A1256H-10P
A1256H-10P
    CJT(长江连接器)
    P=1.25mm
    胶壳 间距P=1.25mm 10Pin(1x10)
A1256H-10P 数据手册
A1256 SERIES 1.25mm pitch wire to board connector Specifications Current rating:1A AC,DC Voltage rating:150V AC,DC Temperature range:-40°C~+105°C Contact resistance:30m Max. Insulation resistance:500M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 7.20 REF 7.40 REF 7.00 REF 3.70 0.80 0.80 3.70 3.85 0.80 0.80 1.85 2.06 7.25 REF 7.40 REF 0.80 E326732 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-69 A1256 SERIES A1256-T 1.25mm pitch wire to board connector 1.25mm pitch Crimp Terminal Reference Informations: *Used in CJT A1256H,HD-XP,A1255HA-XP series Housing 1.35±0.25 0.15 0.50 1.60±0.25 1.20±0.15 2.30±0.25 1.28±0.25 1.05 B 0.80 B SEC:A-A 0.95 A 5.05±0.25 A SEC:B-B 0.95 Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A1256-TP AWG#28-#32 0.90mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS A1256-GP AWG#28-#32 0.90mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Part NO Optional Gold plating available but MOQ requested A1256H-XP 1.25mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1256-T series Terminal *Mates with CJT A1256WR-S,WRA-S-XP series Wafer *Color:Black Ordering Information: A1256H-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 1.25±0.10 A±0.20 Circuit 1 B±0.25 1.35±0.25 Ordering Information & Dimensions: 5.90±0.25 PART NO. C±0.25 1.95±0.25 2P 3P 4P 5P 6P 8P 10P 15P 20P 25P 30P A 1.25 2.50 3.75 5.00 6.25 8.75 11.25 17.25 23.75 30.00 36.25 Dimensions B 3.80 5.05 6.30 7.55 8.80 11.30 13.80 20.05 26.30 32.55 38.80 C 6.00 7.25 8.50 9.75 11.00 13.50 16.00 22.25 28.50 34.75 41.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-70 A1256 SERIES A1256HD-XP 1.25mm pitch wire to board connector 1.25mm pitch Dual Row Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1256-T series Terminal *Mates with CJT A1256WVD-S-F ,WRD-S, WRDA-S-XP series Dual Row Wafer *Color:Black 0.63±0.10 Circuit 2 1.40±0.10 1.40±0.10 Ordering Information: A1256HD-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 0.63±0.10 Circuit 2 Circuit 1 1.25±0.10 Circuit 1 1.25±0.10 A±0.20 A±0.20 Ordering Information & Dimensions: C±0.25 C±0.25 B±0.20 PART NO. B±0.20 5.90±0.25 2.80±0.20 5.90±0.25 2.80±0.20 3.44±0.25 3.44±0.25 13,15,17,19,21,31,41 Contacts 5,7,9,11 Contacts 5P 7P 9P 11P 13P 15P 17P 19P 21P 31P 41P A 2.50 3.75 5.00 6.25 7.50 8.75 10.00 11.25 12.50 18.75 25.00 Dimensions B 4.90 6.15 7.40 8.65 9.90 11.15 12.40 13.65 14.90 21.15 27.60 C 6.00 7.25 8.50 9.75 11.00 12.25 13.50 14.75 16.00 22.25 28.50 Unit: mm A1256WR-S-XP 1.25mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1256H-XP series Housing *Color:White Ordering Information: A1256WR-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A±0.20 A±0.10 1.25±0.05 0.30 1.90±0.10 Circuit 1 1.60±0.10 1.45±0.10 0.70±0.10 1.35±0.10 SUGGESTED PCB LAYOUT (COMPONENT SIDE) 1.80±0.10 B±0.25 C±0.25 Circuit 1 4.30±0.20 1.60 1.00±0.10 5.65±0.10 1.25±0.10 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 8P 10P 15P 20P 25P 30P A 1.25 2.50 3.75 5.00 6.25 8.75 11.25 17.25 23.75 30.00 36.25 Dimensions B 6.10 7.35 8.60 9.85 11.10 13.60 16.10 22.35 28.60 34.85 41.10 C 4.01 5.26 6.51 7.76 9.01 11.51 14.01 20.26 26.51 32.76 39.01 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-71 A1256 SERIES A1256WRA-S-XP 1.25mm pitch wire to board connector 1.25mm pitch 90° Wafer-SMT TYPE Ordering Information: A1256WRA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Shell:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A1256H-XP series Housing *Color:White A±0.20 1.25±0.10 2.875±0.10 2.00±0.10 0.30 1.25±0.05 1.70±0.05 0.80±0.05 1.96±0.10 2.50±0.10 B±0.25 C±0.25 1.25±0.10 SUGGESTED PCB LAYOUT (COMPONENT SIDE) 4.25±0.25 Ordering Information & Dimensions: 1.10±0.10 Circuit 1 PART NO. 20P 30P A 23.75 36.25 Dimensions B 31.40 43.60 C 26.60 39.10 Unit: mm A1256WVD-S-F-XP 1.25mm Pitch 180° Dual Row Wafer-SMT TYPE Reference Informations: Ordering Information: A1256WVD-S-F-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ *Material:Pin:Brass/Gold over Nickel Shell:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 Cap:Nylon 6T,UL94V-0 *Mates with CJT A1256HD-XP series Dual Row Housing *Color:White 1.275±0.10 1.35±0.10 0.625±0.25 Circuit 2 A±0.10 0.30 0.625±0.10 0.40 B±0.25 3.85±0.20 3.95±0.20 A±0.20 SUGGESTED PCB LAYOUT (COMPONENT SIDE) 0.55 C±0.25 Cap Ordering Information & Dimensions: PART NO. 1.00 0.60 2.85±0.05 2-∅0.75±0.05 1.60±0.10 C±0.05 1.45±0.10 Circuit 1 6.00±0.10 1.25±0.10 1.40±0.25 A±0.20 0.85 0.70 21P 31P A 12.50 18.75 Dimensions B 16.85 23.10 C 11.25 17.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-72 A1256 SERIES A1256WRD-S-XP 1.25mm pitch wire to board connector 1.25mm Pitch 90° Dual Row Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Shell:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1256HD-XP series Dual Row Housing *Color:White Ordering Information: A1256WRD-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A±0.20 0.625±0.10 0.65±0.10 1.35±0.10 1.60 6.00±0.10 0.30 1.45±0.10 0.625±0.05 0.40±0.05 B±0.25 A±0.10 SUGGESTED PCB LAYOUT (COMPONENT SIDE) 1.40 A±0.20 1.25±0.10 4.45±0.25 3.70±0.25 Circuit 1 Ordering Information & Dimensions: PART NO. 21P 31P 41P 0.95 Circuit 2 Dimensions A B 12.50 16.55 18.75 22.80 25.00 29.05 Unit: mm A1256WRDA-S-XP 1.25mm pitch 90° Dual Row Wafer-SMT TYPE A±0.10 1.45±0.10 1.60±0.10 A±0.20 A±0.20 0.625 0.625±0.05 0.40±0.10 0.30 0.625 1.325±0.10 Circuit 1 6.00±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1256HD-XP series dual row Housing *Color:White Ordering Information: A1256WRDA-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 1.35±0.10 SUGGESTED PCB LAYOUT (COMPONENT SIDE) 0.30 Ordering Information & Dimensions: B±0.25 B±0.20 A±0.20 A±0.20 Circuit 2 5,7,9,11 Contacts 1.25±0.10 Circuit 1 1.40 0.625 Circuit 1 1.40 1.25±0.10 3.70±0.25 PART NO. 0.625 Circuit 2 13,15,17,19,21,31,41 Contacts 4.45±0.25 0.95 5P 7P 9P 11P 13P 15P 17P 19P 21P 31P 41P Dimensions A B 2.50 6.10 3.75 7.35 5.00 8.60 6.25 9.85 7.50 11.10 8.75 12.35 10.00 13.60 11.25 14.85 12.50 16.10 18.75 22.35 25.00 28.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-73
A1256H-10P 价格&库存
很抱歉,暂时无法提供与“A1256H-10P”相匹配的价格&库存,您可以联系我们找货
