A1253H-13P
A1253H-13P
    CJT(长江连接器)
    P=1.25mm
    胶壳 间距P=1.25mm 13Pin(1x13)
A1253H-13P 数据手册
A1253 SERIES 1.25mm pitch wire to board connector Specifications Current rating:1A AC,DC Voltage rating:200V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m Max. Insulation resistance:100M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 0.90 5.80 REF 0.80 5.90 REF 0.80 0.90 3.35 3.15 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-57 A1253 SERIES A1253-T 1.25mm pitch wire to board connector 1.25mm pitch Crimp Terminal 1.50±0.25 Reference Informations: *Used in CJT A1253H-XP series Housing B B 1.20±0.25 SEC:A-A 0.90 A 1.70±0.25 1.25±0.25 1.10 A 4.00±0.25 0.55±0.25 0.15 1.25±0.25 1.75±0.25 0.30 0.35 SEC:B-B 0.94 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1253-TP AWG#28-#32 1.00mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS AWG#28-#32 1.00mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS A1253-GP Optional Gold plating available but MOQ requested A1253H-XP 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1253-T series Terminal *Mates with CJT A1253WV,A1253WR-XP series Wafer *Color:Reddish brown Circuit 1 Ordering Information: A1253H-XP - ** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 1.25±0.10 A±0.20 Ordering Information & Dimensions: PART NO. B±0.25 4.30±0.25 3.15±0.25 2.40±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.25 3.95 2.50 5.20 3.75 6.45 5.00 7.70 6.25 8.95 7.50 10.20 8.75 11.45 10.00 12.70 11.25 13.95 12.50 15.20 13.75 16.45 15.00 17.70 16.25 18.95 17.50 20.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-58 A1253 SERIES A1253WV-XP 1.25mm pitch wire to board connector 1.25mm pitch 180° Wafer Ordering Information: A1253WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1253H-XP series Housing *Color:Reddish brown 1.25±0.10 1.25±0.10 ∅0.60±0.05 P.C.B LAYOUT A±0.20 3.15±0.25 2.00±0.20 PIN 0.35 SQ PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 1.70±0.25 4.70±0.25 B±0.25 Ordering Information & Dimensions: Circuit 1 Dimensions A B 1.25 4.25 2.50 5.50 3.75 6.75 5.00 8.00 6.25 9.25 7.50 10.50 8.75 11.75 10.00 13.00 11.25 14.25 12.50 15.50 13.75 16.75 15.00 18.00 16.25 19.25 17.50 20.50 Unit: mm A1253WR-XP 1.25mm pitch 90° Wafer Ordering Information: A1253WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1253H-XP series Housing *Color:Reddish brown 1.25±0.10 ∅0.60±0.05 P.C.B LAYOUT 1.25±0.10 PART NO. A±0.20 B±0.25 4.80±0.25 5.60±0.25 3.35±0.25 PIN 0.35 SQ Circuit 1 Ordering Information & Dimensions: 1.70±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.25 4.25 2.50 5.50 3.75 6.75 5.00 8.00 6.25 9.25 7.50 10.50 8.75 11.75 10.00 13.00 11.25 14.25 12.50 15.50 13.75 16.75 15.00 18.00 16.25 19.25 17.50 20.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-59
A1253H-13P 价格&库存
很抱歉,暂时无法提供与“A1253H-13P”相匹配的价格&库存,您可以联系我们找货
