A1253 SERIES
1.25mm pitch wire to board connector
Specifications
Current rating:1A AC,DC
Voltage rating:200V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:20m Max.
Insulation resistance:100M Min.
Withstanding voltage:500V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
0.90
5.80 REF
0.80
5.90 REF
0.80
0.90
3.35
3.15
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
A-57
A1253 SERIES
A1253-T
1.25mm pitch Crimp Terminal
1.50±0.25
Reference Informations:
*Used in CJT A1253H-XP series Housing
B
B
1.20±0.25
SEC:A-A
0.90
A
1.70±0.25
1.25±0.25
1.10
A
4.00±0.25
0.55±0.25
0.15
1.25±0.25
1.75±0.25
0.30
0.35
SEC:B-B
0.94
Unit:mm
Ordering information & Specifications:
Part NO.
Wire Range
Insulation O.D.
Material
Finish
Qty/reel
A1253-TP
AWG#28-#32
1.00mm(max)
Phosphor Bronze
Tin over Nickel
10,000 PCS
AWG#28-#32
1.00mm(max)
Phosphor Bronze
Gold over Nickel
10,000 PCS
A1253-GP
Optional Gold plating available but MOQ requested
A1253H-XP
1.25mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT A1253-T series Terminal
*Mates with CJT A1253WV,A1253WR-XP series Wafer
*Color:Reddish brown
Circuit 1
Ordering Information:
A1253H-XP - **
1
2
1.Part No.
2.Material:
(Blank):Nylon 66,UL94V-0
GWT :Nylon 66,UL94V-0 GWT 750 ℃
1.25±0.10
A±0.20
Ordering Information & Dimensions:
PART NO.
B±0.25
4.30±0.25
3.15±0.25
2.40±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
1.25
3.95
2.50
5.20
3.75
6.45
5.00
7.70
6.25
8.95
7.50
10.20
8.75
11.45
10.00
12.70
11.25
13.95
12.50
15.20
13.75
16.45
15.00
17.70
16.25
18.95
17.50
20.20
Unit: mm
A-58
A1253 SERIES
A1253WV-XP
1.25mm pitch 180° Wafer
A1253WV-XP - *** - **
1
2 3
1.Part No.
2.Material:
GWT:Nylon 66,UL94V-0,GWT 750 ℃
3.Finish:
(Blank):Tin over Nickel
G:Gold over Nickel
*Material:Pin:Brass/Tin over Nickel
Insulator:Nylon 66,UL94V-0
*Mates with CJT A1253H-XP series Housing
1.25±0.10
1.25±0.10
∅0.60±0.05
P.C.B LAYOUT
A±0.20
3.15±0.25
2.00±0.20
PIN 0.35 SQ
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
1.70±0.25
4.70±0.25
B±0.25
Circuit 1
Dimensions
A
B
1.25
4.25
2.50
5.50
3.75
6.75
5.00
8.00
6.25
9.25
7.50
10.50
8.75
11.75
10.00
13.00
11.25
14.25
12.50
15.50
13.75
16.75
15.00
18.00
16.25
19.25
17.50
20.50
Unit: mm
A1253WR-XP
1.25mm pitch 90° Wafer
A1253WR-XP - *** - **
1
2 3
1.Part No.
2.Material:
GWT :Nylon 66,UL94V-0,GWT 750 ℃
3.Finish:
G:Gold over Nickel
1.25±0.10
∅0.60±0.05
P.C.B LAYOUT
1.25±0.10
PART NO.
A±0.20
B±0.25
4.80±0.25
5.60±0.25
3.35±0.25
PIN 0.35 SQ
Circuit 1
1.70±0.20
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
1.25
4.25
2.50
5.50
3.75
6.75
5.00
8.00
6.25
9.25
7.50
10.50
8.75
11.75
10.00
13.00
11.25
14.25
12.50
15.50
13.75
16.75
15.00
18.00
16.25
19.25
17.50
20.50
Unit: mm
A-59
很抱歉,暂时无法提供与“A1253H-10P”相匹配的价格&库存,您可以联系我们找货
