A2549H-2x4P
A2549H-2x4P
    CJT(长江连接器)
    Housings
    间距P=2.54mm 胶壳 8(2x4)pin 250V 3A
A2549H-2x4P 数据手册
A2549 SERIES Specifications 2.54mm pitch wire to board connector Standards Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* E326732 E326732 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-458 A2549 SERIES 2.54mm pitch wire to board connector 5.00 7.70 1.60 19.45.REF 1.30 1.60 1.90 5.00 5.08 1.60 1.30 1.90 1.30 17.30 REF. 17.80 REF. 7.10 1.60 1.60 1.90 1.60 17.80 REF. 17.60.REF 5.08 21.64 REF. 7.10 1.60 7.70 1.90 1.30 1.60 19.10 REF. 20.64 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-459 A2549 SERIES A2549-T-A 2.54mm pitch wire to board connector Reference Informations: *Used in CJT A2549HB-XP,A2549HB-2xXP series Housing 2.05±0.20 2.54mm Pitch Crimp Terminal 2.20±0.20 1.10 0.25 1.50±0.20 A 1.90 A SEC: A-A B 13.10±0.25 C 1.60±0.15 7.65±0.20 SEC: B-B 1.30±0.20 B 1.33±0.20 1.60±0.15 SEC: C-C C Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A2549-TP-A AWG#22-#28 1.55mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS A2549-GP-A AWG#22-#28 1.55mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Part NO. Optional Gold plating available but MOQ requested A2549-T-C 2.54mm Pitch Crimp Terminal C±0.20 ∅1.45 1.50 0.20 SEC:A-A F±0.20 7.60±0.25 2.70±0.15 D±0.20 Reference Informations: *Used in CJT A2549HC-XP,A2549HC-2xXP,A2549HD-XP,A2549HD-2xXP, A2549HE-2xXP,A2549HG-2xXP,A2549HL-2xXP series Housing C SEC:B-B 0.61 1.50±0.10 B 2.50 B 4.20±0.20 A 11.30±0.25 18.00±0.25 E±0.20 A 1.73±0.10 3.29±0.20 C 0.25±0.05 SEC:C-C Unit:mm Ordering information & Specifications: Part NO. Wire Range Finish C D E F Qty/reel A2549-TP-C AWG#22-#26 Material Insulation O.D. 1.55mm(max) Phosphor Bronze Tin over Nickel 2.25 2.03 1.70 1.55 8,000 PCS A2549-GP-C AWG#22-#26 1.55mm(max) Phosphor Bronze Gold over Nickel 2.25 2.03 1.70 1.55 8,000 PCS A2549-TP-C-H AWG#20-#24 1.90mm(max) Phosphor Bronze Tin over Nickel 2.61 2.03 2.03 1.80 8,000 PCS A2549-GP-C-H AWG#20-#24 1.90mm(max) Phosphor Bronze Gold over Nickel 2.61 2.03 2.03 1.80 8,000 PCS A2549-TP-C-L AWG#28-#32 0.90mm(max) Phosphor Bronze Tin over Nickel 2.01 1.54 1.35 1.23 8,000 PCS A2549-GP-C-L AWG#28-#32 0.90mm(max) Phosphor Bronze Gold over Nickel 2.01 1.54 1.35 1.23 8,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-460 A2549 SERIES A2549-T-I 2.54mm pitch wire to board connector 2.54mm Pitch Crimp Terminal Reference Informations: *Used in CJT A2549HI-2xXP series Housing 0.25 2.60±0.20 1.50 2.80±0.20 2.00±0.20 0.50±0.10 SEC:B-B 2.90±0.20 0.45±0.05 1.37±0.20 1.85±0.20 B 3.90±0.20 B 11.00±0.25 A 2.50 SEC:A-A A 1.65±0.20 Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A2549-TP-I AWG#20-#24 1.55mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A2549-GP-I AWG#20-#24 1.55mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested A2549-T-K 2.54mm Pitch Crimp Terminal Reference Informations: *Used in CJT A2549HK-XP,A2549HK-2xXP series Housing 2.54 0.20 D±0.20 2.54 1.80 E±0.20 5.98±0.20 B 11.36±0.20 3.06±0.20 A B SEC:A-A F±0.20 A 16.56±0.25 2.90±0.20 C±0.20 SEC:B-B 1.60±0.10 1.60±0.10 Unit:mm Ordering information & Specifications: Part NO Wire Range Finish C D E F Qty/reel A2549-TP-K AWG#22-#30 Insulation O.D. Material 1.50mm(max) Phosphor Bronze Tin over Nickel 2.19 2.60 1.64 1.60 A2549-GP-K AWG#22-#30 1.50mm(max) 15,000 PCS Phosphor Bronze Gold over Nickel 2.19 2.60 1.64 1.60 A2549-TP-K-H AWG#20-#22 15,000 PCS 1.60mm(max) Phosphor Bronze Tin over Nickel 2.40 2.20 2.10 2.00 A2549-GP-K-H AWG#20-#22 15,000 PCS 1.60mm(max) Phosphor Bronze Gold over Nickel 2.40 2.20 2.10 2.00 15,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-461 A2549 SERIES A2549M-T 2.54mm pitch wire to board connector 2.54mm Pitch Crimp Terminal 1.45±0.25 Reference Informations: *Used in CJT A2549HM-XP,A2549HM-2xXP series Housing 0.20 1.76±0.25 20.73±0.25 1.88±0.20 2.10±0.25 1.65 SEC:B-B 1.68±0.25 C 11.72±0.20 C SEC:A-A 13.02±0.20 B 2.30 A B 28.20±0.25 A 1.00 1.27 1.80±0.25 1.60±0.25 0.64±0.10 0.64 SEC:C-C Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel A2549M-TP AWG#22-#26 1.55mm(max) Phosphor Bronze Tin over Nickel 10,000 PCS A2549M-GP AWG#22-#26 1.55mm(max) Phosphor Bronze Gold over Nickel 10,000 PCS Part NO. Optional Gold plating available but MOQ requested A2549H-XP 2.54mm pitch Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2547-T-B series Terminal *Mates with CJT A2549HM-XP series Housing or A2549WV,WR-XP,A2547WVE,WRE-XP series Wafer *Color:Black Circuit 1 2.54±0.10 Ordering Information: A2549H-XP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ A±0.20 4.05±0.20 13.70±0.25 C±0.20 B±0.25 4.80±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P A 2.54 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 Dimensions B 7.10 9.64 12.18 14.72 17.26 19.80 22.34 24.88 27.42 29.96 32.50 35.04 37.58 40.12 42.66 45.20 47.74 50.28 52.82 55.36 57.90 C 5.60 8.14 10.68 13.22 15.76 18.30 20.84 23.38 25.92 28.46 31.00 33.54 36.08 38.62 41.16 43.70 46.24 48.78 51.32 53.86 56.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-462 A2549 SERIES A2549HM-XP 2.54mm pitch wire to board connector 2.54mm pitch Housing Reference Informations: *Material:PBT, UL94V-0 *Suitable CJT A2549M-T series Terminal *Mates with CJT A2549H-XP series Housing *Color:Black Ordering Information: A2549HM-XP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ B±0.25 2.54±0.10 Dimensions A B 2.54 7.42 5.08 9.96 7.62 12.50 10.16 15.04 12.70 17.58 15.24 20.12 17.78 22.66 20.32 25.20 22.86 27.74 25.40 30.28 27.94 32.82 30.48 35.36 33.02 37.90 35.56 40.44 38.10 42.98 40.64 45.52 43.18 48.06 45.72 50.60 48.26 53.14 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Circuit 1 5.00±0.25 23.80±0.25 8.40±0.20 A±0.20 Ordering Information & Dimensions: Unit: mm A2549HA-XP 2.54mm pitch Housing Reference Informations: *Material:PBT, UL94V-0 *Suitable CJT A2547-T-B series Terminal *Mates with CJT A2549WV,WR-XP,A2547WVE,WRE-XP series Wafer *Color:Black Circuit 1 2.54±0.10 Ordering Information: A2549HA-XP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ A±0.25 C±0.25 4.05±0.20 Ordering Information & Dimensions: 13.70±0.25 PART NO. 4.80±0.25 B±0.25 2P 4P 6P 8P 9P 10P 12P 15P 22P A 2.54 7.62 12.70 17.78 20.32 22.86 27.94 35.56 53.34 Dimensions B 7.10 12.20 17.30 22.30 24.84 27.38 32.46 41.08 58.86 C 5.60 10.68 15.76 20.84 23.38 25.92 31.00 38.64 56.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-463 A2549 SERIES A2549HB-XP 2.54mm pitch wire to board connector 2.54mm pitch Single Row Housing Reference Informations: *Material:Nylon 66+15%GF,UL94V-0 *Suitable CJT A2549-T-A series Terminal *Mates with CJT A2549WVB,WRB-XP series Wafer *Color:Blue Circuit 1 Ordering Information: A2549HB-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank): Nylon 66,UL94V-0 GWT: Nylon 66,UL94V-0 GWT 750 ℃ 3.Color: (blank):Blue BK:Black 2.54±0.10 A±0.20 B±0.25 4.50±0.20 1.30±0.10 Ordering Information & Dimensions: 1.50 15.10±0.25 2.40±0.20 4.45±0.20 PART NO. 5.08±0.25 A2549HC-XP 2P 3P 4P 5P 6P 7P 8P 9P 10P 12P 15P 18P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 27.94 30.48 35.56 38.10 43.18 45.72 Unit: mm 2.54mm pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2541 series Wafer *Color:Black Circuit 1 Ordering Information: A2549HC-XP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ 2.54±0.10 A±0.10 Ordering Information & Dimensions: PART NO. 3.56±0.20 2.54±0.10 CJTCONN 15.24±0.25 B±0.25 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-464 A2549 SERIES A2549HD-XP 2.54mm pitch wire to board connector 2.54mm pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2547WVF,WRF-XP series Wafer *Color:Black 1.10 Ordering Information: A2549HD-XP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Circuit 1 2.54±0.10 Ordering Information & Dimensions: PART NO. A±0.20 4.10±0.20 2.54±0.10 B±0.25 15.24±0.25 CJTCONN 3.00 3.23±0.20 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2549HK-XP 2.54mm pitch Single Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-K series Terminal *Mates with CJT A2549WVK,WRK-XP series Wafer *Color:Blue Ordering Information: A2549HK-XP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Circuit 1 2.54±0.10 Ordering Information & Dimensions: A±0.20 PART NO. 8P~36P B±0.25 3.80±0.20 2P~7P 13.85±0.25 14.10±0.25 2.66 1.20 3.10±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-465 A2549 SERIES A2549H-2xXP 2.54mm pitch wire to board connector 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2547-T-B series Terminal *Mates with CJT A2549HM-2xXP series Housing or A2549WV,WR-2xXP series Wafer *Color:Black Circuit 2 2.54±0.10 Circuit 1 Ordering Information: A2549H-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ 2.54±0.20 Last Circuit A±0.20 6.30±0.25 C±0.25 13.70±0.25 12.20±0.20 5.30±0.20 B±0.25 7.10±0.25 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P A 2.54 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 Dimensions B 7.10 9.64 12.18 14.72 17.26 19.80 22.34 24.88 27.42 29.96 32.50 35.04 37.58 40.12 42.66 45.20 47.74 50.28 52.82 55.36 57.90 C 5.60 8.14 10.68 13.22 15.76 18.30 20.84 23.38 25.92 28.46 31.00 33.54 36.08 38.62 41.16 43.70 46.24 48.78 51.32 53.86 56.40 Unit: mm A2549HM-2xXP 2.54mm pitch Dual Row Housing Circuit 1 2.45±0.10 Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549M-T series Terminal *Mates with CJT A2549H-2xXP series Dual Row Housing *Color:Black Last Circuit 2.54±0.10 A±0.20 Ordering Information: A2549HM-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Ordering Information & Dimensions: PART NO. Circuit 2 7.00±0.25 23.79±0.25 9.10±0.20 B±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P Dimensions A B 2.54 7.42 5.08 9.96 7.62 12.50 10.16 15.04 12.70 17.58 15.24 20.12 17.78 22.66 20.32 25.20 22.86 27.74 25.40 30.28 27.94 32.82 30.48 35.36 33.02 37.90 35.56 40.44 38.10 42.98 40.64 45.52 43.18 48.06 45.72 50.60 48.26 53.14 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-466 A2549 SERIES A2549HB-2xXP 2.54mm pitch wire to board connector 2.54mm pitch Dual Row Housing 2.54±0.10 Reference Informations: *Material:Nylon 66 ,UL94V-0 *Suitable CJT A2549-T-A series Terminal *Mates with CJT A2549WVB,WRB-2xXP series Dual Row Wafer *Color:Blue Circuit 2 Last Circuit 2.54±0.10 Ordering Information: A2549HB-2xXP - *** - ** 1 2 3 1.Part No. 2.Material: (blank): Nylon 66,UL94V-0 GWT: Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (blank):Blue BK:Black Circuit 1 A±0.20 B±0.25 7.05±0.20 1.30±0.10 Ordering Information & Dimensions: Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 27.94 30.48 35.56 38.10 43.18 45.72 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x12P 2x15P 2x18P 1.50 15.10±0.25 2.40±0.10 4.45±0.20 PART NO. 7.70±0.25 A2549HC-2xXP Unit: mm 2.54mm pitch Dual Row Housing Ordering Information: A2549HC-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Color:Black A±0.20 12.20 1.25 0.75 0.53 odd number odd number even number 12.20 2x3P~2x9P 1.25 2.54±0.10 Last Circuit Circuit 2 even number 2x10P~2x36P Circuit 1 Ordering Information & Dimensions: 2.54±0.10 0.75 PART NO. 6.65±0.20 B±0.25 1.35 1.92 15.24±0.25 CJTCONN 5.84 2.54 6.10±0.20 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-467 A2549 SERIES A2549HD-2xXP 2.54mm pitch wire to board connector 2.54mm pitch Dual Row Housing Ordering Information: A2549HD-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Color:Black A±0.20 12.20 1.25 2x3P~2x9P odd number 12.20 1.25 2.54±0.10 Last Circuit Circuit 2 even number 2x10P~2x36P 2.54±0.10 Ordering Information & Dimensions: Circuit 1 PART NO. 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P B±0.25 6.65±0.20 2.54 15.24±0.25 CJTCONN 1.92 1.35 6.10±0.20 Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2549HE-2xXP 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2541 series Wafer *Color:Black Ordering Information: A2549HE-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ A±0.20 2.54±0.10 Circuit 2 Last Circuit 2.54±0.10 Ordering Information & Dimensions: Circuit 1 PART NO. B±0.25 15.24±0.25 CJTCONN 6.10±0.20 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-468 A2549 SERIES A2549HG-2xXP 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2541 series Wafer *Color:Black Ordering Information: A2549HG-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ A±0.20 2.54±0.10 Circuit 2 Last Circuit Ordering Information & Dimensions: 2.54±0.10 Circuit 1 2.54mm pitch wire to board connector PART NO. B±0.25 15.24±0.25 CJTCONN 5.03±0.20 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2549HG-N-2xXP 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2547WV-N,WR-N-2xXP series Dual Row Wafer *Color:Black A±0.20 2.54±0.10 Last Circuit 2.54±0.10 Circuit 2 Circuit 1 Ordering Information: A2549HG-N-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ 3.30 B±0.20 CJTCONN 15.24±0.25 2.54±0.10 5.03±0.20 Ordering Information & Dimensions: PART NO. 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-469 A2549 SERIES A2549HK-2xXP 2.54mm pitch wire to board connector 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-K series Terminal *Mates with CJT A2549WVK,WRK-2xXP series Wafer *Color:Blue Circuit 2 2.54±0.20 Last Circuit Ordering Information: A2549HK-2xXP - *** 1 2 1.Part No. 2.Material: (Blank): PBT,UL94V-0 GWT: PBT,UL94V-0 GWT 750 ℃ Ordering Information & Dimensions: Circuit 1 2.54±0.10 PART NO. A±0.20 2x8P~2x36P B±0.25 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 6.34±0.20 13.85±0.25 14.10±0.25 2.66 1.20 2x2P~2x7P 5.64±0.20 Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2549HI-2xXP 2.54mm pitch Dual Row Housing Reference Informations: *Material:Nylon 66 , UL94V-0 *Suitable CJT A2549-T-I series Terminal *Mates with CJT A2549WVI,WRI-2xXP, A2549WVI-S-2xXP series Dual Row Wafer *Color:White Ordering Information: A2549HI-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ Last Circuit Ordering Information & Dimensions: PART NO. Circuit 1 Circuit 2 2.54±0.10 12.83±0.25 7.24±0.20 1.30 A±0.20 6.40±0.20 B±0.25 8.97±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.54 6.48 5.08 9.02 7.62 11.56 10.16 14.10 12.70 16.64 15.24 19.18 17.78 21.72 20.32 24.26 22.86 26.80 25.40 29.34 27.94 31.88 30.48 34.42 33.02 36.96 35.56 39.50 38.10 42.04 40.64 44.58 43.18 47.12 45.72 49.66 48.26 52.20 50.80 54.74 53.34 57.28 55.88 59.82 58.42 62.36 60.96 64.90 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-470 A2549 SERIES A2549HL-2xXP 2.54mm pitch wire to board connector 2.54mm pitch Dual Row Housing Reference Informations: *Material:PBT,UL94V-0 *Suitable CJT A2549-T-C series Terminal *Mates with CJT A2547WV,WR,WVC,WRC-2xXP series Wafer *Color:Black A±0.20 Ordering Information: A2549HL-2xXP - *** 1 2 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 2.54±0.10 2.54±0.10 Circuit 2 Last Circuit Circuit 1 3.30±0.20 Ordering Information & Dimensions: 7.24±0.25 PART NO. B±0.25 15.24±0.25 6.60±0.20 CJTCONN 14.48±0.20 5.77±0.20 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P Dimensions A B 7.62 14.73 10.16 17.27 12.70 19.81 15.24 22.35 17.78 24.89 20.32 27.43 22.86 29.97 25.40 32.51 27.94 35.05 30.48 37.59 33.02 40.13 35.56 42.67 38.10 45.21 40.64 47.75 43.18 50.29 PART NO. 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x32P 2x32P Dimensions A B 45.72 52.83 48.26 55.37 50.80 57.91 53.34 60.45 55.88 62.99 58.42 65.53 60.96 68.07 63.50 70.61 66.04 73.15 68.58 75.69 78.23 71.12 73.66 80.77 76.20 83.31 78.74 85.85 Unit: mm A2549WV-XP 2.54mm pitch 180° Single Row Wafer Ordering Information: A2549WV-XP - *** - *** 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin 2.54±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2549H-XP,A2550H-XP-C series Housing *Nylon 6T is available *Color:Black Circuit 1 2.54±0.10 A±0.20 3.50±0.20 Gold(G15,G30) PIN 0.64 SQ 5.00±0.25 12.60±0.25 ∅1.02±0.10 P.C.B LAYOUT B±0.25 2.80±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P Dimensions A B 2.54 7.62 5.08 10.16 7.62 12.70 10.16 15.24 12.70 17.78 15.24 20.32 17.78 22.86 20.32 25.40 22.86 27.94 25.40 30.48 27.94 33.02 30.48 35.56 33.02 38.10 35.56 40.64 38.10 43.18 40.64 45.72 43.18 48.26 45.72 50.80 48.26 53.34 50.80 55.88 53.34 58.42 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-471 A2549 SERIES A2549WR-XP 2.54mm pitch wire to board connector 2.54mm pitch 90° Single Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2549H-XP,A2550H-XP-C series Housing *Nylon 6T is available Ordering Information: *Color:Black Circuit 1 2.54±0.10 A±0.20 2.54±0.10 ∅1.00±0.05 A2549WR-XP - *** - *** P.C.B LAYOUT 1 2 3 1.Part No. 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin B±0.25 1.85±0.20 12.60±0.25 Gold(G15,G30) 3.50±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P Dimensions A B 2.54 7.62 5.08 10.16 7.62 12.70 10.16 15.24 12.70 17.78 15.24 20.32 17.78 22.86 20.32 25.40 22.86 27.94 25.40 30.48 27.94 33.02 30.48 35.56 33.02 38.10 35.56 40.64 38.10 43.18 40.64 45.72 43.18 48.26 45.72 50.80 48.26 53.34 50.80 55.88 53.34 58.42 Unit: mm 2.54±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2549H-2xXP series Housing *Color:Black Circuit 2 A±0.20 B±0.25 2.54mm pitch 180° Dual Row Wafer 2.54±0.10 Ordering Information: A2549WV-2xXP - *** - *** ∅1.00±0.05 1 2 3 1.Part No. P.C.B LAYOUT 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ Ordering Information & Dimensions: 3.Finish: Dimensions (blank):Tin over Nickel PART NO. A B G:Gold-flash 2.54 7.62 2x2P G15:15μin (0.38μm) MIN.Select Gold 2x3P 5.08 10.16 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 2x4P 7.62 12.70 100μin (2.54μm) MIN.Select Tin 2x5P 10.16 15.24 2.54±0.10 A2549WV-2xXP Last Circuit 2.54±0.10 PART NO. 5.00±0.25 PIN 0.64 SQ Circuit 1 Ordering Information & Dimensions: Gold(G15,G30) 3.50±0.20 12.60±0.20 7.00±0.25 2.54±0.20 PIN 0.64 SQ 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-472 A2549 SERIES A2549WR-2xXP 2.54mm pitch 90° Dual Row Wafer A±0.20 2.54±0.10 Circuit 1 Circuit 2 2.54±0.10 Ordering Information: A2549WR-2xXP - *** - *** ∅1.00±0.05 1 2 3 1.Part No. P.C.B LAYOUT 2.Material: (Blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin 7.00±0.25 13.40±0.25 2.54±0.20 17.40±0.25 Gold(G15,G30) 7.30±0.20 B±0.25 3.50±0.20 P.C.B LAYOUT 5.08±0.20 B±0.25 7.00±0.20 8.80±0.20 11.50±0.25 3.68±0.20 PIN 0.64 SQ Ordering Information & Dimensions: PART NO. 2.90±0.20 A±0.20 ∅1.00±0.05 A±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P Dimensions A B 2.54 7.62 5.08 10.16 7.62 12.70 10.16 15.24 12.70 17.78 15.24 20.32 17.78 22.86 20.32 25.40 22.86 27.94 25.40 30.48 27.94 33.02 30.48 35.56 33.02 38.10 35.56 40.64 38.10 43.18 40.64 45.72 43.18 48.26 45.72 50.80 48.26 53.34 50.80 55.88 53.34 58.42 Ordering Information: A2549WVB-XP -*** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Blue BK:Black 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin 2.54±0.10 2.54±0.10 PART NO. 2.54mm pitch 180° Single Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2549HB-XP,A2550HA-XP series Housing *Color:Blue Circuit 1 Ordering Information & Dimensions: Unit: mm Gold(G15,G30) A2549WVB-XP 2.54±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A2549H-2xXP series Housing *Color:Black Last Circuit 2.54mm pitch wire to board connector 2P 3P 4P 5P 6P 7P 8P 10P 12P 15P 17P 18P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 22.86 25.40 27.94 30.48 35.56 38.10 40.64 43.18 43.18 45.72 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-473 A2549 SERIES A2549WRB-XP 2.54mm pitch wire to board connector 2.54mm pitch 90° Single Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2549HB-XP,A2550HA-XP series Housing *Color:Blue Ordering Information: A2549WRB-XP - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Blue BK:Black 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin Circuit 1 A±0.20 2.54±0.10 P.C.B LAYOUT Gold(G15,G30) A±0.20 2.90±0.20 2.54±0.10 ∅1.00±0.05 5.08±0.20 B±0.25 PART NO. 7.00±0.20 2P 3P 4P 5P 6P 7P 8P 10P 12P 15P 17P 18P 4.00 11.50±0.25 8.80±0.20 3.68±0.20 Ordering Information & Dimensions: PIN 0.64 SQ Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 22.86 25.40 27.94 30.48 35.56 38.10 40.64 43.18 43.18 45.72 Unit: mm A2549WRB-S-XP 2.54mm pitch 90° Single Row Wafer-SMT TYPE Ordering Information: A2549WRB-S-XP - *** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 6T,UL94V-0 GWT:Nylon 6T,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Blue BK:Black 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin Circuit 1 3.20±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 6T,UL94V-0 *Mates with CJT A2549HB-XP,A2550HA-XP series Housing *Color:Blue A±0.10 2.54±0.10 2.54±0.10 1.00±0.05 A±0.20 P.C.B LAYOUT B±0.25 5.08±0.20 3.68±0.20 Ordering Information & Dimensions: Gold(G15,G30) 7.00±0.20 8.80±0.20 4.80±0.20 11.50±0.25 PART NO. PIN 0.64 SQ 2P 3P 4P 5P 6P 7P 8P 10P 12P 15P 17P 18P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 22.86 25.40 27.94 30.48 35.56 38.10 40.64 43.18 43.18 45.72 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-474 A2549 SERIES A2549WVB-2xXP 2.54mm pitch wire to board connector 2.54mm pitch 180° Dual Row Wafer Ordering Information: A2549WVB-2xXP -*** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Blue BK:Black 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin 2.54±0.10 2.54±0.10 Circuit 2 ∅1.00±0.05 A±0.20 P.C.B LAYOUT B±0.25 7.62±0.25 Ordering Information & Dimensions: PART NO. 7.00±0.20 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x10P 2x12P 2x15P 2x17P 2x18P 2.90 11.50±0.25 8.80±0.25 6.22±0.20 Gold(G15,G30) Last Circuit A±0.20 2.54±0.10 Circuit 1 2.54±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2549HB-2xXP,A2550HA-2xXP series Housing *Color:Blue PIN 0.64 SQ Unit: mm A2549WRB-2xXP 2.54mm pitch 90° Dual Row Wafer 2.54±0.10 A±0.20 2.54±0.10 Circuit 2 2.54±0.10 A±0.20 2.90±0.20 Last Circuit ∅1.00±0.05 Ordering Information: A2549WRB-2xXP -*** - ** - *** 1 2 3 4 1.Part No. 2.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Color: (Blank):Blue BK:Black 4.Finish: (blank):Tin over Nickel G:Gold-flash G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin P.C.B LAYOUT 7.62±0.25 B±0.25 7.00±0.20 4.00±0.20 2.54 12.80±0.25 11.50±0.25 6.22±0.20 Gold(G15,G30) 2.54±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2549HB-2xXP,A2550HA-2xXP series Housing *Color:Blue Circuit 1 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 22.86 25.40 27.94 30.48 35.56 38.10 40.64 43.18 43.18 45.72 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x10P 2x12P 2x15P 2x17P 2x18P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 22.86 25.40 27.94 30.48 35.56 38.10 40.64 43.18 43.18 45.72 Unit: mm PIN 0.64 SQ CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-475 A2549 SERIES A2549WVI-2xXP 2.54mm pitch 180° Dual Row Wafer 2x3P~2x15P TYPE 2 6.35±0.20 Last Circuit A±0.20 TYPE 1 B±0.25 3.05±0.20 8.13±0.25 7.35±0.25 PIN 0.64 SQ A2549WRI-2xXP TYPE 2 Ordering Information: A2549WRI-2xXP - * - *** - ** - *** 1 2 3 4 5 1.Part No. 2.Style: (Blank):TYPE 1 K:TYPE 2 3.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 4.Color: (Blank):Ivory BK:Black 5.Finish: (blank):Tin over Nickel G:Gold-flash G10:10μin (0.25μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin Last Circuit A±0.20 TYPE 1 8.13±0.25 1.20±0.20 7.35±0.25 B±0.25 Gold (G10,G15,G30) 2x2P 6.35±0.20 2.54±0.10 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P Dimensions A B 2.54 6.60 5.08 9.14 7.62 11.68 10.16 14.22 12.70 16.76 15.24 19.30 17.78 21.84 20.32 24.38 22.86 26.92 25.40 29.46 27.94 32.00 30.48 34.54 33.02 37.08 35.56 39.62 2.54mm pitch 90° Dual Row Wafer 2x3P~2x15P 2.54±0.10 P.C.B LAYOUT Unit: mm Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2549HI-2xXP series Housing *Color:Ivory Circuit 2 Circuit 1 Ø1.02±0.05 PIN 0.64 SQ 2.16±0.20 2.54±0.05 Ø1.02±0.05 P.C.B LAYOUT 2.54±0.05 2.54±0.10 Gold (G10,G15,G30) 2.54±0.10 2x2P 2.54±0.05 2.54±0.05 Ordering Information: A2549WVI-2xXP - * - *** - ** - *** 1 2 3 4 5 1.Part No. 2.Style: (Blank):TYPE 1 K:TYPE 2 3.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 4.Color: (Blank):Ivory BK:Black 5.Finish: (blank):Tin over Nickel G:Gold-flash G10:10μin (0.25μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2549HI-2xXP series Housing *Color:Ivory Circuit 2 Circuit 1 2.54mm pitch wire to board connector Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P Dimensions A B 2.54 6.60 5.08 9.14 7.62 11.68 10.16 14.22 12.70 16.76 15.24 19.30 17.78 21.84 20.32 24.38 22.86 26.92 25.40 29.46 27.94 32.00 30.48 34.54 33.02 37.08 35.56 39.62 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-476 A2549 SERIES A2549WVI-S-2xXP 2.54mm pitch 180° Dual Row Wafer - SMT TYPE 2x3P~2x15P 6.35±0.20 2.54±0.10 Last Circuit A±0.20 TYPE 1 7.35±0.25 PIN 0.64 SQ 8.45±0.25 8.13±0.25 B±0.25 Gold (G10,G15,G30) 2.54±0.10 2x2P TYPE 2 9.58±0.25 2.54±0.05 10.60±0.10 1.02±0.05 4.50±0.10 Ordering Information: A2549WVI-S-2xXP - * - *** - ** - *** 1 2 3 4 5 1.Part No. 2.Style: (Blank):TYPE 1 K:TYPE 2 3.Material: (Blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750 ℃ 4.Color: (Blank):Ivory BK:Black 5.Finish: (blank):Tin over Nickel G:Gold-flash G10:10μin (0.25μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G15:15μin (0.38μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin G30:30μin (0.76μm) MIN.Select Gold 100μin (2.54μm) MIN.Select Tin Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT A2549HI-2xXP series Housing *Color:Ivory Circuit 2 Circuit 1 2.54mm pitch wire to board connector A±0.10 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P Dimensions A B 2.54 6.60 5.08 9.14 7.62 11.68 10.16 14.22 12.70 16.76 15.24 19.30 17.78 21.84 20.32 24.38 22.86 26.92 25.40 29.46 27.94 32.00 30.48 34.54 33.02 37.08 35.56 39.62 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-477
A2549H-2x4P 价格&库存
很抱歉,暂时无法提供与“A2549H-2x4P”相匹配的价格&库存,您可以联系我们找货
A2549H-2x4P
  • 1+1.16472
  • 10+1.12252
  • 100+0.99592
  • 500+0.97060
库存:346
A2549H-2X4P
    • 1+3.14780
    库存:2
