A1502WV-S-12P
A1502WV-S-12P
    CJT(长江连接器)
    SMD,P=1.5mm
    线对板连接器 12Pin(1x12) P=1.50mm 立贴
A1502WV-S-12P 数据手册
A1502 SERIES 1.50mm pitch wire to board connector Specifications Current rating:3A AC,DC Voltage rating:350V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m Max. Insulation resistance:1000M Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.45 4.70 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-135 0.80 3.35 4.25 REF. 7.55 REF 0.80 0.80 4.55 3.35 7.45 REF A1502 SERIES A1502-T 1.50mm pitch wire to board connector 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A1502H-XP series Housing 0.90±0.20 0.15 2.10±0.25 1.20±0.25 1.25±0.20 0.70±0.10 SEC:A-A 0.30±0.10 1.10±0.20 B 1.50±0.10 B 0.80±0.20 A 5.25±0.25 A 2.00±0.25 1.40±0.25 0.35±0.10 SEC:B-B 0.90±0.10 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A1502-TP AWG#24-#28 1.10mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS AWG#24-#28 1.10mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS A1502-GP Optional Gold plating available but MOQ requested A1502-T-A 1.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A1502HA-XP series Housing 0.20 B 0.34 1.70±0.20 2.11±0.20 0.90±0.20 0.89±0.20 SEC:B-B 1.30±0.20 B 1.00±0.20 A SEC:A-A 1.41±0.20 A 4.72±0.25 8.25±0.30 0.70 2.00±0.20 3.02±0.20 1.82±0.20 0.40±0.10 1.10±0.20 Ordering information & Specifications: Unit:mm Wire Range Insulation O.D. Material Finish Qty/reel A1502-TP-A AWG#24-#28 1.10mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A1502-GP-A AWG#24-#28 1.10mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-136 A1502 SERIES A1502H-XP 1.50mm pitch wire to board connector 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1502-T series Terminal *Mates with CJT A1502WV,WR,WV-S,WR-S,WVA,WRA-XP series Wafer *Color:White 1.50±0.10 Odering Information: A1502H-XP - ** - *** 1 2 3 1.Part No. 2.Color: (blank) : White BK : Black 3.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ Circuit 1 A±0.20 Ordering Information & Dimensions: 2.70±0.25 PART NO. 3.35±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 5.70±0.25 B±0.25 Dimensions A B 1.50 4.10 3.00 5.60 4.50 7.10 6.00 8.60 7.50 10.10 9.00 11.60 10.50 13.10 12.00 14.60 13.50 16.10 15.00 17.60 16.50 19.10 18.00 20.60 19.50 22.10 21.00 23.60 Unit: mm A1502HA-XP 1.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A1502-T-A series Terminal *Mates with CJT A1502WVA-IT-S-XP series Wafer *Color:White Circuit 1 0.70 1.00 A Odering Information: A1502HA-XP - ** - *** 1 2 3 1.Part No. 2.Color: (blank) : White BL : Blue 3.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 1.50±0.20 3.50±0.25 A±0.20 1.50±0.20 0.70 1.50±0.20 6.00±0.25 3.00±0.20 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 1.50 3.50 3.00 5.00 4.50 6.50 6.00 8.00 7.50 9.50 9.00 11.00 10.50 12.50 12.00 14.00 13.50 15.50 15.00 17.00 16.50 18.50 18.00 20.00 19.50 21.50 21.00 23.00 22.50 24.50 24.00 26.00 25.50 27.50 27.00 29.00 28.50 30.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-137 A1502 SERIES A1502WV-XP 1.50mm pitch wire to board connector 1.50mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:White B±0.25 A±0.10 1.50±0.05 Odering Information: A1502WV-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (blank):White BK:Black 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel ∅0.70±0.05 1.50±0.10 P.C.B LAYOUT Ordering Information & Dimensions: A±0.10 PART NO. 4.80±0.25 2.60±0.20 3.60±0.25 Circuit 1 Pin 0.50SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 19.50 22.50 21.00 24.00 Unit: mm A1502WR-XP 1.50mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:White PIN 0.50 SQ Circuit 1 A±0.10 1.50±0.05 Odering Information: A1502WR-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (blank):White BK:Black 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel ∅0.70±0.05 P.C.B LAYOUT Ordering Information & Dimensions: 1.50±0.10 PART NO. A±0.10 B±0.25 4.00±0.25 6.10±0.25 2.60±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 19.50 22.50 21.00 24.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-138 A1502 SERIES A1502WV-S-XP 1.50mm pitch 180° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:Ivory Circuit 1 2.65+0.05 -0.00 1.50±0.10 7.00±0.10 3.55+0.05 -0.00 A±0.20 Circuit 1 1.50mm pitch wire to board connector Odering Information: A1502WV-S-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (blank):White BK:Black 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel 0.85±0.05 Ordering Information & Dimensions: 1.50±0.05 PART NO. A±0.05 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P P.C.B LAYOUT B±0.25 5.75±0.25 5.00±0.20 4.45±0.20 6.00±0.25 Dimensions A B 1.50 4.30 3.00 5.80 4.50 7.30 6.00 8.80 7.50 10.30 9.00 11.80 10.50 13.30 12.00 14.80 13.50 16.30 15.00 17.80 16.50 19.30 18.00 20.80 19.50 22.30 21.00 23.80 Unit: mm A1502WR-S-XP 1.50mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:Ivory 7.00±0.10 3.55+0.05 -0.00 A±0.20 1.50±0.10 2.65+0.05 -0.00 Circuit 1 Circuit 1 Odering Information: A1502WR-S-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (blank):White BK:Black 4.Finish: (Blank):Tin over Nickel G:Gold over Nickel Ordering Information & Dimensions: 0.85±0.05 1.50±0.05 PART NO. A±0.05 P.C.B LAYOUT B±0.25 6.00±0.20 7.75±0.25 5.75±0.25 5.00±0.20 4.45±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 4.30 3.00 5.80 4.50 7.30 6.00 8.80 7.50 10.30 9.00 11.80 10.50 13.30 12.00 14.80 13.50 16.30 15.00 17.80 16.50 19.30 18.00 20.80 19.50 22.30 21.00 23.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-139 A1502 SERIES A1502WVA-XP 1.50mm pitch wire to board connector 1.50mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:Gray B±0.25 Odering Information: A1502WVA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel A±0.10 1.50±0.10 ∅0.70±0.05 P.C.B LAYOUT 1.50±0.10 Ordering Information & Dimensions: A±0.10 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 2.60±0.20 4.90±0.25 3.40±0.25 1.30±0.10 Pin 0.50±0.05 SQ Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 19.50 22.50 21.00 24.00 Unit: mm A1502WRA-XP 1.50mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A1502H-XP series Housing *Color:Gray Odering Information: A1502WRA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel PIN 0.50±0.05 SQ A±0.10 1.50±0.10 ∅0.70±0.05 P.C.B LAYOUT Ordering Information & Dimensions: 1.50±0.10 PART NO. A±0.10 B±0.25 2.60±0.20 6.10±0.25 5.10±0.25 3.60±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.50 4.50 3.00 6.00 4.50 7.50 6.00 9.00 7.50 10.50 9.00 12.00 10.50 13.50 12.00 15.00 13.50 16.50 15.00 18.00 16.50 19.50 18.00 21.00 19.50 22.50 21.00 24.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-140 A1502 SERIES 1.50mm pitch thru board inverted SMT 180° Wafer Odering Information: A1502WVA-IT-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 3.Finish: (Blank):Tin over Nickel G:Gold over Nickel C D 1.00 5.00 3.28±0.25 3.00±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Solder Tabs:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A1502HA-XP series Housing *Color:Ivory 3.25 A1502WVA-IT-S-XP 1.50mm pitch wire to board connector 4.25 1.50 R0.50 MAX 0.50±0.10 0.70 CUT-OUT IN PCB A±0.20 2.55±0.20 B±0.25 A 4.70±0.25 PART NO. 2P 3P 4P 5P 6P 3.35±0.20 1.00 6.90±0.25 Ordering Information & Dimensions: 1.81 A 1.50 3.00 4.50 6.00 7.50 Dimensions B C 5.50 6.00 7.00 7.50 8.50 9.00 10.00 10.50 11.50 12.00 D 4.10 4.85 5.60 6.35 7.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-141
A1502WV-S-12P
物料型号:A1502系列
器件简介:1.50mm间距线对板连接器,适用于多种电子设备。
引脚分配:文档中提供了不同型号的引脚分配信息,例如A1502-T、A1502H-XP、A1502WV-XP等,具体引脚分配根据型号而异。
参数特性: - 电流额定值:3A AC/DC - 电压额定值:350V AC/DC - 温度范围:-40°C至+105°C - 接触电阻:最大20mΩ - 绝缘电阻:最小1000MΩ - 耐电压:500V AC/分钟 - 符合RoHS和REACH标准,可定制无卤/无卤素产品
功能详解:文档中详细描述了不同型号的连接器的功能特点,例如180°和90°的Wafer,以及SMT类型的Wafer。
应用信息:适用于需要1.50mm间距连接器的电子设备,文档中提供了不同型号的参考信息和订购信息。
封装信息:提供了不同型号的尺寸和材料信息,例如A1502H-XP系列的外壳材料为Nylon 66, UL94V-0,颜色为白色。
订购信息:提供了详细的订购指南,包括部件编号、线规范围、绝缘外径、材料、表面处理和每卷数量。
A1502WV-S-12P 价格&库存
很抱歉,暂时无法提供与“A1502WV-S-12P”相匹配的价格&库存,您可以联系我们找货
