A2009WR-2X8P
A2009WR-2X8P
    CJT(长江连接器)
    弯插,P=2mm
    线对板针座 2x8P 弯插 间距:2mm
A2009WR-2X8P 数据手册
A2009 SERIES 2.00mm pitch wire to board connector Specifications Current rating:2A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:30mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:800V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 5.00 12.10 REF DIP TYPE 9.50 REF 1.60 1.60 5.00 8.90 REF 5.00 SMT TYPE CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-146 A2009 SERIES A2009-T 2.00mm pitch wire to board connector 2.00mm pitch Crimp Terminal 2.30±0.25 Reference Informations: *Used in CJT A2009 series Housing 2.25±0.25 B 1.45±0.15 C C 0.25±0.05 1.35±0.25 1.85±0.10 Ordering information & Specifications: Wire Range Part NO. Insulation O.D. 1.45mm(max) A2009-TP AWG#22-#30 1.45mm(max) A2009-GP AWG#22-#30 1.55±0.25 SEC:B-B 1.20±0.10 B 6.30±0.25 A SEC:A-A 3.10±0.15 A 1.20±0.20 0.75±0.20 0.20 1.38±0.10 SEC:C-C Unit:mm Qty/reel Material Finish Phosphor Bronze Tin over Nickel 10,000 PCS Phosphor Bronze Gold over Nickel 10,000 PCS Optional Gold plating available but MOQ requested A2009H-2 2.00mm pitch Dual Row Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2009 series Terminal *Mates with CJT A2009 series Dual Row Wafer *Color:Black Circuit 2 Ordering Information & Dimensions: 2.00±0.10 Circuit 1 A±0.20 2.00±0.10 PART NO. 4.46±0.25 B±0.25 7.30±0.25 1 4.06±0.25 4.96±0.25 A2009H-2x2P A2009H-2x3P A2009H-2x4P A2009H-2x5P A2009H-2x6P A2009H-2x7P A2009H-2x8P A2009H-2x9P A2009H-2x10P A2009H-2x11P A2009H-2x12P A2009H-2x13P A2009H-2x14P A2009H-2x15P A2009H-2x16P A2009H-2x17P A2009H-2x18P A2009H-2x19P A2009H-2x20P Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-147 A2009 SERIES A2009WV-2 2.00mm pitch wire to board connector Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2009 series Housing *Color:Black Circuit 2 2.00±0.10 2.00mm pitch 180° Dual Row Wafer Ordering Information & Dimensions: 2.00±0.10 PART NO. A±0.20 Circuit 1 2.00±0.10 2.00±0.10 Ø0.80+0.10 -0.00 P.C.B LAYOUT B±0.25 3.00±0.20 6.50±0.25 5.00±0.25 PIN 0.50 SQ A2009WR-2 A2009WV-2x2P A2009WV-2x3P A2009WV-2x4P A2009WV-2x5P A2009WV-2x6P A2009WV-2x7P A2009WV-2x8P A2009WV-2x9P A2009WV-2x10P A2009WV-2x11P A2009WV-2x12P A2009WV-2x13P A2009WV-2x14P A2009WV-2x15P A2009WV-2x16P A2009WV-2x17P A2009WV-2x18P A2009WV-2x19P A2009WV-2x20P Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm 2.00mm pitch 90° Dual Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Wafer:Nylon 66,UL94V-0 *Mates with CJT A2009 series dual row Housing *Color:Black PIN 0.50 SQ Ordering Information & Dimensions: 2.00±0.10 Circuit 1 Ø0.80+0.10 -0.00 P.C.B LAYOUT 9.50±0.25 7.70±0.25 5.00±0.25 B±0.25 3.00±0.20 2.00 A±0.20 PART NO. 2.00±0.10 2.00±0.10 2.00±0.10 Circuit 2 A2009WR-2x2P A2009WR-2x3P A2009WR-2x4P A2009WR-2x5P A2009WR-2x6P A2009WR-2x7P A2009WR-2x8P A2009WR-2x9P A2009WR-2x10P A2009WR-2x11P A2009WR-2x12P A2009WR-2x13P A2009WR-2x14P A2009WR-2x15P A2009WR-2x16P A2009WR-2x17P A2009WR-2x18P A2009WR-2x19P A2009WR-2x20P Dimensions A B 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-148 A2009 SERIES A2009WVA-S-F-2 2.00mm pitch wire to board connector 2.00mm pitch 180° Dual Row Wafer With Boss-SMT TYPE 2.00±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 Cap:Nylon 6T,UL94V-0 *Mates with CJT A2009 series Dual Row Housing *Color:Ivory 2.00±0.05 1.10±0.10 2.00±0.10 Circuit 1 A±0.20 Ø1.10+0.10 -0.00 C±0.10 P.C.B LAYOUT 5.00±0.25 1.00±0.15 7.00±0.25 B±0.25 1.50±0.20 PIN 0.50 SQ Ø1.00±0.10 Ordering Information & Dimensions: PART NO. 5.10±0.10 2.00±0.10 A±0.10 1.50±0.20 A2009WVA-S-F-2x2P A2009WVA-S-F-2x3P A2009WVA-S-F-2x4P A2009WVA-S-F-2x5P A2009WVA-S-F-2x6P A2009WVA-S-F-2x7P A2009WVA-S-F-2x8P A2009WVA-S-F-2x9P A2009WVA-S-F-2x10P A2009WVA-S-F-2x11P A2009WVA-S-F-2x12P A2009WVA-S-F-2x13P A2009WVA-S-F-2x14P A2009WVA-S-F-2x15P A2009WVA-S-F-2x16P A2009WVA-S-F-2x17P A2009WVA-S-F-2x18P A2009WVA-S-F-2x19P A2009WVA-S-F-2x20P Dimensions A B C 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 6.00 4.00 8.00 6.00 10.00 8.00 12.00 10.00 14.00 12.00 16.00 14.00 18.00 16.00 20.00 18.00 22.00 20.00 24.00 22.00 26.00 24.00 28.00 26.00 30.00 28.00 32.00 30.00 34.00 32.00 36.00 34.00 38.00 36.00 40.00 38.00 42.00 40.00 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-149
A2009WR-2X8P 价格&库存
很抱歉,暂时无法提供与“A2009WR-2X8P”相匹配的价格&库存,您可以联系我们找货
