A2007WV-14P
A2007WV-14P
    CJT(长江连接器)
    插件,P=2mm
    线对板连接器 14Pin(1x14P) P=2.00mm 直插
A2007WV-14P 数据手册
A2007 SERIES 2.00mm pitch wire to board connector Specifications Current rating:4A AC,DC Voltage rating:125V AC,DC Temperature range:-40°C~+105°C Contact resistance:10m Max. Insulation resistance:1000M Min. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 4.60 6.80 REF 1.60 1.60 0.30 5.00 7.10 REF 1.60 1.60 1.60 1.60 6.80 REF 4.60 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-234 A2007 SERIES A2007-T 2.00mm pitch wire to board connector 2.00mm pitch Crimp Terminal 2.50±0.25 1.57±0.25 0.60 1.13 0.25 1.85±0.25 Reference Informations: *Used in CJT A2007H-XP series Housing D B 0.35 2.90±0.25 1.00 D 2.00±0.25 1.15 C 1.55 C 1.80±0.25 A SEC:C-C 1.05 A 4.55±0.25 SEC:A-A B SEC:B-B SEC:D-D Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2007-TP AWG#22-#26 1.50mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS AWG#22-#26 1.50mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS A2007-GP Optional Gold plating available but MOQ requested A2007H-XP 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2007-T series Terminal *Mates with CJT A2007WV,WR,WR-S,WR-S-F-XP, A2007WVD,WRD-XP series Wafer *Color:White Ordering Information: A2007H-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue YL:Yellow 2.00±0.10 Circuit 1 Ordering Information & Dimensions: A±0.20 5.10±0.25 4.00±0.20 4.60±0.25 B±0.25 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 2.00 5.60 4.00 7.60 6.00 9.60 8.00 11.60 10.00 13.60 12.00 15.60 14.00 17.60 16.00 19.60 18.00 21.60 20.00 23.60 22.00 25.60 24.00 27.60 26.00 29.60 28.00 31.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-235 A2007 SERIES A2007HD-XP 2.00mm pitch wire to board connector 2.00mm pitch IDC Housing Reference Informations: *Material: Terminal:Phosphor Bronze/Tin over Nickel Housing:Nylon 66,UL94V-0 *Mates with CJT A2007WV,WR,WR-S,WR-S-F-XP, A2007WVD,WRD-XP series Wafer *Color:White Ordering Information: A2007HD-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue YL:Yellow A±0.20 5.10±0.25 2.00±0.10 Ordering Information & Dimensions: Circuit 1 PART NO. 0.60 4.00±0.25 B±0.25 C±0.25 3P 2P 4P~20P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 Dimensions B 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 C 4.80 6.80 8.80 10.80 12.80 14.80 16.80 18.80 20.80 22.80 24.80 26.80 28.80 30.80 Unit: mm A2007WV-XP 2.00mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:White 3.60±0.25 2.00±0.10 ∅0.80+0.10 -0.00 Ordering Information: A2007WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue YL:Yellow P.C.B LAYOUT 2.00±0.10 Circuit 1 A±0.20 Ordering Information & Dimensions: B±0.25 PIN ∅0.60 6.80±0.25 PART NO. 3.20±0.20 1.70±0.20 2.60±0.20 2.00±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 2.00 5.96 4.00 7.96 6.00 9.96 8.00 11.96 10.00 13.96 12.00 15.96 14.00 17.96 16.00 19.96 18.00 21.96 20.00 23.96 22.00 25.96 24.00 27.96 26.00 29.96 28.00 31.96 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-236 A2007 SERIES A2007WR-XP 2.00mm pitch wire to board connector 2.00mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:White PIN ∅0.60 2.00±0.10 Ordering Information: A2007WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue YL:Yellow ∅0.80+0.10 -0.00 P.C.B LAYOUT Ordering Information & Dimensions: Circuit 1 2.00±0.10 A±0.20 PART NO. 4.00±0.25 B±0.25 1.70±0.20 1.70±0.20 8.80±0.25 5.10±0.25 3.00±0.20 3.20±0.20 A2007WVD-XP A±0.10 2.00±0.05 ∅0.80+0.10 -0.00 P.C.B LAYOUT 5.80±0.25 5.80±0.25 Circuit 1 2.00±0.10 A±0.20 Unit: mm 2.00mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:White Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 2.00±0.10 A±0.20 Ordering Information: A2007WVD-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue Ordering Information & Dimensions: YL:Yellow PART NO. 4P~15P 3.20±0.20 3.00±0.20 6.80±0.25 6.80±0.25 B±0.25 2P~3P 1.70±0.20 B±0.25 Dimensions A B 2.00 5.96 4.00 7.96 6.00 9.96 8.00 11.96 13.96 10.00 12.00 15.96 14.00 17.96 16.00 19.96 18.00 21.96 20.00 23.96 22.00 25.96 24.00 27.96 26.00 29.96 28.00 31.96 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 2.00 5.80 4.00 7.80 6.00 9.80 8.00 11.80 10.00 13.80 12.00 15.80 14.00 17.80 16.00 19.80 18.00 21.80 20.00 23.80 22.00 25.80 24.00 27.80 26.00 29.80 28.00 31.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-237 A2007 SERIES A2007WRD-XP 2.00mm pitch wire to board connector 2.00mm pitch 90° Wafer A±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:White 2.00±0.05 ∅0.80+0.10 -0.00 P.C.B LAYOUT A±0.20 A±0.20 Ordering Information: A2007WRD-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black Ordering Information & Dimensions: BL:Blue Dimensions YL:Yellow PART NO. A B 2.00 5.80 2P 3P 4.00 7.80 3.00±0.20 4P 6.00 9.80 5P 8.00 11.80 13.80 6P 10.00 7P 12.00 15.80 8P 14.00 17.80 9P 16.00 19.80 10P 18.00 21.80 11P 20.00 23.80 22.00 25.80 12P 13P 24.00 27.80 14P 26.00 29.80 3.20±0.20 15P 28.00 31.80 2.00±0.10 5.80±0.25 5.80±0.25 2.00±0.10 Circuit 1 Circuit 1 B±0.25 4P~15P 1.70±0.20 8.80±0.25 6.80±0.25 8.80±0.25 6.80±0.25 B±0.25 2P~3P Unit: mm A2007WV-F-3P 2.00mm pitch 180° Wafer With Foot Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2007H,HD-3P series Housing *Color:White ∅0.80+0.10 -0.00 Circuit 1 4.00±0.20 P.C.B LAYOUT 7.96±0.25 1.90±0.20 3.20±0.20 2.60±0.20 1.70±0.20 PIN ∅0.60 ∅0.90±0.10 1.00±0.10 ∅0.80 6.80±0.25 2.00±0.10 1.50±0.10 3.60±0.25 2.00±0.10 Ordering Information: A2007WV-F-3P - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):White BK:Black BL:Blue YL:Yellow 2.00±0.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-238 A2007 SERIES A2007WR-S-XP A±0.20 Circuit 1 5.20 A 2.40 1.20 3.50 Ordering Information: A2007WR-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):Beige BK:Black BL:Blue YL:Yellow 3.30 2.00mm pitch 90° Wafer - SMT TYPE Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:Beige 2.00±0.10 2.00mm pitch wire to board connector 1.50 2.10 P.C.B LAYOUT 2P~3P 4P~15P Dimensions A B 2.00 8.00 4.00 10.00 6.00 12.00 8.00 14.00 10.00 16.00 12.00 18.00 14.00 20.00 16.00 22.00 18.00 24.00 20.00 26.00 22.00 28.00 24.00 30.00 32.00 26.00 28.00 34.00 PART NO. 5.80±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P B±0.25 6.80±0.25 4.70±0.20 3.00±0.20 ∅0.60 Unit: mm 2.10 C±0.20 Circuit 1 0.50 2.40 C 1.50 2.10 5.20 1.20 3.50 1.20 5.20 A 3.30 ∅1.10 3.00 ∅1.10 Ordering Information: A2007WR-S-F-XP - *** - ** 1 2 3 1.Part No. 2.40 2.Material: (Blank):Nylon 66,UL94V-0 GWT :Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (Blank):Beige BK:Black BL:Blue YL:Yellow 3.50 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2007H,HD-XP series Housing *Color:Beige 2.00mm pitch 90° Wafer - SMT TYPE 3.30 A2007WR-S-F-XP 1.50 2.10 A 2P~3P 4P~15P P.C.B LAYOUT 2P~3P 4P~15P PART NO. B±0.25 5.80±0.25 A±0.20 3.00±0.20 ∅1.00 6.80±0.25 4.70±0.20 ∅0.60 2.25 1.00 2.00±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 Dimensions B 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 C ------5.60 7.60 9.60 11.60 13.60 15.60 17.60 19.60 21.60 23.60 25.60 27.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 http://www.CJT.cn A-239
A2007WV-14P 价格&库存
很抱歉,暂时无法提供与“A2007WV-14P”相匹配的价格&库存,您可以联系我们找货
