A2001WR-S-9P
A2001WR-S-9P
    CJT(长江连接器)
    SMD,P=2mm
    线对板连接器 9Pin(1x9) P=2.00mm 立贴
A2001WR-S-9P 数据手册
A2001 SERIES 2.00mm pitch wire to board connector Specifications Current rating:2A AC,DC Voltage rating:100V AC,DC Temperature range:-40°C~+105°C Contact resistance:10m Max. Insulation resistance:1000M Min. Withstanding voltage:800V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.85 2.00 17.00 REF. 1.60 1.60 1.80 8.10 REF. 5.00 8.25 REF. 1.60 8.60 REF. 1.60 1.80 1.80 4.70 4.70 DIP TYPE 5.40 5.60 8.70 REF. 9.70 REF. SMT TYPE CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A2001 SERIES A2001-T 2.00mm pitch wire to board connector 2.00mm pitch Crimp Terminal Reference Informations: *Used in CJT [A2001H] series Housing 0.20 2.50 0.80 2.20 SEC:A-A B 1.50 1.62 1.00 1.70 2.10 0.45 1.40 B 1.32 A 5.60 A SEC:B-B 0.71 1.40 Ordering information & Specifications: Unit:mm Wire Range Part NO Insulation O.D. 1.50mm(max) A2001-TP AWG#24-#30 1.50mm(max) A2001-GP AWG#24-#30 Optional Gold plating available but MOQ requested A2001M-T Qty/reel Material Finish Phosphor Bronze Tin over Nickel 10,000 PCS Phosphor Bronze Gold over Nickel 10,000 PCS 2.00mm pitch Crimp Terminal Reference Informations: *Used in CJT [A2001HM] series Housing 0.20 B SEC:A-A 7.70 11.20 B 1.80 A 7.30 A 1.50 1.00 1.85 1.30 1.30 0.50 1.50 0.50 1.50 SEC:B-B 0.65 Ordering information & Specifications: Wire Range Part NO Insulation O.D. 1.50mm(max) A2001M-TP AWG#24-#30 1.50mm(max) A2001M-TB AWG#24-#30 1.50mm(max) A2001M-GP AWG#24-#30 1.50mm(max) A2001M-GB AWG#24-#30 Optional Gold plating available but MOQ requested Unit:mm Qty/reel Material Finish Phosphor Bronze Tin over Nickel 10,000 PCS Brass Tin over Nickel 10,000 PCS Phosphor Bronze Gold over Nickel 10,000 PCS Brass Gold over Nickel 10,000 PCS CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A2001 SERIES A2001H 2.00mm pitch wire to board connector 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT [A2001-T] series Terminal *Mates with CJT [A2001WV,A2001WR,A2001WV-S,A2001WR-S, A2001WVR,A2001WV-F-H] series Wafer *Color:White Circuit 1 Ordering Information & Dimensions: Dimensions A B PART NO. 2.00 A 4.50 6.85 B 3.45 A2001HM A2001H-2P A2001H-3P A2001H-4P A2001H-5P A2001H-6P A2001H-7P A2001H-8P A2001H-9P A2001H-10P A2001H-11P A2001H-12P A2001H-13P A2001H-14P A2001H-15P A2001H-16P A2001H-17P A2001H-18P A2001H-19P A2001H-20P 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 5.80 7.80 9.80 11.80 13.80 15.80 17.80 19.80 21.80 23.80 25.80 27.80 29.80 31.80 33.80 35.80 37.80 39.80 41.80 Unit: mm 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT [A2001M-T] series Terminal *Color:White 2.00 Ordering Information: A2001HM-XP - ** 1 2 1.Part No. 2.Color: (Blank):White RD:Red YL:Yellow BL:Blue BK:Black GN:Green A A 3P~20P 2P 4.80 C 2.90 12.70 6.00 B Ordering Information & Dimensions: PART NO. A2001HM-2P A2001HM-3P A2001HM-4P A2001HM-5P A2001HM-6P A2001HM-7P A2001HM-8P A2001HM-9P A2001HM-10P A2001HM-11P A2001HM-12P A2001HM-13P A2001HM-14P A2001HM-15P A2001HM-16P A2001HM-17P A2001HM-18P A2001HM-19P A2001HM-20P A Dimensions B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 C 4.60 6.60 8.60 10.60 12.60 14.60 16.60 18.60 20.60 22.60 24.60 26.60 28.60 30.60 32.60 34.60 36.60 38.60 40.60 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A2001 SERIES A2001WV 2.00mm pitch wire to board connector 2.00mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:White Ordering Information: A2001WV-XP - ** 1 2 1.Part No. 2.Style: (blank) :Type 1 2 :Type 2 3 :Type 3 Ordering Information & Dimensions: PART NO. 2.00 Circuit 1 2.00 Ø0.70 A TYPE 1 P.C.B LAYOUT 4.50 B 6.10 1.80 3.40 TYPE 2 0.80 Pin 0.50SQ TYPE 3 A2001WR A2001WV-2P A2001WV-3P A2001WV-4P A2001WV-5P A2001WV-6P A2001WV-7P A2001WV-8P A2001WV-9P A2001WV-10P A2001WV-11P A2001WV-12P A2001WV-13P A2001WV-14P A2001WV-15P A2001WV-16P A2001WV-17P A2001WV-18P A2001WV-19P A2001WV-20P Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm 2.00mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:White Ordering Information: A2001WR-XP - ** 1 2 1.Part No. 2.Style: (blank) :Type 1 2 :Type 2 PIN 0.50 SQ Ordering Information & Dimensions: 2.00 PART NO. Ø0.70 P.C.B LAYOUT 2.00 Circuit 1 A 4.85 B 6.25 3.40 TYPE 1 0.80 7.60 6.10 1.80 TYPE 2 A2001WR-2P A2001WR-3P A2001WR-4P A2001WR-5P A2001WR-6P A2001WR-7P A2001WR-8P A2001WR-9P A2001WR-10P A2001WR-11P A2001WR-12P A2001WR-13P A2001WR-14P A2001WR-15P A2001WR-16P A2001WR-17P A2001WR-18P A2001WR-19P A2001WR-20P Dimensions B A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A2001 SERIES A2001WV-S 2.00mm pitch wire to board connector 2.00mm pitch 180° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:Ivory A 1.00 2.00 1.60 A Ordering Information & Dimensions: 3.00 2.00 PART NO. A2001WV-S-2P A2001WV-S-3P A2001WV-S-4P A2001WV-S-5P A2001WV-S-6P A2001WV-S-7P A2001WV-S-8P A2001WV-S-9P A2001WV-S-10P A2001WV-S-11P A2001WV-S-12P A2001WV-S-13P A2001WV-S-14P A2001WV-S-15P A2001WV-S-16P A2001WV-S-17P A2001WV-S-18P A2001WV-S-19P A2001WV-S-20P 5.50 1.60 1.00 Circuit 1 P.C.B LAYOUT 5.40 B 6.42 2.43 2.00 PIN 0.50 SQ A2001WR-S 1.50 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 Unit: mm 3.40 1.60 5.70 A Circuit 1 1.00 A P.C.B LAYOUT 5.50 B 1.00 7.65 2.43 6.00 Ordering Information & Dimensions: 9.20 2.00 PIN 0.50 SQ 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 2.00mm pitch 90° Wafer-SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:Ivory 2.00 Dimensions A B PART NO. A2001WR-S-2P A2001WR-S-3P A2001WR-S-4P A2001WR-S-5P A2001WR-S-6P A2001WR-S-7P A2001WR-S-8P A2001WR-S-9P A2001WR-S-10P A2001WR-S-11P A2001WR-S-12P A2001WR-S-13P A2001WR-S-14P A2001WR-S-15P A2001WR-S-16P A2001WR-S-17P A2001WR-S-18P A2001WR-S-19P A2001WR-S-20P Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A2001 SERIES A2001WVR 2.00mm pitch wire to board connector 2.00mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:White Ordering Information: A2001WVR-XP - ** 1 2 1.Part No. 2.Style: (blank) :Type 1 2 :Type 2 Ordering Information & Dimensions: PART NO. A2001WVR-2P A2001WVR-3P A2001WVR-4P A2001WVR-5P A2001WVR-6P A2001WVR-7P A2001WVR-8P A2001WVR-9P A2001WVR-10P A2001WVR-11P A2001WVR-12P A2001WVR-13P A2001WVR-14P A2001WVR-15P A2001WVR-16P A2001WVR-17P A2001WVR-18P A2001WVR-19P A2001WVR-20P 2.00 Ø0.70 2.00 Circuit 1 P.C.B LAYOUT A 4.70 B 6.60 6.10 1.80 0.81 3.40 Circuit 1 TYPE 1 A2001WV-F-H TYPE 2 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT [A2001H] series Housing *Color:White 1.40 Ø1.00 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. Circuit 1 A 4.85 B 3.60 1.50 15.00 1.80 Ø0.80 PIN 0.50 SQ 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm 2.00 Ø0.70 2.00 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 2.00mm pitch 180° Wafer-High box type 1.50 PIN 0.50 SQ Dimensions A B 1.40 1.50 6.00 A2001WV-F-2P-H A2001WV-F-3P-H A2001WV-F-4P-H A2001WV-F-5P-H A2001WV-F-6P-H A2001WV-F-7P-H A2001WV-F-8P-H A2001WV-F-9P-H A2001WV-F-10P-H A2001WV-F-11P-H A2001WV-F-12P-H A2001WV-F-13P-H A2001WV-F-14P-H A2001WV-F-15P-H A2001WV-F-16P-H A2001WV-F-17P-H A2001WV-F-18P-H A2001WV-F-19P-H A2001WV-F-20P-H Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn
A2001WR-S-9P
物料型号: - A2001-T:2.00mm间距焊压端子 - A2001M-T:2.00mm间距焊压端子,适用于CJT A2001HM-XP系列外壳 - A2001H-XP:2.00mm间距外壳 - A2001WV-XP/WR-XP:2.00mm间距180°/90°焊片 - A2001WV-S-XP/WR-S-XP:2.00mm间距180°/90°SMT焊片 - A2001WVR-XP:2.00mm间距90°焊片 - A2001WV-F-XP-H:2.00mm间距180°高盒型焊片
器件简介: A2001系列提供2.00mm间距的线对板连接器解决方案,包括焊压端子、外壳、焊片等多种形式,适用于不同的电路连接需求。
引脚分配: - 端子的引脚分配根据型号不同而有所变化,但通常包括多个引脚配置,如2P至20P,表示2至20个引脚的配置。
参数特性: - 电流额定值:2A AC/DC - 电压额定值:100V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大10mΩ - 绝缘电阻:最小1000MΩ - 耐电压:800V AC/分钟 - 符合RoHS和REACH标准
功能详解: - 提供不同材质和表面处理的端子,如磷青铜镀锡、镀金等。 - 提供不同绝缘外径的端子,以适应不同线径的电线。 - 可选的金镀层,但需满足最小订购量(MOQ)。
应用信息: - 适用于需要高密度连接的场合,如电子设备内部连接。
封装信息: - 提供多种颜色和材料的外壳,以适应不同的设计和环境要求。
A2001WR-S-9P 价格&库存
很抱歉,暂时无法提供与“A2001WR-S-9P”相匹配的价格&库存,您可以联系我们找货
A2001WR-S-9P
  • 1+1.13501
  • 30+1.09587
  • 100+1.01760
  • 500+0.93932
  • 1000+0.90018
库存:133
