A2541WV-10P
A2541WV-10P
    CJT(长江连接器)
    插件,P=2.54mm
    排针 P=2.54mm 10Pin(1x10)黄铜 镀金 直插
A2541WV-10P 数据手册
A2541 SERIES 2.54mm pitch wire to board connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-353 A2541 SERIES 5.08 5.08 18.36.REF 1.60 2.54 7.90 13.95 1.40 1.60 2.54 1.40 1.60 9.00 1.60 20.84.REF 20.58.REF 1.40 1.60 7.90 1.40 1.40 16.86.REF 1.40 5.08 14.32.REF 7.85 1.60 1.60 18.04.REF 5.08 1.40 1.60 2.54 5.31 1.60 1.40 16.60.REF 16.70.REF 9.00 20.38.REF 1.40 1.60 1.40 18.36.REF 16.54.REF 2.54 16.54.REF 2.54 2.54mm pitch wire to board connector 20.94.REF CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-354 A2541 SERIES A2541-T 2.54mm pitch wire to board connector 2.60±0.25 2.54mm Pitch Crimp Terminal Reference Informations: *Used in CJT A2510HF-3P-P,A2510HF-3P-R,A2541H-XP,A2541H-N-XP(-2), A2541H-2xXP,A2541H-N-2xXP(-2) series Housing 2.30±0.25 0.20 1.60±0.25 SEC:A-A 1.60±0.25 A C C D SEC:B-B 1.55±0.25 B 1.60±0.25 4.50±0.20 B 11.50±0.25 A D SEC:C-C 1.55±0.25 SEC:D-D Unit:mm Ordering information & Specifications: Part NO. A2541-TB A2541-TP A2541-GB A2541-GP Wire Range AWG#22-#26 AWG#22-#26 AWG#22-#26 AWG#22-#26 Insulation O.D. 1.63mm(max) 1.63mm(max) 1.63mm(max) 1.63mm(max) Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Material Brass Phosphor Bronze Brass Phosphor Bronze Optional Gold plating available but MOQ requested A2541M-T Reference Informations: *Used in CJT A2510HF-3P-P,A2510HF-3P-R,A2510HMA-3P-BRD, A2541H-XP,A2541H-2xXP series Housing 0.20 2.23±0.25 1.90 SEC:A-A 3.75 SEC:B-B 1.50±0.25 C 2.85 C 1.70±0.25 1.64±0.25 7.71±0.25 B 18.60±0.25 B 1.70±0.25 A 2.55 A 2.60±0.25 2.54mm Pitch Crimp Terminal SEC:C-C Unit:mm 0.64 Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2541M-TB AWG#22-#26 1.63mm(max) Brass Tin over Nickel 10,000 PCS Phosphor Bronze A2541M-TP AWG#22-#26 1.63mm(max) Tin over Nickel 10,000 PCS A2541M-GB AWG#22-#26 1.63mm(max) Brass Gold over Nickel 10,000 PCS A2541M-GP AWG#22-#26 1.63mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-355 A2541 SERIES A2541H-XP 2.54mm pitch wire to board connector 2.54mm Pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2541-T,A2541M-T series Terminal *Mates with CJT A2541WV,WR-XP,A2541WVA,WRA-XP, A2541WV-S-XP,A2541WVA-S-XP series Single row Wafer *Color:Black Ordering Information: A2541H-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T: Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ Circuit 1 Ordering Information & Dimensions: PART NO. 2.54±0.10 A±0.20 B±0.25 13.95±0.25 2.54±0.25 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.54 ---2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541H-N-XP 2.54mm Pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2541-T series Terminal *Mates with CJT A2541WV,WR-XP,A2541WVA,WRA-XP, A2541WV-S-XP,A2541WVA-S-XP series Single row Wafer *Color:Black Ordering Information: A2541H-N-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T: Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ Circuit 1 Ordering Information & Dimensions: PART NO. 2.54±0.10 3.50±0.20 A±0.20 2.54±0.25 14.00±0.25 3.90±0.20 1.08±0.20 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.14 5.08 7.68 7.62 10.22 10.16 12.76 12.70 15.30 15.24 17.84 17.78 20.38 20.32 22.92 22.86 25.46 25.40 28.00 27.94 30.54 30.48 33.08 33.02 35.62 35.56 38.16 38.10 40.70 40.64 43.24 43.18 45.78 45.72 48.32 48.26 50.86 50.80 53.40 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.94 55.88 58.48 58.42 61.02 60.96 63.56 63.50 66.10 66.04 68.64 68.58 71.18 73.72 71.12 73.66 76.26 76.20 78.80 78.74 81.34 81.28 83.88 83.82 86.42 86.36 88.96 88.90 91.50 91.44 94.04 93.98 96.58 96.52 99.12 99.06 101.66 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-356 A2541 SERIES A2541H-N-XP-2 2.54mm pitch wire to board connector 2.54mm Pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2541-T series Terminal *Mates with CJT A2541WV,WR-XP,A2541WVA,WRA-XP, A2541WV-S-XP,A2541WVA-S-XP series Single row Wafer *Color:Black Ordering Information: A2541H-N-XP-2 - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T: Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ Circuit 1 Ordering Information & Dimensions: PART NO. 2.54±0.10 2.40±0.20 A±0.20 2.54±0.25 B±0.25 3.90±0.20 14.00±0.25 2.92±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.14 5.08 7.68 7.62 10.22 10.16 12.76 12.70 15.30 15.24 17.84 17.78 20.38 20.32 22.92 22.86 25.46 25.40 28.00 27.94 30.54 30.48 33.08 33.02 35.62 35.56 38.16 38.10 40.70 40.64 43.24 43.18 45.78 45.72 48.32 48.26 50.86 50.80 53.40 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.94 55.88 58.48 58.42 61.02 60.96 63.56 63.50 66.10 66.04 68.64 68.58 71.18 73.72 71.12 73.66 76.26 76.20 78.80 78.74 81.34 81.28 83.88 83.82 86.42 86.36 88.96 88.90 91.50 91.44 94.04 93.98 96.58 96.52 99.12 99.06 101.66 Unit: mm A2541H-2xXP 2.54mm Pitch Dual Row Housing Reference Informations: *Material:PBT15%GF,UL94V-0 *Suitable CJT A2541-T,A2541M-T series Terminal *Mates with CJT A2541WV,WR-2xXP ,A2541WVA,WRA-2xXP, A2541WV-S-2xXP,A2541WVA-S-2xXP, series Dual row Wafer *Color:Black Circuit 1 2.54±0.10 A±0.20 14.00±0.25 B±0.25 Last Circuit Ordering Information: A2541H-2xXP - * - ** - *** 1 2 3 4 Ordering Information & Dimensions: 1.Part No. 2.Color: Dimensions (bank):Black PART NO. PART NO. A B 3.Plug Hole: 2.54 2x2P 2x22P 5.08 (bank):Don't plug hole 4.Material: 2x3P 5.08 7.62 2x23P (Blank):PBT,UL94V-0 2x4P 7.62 10.16 2x24P 6T: Nylon 6T,UL94V-0 2x5P 10.16 12.70 2x25P GWT :Nylon 6T,UL94V-0 GWT 750 ℃ 2x6P 12.70 15.24 2x26P 2x7P 15.24 17.78 2x27P 5.10±0.25 2x8P 17.78 20.32 2x28P 2x9P 20.32 22.86 2x29P 2x10P 2x30P 22.86 25.40 2x11P 25.40 27.94 2x31P 2x32P 2x12P 27.94 30.48 2x13P 30.48 33.02 2x33P 2x14P 33.02 35.56 2x34P 2x15P 2x35P 35.56 38.10 2x16P 38.10 40.64 2x36P 2x37P 2x17P 40.64 43.18 2x18P 2x38P 43.18 45.72 2x19P 45.72 48.26 2x39P 2x20P 2x40P 48.26 50.80 50.80 53.34 2x21P 2.54±0.10 Circuit 2 Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-357 A2541 SERIES A2541H-N-2xXP 2.54mm pitch wire to board connector 2.54mm Pitch Dual Row Housing Reference Informations: *Material:PBT15%GF,UL94V-0 *Suitable CJT A2541-T series Terminal *Mates with CJT A2547WV-N,WR-N-2xXP series Dual row Wafer *Color:Black Last Circuit 2.54±0.10 Circuit 1 3.50±0.20 A±0.20 14.00±0.25 B±0.25 Ordering Information: A2541H-N-2xXP - *** 1 2 Ordering Information & Dimensions: 1.Part No. 2.Material: Dimensions (Blank):PBT,UL94V-0 PART NO. PART NO. A B 6T: Nylon 6T,UL94V-0 2.54 5.08 2x2P 2x22P GWT :Nylon 6T,UL94V-0 GWT 750 ℃ 2x3P 5.08 7.62 2x23P 2x4P 7.62 10.16 2x24P 2x5P 10.16 12.70 2x25P 5.08±0.25 2x6P 12.70 15.24 2x26P 1.42±0.20 2x7P 15.24 17.78 2x27P 2x8P 17.78 20.32 2x28P 2x9P 2x29P 20.32 22.86 2x10P 22.86 25.40 2x30P 2x11P 25.40 27.94 2x31P 2x32P 2x12P 27.94 30.48 2x13P 30.48 33.02 2x33P 2x14P 33.02 35.56 2x34P 2x15P 2x35P 35.56 38.10 2x16P 38.10 40.64 2x36P 2x37P 2x17P 40.64 43.18 2x18P 43.18 45.72 2x38P 2x19P 45.72 48.26 2x39P 2x20P 2x40P 48.26 50.80 50.80 53.34 2x21P 3.90±0.20 2.54 Circuit 2 Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541H-N-2xXP-2 2.54mm Pitch Dual Row Housing Reference Informations: *Material:PBT15%GF,UL94V-0 *Suitable CJT A2541-T series Terminal *Mates with CJT A2547WV-N,WR-N-2xXP series Dual row Wafer *Color:Black Last Circuit 2.54 Circuit 2 2.54±0.10 Circuit 1 2.38±0.20 Ordering Information: A2541H-N-2xXP-2 - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T: Nylon 6T,UL94V-0 GWT :Nylon 6T,UL94V-0 GWT 750 ℃ A±0.20 5.08±0.25 B±0.25 3.90±0.20 14.00±0.25 2.92±0.20 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-358 A2541 SERIES A2541WV-XP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: C(6.00±0.20) D(3.00±0.20) H(2.54±0.25) PIN 0.64 SQ D(3.00±0.20) B±0.25 C(6.00±0.20) A±0.20 ∅1.02±0.05 A2541WV-XP - *** - * - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): (blank):2.54mm H15:1.50mm H17:1.70mm H20:2.00mm H30:3.00mm 3.Style: (blank):Type 1 K:Type 2 4.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.25 2.54±0.10 2.54±0.05 Type 1 A2541WR-XP Type 2 PIN 0.64 SQ C(6.00±0.25) Ordering Information: A2541WR-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):2.54mm H15:1.50mm H17:1.70mm H20:2.00mm H30:3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel H(2.54±0.25) B±0.25 PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.54 ----2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm 2.54±0.05 D(1.50±0.20) 2.54±0.25 A±0.20 Ordering Information & Dimensions: 2.54mm Pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 P.C.B LAYOUT E(3.00±0.25) ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B ----2.54 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 71.12 73.66 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-359 A2541 SERIES A2541WV-S-XP-A 2.54mm pitch wire to board connector 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541H-XP,A2541H-N-XP, A2541H-N-XP-2 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: A±0.20 D(1.50) H(2.54±0.25) B±0.25 C(6.00±0.25) 2.54±0.10 2.54±0.25 Circuit 1 A2541WV-S-XP-A - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):2.54mm H15:1.50mm H17:1.70mm H20:2.00mm H30:3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel E(4.94±0.25) PIN 0.64 SQ 3.17±0.10 2.54mm Pitch 180° Single Row Pin Header-SMT A TYPE 1.27±0.10 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WV-S-XP-B 2.54mm Pitch 180° Single Row Pin Header-SMT B TYPE H(2.54±0.25) B±0.25 PIN 0.64 SQ C(6.00±0.25) A±0.20 D(1.50) 2.54±0.10 2.54±0.25 Circuit 1 Ordering Information: A2541WV-S-XP-B - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):2.54mm H15:1.50mm H17:1.70mm H20:2.00mm H30:3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel E(4.94±0.25) 1.27±0.10 3.17±0.10 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T , UL94V-0 *Mates with CJT A2541H-XP,A2541H-N-XP, A2541H-N-XP-2 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-360 A2541 SERIES A2541WR-S-XP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Pin Header - SMT TYPE A±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541H-XP,A2541H-N-XP, A2541H-N-XP-2 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 PIN 0.64 SQ A2541WVA-XP 2.54±0.25 A±0.20 Ordering Information: A2541WVA-XP - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Type 1 Type 2 E(10.00±0.20) C(6.00±0.20) D(3.00±0.20) E(10.00±0.20) C(6.00±0.20) D(3.00±0.20) H(2.54±0.25) Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm B±0.25 PIN 0.64 SQ P.C.B LAYOUT 2.54mm Pitch 180° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541A2541H-XP,A2541H-N-XP, A2541H-N-XP-2 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 1.02 3.17 2.60±0.20 2.20±0.20 H(2.54±0.20) B±0.25 Ordering Information: A2541WR-S-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 5.80±0.20 2.54±0.20 A±0.20 2.54±0.10 2.54±0.05 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B ----2.54 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 71.12 73.66 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-361 A2541 SERIES A2541WRA-XP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Pin Header 2.54±0.10 C(6.00±0.25) D(1.50±0.20) B±0.25 ∅1.02±0.05 Ordering Information: A2541WRA-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel H(2.54±0.25) A±0.20 2.54±0.05 E(3.00±0.20) 2.54±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black PIN 0.64 SQ P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.54 ----2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WVB-XP 2.54mm Pitch 180° Single Row Pin Header 2.54±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black B±0.25 1.00 2.54±0.25 0.64 C(8.50±0.20) A±0.20 ∅1.02±0.05 P.C.B LAYOUT Ordering Information: A2541WVB-XP - *** - *** 1 2 3 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 Dimensions 6T:Nylon 6T,UL94V-0 PART NO. PART NO. GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A B 3.Finish: 2.54 2P 22P 5.08 (blank):Gold-flash 3P 5.08 7.62 23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 4P 7.62 10.16 24P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 5P 10.16 12.70 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.24 26P T:Tin over Nickel D(2.85±0.20) 2.54±0.10 2.54±0.05 0.64 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-362 A2541 SERIES A2541WRA-XP-D 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: ∅1.02±0.05 D(1.50±0.20) H(2.54±0.25) B±0.25 F(10.00±0.25) A±0.20 C(6.00±0.25) A2541WRA-XP-D - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.25 2.54±0.10 2.54±0.05 E(3.00±0.25) PIN 0.64 SQ P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WVC-XP 2.54mm Pitch 180° Single Row Pin Header Ordering Information: 1.64 DIA DRILLED HOLE 1.41/1.07 DIA FINESHED PLATED HOLE 3.54 A2541WVC-XP - *** - *** Reference Informations: 1 2 3 *Material:Pin:Brass/Gold over Nickel 1.Part No. Insulator:PBT 30%GF,UL94V-0 2.Material: (Blank):PBT,UL94V-0 *Mates with CJT A2541series Single row Housing 6T:Nylon 6T,UL94V-0 *Optional Gold plating available but MOQ requested GWT:Nylon 6T,UL94V-0,GWT 750 ℃ *Color:Black 3.Finish: 0.03 Min 2.54±0.10 A±0.25 2.54±0.25 (blank):Gold-flash ELECTRO-DEPOSITED 0.02 Max Tin Plate G15:15μin (0.38μm) MIN.Select Gold(Mating Area) COPPER 100μin (2.54μm) MIN.Select Tin SEC:A-A G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering Information & Dimensions: T:Tin over Nickel PART NO. A 2.54±0.05 A A ∅1.09±0.05 (6.00±0.25) 11.54±0.25 2.54±0.25 B±0.25 3.00±0.25 P.C.B LAYOUT 0.64 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-363 A2541 SERIES A2541WVA-S-XP-A 2.54mm Pitch 180° Single Row Pin Header-SMT A TYPE F(4.94±0.25) PIN 0.64 SQ Type 1 2.54±0.25 Circuit 1 E(10.00±0.20) Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm Ordering Information: A2541WVA-S-XP-B - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(6.00±0.20) F(4.94±0.25) Type 1 E(10.00±0.20) D(1.50±0.20) E(10.00±0.20) D(1.50±0.20) C(6.00±0.20) B±0.25 H(2.54±0.25) 1.27±0.10 P.C.B LAYOUT 2.54mm Pitch 180° Single Row Pin Header-SMT B TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black A±0.20 F(4.94±0.25) Type 2 A2541WVA-S-XP-B 2.54±0.10 C(6.00±0.20) D(1.50±0.20) E(10.00±0.20) C(6.00±0.20) D(1.50±0.20) H(2.54±0.25) B±0.25 2.54±0.05 F(4.94±0.25) Type 2 2.54±0.05 1.27±0.10 P.C.B LAYOUT 3.17±0.10 A±0.20 2.54±0.25 Circuit 1 Ordering Information: A2541WVA-S-XP-A - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 3.17±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Housing *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.54mm pitch wire to board connector Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-364 A2541 SERIES A2541WRB-XP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Pin Header A Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT 30%GF,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.05 ∅1.02±0.05 2.54±0.25 Ordering Information: P.C.B LAYOUT A2541WRB-XP - *** - *** 1 2 3 1.Part No. Ordering Information & Dimensions: 2.Material: (Blank):PBT,UL94V-0 Dimensions PART NO. PART NO. 6T:Nylon 6T,UL94V-0 A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2.54 ----1P 21P 3.Finish: 2P 2.54 5.08 22P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 3P 23P 5.08 7.62 100μin (2.54μm) MIN.Select Tin 7.62 10.16 4P 24P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 5P 10.16 12.70 25P 100μin (2.54μm) MIN.Select Tin 6P 26P 12.70 15.24 T:Tin over Nickel 2.54±0.10 B±0.25 2.54±0.25 D(1.50) E(3.00±0.20) C(6.00±0.25) PIN 0.64 SQ 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P A±0.20 F(1.50) 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WRB-2xXP 2.54mm Pitch 90° Dual Row Pin Header 2.54±0.20 B±0.25 PIN 0.64 SQ C(6.00±0.25) E(3.00±0.20) A±0.20 2.54±0.10 2.54±0.10 F(1.50±0.20) 2.54±0.10 2.54±0.05 2.54±0.05 Ordering Information: A2541WRB-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(1.50±0.20) 5.08±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT30%GF,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.54 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 71.12 73.66 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-365 A2541 SERIES A2541WV-XP-H3 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Pin Header 2.54±0.10 A±0.20 2.54±0.05 ∅1.02±0.05 A2541WV-XP-H3 - *** - *** 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: (Blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ Dimensions 3.Finish: PART NO. PART NO. A B (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2.54 5.08 2P 22P 100μin (2.54μm) MIN.Select Tin 3P 5.08 7.62 23P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 4P 7.62 10.16 24P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 5P 10.16 12.70 25P E(7.62±0.20) D(3.00±0.20) PIN 0.64 SQ 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 2.54mm Pitch 180° Single Row Pin Header 2.54±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator: PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black A±0.20 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WV-XP-H4 2.54±0.10 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P C(6.00±0.20) B±0.25 2.54±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator: PBT,UL94V-0 *Mates with CJT A2541 series Single Row Housing *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: Ordering Information: A2541WV-XP-H4 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 2.54±0.05 ∅1.02±0.05 P.C.B LAYOUT Information & Dimensions: PART NO. E(10.16±0.20) D(3.00±0.20) C(6.00±0.20) B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm PIN 0.64 SQ CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-366 A2541 SERIES A2541WV-2xXP 2.54mm pitch wire to board connector 2.54±0.05 2.54mm Pitch 180° Dual Row Pin Header 2.54±0.10 A±0.20 D(3.00±0.20) H(2.54±0.25) B±0.25 Ordering Information: A2541WV-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.05 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P C(6.00±0.20) 2.54±0.10 5.08±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT30%GF,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black PIN 0.64 SQ 2.54±0.20 C(6.00±0.20) E(3.00±0.20) 2.54±0.05 2.54±0.05 Ordering Information: A2541WR-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel D(1.50±0.20) 5.08±0.25 2.54±0.10 H(2.54±0.25) B±0.25 PIN 0.64 SQ 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 2.54mm Pitch 90° Dual Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT30%GF,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black A±0.20 PART NO. Unit: mm A2541WR-2xXP 2.54±0.10 Dimensions A B 2.54 ----2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.54 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 71.12 73.66 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-367 A2541 SERIES A2541WVA-2xXP 2.54mm Pitch 180° Dual Row Pin Header 5.08±0.25 Type 2 Dimensions A B 2.54 ----2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 2.54mm Pitch 90° Dual Row Pin Header 5.08±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT30%GF,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.54±0.05 Ordering Information: A2541WRA-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(6.00±0.20) E(3.00±0.20) D(1.50±0.20) 2.54±0.20 H(2.54±0.20) A±0.20 PIN 0.64 SQ P.C.B LAYOUT Unit: mm A2541WRA-2xXP B±0.25 E(10.00±0.20) C(6.00±0.20) D(3.00±0.20) C(6.00±0.20) E(10.00±0.20) D(3.00±0.20) Type 1 PIN 0.64 SQ ∅1.02±0.05 Ordering Information & Dimensions: 2.54±0.05 2.54±0.10 B±0.25 H(2.54±0.25) A±0.20 2.54±0.05 2.54±0.05 Ordering Information: A2541WVA-2xXP - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT30%GF,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.54mm pitch wire to board connector ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B ----2.54 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 PART NO. 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 71.12 73.66 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-368 A2541 SERIES A2541WVC-2xXP 1.64 DIA DRILLED HOLE 1.41/1.07 DIA FINESHED PLATED HOLE 3.54 A D(3.50±0.25) 2.54±0.25 B±0.25 PIN 0.64 SQ C(6.00±0.25) 2.54±0.10 A ∅1.09±0.05 0.03 Min ELECTRO-DEPOSITED P.C.B LAYOUT 0.02 Max Tin Plate COPPER SEC:A-A Ordering Information: Ordering Information & Dimensions: A2541WVC-2xXP - *** - *** Dimensions 1 2 3 PART NO. PART NO. A B 1.Part No. 2.54 5.08 2x2P 2x22P 2.Material: (blank):PBT,UL94V-0 2x3P 5.08 7.62 2x23P 6T:Nylon 6T,UL94V-0 2x4P 7.62 10.16 2x24P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x5P 10.16 12.70 2x25P 3.Finish: 2x6P 12.70 15.24 2x26P (blank):Gold-flash 2x7P 15.24 17.78 2x27P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x8P 17.78 20.32 2x28P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x9P 2x29P 20.32 22.86 100μin (2.54μm) MIN.Select Tin 2x10P 22.86 25.40 2x30P T:Tin over Nickel 2x11P 25.40 27.94 2x31P 2x32P 2x12P 27.94 30.48 2x13P 30.48 33.02 2x33P 2x14P 33.02 35.56 2x34P 2x15P 2x35P 35.56 38.10 2x16P 38.10 40.64 2x36P 2x37P 2x17P 40.64 43.18 2x18P 43.18 45.72 2x38P 2x19P 45.72 48.26 2x39P 2x20P 2x40P 48.26 50.80 50.80 53.34 2x21P 5.08±0.25 A±0.20 2.54±0.05 2.54±0.05 2.54mm Pitch 180° Dual Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.54mm pitch wire to board connector Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WV-S-2xXP 2.54mm Pitch 180° Dual Row Pin Header-SMT TYPE H(2.54±0.25) B±0.25 PIN 0.64 SQ 8.88±0.10 C(6.00±0.25) A±0.20 D(1.50) 5.08±0.25 2.54±0.10 2.54±0.10 Ordering Information: A2541WV-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750°C 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel E(7.50±0.20) 1.27 3.17±0.10 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T ,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-369 A2541 SERIES A2541WR-S-2xXP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Dual Row Pin Header - SMT TYPE Pin 0.64 SQ A2541WV-S-F-2xXP PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 1.02±0.10 8.50±0.20 Ordering Information: A2541WV-S-F-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel ∅1.60 PIN 0.64 SQ 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 2.54±0.05 E(7.50±0.25) C(6.00±0.25) 2.00±0.20 H(2.54±0.25) B±0.25 PART NO. 2.54mm Pitch 180° Dual Row Pin Header - SMT TYPE D(0.50±0.20) 2.54±0.10 5.08±0.25 A±0.20 Ordering Information & Dimensions: Unit: mm Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.50 6.70 8.50±0.25 1.30 3.95±0.25 6.00±0.25 H(2.54±0.20) B±0.25 P.C.B LAYOUT ∅1.80±0.10 2.26 A±0.20 1.30 2.54±0.10 1.02±0.05 2.54±0.05 Ordering Information: A2541WR-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.10 6.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 1.27±0.10 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-370 A2541 SERIES A2541WR-S-F-2xXP 2.54mm Pitch 90° Dual Row Pin Header - SMT TYPE 5.08±0.25 2.54±0.10 2.50 6.70 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 8.50±0.25 1.30 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm Type 1 F(7.50±0.25) Type 2 C(6.00±0.20) E(10.00±0.20) D(1.50±0.20) C(6.00±0.20) D(1.50±0.20) E(10.00±0.20) 2.54±0.25 F(7.50±0.25) 2.54±0.05 1.27±0.10 3.17±0.10 Ordering Information: A2541WVA-S-2xXP - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel B±0.25 PIN 0.64 SQ PART NO. 2.54mm Pitch 180° Daul Row Pin Header-SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T ,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black A±0.20 1.30 ∅1.30±0.20 A2541WVA-S-2xXP 3.95±0.25 Pin 0.64 SQ P.C.B LAYOUT 8.88±0.10 H(2.54±0.20) 1.20±0.20 ∅1.80±0.05 Ordering Information & Dimensions: 6.00±0.25 2.54±0.10 6.00±0.25 B±0.25 2.54±0.10 1.27±0.10 A2541WR-S-F-2xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel A±0.20 1.02±0.05 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black Ordering Information: 2.54±0.10 2.54mm pitch wire to board connector P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-371 A2541 SERIES A2541WVA-S-F-2xXP 2.54mm Pitch 180° Daul Row Pin Header-SMT TYPE ∅1.60 PIN 0.64 SQ F(7.50±0.25) F(7.50±0.25) Type 1 Type 2 A2541WV-2xXP-H43 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 3.10±0.10 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm 5.80±0.25 C(6.00±0.25) D(3.00±0.25) PIN 0.64 SQ 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2.54±0.05 ∅1.02±0.05 P.C.B LAYOUT Information & Dimensions: PART NO. B±0.25 4.30±0.25 Ordering Information & Dimensions: Ordering Information: A2541WV-2xXP-H43 - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 2.54±0.10 A±0.20 P.C.B LAYOUT 1.27±0.10 2.54mm Pitch 180° Daul Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT ,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 C(6.00±0.20) 2.00 D(1.50±0.20) E(10.00±0.20) H(2.54±0.25) B±0.25 2.54±0.05 ∅1.80 8.50±0.10 Ordering Information: A2541WVA-S-F-2xXP - * - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 4.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.05 2.54±0.10 A±0.20 5.08±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T ,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 2.54mm pitch wire to board connector Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-372 A2541 SERIES A2541WR-2xXP-H43 2.54mm pitch wire to board connector 2.54±0.05 2.54mm Pitch 90° Daul Row Pin Header 2.54±0.10 2.54±0.10 5.80±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black A±0.20 Ordering Information: A2541WR-2xXP-H43 - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 6.00±0.25 2.54±0.10 4.30±0.25 B±0.25 3.00±0.25 PIN 0.64 SQ 2.54±0.05 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WV-S-2xXP-H43 2.54mm Pitch 180° Daul Row Pin Header-SMT TYPE 5.80±0.25 A±0.20 2.54±0.10 2.54±0.10 Ordering Information: A2541WV-S-2xXP-H43 - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 6.00±0.25 4.60±0.25 4.30±0.25 B±0.25 PIN 0.64 SQ 7.50±0.25 1.02±0.10 8.50±0.10 3.20±0.10 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T ,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-373 A2541 SERIES A2541WV-2xXP-H74 2.54mm pitch wire to board connector 2.54mm Pitch 180° Daul Row Pin Header 2.54±0.05 A±0.20 7.40±0.25 2.54±0.05 D(3.00±0.25) B±0.25 ∅1.02±0.05 P.C.B LAYOUT Ordering Information: A2541WV-2xXP-H74 - *** - *** 1 2 3 1.Part No. 2.Material: Ordering Information & Dimensions: (blank):PBT,UL94V-0 Dimensions 6T:Nylon 6T,UL94V-0 PART NO. PART NO. GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A B 3.Finish: 2.54 5.08 2x2P 2x22P (blank):Gold-flash 2x3P 5.08 7.62 2x23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x4P 7.62 10.16 2x24P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x5P 10.16 12.70 2x25P 100μin (2.54μm) MIN.Select Tin 2x6P 12.70 15.24 2x26P T:Tin over Nickel C(6.00±0.25) 2.54±0.10 2.54±0.10 6.40±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P PIN 0.64 SQ Unit: mm A2541WR-2xXP-H74 2.54mm Pitch 90° Daul Row Pin Header 2.54±0.05 A±0.20 2.54±0.10 6.40±0.25 Ordering Information: A2541WR-2xXP-H74 - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(6.00±0.25) 7.40±0.25 B±0.25 D(3.00±0.25) 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black 2.54±0.10 Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-374 A2541 SERIES A2541WVA-2xXP-H 2.54mm pitch wire to board connector 2.54mm Pitch 180° Daul Row Pin Header 2.54±0.05 A±0.20 E(15.00±0.25) 2.54±0.05 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm Ordering Information: A2541WRA-2xXP-D - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 2.54mm H15: 1.50mm H17: 1.70mm H20: 2.00mm H30: 3.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel C(6.00±0.25) 2.54±0.20 H(2.54±0.25) 2.54±0.05 D(1.50±0.20) 5.08±0.25 2.54±0.10 A±0.20 PIN 0.64 SQ P.C.B LAYOUT 2.54mm Pitch 90° Daul Row Pin Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested *Color:Black B±0.25 C(6.00±0.25) Type 2 A2541WRA-2xXP-D 2.54±0.10 D(3.00±0.25) C(6.00±0.25) Type 1 F(10.00±0.25) PIN 0.64 SQ E(15.00±0.25) D(3.00±0.25) 2.54±0.25 2.54±0.25 B±0.25 ∅1.02±0.05 Ordering Information & Dimensions: E(3.00±0.25) 2.54±0.05 2.54±0.10 A2541WVA-2xXP-H - * - *** - *** 1 2 3 4 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 5.08±0.25 2.54±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series dual row Housing Optional Gold plating available but MOQ requested Ordering Information: *Color:Black ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-375 A2541 SERIES A2541WV-3xXP 2.54mm Pitch 180° Triple Row Pin Header 7.62±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series triple row Female Header *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: A2541WV-3xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering 2.54±0.05 2.54±0.05 5.08±0.20 5.08±0.20 D(3.00±0.25) 2.54±0.25 B±0.25 ∅1.02±0.05 P.C.B LAYOUT C(6.00±0.25) A±0.20 2.54±0.10 2.54±0.10 2.54mm pitch wire to board connector PIN 0.64 SQ Information & Dimensions: PART NO. 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WR-3xXP 2.54mm Pitch 90° Triple Row Pin Header Ordering Information: A2541WR-3xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 2.54±0.05 5.08±0.20 5.08±0.10 2.54±0.10 2.54±0.10 7.62±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series triple row Female Header *Optional Gold plating available but MOQ requested *Color:Black 2.54±0.05 A±0.20 ∅1.02±0.05 P.C.B LAYOUT PIN 0.64 SQ C(6.00±0.25) 2.54±0.10 2.54±0.25 D(1.50±0.20) B±0.25 E(3.00±0.25) Information & Dimensions: PART NO. 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-376 A2541 SERIES A2541WVA-3xXP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Triple Row Pin Header 2.54±0.05 A±0.20 5.08±0.20 2.54±0.10 2.54±0.10 PIN 0.64 SQ 2.54±0.25 Type 1 5.08±0.20 E(10.00±0.25) D(3.00±0.25) C(6.00±0.25) 2.54±0.25 B±0.25 A2541WVA-3xXP - * - *** - *** 1 2 3 4 1.Part No. 2.Style: (blank): Type 1 R: Type 2 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Type 2 2.54±0.05 7.62±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series triple row Female Header *Optional Gold plating available but MOQ requested *Color:Black Ordering Information: ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-377 A2541 SERIES A2541HWV-XP Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 2.54±0.10 A±0.20 2.54mm Pitch 180° Single Row Female Header Ordering Information: A2541HWV-XP - **** - *** - *** - *** 2.54 ±0.05 1 2 3 4 5 1.Part No. 2.Size(H): (blank): 8.50mm H71: 7.10mm H57: 5.70mm ∅1.19±0.05 H50: 5.00mm H35: 3.50mm(B:B-0.50mm) P.C.B LAYOUT H110: 11.00mm 3.Size(D): (blank):3.20mm(H85,H71,H57,H50,H110) D26:2.60mm(H35) Ordering Information & Dimensions: D21:2.10mm(H50) 4.Material: Dimensions PART NO. PART NO. (blank):PBT,UL94V-0 A B 6T:Nylon 6T,UL94V-0 2.54 5.58 2P 22P GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: 3P 5.08 8.12 23P (blank):Gold-flash 4P 7.62 10.66 24P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 5P 10.16 13.20 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.74 26P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 7P 15.24 18.28 27P T:Tin over Nickel 2.50±0.25 D(3.20±0.25) H(8.50±0.25) B±0.25 2.54mm pitch wire to board connector PIN 0.64x0.40 B±0.25 A±0.20 2.54±0.10 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 2.54mm Pitch 90° Single Row Female Header Ordering Information: A2541HWR-XP - **** - *** - *** - *** 2.54 ±0.05 1 2 3 4 5 1.Part No. 2.Size(H): (blank): 8.50mm H71: 7.10mm H57: 5.70mm H50: 5.00mm ∅1.19±0.05 H35: 3.50mm(B:B-0.50mm) H110: 11.00mm P.C.B LAYOUT 3.Size(D): (blank):3.20mm(H85,H71,H57,H50,H110) D26:2.60mm(H35) Ordering Information & Dimensions: D21:2.10mm(H50) 4.Material: Dimensions PART NO. PART NO. (blank):PBT,UL94V-0 A B 6T:Nylon 6T,UL94V-0 2.54 2P 22P 5.58 GWT:Nylon 6T,UL94V-0,GWT 750°C 5.Finish: 3P 5.08 8.12 23P (blank):Gold-flash 4P 7.62 10.66 24P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 5P 10.16 13.20 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.74 26P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 7P 15.24 18.28 27P T:Tin over Nickel 1.60±0.25 H(8.50±0.25) 2.50±0.25 PIN 0.64x0.40 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 Unit: mm A2541HWR-XP Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 3.20±0.20 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-378 A2541 SERIES A2541HWV-S-XP-A 2.54mm Pitch 180° Single Row Female Header - SMT TYPE 2.50±0.20 A±0.20 3.18±0.10 Ordering Information: 1.02±0.05 A2541HWV-S-XP-A - **** - *** - *** P.C.B LAYOUT 1 2 3 4 1.Part No. 2.Size(H): Ordering Information & Dimensions: (blank): 8.50mm H71: 7.10mm Dimensions PART NO. PART NO. H57: 5.70mm A B H50: 5.00mm 2.54 5.58 2P 22P H110: 11.00mm 3P 5.08 8.12 23P 3.Material: (blank):Nylon 6T,UL94V-0 4P 7.62 10.66 24P GWT:Nylon 6T,UL94V-0,GWT 750℃ 5P 10.16 13.20 25P 4.Finish: 6P 12.70 15.74 26P (blank):Gold-flash 7P 15.24 18.28 27P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 8P 17.78 20.82 28P 100μin (2.54μm) MIN.Select Tin 9P 29P 20.32 23.36 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 10P 22.86 25.90 30P T:Tin over Nickel 11P 25.40 28.44 31P 32P 12P 27.94 30.98 13P 30.48 33.52 33P 14P 33.02 36.06 34P 15P 35P 35.56 38.60 16P 38.10 36P 41.14 37P 17P 40.64 43.68 18P 43.18 46.22 38P 19P 45.72 48.76 39P 20P 40P 48.26 51.30 4.45±0.25 50.80 53.84 21P H(8.50±0.25) B±0.25 5.35±0.10 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 2.54±0.10 2.54mm pitch wire to board connector Pin 0.64x0.40 Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWV-S-XP-B 3.18±0.10 2.54mm Pitch 180° Single Row Female Header - SMT TYPE 2.54±0.10 A±0.20 Pin 0.64x0.40 4.45±0.25 2.54±0.05 5.35±0.10 Ordering Information: A2541HWV-S-XP-B - **** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 8.50mm H71: 7.10mm H57: 5.70mm H50: 5.00mm H110: 11.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel H(8.50±0.25) B±0.25 2.50±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-379 A2541 SERIES A2541HWR-S-XP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Female Header - SMT TYPE A±0.20 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Ordering Information: 0.80±0.20 H(8.50±0.25) 2.54±0.10 2.00±0.20 A±0.20 Pin 0.64x0.40 3.00 A2541HWR-S-XP - **** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank): 8.50mm H71: 7.10mm H57: 5.70mm H50: 5.00mm H110: 11.00mm 3.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.50±0.25 B±0.25 P.B.C LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 2.54mm Pitch 180° Single Row Female Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Ordering Information: 12.20±0.25 8.50±0.25 B±0.25 2.54±0.20 2.54±0.10 ∅1.02±0.05 A2541HWV-XP-H-L12 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.50±0.10 A±0.20 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 Unit: mm A2541HWV-XP-H-L12 2.54±0.10 1.02 2.54±0.10 Pin 0.64x0.60 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-380 A2541 SERIES A2541HWV-XP-H2 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Female Header A±0.20 Ordering Information: A2541HWV-XP-H2 - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 3.00±0.25 2.54±0.20 B±0.25 2.54±0.10 8.50±0.25 2.54±0.10 2.50±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Pin 0.64x0.60 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541HWV-XP-U 2.54mm Pitch 180° Single Row Female Header A±0.20 Ordering Information: A2541HWV-XP-U - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):8.50mm H71: 7.10mm H50: 5.00mm(Pin:0.60x0.20) H35: 5.00mm(Pin:0.50x0.20,B:B-0.50mm D:3.50mm) 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel H(8.50±0.25) B±0.30 2.54±0.10 3.08±0.20 2.54±0.10 2.50±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Pin 0.64x0.25 ∅1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-381 A2541 SERIES A2541HWR-XP-U 2.54mm pitch wire to board connector 2.54mm Pitch 90° Single Row Female Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Pin 0.60x0.25 2.50±0.25 A±0.20 ∅1.02±0.05 Ordering Information: P.C.B LAYOUT A2541HWR-XP-U - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):8.50mm Ordering Information & Dimensions: H71:7.10mm(D:2.80mm) H50:5.00mm(D:3.00mm) Dimensions PART NO. PART NO. 3.Material: A B (blank):PBT,UL94V-0 2.54 5.58 2P 22P 6T:Nylon 6T,UL94V-0 3P 5.08 8.12 23P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: 4P 7.62 10.66 24P (blank):Gold-flash 5P 10.16 13.20 25P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 6P 12.70 15.74 26P 100μin (2.54μm) MIN.Select Tin 7P 15.24 18.28 27P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 8P 17.78 20.82 28P T:Tin over Nickel Circuit 1 2.54±0.10 2.54±0.10 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P H(8.50±0.25) B±0.25 D(3.20±0.25) 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWV-XP-A-U 2.54mm Pitch 180° Single Row Female Header 2.54±0.10 A±0.20 A2541HWV-XP-A-U - *** - *** - *** 1 2 3 4 ∅1.20±0.05 1.Part No. 2.Size(H): P.C.B LAYOUT (blank): 8.50mm H71: 7.10mm(Pin 0.60x0.25,D:3.40mm) Ordering Information & Dimensions: H50: 5.00mm(Pin 0.60x0.25,D:3.00mm) H35: 3.50mm(Pin 0.50x0.20,B:B-0.50mm, Dimensions D:2.60mm) PART NO. PART NO. A B 3.Material: (blank):PBT,UL94V-0 2.54 2P 22P 5.58 6T:Nylon 6T,UL94V-0 3P 5.08 8.12 23P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4P 7.62 10.66 24P 4.Finish: (blank):Gold-flash 5P 10.16 13.20 25P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 6P 12.70 15.74 26P 100μin (2.54μm) MIN.Select Tin 7P 15.24 18.28 27P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 8P 17.78 20.82 28P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 9P 29P 20.32 23.36 Pin 0.80x0.25 D(3.65±0.25) H(8.50±0.25) B±0.25 2.50±0.25 Circuit 1 ∅1.02±0.05 5.08±0.25 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 5.08±0.10 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Ordering Information: Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-382 A2541 SERIES A2541HWV-XP-B-U 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Female Header 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Ordering Information: 2.54±0.10 2.50±0.25 A±0.20 A2541HWV-XP-B-U - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): P.C.B LAYOUT (blank):8.50mm H71:7.10mm(Pin 0.60x0.25,D:3.40mm) Ordering Information & Dimensions: H50:5.00mm(Pin 0.60x0.25,D:3.00mm) H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm, Dimensions D:2.60mm) PART NO. PART NO. A B 3.Material: (blank):PBT,UL94V-0 2.54 5.58 2P 22P 6T:Nylon 6T,UL94V-0 3P 5.08 8.12 23P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4P 7.62 10.66 24P 4.Finish: 5P 10.16 13.20 25P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 6P 12.70 15.74 26P 100μin (2.54μm) MIN.Select Tin 7P 15.24 18.28 27P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 8P 17.78 20.82 28P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 9P 29P 20.32 23.36 D(3.65±0.25) H(8.50±0.25) B±0.25 ∅1.20±0.05 5.08±0.25 Pin 0.80x0.25 A2541HWV-XP-C-U 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 2.54±0.05 Pin 0.50x0.25 ∅1.02±0.05 E±0.10 A2541HWV-XP-C-U - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(E): (blank):5.08mm E40:3.96mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.20 3.00±0.25 B±0.25 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 2.54mm Pitch 180° Single Row Female Header 8.50±0.25 A±0.20 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Ordering Information: 2.54±0.10 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 5.08±0.10 Circuit 1 ∅1.02±0.05 E(5.08±0.25) P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 4.78 5.08 7.32 7.62 9.86 10.16 12.40 12.70 14.94 15.24 17.48 17.78 20.02 20.32 22.56 22.86 25.10 25.40 27.64 27.94 30.18 30.48 32.72 33.02 35.26 35.56 37.80 38.10 40.34 40.64 42.88 43.18 45.42 45.72 47.96 48.26 50.50 50.80 53.04 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.58 55.88 58.12 58.42 60.66 60.96 63.20 63.50 65.74 66.04 68.28 68.58 70.82 73.36 71.12 73.66 75.90 76.20 78.44 78.74 80.98 81.28 83.52 83.82 86.06 86.36 88.60 88.90 91.14 91.44 93.68 93.98 96.22 96.52 98.76 99.06 101.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-383 A2541 SERIES A2541HWVA-XP-U 2.54mm Pitch 180° Single Row Female Header Ordering Information: A2541HWVA-XP-U - *** - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm H50:5.00mm H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm, D:2.60mm) 3.Size(E): (blank):2.54mm E13:1.27mm(H35) 4.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel E(2.54±0.25) Pin 0.60x0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 2.54±0.05 1.02±0.05 Ordering Information: A2541HWV-S-XP-A-U - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm H50:5.00mm(Pin 0.50x0.20,E:4.80mm) H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm) 3.Material: (blank):Nylon 6T,UL94V-0 P.C.B LAYOUT GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: Ordering Information & Dimensions: (blank):Gold-flash Dimensions Dimensions G15:15μin (0.38μm) MIN.Select Gold(Mating Area) PART NO. PART NO. 100μin (2.54μm) MIN.Select Tin A B A B G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2.54 53.34 56.38 2P 22P 5.58 100μin (2.54μm) MIN.Select Tin 3P 5.08 8.12 23P 55.88 58.92 T:Tin over Nickel 2.10±0.05 2.50±0.25 Pin 0.50x0.25 A±0.20 P.C.B LAYOUT 2.54mm Pitch 180° Single Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 2.54±0.10 ∅1.02±0.05 Unit: mm A2541HWV-S-XP-A-U Circuit 1 D(3.00±0.25) H(8.50±0.25) B±0.25 2.54±0.05 5.20±0.10 A±0.20 2.50±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black 2.54±0.10 2.54mm pitch wire to board connector H(8.50±0.25) B±0.25 E(4.50±0.25) 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 10.66 13.20 15.74 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 58.42 60.96 63.50 66.04 68.58 71.12 73.66 76.20 78.74 81.28 83.82 86.36 88.90 91.44 93.98 96.52 99.06 61.46 64.00 66.54 69.08 71.62 74.16 76.70 79.24 81.78 84.32 86.86 89.40 91.94 94.48 97.02 99.56 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-384 A2541 SERIES A2541HWV-S-XP-B-U 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Female Header - SMT TYPE 2.50±0.25 A±0.20 2.54±0.10 Circuit 1 Pin 0.50x0.25 E(4.50±0.25) 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P 5.20±0.10 2.10±0.05 Ordering Information: A2541HWV-S-XP-B-U - *** - *** - *** 1 2 3 4 1.Part No. P.C.B LAYOUT 2.Size(H): (blank):8.50mm H71:7.10mm Ordering Information & Dimensions: H50:5.00mm(Pin 0.50x0.20,E:4.80mm) Dimensions H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm) PART NO. PART NO. 3.Material: A B (blank):Nylon 6T,UL94V-0 2.54 5.58 2P 22P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3P 5.08 8.12 23P 4.Finish: 4P 7.62 10.66 24P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 5P 10.16 13.20 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.74 26P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 7P 15.24 18.28 27P 100μin (2.54μm) MIN.Select Tin 8P 17.78 20.82 28P T:Tin over Nickel H(8.50±0.25) B±0.25 1.02±0.05 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWRA-XP 2.54mm Pitch 90° Single Row Female Header 2.54±0.10 Ordering Information: A2541HWRA-XP - *** - *** 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions PART NO. PART NO. GWT:PBT,UL94V-0,GWT 750℃ A B 3.Finish: 2.54 2P 22P 5.08 (blank):Gold-flash 3P 5.08 7.62 23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 4P 7.62 10.16 24P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 5P 10.16 12.70 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.24 26P T:Tin over Nickel 7P 15.24 17.78 27P 8P 17.78 20.32 28P 9P 29P 20.32 22.86 8.10±0.20 10P 30P 22.86 25.40 11P 25.40 27.94 31P 32P 12P 27.94 30.48 13P 30.48 33.02 33P 14P 33.02 35.56 34P 15P 35P 35.56 38.10 16P 38.10 40.64 36P 37P 17P 40.64 43.18 7.87±0.20 18P 43.18 38P 45.72 Pin 0.70x0.25 19P 45.72 48.26 39P 20P 40P 48.26 50.80 50.80 53.34 21P 3.40±0.20 3.00±0.20 B±0.30 2.54±0.10 A±0.20 ∅1.02±0.05 7.87±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT 15%GF,UL94V-0 *Mates with CJT A2541 series Single row Housing *Color:Black Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-385 A2541 SERIES A2541HWRA-S-XP 2.54mm Pitch 90° Single Row Female Header - SMT TYPE Ordering Information: A2541HWRA-S-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Single row Pin Header *Color:Black Pin 0.70x0.25 1.02±0.05 1.90±0.05 12.19±0.10 2.54±0.10 2.54±0.10 2.54mm pitch wire to board connector A±0.20 B±0.25 3.95±0.20 3.40±0.20 P.C.B LAYOUT 8.10±0.20 11.00±0.20 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P & Dimensions: Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541HWV-2xXP 2.54±0.10 5.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.10 A±0.20 Ordering Information: A2541HWV-2xXP - **** - *** - *** - *** 2.54±0.05 1 2 3 4 5 ∅1.02±0.05 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm H57:5.70mm H50:5.00mm H35:3.50mm(B:B-0.50mm) H110:11.00mm 3.Size(D): P.C.B LAYOUT (blank):3.20mm(H85,H71,H57,H50,H110) D26:2.60mm(H35) D21:2.10mm(H50) 4.Material: Ordering Information & Dimensions: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions GWT:Nylon 6T,UL94V-0,GWT 750 ℃ PART NO. PART NO. 5.Finish: A B (blank):Gold-flash 2.54 2x2P 2x22P 5.58 G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x3P 5.08 8.12 2x23P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P D±0.25 H(8.50±0.25) B±0.25 PIN 0.64x0.40 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 13.20 15.74 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-386 A2541 SERIES A2541HWR-2xXP 2.54mm pitch wire to board connector B±0.25 A±0.20 H±0.25 2.54±0.10 5.00±0.25 2.54±0.10 Ordering Information: A2541HWR-2xXP - **** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm H57:5.70mm H50:5.00mm H35:3.50mm(B:B-0.50mm) H110:11.00mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 1.60±0.25 3.20±0.20 PIN 0.64x0.40 2.54 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.05 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 90° Dual Row Female Header P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWV-2xXP-H 2.54±0.10 5.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Ordering Information: A2541HWV-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering 2.54±0.05 P.C.B LAYOUT Information & Dimensions: PART NO. 2.54±0.10 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P A±0.20 3.20±0.20 8.50±0.25 2.54±0.20 B±0.25 PIN 0.64x0.40 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-387 A2541 SERIES A2541HWV-S-2xXP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Dual Row Female Header - SMT TYPE 5.00±0.25 2.54±0.10 2.54±0.10 A±0.20 Ordering Information: A2541HWV-S-2xXP - **** - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): P.C.B LAYOUT (blank):8.50mm Ordering Information & Dimensions: H71:7.10mm H57:5.70mm Dimensions H50:5.00mm PART NO. PART NO. H110:11.00mm A B 3.Size(E): 2.54 5.58 2x2P 2x22P (blank):7.00mm 2x3P 5.08 8.12 2x23P E80:8.00mm 2x4P 7.62 10.66 2x24P 4.Material: (blank):Nylon 6T,UL94V-0 2x5P 10.16 13.20 2x25P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x6P 12.70 15.74 2x26P 5.Finish: 2x7P 15.24 18.28 2x27P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x8P 17.78 20.82 2x28P 100μin (2.54μm) MIN.Select Tin 2x9P 2x29P 20.32 23.36 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x10P 22.86 25.90 2x30P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x11P 25.40 28.44 2x31P 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P H±0.25 B±0.25 1.02±0.05 (E+1.00)±0.10 Pin 0.64x0.40 2.54±0.05 2.20±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black E(7.00±0.25) 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWR-S-2xXP 2.54mm Pitch 90° Dual Row Female Header - SMT TYPE 2.54±0.10 2.54±0.10 A±0.20 B±0.25 Pin 0.64x0.40 8.40±0.25 1.27±0.20 3.40±0.25 1.27±0.20 8.50±0.25 5.00±0.25 5.80±0.10 Ordering Information: A2541HWR-S-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.00±0.10 A±0.10 2.54±0.05 Reference Informations: *Material:Pin:Phosphor Bronze/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 1.02±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-388 A2541 SERIES A2541HWV-S-F-2xXP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Dual Row Female Header - SMT TYPE 5.00±0.25 2.54±0.10 A±0.20 1.40 B±0.25 ∅1.50 (E+1.00)±0.10 1.02±0.05 E(7.00±0.25) 1.10 ∅1.80 Ordering Information: A2541HWV-S-F-2xXP - **** - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm H57:5.70mm H50:5.00mm H110:11.00mm 3.Size(E): (blank):7.00mm E80:8.00mm 4.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 5.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel H±0.25 2.54±0.10 Pin 0.64x0.40 2.54±0.05 2.20±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 1.27 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWVA-2xXP 2.54mm Pitch 180° Dual Row Female Header 2.54±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.10 A±0.20 Ordering Information: A2541HWVA-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 5.00±0.25 Pin 0.64x0.40 3.00±0.25 8.50±0.25 B±0.25 1.60±0.20 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-389 A2541 SERIES A2541HWV-N-2xXP 2.54mm pitch wire to board connector 2.54±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.05 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Ordering Information: A2541HWV-N-2xXP - *** - *** 1 2 3 1.Part No. P.C.B LAYOUT 2.Material: (blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ Dimensions 3.Finish: PART NO. PART NO. A B (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2.54 2x2P 2x22P 5.58 100μin (2.54μm) MIN.Select Tin 2x3P 5.08 8.12 2x23P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x5P 10.16 13.20 2x25P 2.54±0.10 A±0.20 B±0.25 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 5.00±0.25 3.70 3.20±0.20 8.50±0.25 1.00 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 15.74 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Unit: mm A2541HWR-N-2xXP Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.05 2.54±0.10 Ordering Information: A2541HWR-N-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.10 A±0.20 5.00±0.25 B±0.25 1.00 2.54 PIN 0.64 *0.40 3.20±0.20 1.60±0.25 H±0.25 3.70 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 90° Dual Row Female Header P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-390 A2541 SERIES A2541HWV-N-2xXP-A 2.54mm pitch wire to board connector Ordering Information: A2541HWV-N-2xXP-A - *** - *** 1 2 3 1.Part No. 2.Material: (blank): PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT: Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin Ordering T:Tin over Nickel 2.54±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black B±0.25 6.00±0.25 3.70±0.25 3.20±0.25 8.50±0.25 1.00±0.25 Pin 0.64x0.40 2.54±0.10 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 2.54mm Pitch 180° Dual Row Female Header - SMT TYPE 2.54±0.05 2.20±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black A±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 Unit: mm A2541HWV-N-S-2xXP 2.54±0.10 Information & Dimensions: PART NO. A±0.20 Pin 0.64x0.40 P.C.B LAYOUT 1.02±0.05 Ordering Information: A2541HWV-N-S-2xXP - *** - *** - *** 1 2 3 4 1.Part No. P.C.B LAYOUT 2.Size(E): (blank):7.00mm Ordering Information & Dimensions: E80:8.00mm 3.Material: Dimensions (blank):Nylon 6T,UL94V-0 PART NO. PART NO. GWT:Nylon 6T,UL94V-0,GWT 750 ℃ A B 4.Finish: 2.54 2x2P 2x22P 5.58 (blank):Gold-flash 2x3P 5.08 8.12 2x23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x5P 10.16 13.20 2x25P 100μin (2.54μm) MIN.Select Tin 2x6P 12.70 15.74 2x26P T:Tin over Nickel B±0.25 6.00±0.25 1.00 8.50±0.25 3.70±0.25 E(7.00±0.25) 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P (E+1.00)±0.10 2.54±0.10 2.54±0.05 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-391 A2541 SERIES A2541HWV-N-S-2xXP-A 2.54mm pitch wire to board connector Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 1.02±0.05 Ordering Information: A2541HWV-N-S-2xXP-A - *** - *** - *** 1 2 3 4 P.C.B LAYOUT 1.Part No. 2.Size(E): (blank):7.00mm Ordering Information & Dimensions: E80:8.00mml 3.Material: Dimensions PART NO. PART NO. (blank):Nylon 6T,UL94V-0 A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2.54 2x2P 2x22P 5.58 4.Finish: 2x3P 5.08 8.12 2x23P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin 2x5P 10.16 13.20 2x25P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x6P 12.70 15.74 2x26P 100μin (2.54μm) MIN.Select Tin 2x7P 15.24 18.28 2x27P T:Tin over Nickel Pin 0.64x0.40 2.54±0.10 2.54±0.05 2.54±0.10 A±0.20 B±0.25 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 6.00±0.25 3.70±0.25 8.50±0.25 1.00 E(7.00±0.25) 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 (E+1.00)±0.10 2.20±0.10 2.54mm Pitch 180° Dual Row Female Header -SMT TYPE Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Unit: mm A2541HWV-N1-2xXP 2.54±0.10 A±0.20 2.54±0.05 ∅1.02±0.05 Ordering Information: A2541HWV-N1-2xXP - *** - *** - *** 1 2 3 4 1.Part No. P.C.B LAYOUT 2.Size(W): (blank):6.00mm W50:5.00mm Ordering Information & Dimensions: 3.Material: (blank):PBT,UL94V-0 Dimensions 6T:Nylon 6T,UL94V-0 PART NO. PART NO. A B GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: 2.54 2x2P 2x22P 5.58 (blank):Gold-flash 2x3P 5.08 8.12 2x23P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x5P 10.16 13.20 2x25P 100μin (2.54μm) MIN.Select Tin 2x6P 12.70 15.74 2x26P T:Tin over Nickel B±0.25 6.00±0.25 3.70±0.25 8.50±0.25 1.00 3.20±0.25 2.54±0.10 W±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Pin 0.64x0.40 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-392 A2541 SERIES A2541HWV-N1-2xXP-A 2.54mm pitch wire to board connector 2.54±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.05 ∅1.02±0.05 2.54±0.05 2.54mm Pitch 180° Dual Row Female Header Ordering Information: A2541HWV-N1-2xXP-A - *** - *** 1 2 3 1.Part No. P.C.B LAYOUT 2.Material: (blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ Dimensions 3.Finish: PART NO. PART NO. A B (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2.54 2x2P 2x22P 5.58 100μin (2.54μm) MIN.Select Tin 2x3P 5.08 8.12 2x23P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x4P 7.62 10.66 2x24P 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2x5P 10.16 13.20 2x25P 2.54±0.10 A±0.20 B±0.25 6.00±0.25 3.70±0.25 3.20±0.25 8.50±0.25 1.00 Pin 0.64x0.40 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 15.74 18.28 20.82 23.36 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWV-2xXP-U 2.54±0.10 A±0.20 PIN 0.64x0.25 ∅1.02±0.05 Ordering Information: A2541HWV-2xXP-U - *** - *** - *** 1 2 3 4 P.C.B LAYOUT 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm Ordering Information & Dimensions: H50:5.00mm(Pin:0.60x0.20) Dimensions H35:3.50mm(Pin:0.50x0.15,B:B-0.50mm, PART NO. PART NO. D:3.50mm) A B 3.Material: 2.54 2x2P 2x22P 5.58 (blank):PBT,UL94V-0 2x3P 5.08 8.12 2x23P 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x4P 7.62 10.66 2x24P 4.Finish: 2x5P 10.16 13.20 2x25P (blank):Gold-flash 2x6P 12.70 15.74 2x26P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x7P 15.24 18.28 2x27P 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x8P 17.78 20.82 2x28P 100μin (2.54μm) MIN.Select Tin 2x9P 20.32 23.36 2x29P T:Tin over Nickel H±0.20 B±0.30 2.54±0.10 D(3.20±0.20) 2.54±0.10 5.00±0.25 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black 2.54±0.10 2.54mm Pitch 180° Dual Row Female Header 2.54±0.20 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 25.90 28.44 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-393 A2541 SERIES A2541HWV-S-2xXP-U 2.54mm pitch wire to board connector 2.54mm Pitch 180° Dual Row Female Header - SMT TYPE 2.54±0.05 5.00±0.25 2.54±0.10 A±0.20 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P H±0.25 0.40±0.15 B±0.25 E(7.10±0.25) 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P (E+1.00)±0.10 Ordering Information: A2541HWV-S-2xXP-U - *** - *** - *** - *** 1 2 3 4 5 1.Part No. P.C.B LAYOUT 2.Size(H): (blank):8.50mm Ordering Information & Dimensions: H71:7.10mm(Pin 0.60x0.25) H50:5.00mm(Pin 0.60x0.25) Dimensions PART NO. PART NO. H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm) A B 3.Size(E): 2.54 2x2P 2x22P 5.58 (blank):7.10mm(H85,H71,H35) 2x3P 5.08 8.12 2x23P E74:7.40mm(H50) E66:6.60mm(H50,H35) 2x4P 7.62 10.66 2x24P 4.Material: 2x5P 10.16 13.20 2x25P (blank):Nylon 6T,UL94V-0 2x6P 12.70 15.74 2x26P GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x7P 15.24 18.28 2x27P 5.Finish: 2x8P 17.78 20.82 2x28P (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x9P 2x29P 20.32 23.36 100μin (2.54μm) MIN.Select Tin 2x10P 2x30P 22.86 25.90 G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x11P 25.40 28.44 2x31P 100μin (2.54μm) MIN.Select Tin 2x32P 2x12P 27.94 30.98 T:Tin over Nickel Pin 0.50x0.25 2.54±0.10 1.02±0.05 2.30±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWV-S-F-2xXP-U 2.54mm Pitch 180° Dual Row Female Header - SMT TYPE 2.54±0.05 2.54±0.10 A±0.20 1.40 B±0.25 ∅1.00 ∅1.20 E(7.10±0.25) 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 30.98 33.52 36.06 38.60 41.14 43.68 46.22 48.76 51.30 53.84 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P (E+1.00)±0.10 1.02±0.05 Ordering Information: A2541HWV-S-2xXP-U - *** - *** - *** - *** 1 2 3 4 5 1.Part No. 2.Size(H): P.C.B LAYOUT (blank):8.50mm Ordering Information & Dimensions: H71:7.10mm(Pin 0.60x0.25) H50:5.00mm(Pin 0.60x0.25) Dimensions H35:3.50mm(Pin 0.50x0.20,B:B-0.50mm) PART NO. PART NO. A B 3.Size(E): (blank):7.10mm(H85,H71,H35) 2.54 2x2P 2x22P 5.58 E74:7.40mm(H50) 2x3P 5.08 8.12 2x23P E66:6.60mm(H50,H35) 2x4P 7.62 10.66 2x24P 4.Material: 2x5P 10.16 13.20 2x25P (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 2x6P 12.70 15.74 2x26P 5.Finish: 2x7P 15.24 18.28 2x27P (blank):Gold-flash 2x8P 17.78 20.82 2x28P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x9P 20.32 23.36 2x29P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 2x10P 2x30P 22.86 25.90 100μin (2.54μm) MIN.Select Tin 2x11P 25.40 28.44 2x31P T:Tin over Nickel H±0.25 5.00±0.25 2.54±0.10 Pin 0.50x0.25 2.30±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-394 A2541 SERIES A2541HWRA-2xXP 2.54mm pitch wire to board connector 2.54mm Pitch 90° Dual Row Female Header 2.54±0.10 Ordering Information: A2541HWRA-2xXP - *** - *** 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: (blank):PBT,UL94V-0 Ordering Information & Dimensions: 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ Dimensions PART NO. PART NO. 3.Finish: A B (blank):Gold-flash 2.54 2x2P 2x22P 5.58 G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x3P 5.08 8.12 2x23P 100μin (2.54μm) MIN.Select Tin 2x4P 7.62 10.66 2x24P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x5P 10.16 13.20 2x25P T:Tin over Nickel 2x6P 12.70 15.74 2x26P 2x7P 15.24 18.28 2x27P 2x8P 17.78 20.82 2x28P 8.10±0.20 2x9P 2x29P 20.32 23.36 2x10P 2x30P 22.86 25.90 2x11P 25.40 28.44 2x31P 2x32P 2x12P 27.94 30.98 2x13P 30.48 33.52 2x33P 2x14P 33.02 36.06 2x34P 2x15P 2x35P 35.56 38.60 2x16P 38.10 2x36P 41.14 2x37P 2x17P 40.64 43.68 7.85±0.20 2x18P 43.18 46.22 2x38P Pin 0.70x0.25 2x19P 45.72 48.76 2x39P 2x20P 2x40P 48.26 51.30 50.80 53.84 2x21P 2.54±0.10 A±0.20 3.00±0.20 2.54±0.10 5.90±0.20 B±0.25 ∅1.02±0.05 7.85±0.10 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWRA-S-2xXP 2.54mm Pitch 90° Dual Row Female Header - SMT TYPE Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2541 series Dual row Pin Header *Color:Black Pin 0.70x0.25 Ordering Information: A2541HWRA-S-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Ordering Information 2.54±0.10 11.68±0.10 1.90±0.05 1.02±0.05 2.54±0.10 A±0.20 B±0.25 6.10±0.20 8.10±0.20 5.90±0.20 2.54±0.10 P.C.B LAYOUT 11.18±0.20 PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P & Dimensions: Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-395 A2541 SERIES A2541WVM-XP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Single Row Pin Header 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541WVF-XP series Single row Female Header *Color:Black ∅2.00±0.05 Ordering Information: P.C.B LAYOUT A2541WVM-XP - *** - *** 1 2 3 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions GWT:PBT,UL94V-0,GWT 750 ℃ PART NO. PART NO. A B 3.Finish: (blank):Gold-flash 2.54 5.08 2P 22P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 3P 5.08 7.62 23P 100μin (2.54μm) MIN.Select Tin 4P 7.62 10.16 24P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 5P 10.16 12.70 25P 100μin (2.54μm) MIN.Select Tin 6P 12.70 15.24 26P T:Tin over Nickel A±0.20 2.54±0.10 Circuit 1 B±0.25 10.00±0.25 3.50±0.20 3.00±0.20 2.54±0.20 ∅0.60 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm A2541WVF-XP 2.54mm Pitch 180° Single Row Female Header Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541WVM-XP series Single row Pin Header *Color:Black Circuit 1 B±0.25 3.00±0.20 2.54±0.20 ∅0.55 7.43±0.25 2.54±0.10 ∅2.00±0.05 Ordering Information: A2541WVF-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.80±0.20 A±0.20 2.54±0.05 ∅1.35 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P 39P 40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-396 A2541 SERIES A2541WVM-2xXP A±0.20 2.54±0.10 Last Circuit Circuit 1 2.54±0.05 Ordering Information: ∅2.00±0.05 A2541WVM-2xXP - *** - *** 1 2 3 P.C.B LAYOUT 1.Part No. 2.Material: Ordering Information & Dimensions: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 Dimensions GWT:PBT,UL94V-0,GWT 750℃ PART NO. PART NO. A B 3.Finish: (blank):Gold-flash 2.54 5.08 2x2P 2x22P G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 2x3P 5.08 7.62 2x23P 100μin (2.54μm) MIN.Select Tin 2x4P 7.62 10.16 2x24P G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin 2x5P 10.16 12.70 2x25P T:Tin over Nickel 2x6P 12.70 15.24 2x26P B±0.25 3.50±0.20 3.00±0.20 5.08±0.25 ∅0.60 10.00±0.25 Circuit 2 2.54mm Pitch 180° Dual Row Pin Header 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT15%GF,UL94V-0 *Mates with CJT A2541WVF-2xXP series Dual row Female Header *Color:Black 2.54mm pitch wire to board connector 2.54±0.10 A2541WVF-2xXP 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm 2.54mm Pitch 180° Dual Row Female Header A±0.20 Circuit 2 2.54±0.10 Last Circuit Ordering Information: A2541WVF-2xXP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel Circuit 1 ∅0.55 ∅1.35 2.54±0.20 2.80±0.20 3.00±0.20 7.43±0.25 5.08±0.25 B±0.25 2.54±0.05 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541WVM-2xXP series Dual row Pin Header *Color:Black ∅2.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 PART NO. 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P 2x37P 2x38P 2x39P 2x40P Dimensions A B 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 91.44 93.98 93.98 96.52 96.52 99.06 99.06 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-397 A2541 SERIES A2541HWV-3xXP 2.54mm pitch wire to board connector 2.54mm Pitch 180° Triple Row Female Header 5.08±0.20 B±0.25 3.20±0.25 H(8.50±0.25) 7.50±0.25 PIN 0.64x0.40 5.08±0.10 P.C.B LAYOUT PART NO. 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm A2541HWR-3xXP 2.54mm Pitch 90° Triple Row Female Header 2.54±0.10 2.54±0.10 A±0.20 2.54±0.05 Ordering Information: A2541HWR-3xXP - *** - *** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 7.50±0.25 5.08±0.20 15.24±0.25 2.54±0.10 8.50±0.25 B±0.25 3.20±0.25 ∅1.19±0.05 P.C.B LAYOUT 5.08±0.10 5.08±0.20 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT ,UL94V-0 *Mates with CJT A2541 series triple row Pin Header Optional Gold plating available but MOQ requested *Color:Black PIN 0.64x0.40 ∅1.19±0.05 Ordering Information & Dimensions: 2.54±0.05 A±0.20 2.54±0.10 2.54±0.10 Ordering Information: A2541HWV-3xXP - *** - *** - *** 1 2 3 4 1.Part No. 2.Size(H): (blank):8.50mm H71:7.10mm 3.Material: (blank):PBT,UL94V-0 6T:Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 4.Finish: (blank):Gold-flash G15:15μin (0.38μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold(Mating Area) 100μin (2.54μm) MIN.Select Tin T:Tin over Nickel 2.54±0.05 2.54±0.05 Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2541 series triple row Pin Header Optional Gold plating available but MOQ requested *Color:Black Ordering Information & Dimensions: PART NO. 3x2P 3x3P 3x4P 3x5P 3x6P 3x7P 3x8P 3x9P 3x10P 3x11P 3x12P 3x13P 3x14P 3x15P 3x16P 3x17P 3x18P 3x19P 3x20P 3x21P Dimensions A B 2.54 5.58 5.08 8.12 7.62 10.66 10.16 13.20 12.70 15.74 15.24 18.28 17.78 20.82 20.32 23.36 22.86 25.90 25.40 28.44 27.94 30.98 30.48 33.52 33.02 36.06 35.56 38.60 38.10 41.14 40.64 43.68 43.18 46.22 45.72 48.76 48.26 51.30 50.80 53.84 PART NO. 3x22P 3x23P 3x24P 3x25P 3x26P 3x27P 3x28P 3x29P 3x30P 3x31P 3x32P 3x33P 3x34P 3x35P 3x36P 3x37P 3x38P 3x39P 3x40P Dimensions A B 53.34 56.38 55.88 58.92 58.42 61.46 60.96 64.00 63.50 66.54 66.04 69.08 68.58 71.62 74.16 71.12 73.66 76.70 76.20 79.24 78.74 81.78 81.28 84.32 83.82 86.86 86.36 89.40 88.90 91.94 91.44 94.48 93.98 97.02 96.52 99.56 99.06 102.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-398
A2541WV-10P 价格&库存
很抱歉,暂时无法提供与“A2541WV-10P”相匹配的价格&库存,您可以联系我们找货
A2541WV-10P
  • 1+0.83311
  • 10+0.80292
  • 100+0.71237
  • 500+0.69425
库存:697
A2541WV-10P
  • 1+1.38106
  • 10+1.24741
  • 50+1.14049
  • 150+1.06921
  • 300+1.02466
