7.10 8.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-40 A1201 SERIES A1201HC-XP 1.20mm pitch wire to board connector 1.20mm pitch Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A1201-T-B series Terminal *Color:Natural B±0.25 C±0.25 1.20±0.20 4.60±0.20 Ordering Information: A1201HC-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ D±0.25 Ordering Information & Dimensions: A±0.20 PART NO. 2P 3P 4P 5P 6P 1.20±0.10 Circuit 1 A 1.20 2.40 3.60 4.80 6.00 Dimensions B C 2.98 2.60 4.18 3.80 5.38 5.00 6.58 6.20 7.78 7.40 D 3.20 4.40 5.60 6.80 8.00 Unit: mm A1201HD-XP Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A1201-T-D series Terminal *Mates with CJT A1201WRD-S-XP series Wafer *Color:Gray Circuit 1 1.20mm pitch Housing Ordering Information: A1201HD-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 1.20±0.10 A±0.15 3.95±0.20 0.50 C±0.25 B±0.20 1.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P A 1.20 2.40 3.60 4.80 6.00 Dimensions B 2.60 3.80 5.00 6.20 7.40 C 3.40 4.60 5.80 7.00 8.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-41 A1201 SERIES A1201WR-S-XP 1.20mm pitch wire to board connector Ordering Information: A1201WR-S-XP - ** - *** 1 2 3 1.Part No. 2.Color: (blank):Black IV:Ivory 3.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.75±0.05 0.80±0.05 0.38 4.50±0.20 1.05 0.60 0.80±0.05 0.80 B±0.25 A±0.05 1.20±0.05 0.44 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 Solder Tab: Phosphor Bronze/Tin over Nickel *Mates with CJT A1201H-XP series Housing *Color:Black 0.85±0.05 1.20mm pitch 90° Wafer - SMT TYPE 0.70±0.05 P.C.B LAYOUT Ordering Information & Dimensions: 1.40 C±0.20 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P A±0.20 1.20±0.10 Circuit 1 0.20 0.20 A 1.20 2.40 3.60 4.80 6.00 7.20 8.40 9.60 10.80 Dimensions B 4.20 5.40 6.60 7.80 9.00 10.20 11.40 12.60 13.80 C 2.60 3.80 5.00 6.20 7.40 8.60 9.80 11.00 12.20 Unit: mm A1201WRA-S-XP 1.20mm pitch 90° Wafer - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 Solder Tab: Phosphor Bronze/Tin over Nickel *Mates with CJT A1201HA-XP series Housing *Color:Ivory 4Pin 2Pin 1.20±0.10 A±0.10 1.20 (2P,3P)0.80 (4P)1.10 0.85 3.75±0.20 4.30±0.20 1.05 1.00 0.80 0.60 Ordering Information & Dimensions: C±0.20 PART NO. (2P,3P)0.70 (4P)0.75 B±0.30 0.80 P.C.B LAYOUT 1.40 0.63 A±0.20 Circuit 1 0.20±0.05 Ordering Information: A1201WRA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (blank):Ivory BK:Black 0.20±0.05 3.95±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P A 1.20 2.40 3.60 4.80 6.00 7.20 8.40 9.60 10.80 Dimensions B 4.20 5.40 6.60 7.80 9.00 10.20 11.40 12.60 13.80 C 2.60 3.80 5.00 6.20 7.40 8.60 9.80 11.00 12.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-42 A1201 SERIES A1201WRD-S-XP 1.20mm pitch wire to board connector 1.20mm pitch 90° Wafer - SMT TYPE Ordering Information: A1201WRD-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon9T,UL94V-0 Solder Tab:Phosphor Bronze/Tin over Nickel *Mates with CJT A1201HD-XP series Housing *Color:Natural Circuit 1 A±0.10 0.60 1.20±0.10 1.10 3.75±0.10 0.85 1.00 1.20 A±0.15 0.80 C±0.20 0.80 RECOMMENDED PCB LAYOUT Ordering Information & Dimensions: GENERAL TOLERANCE ±0.05 B±0.25 0.20±0.05 1.40 1.20 PART NO. 4.30±0.20 2P 3P 4P 5P 6P 7P 8P A 1.20 2.40 3.60 4.80 6.00 7.20 8.40 Dimensions B 4.20 5.40 6.60 7.80 9.00 10.20 11.40 C 2.70 3.90 5.10 6.30 7.50 8.70 9.90 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-43
A1201H-2P 价格&库存
很抱歉,暂时无法提供与“A1201H-2P”相匹配的价格&库存,您可以联系我们找货
