A1501WV-12P
A1501WV-12P
    CJT(长江连接器)
    插件,P=1.5mm
    线对板针座 1x12P 直插 间距:1.5mm
A1501WV-12P 数据手册
A1501 SERIES 1.50mm pitch wire to board and wire to wire connector Specifications Current rating:1A AC,DC Voltage rating:100V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m Max. Insulation resistance:500M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 3.50 1.90 0.80 wire to wire 0.80 2.00 3.60 3.70 5.80 REF 9.10 REF 6.20 REF DIP TYPE 3.70 3.80 7.50 REF 0.80 3.80 0.80 0.80 6.50 REF 7.50 REF SMT TYPE CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-125 A1501 SERIES A1501-T 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A1501H-XP series Housing 0.20 0.90 1.90±0.25 SEC:A-A B SEC:C-C 0.35 0.85±0.10 C 1.10±0.10 C 1.05±0.10 E±0.25 F±0.25 B 1.00 A 4.05±0.25 A 1.55±0.20 0.46±0.10 D±0.25 C±0.25 SEC:B-B Unit:mm Ordering information & Specifications: Part NO. Wire Range Finish C D E F Qty/reel 10,000 PCS A1501-TP AWG#26-#32 Insulation O.D. Material 1.10mm(max) Phosphor Bronze Tin over Nickel 1.55 1.60 1.25 1.30 A1501-GP AWG#26-#32 1.10mm(max) Phosphor Bronze Gold over Nickel 1.55 1.60 1.25 1.30 10,000 PCS A1501-TP-H AWG#24-#30 1.50mm(max) Phosphor Bronze Tin over Nickel 1.80 1.85 1.25 1.30 15,000 PCS A1501-GP-H AWG#24-#30 1.50mm(max) Phosphor Bronze Gold over Nickel 1.80 1.85 1.25 1.30 15,000 PCS Optional Gold plating available but MOQ requested A1501-T-A 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A1501HA-XP series Housing 2.10±0.25 0.15 0.70 1.85±0.25 A A 1.14±0.10 3.05±0.20 1.30±0.25 0.32±0.05 1.05 B 3.80±0.20 B 6.90±0.25 SEC:A-A 1.25±0.25 0.90 SEC:B-B Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A1501-TP-A AWG#24-#28 1.28mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A1501-GP-A AWG#24-#28 1.28mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-126 A1501 SERIES A1501-T-B 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A1501HB-XP series Housing 1.80±0.25 5.30±0.25 0.15 0.70 1.80±0.25 SEC:A-A 0.92±0.10 0.12 1.20±0.25 1.15±0.10 SEC:B-B Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material AWG#28-#32 1.10mm(max) Phosphor Bronze Part NO. A1501-GP-B A1501M-T 1.30±0.25 B 1.00 B 2.70±0.20 A 5.60±0.25 A Finish Qty/reel Gold over Nickel 10,000 PCS 1.50mm pitch Crimp Terminal 0.15 1.50±0.10 1.60±0.10 Reference Informations: *Used in CJT A1501HM-XP series Housing SEC: A-A 1.10±0.10 1.10±0.10 2.80±0.20 B 1.00±0.10 B 2.20±0.20 A 7.00±0.25 A SEC: B-B 0.50±0.10 Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A1501M-TP AWG#28-#32 0.90mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS A1501M-GP AWG#28-#32 0.90mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Part NO. Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-127 A1501 SERIES A1501H-XP 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1501-T(H) series Terminal *Mates with CJT A1501HM-XP series Housing and A1501WV,WR,WV-S,WR-S-XP series Wafer *Color:White Ordering Information: A1501H-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black GY:Gray RD:Red LE:Light blue BL:Blue LY:Lemon yellow GN:Green DO:Dark orange Circuit 1 1.50±0.10 Ordering Information & Dimensions: A±0.20 Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 21.00 24.00 PART NO. B±0.25 4.80±0.25 3.40±0.25 2.65±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 15P Unit: mm A1501HA-XP 1.50mm pitch Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A1501-T-A series Terminal *Mates with CJT A1501WVA-S,WRA-S-XP series Wafer *Color:Beige Ordering Information: A1501HA-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0 GWT 750 ℃ C±0.25 A±0.20 6.10±0.20 1.50±0.10 Circuit 1 4.42±0.20 B±0.25 8.60±0.25 2.85±0.20 2P,3P 4P,5P 6P~15P Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 1.50 3.00 4.50 6.00 7.50 9.00 10.50 12.00 13.50 15.00 16.50 18.00 19.50 21.00 Dimensions B 4.25 5.75 7.25 8.75 10.25 11.75 13.25 14.75 16.25 17.75 19.25 20.75 22.25 23.75 C 7.30 8.80 10.30 11.80 13.30 14.80 16.30 17.80 19.30 20.80 22.30 23.80 25.30 26.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-128 A1501 SERIES A1501HB-XP 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1501-T-B series Terminal *Mates with CJT A1501WRB-S-XP series Wafer *Color:Black Ordering Information: A1501HB-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0 GWT 750 ℃ A±0.20 1.50±0.10 Circuit 1 1.92 B±0.25 1.19 Ordering Information & Dimensions: 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 0.80 6.40±0.20 PART NO. 0.99 C±0.20 A 1.50 3.00 4.50 6.00 7.50 9.00 10.50 12.00 13.50 15.00 16.50 Dimensions B 6.95 8.45 9.95 11.45 12.95 14.45 15.95 17.45 18.95 20.45 21.95 C 5.55 7.05 8.55 10.05 11.55 13.05 14.55 16.05 17.55 19.05 20.55 Unit: mm A1501HM-XP 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1501M-T series Terminal *Mates with CJT A1501H-XP series Housing *Color:White Ordering Information: A1501HM-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0 GWT 750 ℃ 1.50±0.10 A±0.20 B±0.25 Circuit 1 3.60±0.25 Ordering Information & Dimensions: 2.80±0.20 8.40±0.25 4.10±0.20 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P Dimensions A B 1.50 5.55 3.00 7.05 4.50 8.55 6.00 10.05 7.50 11.55 9.00 13.05 10.50 14.55 12.00 16.05 13.50 17.55 15.00 19.05 16.50 20.55 18.00 22.05 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-129 A1501 SERIES A1501WV-XP 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch 180° Wafer Ordering Information: A1501WV-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (blank):Ivory BK:Black 1.50±0.05 RD:Red BL:Blue GN:Green YL:Yellow 4.Finish: Ø0.70±0.03 (Blank):Tin over Nickel G:Gold over Nickel P.C.B LAYOUT Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1501H-XP series Housing *Color:Ivory Circuit 1 1.50±0.10 A±0.20 Ordering Information & Dimensions: B±0.25 PART NO. 3.50±0.25 2.80±0.20 4.50±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 15P ∅0.50 Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 21.00 24.00 Unit: mm A1501WR-XP 1.50mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1501H-XP series Housing *Color: Ivory Ordering Information: A1501WR-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (blank):Ivory BK:Black RD:Red BL:Blue GN:Green YL:Yellow 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel ∅0.50 1.50±0.10 1.50±0.05 Ø0.70±0.03 P.C.B LAYOUT Ordering Information & Dimensions: Circuit 1 A±0.20 PART NO. B±0.25 4.85±0.25 5.00±0.25 6.00±0.25 3.70±0.25 2.80±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 15P Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 21.00 24.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-130 A1501 SERIES A1501WV-S-XP 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch 180° Wafer-SMT TYPE 1.50±0.15 1.40±0.15 1.30±0.15 3.60±0.15 2.30±0.15 Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 Cap:Nylon 6T,UL94V-0 *Mates with CJT A1501H-XP series Housing *Color:Ivory 0.70±0.15 1.50±0.10 Ordering Information: A1501WV-S-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Ivory BK:Black DH:Dark gray RD:Red LE:Light blue BL:Blue LY:Lemon yellow GN:Green DO:Dark orange 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel Ordering Information & Dimensions: 1.50±0.10 A±0.20 PART NO. A±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P P.C.B LAYOUT 3.70±0.25 ∅0.50 PIN,Circuit 1 1.50±0.20 5.00±0.25 B±0.25 Dimensions A B 1.50 6.00 3.00 7.50 4.50 9.00 6.00 10.50 7.50 12.00 9.00 13.50 10.50 15.00 12.00 16.50 13.50 18.00 15.00 19.50 16.50 21.00 18.00 22.50 Unit: mm A1501WR-S-XP 1.50mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1501H-XP series Housing *Color:Ivory A±0.20 ∅0.50 1.10±0.10 A±0.10 0.70±0.05 P.C.B LAYOUT B±0.25 5.00±0.25 3.80±0.25 Circuit 1 0.50 6.00±0.25 1.40±0.10 2.60±0.10 1.50±0.05 1.90±0.10 1.50±0.10 1.40±0.10 Ordering Information: A1501WR-S-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0 GWT 750 ℃ 3.Color: (Blank):Ivory BK:Black DH:Dark gray RD:Red LE:Light blue BL:Blue LY:Lemon yellow GN:Green DO:Dark orange 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P Dimensions A B 1.50 6.00 3.00 7.50 4.50 9.00 6.00 10.50 7.50 12.00 9.00 13.50 10.50 15.00 12.00 16.50 13.50 18.00 15.00 19.50 16.50 21.00 18.00 22.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-131 A1501 SERIES A1501WR-S-XP-A 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch 90° Wafer DIP SMT TYPE Ordering Information: A1501WR-S-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel A±0.10 1.40±0.10 ∅0.70±0.05 B±0.25 P.C.B LAYOUT 1.90±0.10 1.10±0.10 1.50±0.05 2.00±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1501H-XP series Housing *Color:Ivory Ordering Information & Dimensions: 5.00±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 1.50 3.70±0.25 1.50±0.10 6.00±0.25 PIN ∅0.50 Circuit 1 Dimensions A B 1.50 6.00 3.00 7.50 4.50 9.00 6.00 10.50 7.50 12.00 9.00 13.50 10.50 15.00 12.00 16.50 13.50 18.00 15.00 19.50 16.50 21.00 18.00 22.50 PART NO. A±0.25 Unit: mm 1.50mm pitch 180° Wafer-SMT TYPE C±0.30 C±0.30 KAPTON TAPE 1.70±0.05 1.50±0.05 0.80 5.50±0.10 A±0.10 2.40±0.05 Ordering Information: A1501WVA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):LCP,UL94V-0 GWT:LCP,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Solder Tabs: Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A1501HA-XP series Housing *Color:Ivory 3.30 A1501WVA-S-XP 0.25 A±0.20 8P~15P KAPTON TAPE FIGURE P.C.B LAYOUT 4.40±0.25 1.50±0.10 1.05 6.35±0.25 6.80±0.25 1.80±0.05 Ordering Information & Dimensions: PART NO. 2P~7P KAPTON TAPE FIGURE B±0.25 7.25±0.25 0.40 Circuit 1 6P~15P 2P~5P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 1.50 3.00 4.50 6.00 7.50 9.00 10.50 12.00 13.50 15.00 16.50 18.00 19.50 21.00 Dimensions B 7.30 8.80 10.30 11.80 13.30 14.80 16.30 17.80 19.30 20.80 22.30 23.80 25.30 26.80 C 6.10 7.60 9.10 10.60 12.10 13.60 5.00 5.00 5.00 5.00 5.00 5.00 5.00 5.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-132 A1501 SERIES Ordering Information: A1501WRA-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel A±0.10 1.70±0.05 1.50±0.05 0.80 3.80 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Solder Tabs: Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A1501HA-XP series Housing *Color:Ivory 5.15±0.10 1.50mm pitch 90° Wafer-SMT TYPE 2.90±0.05 A1501WRA-S-XP 1.50mm pitch wire to board and wire to wire connector 1.80±0.05 A±0.20 1.50±0.10 P.C.B LAYOUT 0.25 With KAPTON TAPE Ordering Information & Dimensions: PART NO. 6P~15P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 2P~5P 6.36±0.25 B±0.25 Circuit 1 7.25±0.25 1.25 Dimensions A B 1.50 7.30 3.00 8.80 4.50 10.30 6.00 11.80 13.30 7.50 9.00 14.80 10.50 16.30 12.00 17.80 13.50 19.30 15.00 20.80 16.50 22.30 18.00 23.80 25.30 19.50 21.00 26.80 Unit: mm A1501WRB-S-XP 1.50mm pitch 90° Wafer-SMT TYPE 1.25 1.80 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A1501HB-XP series Housing *Color:Black 1.68 Ordering Information: A1501WRB-S-XP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750 ℃ 3.79 1.00 A 1.50 B±0.25 0.60 P.C.B LAYOUT 0.40 PART NO. 0.34 6.10±0.25 Ordering Information & Dimensions: 0.31 1.50±0.10 Circuit 1 2.00±0.25 A±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 1.50 6.75 3.00 8.25 4.50 9.75 6.00 11.25 7.50 12.75 9.00 14.25 10.50 15.75 12.00 17.25 13.50 18.75 15.00 20.25 16.50 21.75 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-133 A1501 SERIES A1501WVD-S-XP 1.50mm pitch wire to board and wire to wire connector 1.50mm pitch 180° Wafer-SMT TYPE 2.40±0.05 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:LCP,UL94V-0 *Color:Beige A±0.10 A±0.20 1.50±0.05 3.30±0.10 1.50±0.10 Ordering Information: A1501WVD-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel 5.50±0.10 0.80±0.05 Ordering Information & Dimensions: PART NO. 1.80±0.05 0.30 1.70±0.05 P.C.B LAYOUT B±0.25 5.80±0.25 0.50 7.50±0.25 1.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 1.50 7.50 3.00 9.00 4.50 10.50 6.00 12.00 7.50 13.50 9.00 15.00 10.50 16.50 12.00 18.00 13.50 19.50 15.00 21.00 16.50 22.50 18.00 24.00 19.50 25.50 21.00 27.00 22.50 28.50 Unit: mm 1.50mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:LCP,UL94V-0 *Color:Beige A±0.10 1.50±0.05 Ordering Information: A1501WVD-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel 2.90±0.05 A1501WRD-S-XP A±0.20 1.50±0.10 3.80±0.10 6.60±0.10 0.80±0.05 1.70±0.05 1.80±0.05 P.C.B LAYOUT B±0.25 7.50±0.25 5.80±0.25 0.50 1.20 0.30 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 1.50 7.50 3.00 9.00 4.50 10.50 6.00 12.00 7.50 13.50 9.00 15.00 10.50 16.50 12.00 18.00 13.50 19.50 15.00 21.00 16.50 22.50 18.00 24.00 19.50 25.50 21.00 27.00 22.50 28.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-134
A1501WV-12P
物料型号:CJTconn A1501系列,包括多种型号,例如A1501-TP、A1501-GP、A1501-TP-H等。
器件简介:A1501系列是1.50mm间距的线对板和线对线连接器,符合RoHS和REACH标准,可定制无卤/无卤素产品。
引脚分配:文档中提供了多种型号的引脚分配,例如A1501-T、A1501-T-A、A1501-T-B等,每个型号都有其特定的引脚布局。
参数特性: - 电流额定值:1A AC/DC - 电压额定值:100V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大20mΩ - 绝缘电阻:最小500MΩ - 耐电压:500V AC/分钟
功能详解:文档中详细描述了不同型号的连接器,包括它们的应用场景和配合使用的外壳型号。
应用信息:适用于需要1.50mm间距连接器的多种应用,文档中提供了不同型号的参考信息和订购信息。
封装信息:提供了不同型号的尺寸和材料信息,例如外壳材料为Nylon 66或PBT,UL94V-0,颜色包括白色、米色、黑色等。
A1501WV-12P 价格&库存
很抱歉,暂时无法提供与“A1501WV-12P”相匹配的价格&库存,您可以联系我们找货
