A2550-TP-J
A2550-TP-J
    CJT(长江连接器)
    端子,磷青铜,100μin(2.54μm),镀锡(Sn),FFC AWG
A2550-TP-J 数据手册
A2550 SERIES Specifications 2.54mm pitch FFC Crimp Flex Connector Standards E326732 1.50±0.05 6.00±0.10 Current rating:3A AC,DC Voltage rating:300V AC,DC Temperature range:-40°C~+105°C E326732 Contact resistance:5mΩ Max. Contact Layout Insulation resistance:1000MΩ Min. Withstanding voltage:1100V AC/minute 2.54±0.10 *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-478 A2550 SERIES A2550-T 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch High Insertion Force Crimp Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J Dual Row 2.54 3.50 A 1.30 5.90 A A2550H-2xXP,A2550HA-2xXP 0.20 Narrow 15.10 1.40 CJT 1.30 4.00 CJT 12.70 B CJT B CJT SEC:A-A 1.45 1.40 SEC:B-B 1.20 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550-TP FFC WIRE -------- Phosphor Bronze A2550-GP FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550-T-H 2.54mm Pitch Low insertion Force Crimp Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J Dual Row 2.54 1.30 3.50 A 5.90 A A2550H-2xXP,A2550HA-2xXP 0.20 Wide 15.10 1.40 CJT 1.30 4.00 CJT 12.70 B CJT B CJT SEC:A-A 1.45 1.40 SEC:B-B 1.20 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-H FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550-GP-H FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-479 A2550 SERIES A2550-T-CR 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch High Insertion Force Crimp Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J A2550H-2xXP,A2550HA-2xXP Dual Row 2.54 1.00 0.20 Narrow 10.00 3.46 1.10 1.60 2.54 2.59 0.85 1.25 12.70 1.20 15.29 1.40 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550-TP-CR FFC WIRE -------- Phosphor Bronze A2550-GP-CR FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550-T-H-CR 2.54mm Pitch Low insertion Force Crimp Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J 2.54 1.00 A2550H-2xXP,A2550HA-2xXP 0.20 Wide 2.59 0.85 1.25 12.70 1.20 15.29 1.40 10.00 3.46 1.10 1.60 2.54 Dual Row 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-H-CR FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550-GP-H-CR FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-480 A2550 SERIES A2550-T-A 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J 2.54 A2550H-2xXP,A2550HA-2xXP Dual Row 2.54 0.25 3.46 6.17 12.00 16.20±0.25 3.10 2.00 1.20 0.80 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. Material Finish Qty/reel Tin over Nickel 10,000 PCS Gold over Nickel 10,000 PCS A2550-TP-A FFC WIRE -------- Phosphor Bronze A2550-GP-A FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550-T-C 2.54mm Pitch Hi-Flex Crimp Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing *The Hi-Flex female contact designed to offer a stable insertion force and low contact resistance over larger number of mating cycles *More resistant to danage by bent or angled pins,primarily on test devices A2550H-XP,A2550HA-XP,A2550HB-XP,A2550H-XP-A Single Row A2550H-XP-B,A2550H-XP-C,A2550H-XP-C1,A2550H-XP-D A2550H-XP-E,A2550H-XP-F,A2550H-XP-J Dual Row 2.54 A2550H-2xXP,A2550HA-2xXP 2.10 0.20 1.20 2.59 0.85 12.70 1.25 15.30 0.39 1.30 10.00 3.48 3.17 1.00 1.35 1.70 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-C FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550-GP-C FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-481 A2550 SERIES A2550-T-D 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Designed for Soldering directly to Flexible PCB or Ultra Thin Rigged PCBs 1.00 2.54 0.20 12.10 9.50 1.10 2.54 1.70 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550-TP-D PCBs -------- Phosphor Bronze A2550-GP-D PCBs -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550-T-E 2.54mm pitch Crimp Flex Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing Single Row A2550H-XP-M A2550H-XP-M1 A2550H-XP-M2 A2550H-XP-MH A2550H-XP-M3 0.20 ∅1.50 2.80 2.54 1.85±0.10 16.80±0.25 2.10±0.20 0.22±0.06 SEC:A-A 6.45±0.20 13.00±0.25 1.68±0.20 0.63 A A 1.50±0.10 1.35±0.10 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-E FFC WIRE -------- Phosphor Bronze Tin over Nickel 15,000 PCS A2550-GP-E FFC WIRE -------- Phosphor Bronze Gold over Nickel 15,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-482 A2550 SERIES A2550-T-F 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire and Electronic wire 2.80±0.25 2.50 3.20±0.25 0.25 5.08 1.90 2.10±0.25 SEC: A-A A 2.00±0.25 13.00±0.25 SEC: B-B 2.00±0.20 B 13.70±0.25 B 2.60 A 1.80±0.20 C C SEC: C-C 1.60±0.10 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-F FFC WIRE/AWG#20-#26 1.80mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS A2550-GP-F FFC WIRE/AWG#20-#26 1.80mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Optional Gold plating available but MOQ requested A2550-T-J 2.54mm pitch Crimp Flex Terminal Use With CJT A2550 series Housing : Single Row Reference Informations: *Used in CJT A2550 series Housing A2550H-XP-G, A2550H-XP-H, A2550H-XP-I 5.08 2.54 1.54 1.75 4.10 12.00 1.85 5.45 Mating Area Crimp Area 18.00 3.44 0.25 Ordering Information: A2550-GP-J - *** 1 2 1.Part No. 2.Finish TG :Mating Area : 100μin (2.54μm) MIN. Tin Crimp Area: 1μin (0.025μm) MIN. Gold GT15 :Mating Area :15μin (0.38μm) MIN. Gold Crimp Area: 100μin (2.54μm) MIN. Tin GT30 :Mating Area :30μin (0.76μm) MIN. Gold Crimp Area: 100μin (2.54μm) MIN. Tin GT50 :Mating Area :50μin (1.27μm) MIN. Gold Crimp Area: 100μin (2.54μm) MIN. Tin GG15 :Mating Area :15μin (0.38μm) MIN. Gold Crimp Area: 1μin (0.025μm) MIN. Gold GG30 :Mating Area :30μin (0.76μm) MIN. Gold Crimp Area: 1μin (0.025μm) MIN. Gold GG50 :Mating Area :50μin (1.27μm) MIN. Gold Crimp Area: 1μin (0.025μm) MIN. Gold 0.80 0.30 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550-TP-J FFC WIRE -------- Phosphor Bronze Tin over Nickel 10,000 PCS A2550-GP-J FFC WIRE -------- Phosphor Bronze Gold over Nickel 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-483 A2550 SERIES A2550-T-K 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550HK series Housing A2550HK-XP Dual Row A2550HK-2xXP 2.54 0.20 0.90 3.06 5.98 1.80 11.81 16.56 2.50 3.10 1.20 2.90 2.54 Single Row 1.60 1.60 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550-TP-K FFC WIRE -------- Phosphor Bronze A2550-GP-K FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T 2.54mm pitch Crimp Flex Terminal Use With CJT A2550 series Housing : Reference Informations: *Used in CJT A2550 series Housing Single Row A2550H-XP, A2550H-XP-D Dual Row 2.54 0.25 3.00 2.54 A2550H-2xXP 1.75 13.30 18.80 23.00 1.66 1.05 6.60 1.40 0.64 0.64 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP FFC WIRE -------- Phosphor Bronze Tin over Nickel 10,000 PCS A2550M-GP FFC WIRE -------- Phosphor Bronze Gold over Nickel 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-484 A2550 SERIES A2550M-T-C 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 2.54 0.20 2.54±0.10 4.60 Ø1.25 Ø0.80±0.05 0.80 2.59 10.40 0.65 15.30 3.70 10.00 P.C.B LAYOUT 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550M-TP-C FFC WIRE -------- Phosphor Bronze A2550M-GP-C FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-CA 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 2.54 2.54±0.10 0.20 4.60 Ø1.25 Ø0.80±0.05 12.50 3.70 0.80 7.60 0.65 10.00 P.C.B LAYOUT 1.70 1.35 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-CA FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550M-GP-CA FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-485 A2550 SERIES A2550M-T-C1 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 2.54 0.20 2.54±0.10 4.60 Ø1.25 Ø0.80±0.05 10.00 15.30 0.40 0.80 2.59 10.40 0.65 3.70 1.40 1.70 P.C.B LAYOUT 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550M-TP-C1 FFC WIRE -------- Phosphor Bronze A2550M-GP-C1 FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-C1A 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 2.54±0.10 1.00 2.54 0.20 Ø0.80±0.05 4.60 Ø1.25 P.C.B LAYOUT 12.50 3.70 0.80 7.60 0.65 10.00 0.40 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-C1A FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550M-GP-C1A FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-486 A2550 SERIES A2550M-T-C2 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 2.54 0.20 2.54±0.10 4.60 Ø1.25 Ø0.80±0.05 10.00 0.80 15.30 10.40 2.59 0.40 0.65 3.70 1.70 P.C.B LAYOUT 0.60 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550M-TP-C2 FFC WIRE -------- Phosphor Bronze A2550M-GP-C2 FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-D 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in CJT A2550HM A2550HMA A2550H-M1 A2550H-M3 series Housing 2.54 2.54 0.20 1.50 21.58 25.01 1.75 8.40 1.40 0.64 0.64 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-D FFC WIRE -------- Phosphor Bronze Tin over Nickel 10,000 PCS A2550M-GP-D FFC WIRE -------- Phosphor Bronze Gold over Nickel 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-487 A2550 SERIES A2550M-T-E 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 1.15 5.08 2.54 0.25 5.80 3.25 3.70 Ø1.50 9.52 1.74 0.66 Unit:mm Ordering information & Specifications: Wire Range Part NO. Insulation O.D. Material Finish Qty/reel Tin over Nickel 10,000 PCS Gold over Nickel 10,000 PCS A2550M-TP-E FFC WIRE -------- Phosphor Bronze A2550M-GP-E FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-KE 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 1.15 5.08 2.54 0.25 5.15 3.25 3.70 Ø1.50 12.05 1.74 0.65 0.65 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-KE FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550M-GP-KE FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-488 A2550 SERIES A2550M-T-F 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 0.20 2.54 2.54±0.10 Ø0.80±0.05 0.65 1.35 5.60 3.90 1.35 15.25 13.10 P.C.B LAYOUT 1.30 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550M-TP-F FFC WIRE -------- Phosphor Bronze A2550M-GP-F FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-G 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 2.54 0.25 2.54±0.10 Ø0.80±0.05 2.00 P.C.B LAYOUT 9.40 1.80 3.60 1.50 0.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-G FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550M-GP-G FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-489 A2550 SERIES A2550M-T-J 2.54mm pitch FFC Crimp Flex connector 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 2.54 0.20 2.59 0.80 15.30 12.70 10.00 2.10 ∅1.25 1.35 1.70 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel Tin over Nickel 20,000 PCS Gold over Nickel 20,000 PCS A2550M-TP-J FFC WIRE -------- Phosphor Bronze A2550M-GP-J FFC WIRE -------- Phosphor Bronze Optional Gold plating available but MOQ requested A2550M-T-K 2.54mm pitch Crimp Flex Terminal Reference Informations: *Used in FFC Wire 2.54 1.00 0.20 2.10 2.54±0.10 2.60 2.54 ∅1.25 ∅0.80±0.05 0.64 2.59 0.80 15.30 12.70 10.00 6.00 P.C.B LAYOUT 0.64 1.70 1.35 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel A2550M-TP-K FFC WIRE -------- Phosphor Bronze Tin over Nickel 20,000 PCS A2550M-GP-K FFC WIRE -------- Phosphor Bronze Gold over Nickel 20,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-490 A2550 SERIES A2550H-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C, A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black Ordering Information: A2550H-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.54±0.10 A±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 14.00±0.25 CJT 7.30±0.20 2.50±0.10 B±0.25 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2550HH-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C, A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black 2.54±0.10 Ordering Information: A2550HH-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.50±0.10 14.00±0.25 CJTCONN B±0.25 7.30±0.20 A±0.20 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-491 A2550 SERIES A2550HA-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C,) *Mates with CJT A2549WVB,WRB-XP series Wafer *Color:Black Ordering Information: A2550HA-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. A±0.20 2.54±0.10 B±0.25 2.30 4.30±0.25 7.00±0.20 14.00±0.25 3.40±0.25 1.60 CJT 4.50±0.25 1.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550HB-XP 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550HB-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C,) *Mates with CJT A2549WVB,WRB-XP series Wafer *Color:Black PART NO. A±0.20 2.54±0.10 B±0.25 2.30 4.00±0.25 14.00±0.25 7.00±0.20 3.10±0.25 1.60 4.50±0.25 1.20 CJT Ordering Information & Dimensions: 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-492 A2550 SERIES A2550H-XP-A 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP,A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information: A2550H-XP-A - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 2.54±0.10 3P 2P A±0.20 4~25P 3.50±0.25 B±0.25 7.30±0.25 CJT 14.00±0.25 2.50 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-A1 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550H-XP-A1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP,A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information & Dimensions: PART NO. 2.54±0.10 A±0.20 2P 3P 4~25P B±0.25 3.50±0.25 7.30 14.00±0.25 2.50 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-493 A2550 SERIES A2550H-XP-A2 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550H-XP-A2 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP,A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information & Dimensions: PART NO. 2.54±0.10 2P A±0.20 3P 4P~25P 3.50±0.25 B±0.25 7.30±0.25 14.00±0.25 2.50 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-A2H 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP,A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information: A2550H-XP-A2H - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. 2.54±0.10 3P A±0.20 4P~25P 3.45±0.25 7.30±0.25 2.50 14.00±0.25 CJTCONN B±0.25 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-494 A2550 SERIES A2550H-XP-A3 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material: PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP,A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information & Dimensions: Ordering Information: A2550H-XP-A3 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.54±0.10 3P A±0.20 4P~25P 3.45±0.25 B±0.25 7.30±0.25 14.00±0.25 CJTCONN 2.50 PART NO. 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-A3H 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2550HM-XP, A2547HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Color:Black Ordering Information & Dimensions: Ordering Information: A2550H-XP-A3H - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ PART NO. 2.54±0.10 3P A±0.20 4P~25P 3.45±0.25 7.30±0.25 2.50 14.00±0.25 CJTCONN B±0.25 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-495 A2550 SERIES A2550H-XP-B 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550H-XP-B - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2547HMA-XP series Housing or A2547 series Wafer *Color:Black Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 2.54±0.10 2P A±0.20 4P~25P 3.50±0.25 2.50 7.30±0.25 14.00±0.25 B±0.25 CJT 3P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-BH 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2547HMA-XP series Housing or A2547 series Wafer *Color:Black Ordering Information: A2550H-XP-BH - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. 2.54±0.10 2P A±0.20 3P 4P~25P 3.45±0.25 7.30±0.25 2.50 14.00±0.25 CJTCONN B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-496 A2550 SERIES A2550H-XP-C 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR,A2550-T-A, A2550-T-C) *Mates with CJT A2547WVE,WRE-XP,A2549WV,WR-XP series Wafer *Color:Black Ordering Information & Dimensions: Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Ordering Information: A2550H-XP-C - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 3.68 2.50 PART NO. 2.54±0.10 A±0.20 B±0.25 7.30±0.25 CJT 14.00±0.25 2.15 3.10±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Unit: mm A2550H-XP-C1 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2547WVE,WRE-XP, A2549WV,WR-XP series Wafer *Color:Black Ordering Information: A2550H-XP-C1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: 3.68 2.50 PART NO. 2.54 A±0.20 B±0.25 7.30±0.25 4.50 CJT 14.00±0.25 2.15 3.10±0.25 C±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P A 2.54 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 Dimensions B 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 C 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 66.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-497 A2550 SERIES A2550H-XP-CH 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C) *Mates with CJT A2547WVE,WRE-XP,A2549WV,WR-XP series Wafer *Color:Black Ordering Information & Dimensions: PART NO. Ordering Information: A2550H-XP-CH - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ A±0.20 2.54±0.10 3.75 B±0.25 2.50 7.20 14.00±0.25 2.50 3.00 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-D 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal(A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550M-T, A2550-T-C) *Mates with CJT A2541 series Wafer *Color:Blue 2.54 A±0.20 2.50±0.25 CJT 14.00±0.25 5.50 B±0.25 Ordering Information: A2550H-XP-D - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ C±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B C 2.54 6.81 10.16 5.08 9.35 12.70 7.62 11.89 15.24 10.16 14.43 17.78 12.70 16.97 20.32 15.24 19.51 22.86 17.78 22.05 25.40 20.32 24.59 27.94 22.86 27.13 30.48 25.40 29.67 33.02 27.94 32.21 35.56 30.48 34.75 38.10 33.02 37.29 40.64 35.56 39.83 43.18 38.10 42.37 45.72 40.64 44.91 48.26 43.18 47.45 50.80 45.72 49.99 53.34 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B C 48.26 52.53 55.88 50.80 55.07 58.42 53.34 57.61 60.96 55.88 60.15 63.50 58.42 62.69 66.04 60.96 65.23 68.58 63.50 67.77 71.12 66.04 70.31 73.66 68.58 72.85 76.20 71.12 75.39 78.74 73.66 77.93 81.28 76.20 80.47 83.82 78.74 83.01 86.36 81.28 85.55 88.90 83.82 88.09 91.44 86.36 90.63 93.98 88.90 93.17 96.52 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-498 A2550 SERIES A2550H-XP-G 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2541 series Wafer *Color:Black B±0.25 Ordering Information: A2550H-XP-G - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 1.40 3.30 13.72±0.25 CJT 2.54mm pitch FFC Crimp Flex connector Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 2.46 A±0.20 2.54±0.10 Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 PART NO. 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P Dimensions A B 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 63.50 65.88 66.04 68.42 68.58 70.96 73.50 71.12 73.66 76.04 76.20 78.58 78.74 81.12 81.28 83.66 83.82 86.20 Unit: mm A2550H-XP-G1 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2541 series Wafer *Color:Black B±0.25 1.40 3.30 13.72±0.25 CJT Ordering Information: A2550H-XP-G1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C Ordering Information & Dimensions: PART NO. 2.46 A±0.20 2.54 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 PART NO. 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P Dimensions A B 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 63.50 65.88 66.04 68.42 68.58 70.96 73.50 71.12 73.66 76.04 76.20 78.58 78.74 81.12 81.28 83.66 83.82 86.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-499 A2550 SERIES A2550H-XP-H 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2547 series Wafer *Color:Black 3.30 B±0.25 Ordering Information: A2550H-XP-H - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C Ordering Information & Dimensions: 6.99 1.40 13.72 CJT PART NO. A±0.20 2.46 Circuit 1 2.89 2.54±0.10 2.89 DETAL FOR 2 POSN ONLY 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P DETAL FOR 3 POSN ONLY 6.77 A2550H-XP-H1 Unit: mm 2.54mm Pitch Crimp Flex Housing 1.40 Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2547 series Wafer *Color:Black B±0.25 3.30 Ordering Information: A2550H-XP-H1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: A±0.20 6.99 CJT 13.72±0.25 PART NO. 2.46 Circuit 1 2.89 2.54±0.10 2.89 DETAL FOR 2 POSN ONLY 6.77 Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 DETAL FOR 3 POSN ONLY 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 45.72 48.10 48.26 50.64 53.18 50.80 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-500 A2550 SERIES A2550H-XP-H2 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2547 series Wafer *Color:Black 3.30 B±0.25 Ordering Information: A2550H-XP-H2 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C Ordering Information & Dimensions: 6.99 1.40 13.72 CJT PART NO. A±0.20 2.46 2.54±0.10 2.89 Circuit 1 2.89 DETAL FOR 2 POSN ONLY 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P DETAL FOR 3 POSN ONLY 6.77 A2550H-XP-I Unit: mm 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550H-XP-I - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2549 series Wafer or A2547WVE,WRE-XP series Wafer *Color:Black B±0.25 Ordering Information & Dimensions: 3.30 2.54 CJT 13.72±0.25 PART NO. 3.75 A±0.20 2.54±0.10 2.46 Circuit 1 1.00 Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-501 A2550 SERIES A2550H-XP-I1 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550H-XP-I1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-J) *Mates with CJT A2549 series Wafer or A2547WVE,WRE-XP series Wafer *Color:Black B±0.25 A±0.20 3.75 2.54±0.10 2.46 Circuit 1 1.00 Ordering Information & Dimensions: PART NO. 2.54 CJT 13.72±0.25 3.30 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 4.92 5.08 7.46 7.62 10.00 10.16 12.54 12.70 15.08 15.24 17.62 17.78 20.16 20.32 22.70 22.86 25.24 25.40 27.78 27.94 30.32 30.48 32.86 33.02 35.40 35.56 37.94 38.10 40.48 40.64 43.02 43.18 45.56 45.72 48.10 48.26 50.64 50.80 53.18 53.34 55.72 55.88 58.26 58.42 60.80 60.96 63.34 Unit: mm A2550H-XP-J 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C, A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black Ordering Information: A2550H-XP-J - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. 2.54±0.10 A±0.20 B±0.25 2.54±0.25 7.00±0.20 14.00±0.25 1.30±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-502 A2550 SERIES A2550HD-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Mates with CJT A2541 series Wafer *Used in FFC Wire *Color:Blue Ordering Information: A2550HD-XP - *** - * 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel B±0.25 A±0.20 2.54±0.10 Ordering Information & Dimensions: 12.40±0.25 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 15.60±0.25 14.30±0.25 2.54±0.20 Dimensions A B 2.54 10.08 5.08 12.62 7.62 15.16 10.16 17.70 12.70 20.24 15.24 22.78 17.78 25.32 20.32 27.86 22.86 30.40 25.40 32.94 27.94 35.48 30.48 38.02 33.02 40.56 35.56 43.10 38.10 45.64 40.64 48.18 43.18 50.72 45.72 53.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 55.80 50.80 58.34 53.34 60.88 55.88 63.42 58.42 65.96 60.96 68.50 63.50 71.04 66.04 73.58 68.58 76.12 78.66 71.12 73.66 81.20 76.20 83.74 78.74 86.28 81.28 88.82 83.82 91.36 86.36 93.90 88.90 96.44 Unit: mm A2550HDM-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Used in FFC Wire *Color:Blue Ordering Information: A2550HDM-XP - *** - * 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel A±0.20 12.70±0.25 2.54±0.10 Ordering Information & Dimensions: PART NO. B±0.25 21.34±0.25 14.22±0.25 15.49±0.25 2.54±0.20 PIN 0.64 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B 2.54 9.91 5.08 12.45 7.62 14.99 10.16 17.53 12.70 20.07 15.24 22.61 17.78 25.15 20.32 27.69 22.86 30.23 25.40 32.77 27.94 35.31 30.48 37.85 33.02 40.39 35.56 42.93 38.10 45.47 40.64 48.01 43.18 50.55 45.72 53.09 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 55.63 50.80 58.17 53.34 60.71 55.88 63.25 58.42 65.79 60.96 68.33 63.50 70.87 66.04 73.41 68.58 75.95 78.49 71.12 73.66 81.03 76.20 83.57 78.74 86.11 81.28 88.65 83.82 91.19 86.36 93.73 88.90 96.27 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-503 A2550 SERIES A2550HE-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Mates with CJT A2541WV,WR-XP, A2549WVB,WRB-XP series Wafer *Used in FFC Wire *Color:Blue Ordering Information: A2550HE-XP - *** - * 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel B±0.25 A±0.20 2.54±0.10 Ordering Information & Dimensions: 15.40±0.25 PART NO. 3.00 15.60±0.25 2.54 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P Dimensions A B 2.54 10.08 5.08 12.62 7.62 15.16 10.16 17.70 12.70 20.24 15.24 22.78 17.78 25.32 20.32 27.86 22.86 30.40 25.40 32.94 27.94 35.48 30.48 38.02 33.02 40.56 35.56 43.10 38.10 45.64 40.64 48.18 43.18 50.72 PART NO. 19P 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P Dimensions A B 45.72 53.26 48.26 55.80 50.80 58.34 53.34 60.88 55.88 63.42 58.42 65.96 60.96 68.50 63.50 71.04 66.04 73.58 68.58 76.12 78.66 71.12 73.66 81.20 76.20 83.74 78.74 86.28 81.28 88.82 83.82 91.36 Unit: mm A2550HF-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Mates with CJT A2547HM-XP, A2550HM-XP series Housing or A2547WVA,WRA-XP series Wafer *Used in FFC Wire *Color:Blue Ordering Information: A2550HF-XP - *** - * 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel B±0.25 A±0.20 2.54±0.10 CJTCONN 12.40±0.25 Ordering Information & Dimensions: PART NO. 2.54 15.60±0.25 1.26 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 12.70 20.24 15.24 22.78 17.78 25.32 20.32 27.86 22.86 30.40 25.40 32.94 27.94 35.48 30.48 38.02 33.02 40.56 35.56 43.10 38.10 45.64 40.64 48.18 43.18 50.72 45.72 53.26 48.26 55.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P Dimensions A B 50.80 58.34 53.34 60.88 55.88 63.42 58.42 65.96 60.96 68.50 63.50 71.04 66.04 73.58 68.58 76.12 78.66 71.12 73.66 81.20 76.20 83.74 78.74 86.28 81.28 88.82 83.82 91.36 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-504 A2550 SERIES A2550HG-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Mates with CJT A2547HM-XP, A2550HM,HMA-XP series Housing or A2547WVA,WRA-XP series Wafer *Used in FFC Wire *Color:Blue Ordering Information: A2550HG-XP - *** - * 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel B±0.25 A±0.20 2.54±0.10 Ordering Information & Dimensions: PART NO. 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 2.54 15.60±0.25 1.26 Dimensions A B 12.70 20.24 15.24 22.78 17.78 25.32 20.32 27.86 22.86 30.40 25.40 32.94 27.94 35.48 30.48 38.02 33.02 40.56 35.56 43.10 38.10 45.64 40.64 48.18 43.18 50.72 45.72 53.26 48.26 55.80 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P Dimensions A B 50.80 58.34 53.34 60.88 55.88 63.42 58.42 65.96 60.96 68.50 63.50 71.04 66.04 73.58 68.58 76.12 78.66 71.12 73.66 81.20 76.20 83.74 78.74 86.28 81.28 88.82 83.82 91.36 Unit: mm A2550HK-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-K) *Color:Blue Ordering Information: A2550HK-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.54±0.10 Ordering Information & Dimensions: A±0.20 PART NO. 8P~36P B±0.25 2P~7P 13.85±0.25 7.20±0.25 14.10±0.25 2.66 3.80±0.25 3.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 83.82 81.28 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-505 A2550 SERIES A2550HL-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C, A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black 2.54±0.10 2.54mm pitch FFC Crimp Flex connector A2550 Terminal FFC/FPC A2550HL-XP Ordering Information: A2550HL-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. A±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 2.50±0.15 6.70±0.25 B±0.25 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 20P 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 83.82 81.28 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2550H-XP-M 2.54mm Pitch Housing With Lock Reference Informations: *Material:PBT30%GF , UL94V-0 *Suitable CJT A2550-T-E series Terminal *Mates with CJT A2547HM-XP A2550HM-XP series Housing or A2547 series single row Wafer *Color:Black Ordering Information: A2550H-XP-M - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. Circuit 1 2.54±0.10 2P 3P A±0.20 4P~25P 3.51±0.20 B±0.25 7.30±0.20 CJTCONN 15.24±0.25 2.51±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-506 A2550 SERIES A2550H-XP-M1 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Housing Reference Informations: *Material:PBT30%GF , UL94V-0 *Suitable CJT A2550-T-E, A2550M-T-D series Terminal *Mates with CJT A2547WV,WR-XP, A2547WVA,WRA-XP series single row Wafer *Color:Black Ordering Information & Dimensions: PART NO. 2.54±0.10 Circuit 1 7.30±0.20 CJTCONN 15.24±0.25 A±0.20 Ordering Information: A2550H-XP-M1 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.54±0.10 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-XP-M2 2.54mm Pitch Housing Reference Informations: *Material:PBT30%GF , UL94V-0 *Suitable CJT A2550-T-E series Terminal *Mates with CJT A2547WV,WR-XP, A2547WVA,WRA-XP series single row Wafer *Color:Black Ordering Information: A2550H-XP-M2 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. 2.54±0.10 2P 3P A±0.20 B±0.25 15.24±0.20 CJTCONN 15.24±0.25 4P~25P 2.54±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-507 A2550 SERIES A2550H-XP-M3 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Housing Ordering Information: A2550H-XP-M3 - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT30%GF , UL94V-0 *Suitable CJT A2550-T-E,A2550M-T-D series Terminal *Color:Black Ordering Information & Dimensions: PART NO. 2.54±0.10 3P 2P A±0.20 4P~25P B±0.25 7.30±0.20 CJTCONN 3.80±0.10 15.24±0.25 2.54±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 3.54±0.20 A2550H-XP-MH Unit: mm 2.54mm Pitch Housing With Lock Reference Informations: *Material:PBT30%GF , UL94V-0 *Suitable CJT A2550-T-E series Terminal *Mates with CJT A2547HM-XP A2550HM-XP series Housing or A2547 series single row Wafer *Color:Black Ordering Information: A2550H-XP-MH - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. Circuit 1 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 2.54±0.10 2P 3P A±0.20 4P~25P 3.51±0.20 B±0.25 7.30±0.20 CJTCONN 15.24±0.25 2.51±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-508 A2550 SERIES A2550HH-N-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR, A2550-T-A, A2550-T-C, A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black Ordering Information & Dimensions: A±0.20 Ordering Information: A2550HH-N-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ 2.54±0.10 3.28 2.50±0.10 B±0.25 7.30±0.20 14.00±0.25 CJTCONN 3.02 1.00 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550HM-XP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550M-T-D series Terminal *Mates with CJT A2550 series Housing (A2550H-XP-A, A2550H-XP-A1,A2550H-XP-A2,A2550H-XP-H,A2547H,HA-XP) *Color:Black Ordering Information: A2550HM-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: A±0.20 2.54±0.10 PART NO. 7.12 3P 2P 4P~25P 6.70±0.25 B±0.25 4.60 6.50 14.40±0.25 24.40±0.25 CJTCONN 8.90±0.25 2.98 3.00 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 2.54 7.12 5.08 9.66 7.62 12.20 10.16 14.74 12.70 17.28 15.24 19.82 17.78 22.36 20.32 24.90 22.86 27.44 25.40 29.98 27.94 32.52 30.48 35.06 33.02 37.60 35.56 40.14 38.10 42.68 40.64 45.22 43.18 47.76 45.72 50.30 48.26 52.84 55.38 50.80 53.34 57.92 55.88 60.46 58.42 63.00 60.96 65.54 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-509 A2550 SERIES A2550HMA-XP Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550M-T-D series Terminal *Mates with CJT A2550H-XP-B, A2547H-XP-3 series Housing *Color:Black 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Ordering Information: A2550HMA-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: A±0.20 PART NO. 2.54±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P 2P 3P 4P~25P B±0.25 2.98 6.50 14.40±0.25 24.40±0.25 8.90 CJTCONN 4.60±0.25 3.00 A2550H-2xXP Unit: mm 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR,A2550-T-A,A2550-T-C,A2550M-T) *Mates with CJT A2541 series Wafer *Color:Black Ordering Information: A2550H-2xXP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: 2.54 PART NO. 2.54±0.10 A±0.20 B±0.25 7.00±0.25 14.00±0.25 4.50 5.80±0.25 1.60 CJT Dimensions A B 2.54 7.12 5.08 9.66 7.62 12.20 10.16 14.74 12.70 17.28 15.24 19.82 17.78 22.36 20.32 24.90 22.86 27.44 25.40 29.98 27.94 32.52 30.48 35.06 33.02 37.60 35.56 40.14 38.10 42.68 40.64 45.22 43.18 47.76 45.72 50.30 48.26 52.84 50.80 55.38 53.34 57.92 55.88 60.46 58.42 63.00 60.96 65.54 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-510 A2550 SERIES A2550HA-2xXP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR,A2550-T-A,A2550-T-C) *Mates with CJT A2549WVB,WRB-2xXP series Dual Row Wafer *Color:Black Ordering Information: A2550HA-2xXP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: 2.54 PART NO. 2.54±0.10 A±0.20 B±0.25 14.00±0.25 7.00±0.25 1.60 CJT 4.50 6.90±0.25 5.80±0.25 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm A2550H-N-2xXP 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T(-H), A2550-T(-H)-CR,A2550-T-A,A2550-T-C,A2550M-T) *Mates with CJT A2541 series Wafer or A2547WV,WR-2xXP series Wafer *Color:Black Ordering Information: A2550H-N-2xXP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: 2.54 PART NO. 2.54±0.10 A±0.20 B±0.25 5.80±0.25 14.00±0.25 7.00±0.25 1.60 CJT 3.05 1.00 4.50 3.23 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 48.26 50.80 53.34 50.80 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-511 A2550 SERIES A2550HK-2xXP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Housing Reference Informations: *Material:PBT30%GF,UL94V-0 *Suitable CJT A2550 series Terminal (A2550-T-K) *Color:Blue Ordering Information: A2550HK-2xXP - *** 1 2 1.Part No. 2.Material: (blank):PBT30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Ordering Information & Dimensions: 2.54±0.10 PART NO. A±0.20 2x8P~2x36P 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P B±0.25 13.85±0.25 7.20±0.25 14.10±0.25 2.66 6.34±0.25 2x2P~2x7P 5.64 Dimensions A B 2.54 5.08 5.08 7.62 7.62 10.16 10.16 12.70 12.70 15.24 15.24 17.78 17.78 20.32 20.32 22.86 22.86 25.40 25.40 27.94 27.94 30.48 30.48 33.02 33.02 35.56 35.56 38.10 38.10 40.64 40.64 43.18 43.18 45.72 45.72 48.26 PART NO. 2x20P 2x21P 2x22P 2x23P 2x24P 2x25P 2x26P 2x27P 2x28P 2x29P 2x30P 2x31P 2x32P 2x33P 2x34P 2x35P 2x36P Dimensions A B 48.26 50.80 50.80 53.34 53.34 55.88 55.88 58.42 58.42 60.96 60.96 63.50 63.50 66.04 66.04 68.58 68.58 71.12 73.66 71.12 73.66 76.20 76.20 78.74 78.74 81.28 81.28 83.82 83.82 86.36 86.36 88.90 88.90 91.44 Unit: mm A2550WVF-XP 2.54mm Pitch Crimp Flex Wafer Ordering Information: A2550WVF-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Color:Black A Ordering Information & Dimensions: 2.54 PART NO. ∅0.85 P.C.B LAYOUT C A 1.27 5.00 2.54 2.54±0.10 A±0.20 FPC/FFC T=0.30 B±0.25 0.52 0.17 2.80±0.20 6.70±0.25 4.50±0.25 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P A 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 Dimensions B 13.04 15.58 18.12 20.66 23.20 25.74 28.28 30.82 33.36 35.90 38.44 40.98 43.52 46.06 48.60 51.14 53.68 56.22 58.76 61.30 63.84 66.38 68.92 C 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 66.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-512 A2550 SERIES A2550WRF-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Wafer Ordering Information: A2550WRF-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ Reference Informations: *Material:PBT,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Color:Black Ordering Information & Dimensions: A 2.54 PART NO. Ø0.85 P.C.B LAYOUT C A 2.54 5.00 2.54±0.10 1.27 0.62 A±0.20 FPC/FFC T=0.30 B±0.25 0.15 6.70±0.25 4.50±0.25 3.20±0.20 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P A 5.08 7.62 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 Dimensions B 13.04 15.58 18.12 20.66 23.20 25.74 28.28 30.82 33.36 35.90 38.44 40.98 43.52 46.06 48.60 51.14 53.68 56.22 58.76 61.30 63.84 66.38 68.92 C 10.16 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 66.04 Unit: mm A2550WVFD-F-XP 2.54mm Pitch Crimp Flex Wafer Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Color:White Ordering Information: A2550WVFD-F-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ Ordering Information & Dimensions: PART NO. A±0.20 B±0.25 0.80 2.54±0.10 2.90 Ø1.50 9.55±0.25 4.40 Circuit 1 2.54±0.10 W0.60*T0.40 13.25±0.25 11.80±0.25 3.00±0.20 7.80±0.25 4.10±0.20 7.50±0.25 A±0.20 14.00±0.25 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 9.34 ---2.54 11.88 5.08 14.42 7.62 16.96 10.16 19.50 12.70 22.04 15.24 24.58 17.78 27.12 20.32 29.66 22.86 32.20 25.40 34.74 27.94 37.28 30.48 39.82 33.02 42.36 35.56 44.90 38.10 47.44 40.64 49.98 43.18 52.52 45.72 55.06 48.26 57.60 50.80 60.14 53.34 62.68 55.88 65.22 58.42 67.76 60.96 70.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-513 A2550 SERIES A2550WRFD-XP 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch Crimp Flex Wafer Reference Informations: *Material:Nylon 66,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Color:White Ordering Information: A2550WRFD-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750℃ A±0.25 B±0.25 2.90 2.54±0.10 ∅1.50 9.55±0.25 4.40 0.80 Circuit 1 2.54±0.10 A±0.20 13.25±0.25 2.60±0.20 7.80±0.25 4.10±0.20 7.50±0.25 11.80±0.25 10.00±0.25 14.00±0.25 Ordering Information & Dimensions: PART NO. 1P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 25P Dimensions A B 9.34 ---2.54 11.88 5.08 14.42 7.62 16.96 10.16 19.50 12.70 22.04 15.24 24.58 17.78 27.12 20.32 29.66 22.86 32.20 25.40 34.74 27.94 37.28 30.48 39.82 33.02 42.36 35.56 44.90 38.10 47.44 40.64 49.98 43.18 52.52 45.72 55.06 48.26 57.60 50.80 60.14 53.34 62.68 55.88 65.22 58.42 67.76 60.96 70.30 Unit: mm A2550WVFC-F-XP 2.54mm Pitch Crimp Flex Wafer Reference Informations: *Material:PBT,UL94V-0 *Terminal Material:Phosphor Bronze/Tin over Nickel *Color:Blue 2.62±0.05 3 4 5 6 7 8 9 1 ∅1.00±0.05 0.27±0.05 2.54±0.10 5.80±0.20 5.50±0.20 2 D±0.20 C±0.25 Ordering Information: A2550WVFC-F-XP - *** 1 2 1.Part No. 2.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750℃ ∅1.70±0.05 P.C.B LAYOUT ∅1.50 2.54±0.10 4.40±0.20 A±0.20 10.40±0.25 12.50±0.25 8.70±0.20 3.20±0.20 1.30 B±0.25 Ordering Information & Dimensions: PART NO. 8P 9P 10P 11P 12P 13P A 17.78 20.32 22.86 25.40 27.94 30.48 Dimensions B C 30.34 23.12 32.88 25.66 35.42 28.20 37.96 30.74 40.50 33.28 43.04 35.82 D 10.16 12.70 15.24 17.78 20.32 22.86 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-514 A2550 SERIES A2550HXXP-L-01 2.54mm pitch FFC Crimp Flex connector 2.54mm Pitch FFC Cable L CN1 CN2 P1 CJT P1 CJT 1 3 2 4 FFC 2.54 0.1x1.27mm CN1 CN2 3 1 Terminal 2 4 Housing A2550H,HA,HB-XP A2550H-XP-A,A2550H-XP-A1 A2550-T A2550-T-H A2550-T-CR A2550-T-H-CR A2550-T-A A2550-T-C A2550H-XP-A2,A2550H-XP-A2H A2550H-XP-A3H,A2550H-XP-B A2550H-XP-BH A2550H-XP-C,A2550H-XP-C1 A2550H-XP-D,A2550H-XP-E A2550H-XP-F,A2550H-XP-J A2550H,HA-2xXP A2550H-XP-M,A2550H-XP-M1 A2550-T-E A2550H-XP-M2,A2550H-XP-M3 A2550H-XP-G,A2550H-XP-G1 A2550-T-J A2550H-XP-H,A2550H-XP-H1 A2550H-XP-I,A2550H-XP-I1 A2550-T-K A2550HK-XP,A2550HK-2xXP A2550H-XP,A2550H-XP-D A2550M-T A2550H-XP-J,A2550H-2xXP Unit: mm A2550HXXPA2550MXX-L-01 2.54mm Pitch FFC Cable L CN1 CJT CN2 P1 1 3 2 FFC 2.54 0.1x1.27mm CN1 1 Terminal CN2 2 Housing 3 Terminal A2550H,HA,HB-XP A2550H-XP-A,A2550H-XP-A1 A2550-T A2550-T-H A2550-T-CR A2550-T-H-CR A2550-T-A A2550-T-C A2550H-XP-A2,A2550H-XP-A2H A2550H-XP-A3H,A2550H-XP-B A2550H-XP-BH A2550H-XP-C,A2550H-XP-C1 A2550H-XP-D,A2550H-XP-E A2550H-XP-F,A2550H-XP-J A2550H,HA-2xXP A2550H-XP-M,A2550H-XP-M1 A2550-T-E A2550H-XP-M2,A2550H-XP-M3 A2550H-XP-G,A2550H-XP-G1 A2550-T-J A2550M-T-C, A2550M-T-CA A2550M-T-C1, A2550M-T-C1A A2550M-T-C2, A2550M-T-E A2550M-T-KE, A2550M-T-F A2550M-T-G, A2550MA-T-G A2550M-T-J, A2550M-T-K A2550H-XP-H,A2550H-XP-H1 A2550H-XP-I,A2550H-XP-I1 A2550-T-K A2550HK-XP,A2550HK-2xXP A2550H-XP,A2550H-XP-D A2550M-T A2550H-XP-J,A2550H-2xXP Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-515
A2550-TP-J
1. 物料型号:A2550系列,包括多种型号,如A2550-T(高插入力压接端子),A2550-T-H(低插入力压接端子),A2550-T-CR(高插入力压接端子),等。
2. 器件简介:A2550系列提供2.54mm间距的FFC压接式连接器,设计用于满足不同的电气和机械性能需求。
3. 引脚分配:文档中提供了多种配置的引脚分配,包括单排和双排配置,例如A2550H-XP、A2550HA-XP、A2550HB-XP等。
4. 参数特性: - 电流额定值:3A AC/DC - 电压额定值:300V AC/DC - 温度范围:-40°C至+105°C - 接触电阻:最大5mΩ - 绝缘电阻:最小1000MΩ - 耐电压:1100V AC/分钟
5. 功能详解:A2550系列连接器设计用于FFC线缆,提供高插入力和低插入力的压接端子选项,以适应不同的应用需求。
6. 应用信息:适用于需要FFC连接的应用,如电子设备中的柔性电路板连接。
7. 封装信息:提供了多种封装选项,包括不同的压接端子和外壳,以适应不同的线缆和应用需求。
8. 其他信息: - 符合RoHS和REACH标准。 - 提供无卤素和低烟产品,需要定制。 - 提供金层压接端子选项,但需要最小订购量。
9. 订购信息:提供了详细的订购指南和规格,包括部件编号、线缆范围、绝缘外径、材料、表面处理和每卷数量。
10. 联系方式:提供了制造商的联系电话、传真和网址。
A2550-TP-J 价格&库存
很抱歉,暂时无法提供与“A2550-TP-J”相匹配的价格&库存,您可以联系我们找货
A2550-TP-J
  • 1+0.13775
  • 30+0.13300
  • 100+0.12350
  • 500+0.11400
  • 1000+0.10925
