A2002 SERIES
2.00mm pitch wire to board connector
Specifications
Current rating:3A AC,DC
Voltage rating:300V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:20m Max.
Insulation resistance:100M Min.
Withstanding voltage:1000V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
1.60
7.70 REF
1.80
1.80
1.60
5.00
4.70
7.80 REF
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
A-152
A2002 SERIES
A2002-T
2.00mm pitch Crimp Terminal
Reference Informations:
*Used in CJT A2002H-XP series Housing
0.20
2.54±0.25
0.70±0.20
1.25±0.25
2.40±0.25
SEC:A-A
B
0.40
1.80±0.20
2.10±0.25
0.95
1.46±0.25
1.60±0.25
B
1.47±0.25
A
5.10±0.25
A
SEC:B-B
0.75
1.52±0.25
Ordering information & Specifications:
Unit:mm
Part NO.
Wire Range
Insulation O.D.
Material
Finish
Qty/reel
A2002-TP
AWG#24-#28
1.50mm(max)
Phosphor Bronze
Tin over Nickel
10,000 PCS
A2002-GP
AWG#24-#28
1.50mm(max)
Phosphor Bronze
Gold over Nickel
10,000 PCS
Optional Gold plating available but MOQ requested
A2002H-XP
2.00mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT A2002-T series Terminal
*Mates with CJT A2002WV,WR-XP series Wafer
*Color:Brown
Ordering Information:
A2002H-XP - ***
1
2
1.Part No.
2.Material:
(Blank):Nylon 66,UL94V-0
GWT :Nylon 66,UL94V-0 GWT 750 ℃
Circuit 1
2.00±0.10
Ordering Information & Dimensions:
PART NO.
A±0.20
B±0.25
5.90±0.25
4.50±0.25
3.50±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
2.00
5.60
4.00
7.60
6.00
9.60
8.00
11.60
10.00
13.60
12.00
15.60
14.00
17.60
16.00
19.60
18.00
21.60
20.00
23.60
22.00
25.60
24.00
27.60
26.00
29.60
28.00
31.60
Unit: mm
A-153
A2002 SERIES
A2002WV-XP
2.00mm pitch 180° Wafer
*Material:Pin:Brass/Tin over Nickel
Insulator:Nylon 66,UL94V-0
*Mates with CJT A2002H-XP series Housing
*Color:Brown
A2002WV-XP - ***
1
2
1.Part No.
2.Material:
Circuit 1
2.00±0.08
∅0.80±0.05
2.00±0.10
P.C.B LAYOUT
A±0.20
PART NO.
4.70±0.25
B±0.25
3.40±0.20
6.10±0.25
1.80
0.80
PIN 0.5 SQ
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
2.00
6.00
4.00
8.00
6.00
10.00
8.00
12.00
10.00
14.00
12.00
16.00
14.00
18.00
16.00
20.00
18.00
22.00
20.00
24.00
22.00
26.00
24.00
28.00
30.00
26.00
28.00
32.00
Unit: mm
A2002WR-XP
2.00mm pitch 90° Wafer
Wafer:Nylon 66,UL94V-0
*Color:Brown
A2002WR-XP - ***
1
2
1.Part No.
2.Material:
PIN 0.5 SQ
2.00±0.08
∅0.80±0.05
P.C.B LAYOUT
2.00±0.10
Circuit 1
PART NO.
A±0.20
5.00±0.25
B±0.25
6.20±0.25
3.40±0.20
0.80
7.70±0.25
6.10±0.25
1.80
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
2.00
6.00
4.00
8.00
6.00
10.00
8.00
12.00
10.00
14.00
12.00
16.00
14.00
18.00
16.00
20.00
18.00
22.00
20.00
24.00
22.00
26.00
24.00
28.00
26.00
30.00
28.00
32.00
Unit: mm
A-154
很抱歉,暂时无法提供与“A2002WR-8P”相匹配的价格&库存,您可以联系我们找货
