A3961WV-10P
A3961WV-10P
    CJT(长江连接器)
    插件,P=3.96mm
    线对板连接器 10Pin(1x10P) P=3.96mm 直插
A3961WV-10P 数据手册
A3961 SERIES 3.96~7.92mm pitch wire to board connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10m Max. Insulation resistance:1000M Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 10.20 REF. 2.00 19.20 REF. 10.20 REF. 1.60 1.60 2.00 1.60 10.30 REF. 1.60 2.00 19.20 REF. 6.30 2.00 E326732 16.57 REF. 24.60 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-526 A3961 SERIES A3961-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3961H-XP,A3961H-XP-2,A3961H-XP-3, A5081H-XP series Housing ∅1.90 3.16±0.25 0.25 2.40±0.20 7.00±0.20 3.45±0.25 A SEC:A-A 2.85±0.10 2.10±0.25 5.50±0.20 B 6.20±0.20 13.60±0.25 B 2.30 A 2.55±0.25 SEC:B-B 1.85±0.10 5.00±0.20 Unit:mm Ordering information & Specifications: Wire Range Part NO. A3961-TB A3961-TP A3961-GB A3961-GP Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Material Brass Phosphor Bronze Insulation O.D. 2.80mm(max) 2.80mm(max) 2.80mm(max) 2.80mm(max) AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Brass Phosphor Bronze Qty/reel 6,000 PCS 6,000 PCS 6,000 PCS 6,000 PCS Optional Gold plating available but MOQ requested A3961-T-1 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3961H-XP,A3961H-XP-2,A3961H-XP-3, A5081H-XP series Housing 3.50±0.25 0.25 B 2.70±0.15 SEC:A-A 0.80 1.42±0.10 2.30±0.25 B 13.40±0.25 A 6.00±0.25 A 2.30 2.20 3.70±0.25 2.30±0.25 SEC:B-B Unit:mm Ordering information & Specifications: Part NO. A3961-TB-1 A3961-TP-1 A3961-GB-1 A3961-GP-1 Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Insulation O.D. 2.80mm(max) 2.80mm(max) 2.80mm(max) 2.80mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 6,000 PCS 6,000 PCS 6,000 PCS 6,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-527 A3961 SERIES A3961H-XP 3.96mm pitch wire to board connector 3.96mm pitch Housing Ordering Information: A3961H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961-T(-1) series Terminal *Mates with CJT A3961WV,WR,WVA,WRA-XP(-A), A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB,WVC,WRC-XP series Wafer *Color:Natural Ordering Information & Dimensions: PART NO. Circuit 1 3.96±0.10 A±0.20 B±0.25 16.00±0.25 7.70±0.25 6.30±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 8.43 7.92 12.39 11.88 16.35 15.84 20.31 19.80 24.27 23.76 28.23 32.19 27.72 31.68 36.15 35.64 40.11 39.60 44.07 43.56 48.03 47.52 51.99 51.48 55.95 55.44 59.91 59.40 63.87 63.36 67.83 67.32 71.79 71.28 75.75 75.24 79.71 79.20 83.67 83.16 87.63 87.12 91.59 91.08 95.55 Unit: mm A3961H-XP-2 3.96mm pitch Housing Ordering Information: A3961H-XP-2 - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961-T(-1) series Terminal *Mates with CJT A3961WV,WR,WVA,WRA-XP(-A), A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB,WVC,WRC-XP series Wafer *Color:Natural Circuit 1 Ordering Information & Dimensions: PART NO. 3.96±0.10 A±0.20 6.30±0.25 16.00±0.25 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 8.43 7.92 12.39 11.88 16.35 15.84 20.31 19.80 24.27 23.76 28.23 32.19 27.72 31.68 36.15 35.64 40.11 39.60 44.07 43.56 48.03 47.52 51.99 51.48 55.95 55.44 59.91 59.40 63.87 63.36 67.83 67.32 71.79 71.28 75.75 75.24 79.71 83.67 79.20 83.16 87.63 87.12 91.59 91.08 95.55 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-528 A3961 SERIES A3961H-XP-3-V0 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3961-T(-1) series Terminal *Mates with CJT A3961WVA,WRA-XP(-A), A3961WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB-XP,D3961WV,WR-XP series Wafer *Color:Natural Ordering Information: A3961H-XP-3 - *** 1 2 1.Part No. 2.Material: V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information & Dimensions: Circuit 1 Dimensions A B 3.96 8.43 7.92 12.39 11.88 16.35 15.84 20.31 19.80 24.27 23.76 28.23 32.19 27.72 31.68 36.15 35.64 40.11 39.60 44.07 43.56 48.03 47.52 51.99 51.48 55.95 55.44 59.91 59.40 63.87 63.36 67.83 67.32 71.79 71.28 75.75 75.24 79.71 79.20 83.67 83.16 87.63 87.12 91.59 91.08 95.55 PART NO. 3.96±0.10 A±0.20 8.30±0.25 16.00±0.25 B±0.25 6.30±0.25 A3961WV-XP 3.96±0.10 ∅1.80±0.05 P.C.B LAYOUT Circuit 1 Ordering Information & Dimensions: Ordering Information: A3961WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.60 11.30±0.20 3.20±0.20 5.60±0.20 B±0.25 17.50±0.25 A±0.20 Unit: mm 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural 3.96±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P PIN 1.14 SQ 10.20±0.20 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 8.43 7.92 12.39 11.88 16.35 15.84 20.31 19.80 24.27 23.76 28.23 32.19 27.72 31.68 36.15 35.64 40.11 39.60 44.07 43.56 48.03 47.52 51.99 51.48 55.95 55.44 59.91 59.40 63.87 63.36 67.83 67.32 71.79 71.28 75.75 75.24 79.71 83.67 79.20 83.16 87.63 87.12 91.59 91.08 95.55 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-529 A3961 SERIES A3961WR-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer 3.96±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural ∅1.80±0.05 P.C.B LAYOUT Circuit 1 Ordering Information & Dimensions: Ordering Information: A3961WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 20 3.96±0.10 A±0.20 5.60±0.20 3.20±0.20 5.40±0.20 18.80±0.25 11.30±0.20 B±0.25 3.60±0.20 PIN 1.14 SQ A3961WVA-XP Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 79.20 83.16 83.16 87.12 87.12 91.08 91.08 95.04 PART NO. 10.20±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Unit: mm 3.96mm pitch 180° Wafer 3.96±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:Natural ∅1.80±0.05 P.C.B LAYOUT 6.35±0.25 Ordering Information & Dimensions: 3.96±0.10 A±0.20 Ordering Information: A3961WVA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.20±0.20 3.60±0.20 17.50±0.25 B±0.25 PIN 1.14 SQ PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 83.16 79.20 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-530 A3961 SERIES A3961WRA-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer 3.96±0.10 6.35±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:Natural 3.96±0.10 ∅1.80±0.25 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. Ordering Information: A3961WRA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel A±0.20 8.50±0.20 3.60 8.10±0.20 3.20±0.20 B±0.25 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 79.20 83.16 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm A3961WV-XP-R 3.96mm pitch 180° Wafer, Round PIN 3.96±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural ∅1.57±0.05 P.C.B LAYOUT Circuit 1 5.60±0.20 17.50±0.25 11.30±0.25 B±0.25 3.20±0.20 A±0.20 3.60±0.20 3.96±0.10 Ordering Information & Dimensions: Ordering Information: A3961WV-XP-R - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 10.20±0.20 PIN 1.14 ROUND PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 83.16 79.20 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-531 A3961 SERIES A3961WVA-XP-R 3.96mm pitch wire to board connector 3.96mm pitch 180° Wafer, Round PIN 3.96±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:Natural ∅1.57±0.05 P.C.B LAYOUT 3.96±0.10 A±0.20 Ordering Information: A3961WVA-XP-R - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.60±0.20 17.50±0.25 B±0.25 PART NO. 3.20±0.20 6.35±0.20 Ordering Information & Dimensions: PIN 1.14 ROUND 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 79.20 83.16 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm A3961WV-XP-A 7.92mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural Circuit 1 Ordering Information: A3961WV-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.92±0.10 ∅1.80±0.05 7.92±0.10 P.C.B LAYOUT A±0.20 5.60±0.20 B±0.25 Ordering Information & Dimensions: 3.20±0.20 3.60±0.20 17.50±0.25 11.30±0.20 PART NO. PIN 1.14 SQ 10.20±0.20 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-532 A3961 SERIES A3961WR-XP-A 7.92mm pitch wire to board connector 7.92mm pitch 90° Wafer Ordering Information: A3961WR-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural Circuit 1 7.92±0.10 20 ∅1.80±0.05 7.92±0.10 P.C.B LAYOUT A±0.20 5.60±0.20 B±0.25 3.20±0.20 PART NO. 3.60±0.20 PIN 1.14 SQ A3961WVA-XP-A 5.40±0.20 18.80±0.25 11.30±0.20 Ordering Information & Dimensions: 10.20±0.20 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm 7.92mm pitch 180° Wafer Ordering Information: A3961WVA-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.35±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:Natural 7.92±0.10 7.92±0.10 ∅1.80±0.05 A±0.20 P.C.B LAYOUT B±0.25 3.20±0.20 3.60±0.20 17.50±0.25 Ordering Information & Dimensions: PIN 1.14 SQ PART NO. 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-533 A3961 SERIES A3961WRA-XP-A 7.92mm pitch wire to board connector 7.92mm pitch 90° Wafer Ordering Information: A3961WRA-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.35±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:Natural 7.92±0.10 ∅1.80±0.05 7.92±0.10 P.C.B LAYOUT A±0.20 Ordering Information & Dimensions: 8.50±0.20 3.20±0.20 8.10±0.20 3.60±0.20 B±0.25 PIN 1.14 SQ PART NO. 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm A3961WV-XP-R-A 7.92mm pitch 180° Wafer Ordering Information: A3961WV-XP-R-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural Circuit 1 7.92±0.10 ∅1.57±0.05 7.92±0.10 A±0.20 P.C.B LAYOUT B±0.25 5.60±0.20 Ordering Information & Dimensions: 3.20±0.20 3.60±0.20 17.50±0.25 11.30±0.25 PART NO. 10.20±0.20 PIN 1.14 ROUND 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-534 A3961 SERIES A3961WVA-XP-R-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer Ordering Information: A3961WVA-XP-R-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.35±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961H-XP-2 or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Natural 7.92±0.10 7.92±0.10 A±0.20 Ø1.80±0.05 P.C.B LAYOUT B±0.25 PART NO. 3.20±0.20 3.60±0.20 17.50±0.25 Ordering Information & Dimensions: 3P 5P 7P 9P 11P 13P 15P 17P 19P PIN 1.14 ROUND Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 Unit: mm A3961WVB-XP 3.96mm pitch 180° Wafer Ordering Information: A3961WVB-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.10 10.20±0.20 7.20±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:White Ø1.80±0.05 Ordering Information & Dimensions: PART NO. P.C.B LAYOUT 3.96±0.10 Circuit 1 A±0.20 5.60±0.20 B±0.25 3.56±0.20 +0 11.43-0.25 3.20±0.20 1.60±0.20 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 55.44 51.48 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-535 A3961 SERIES A3961WVB-F-XP 3.96mm pitch wire to board connector 3.96mm pitch 180° Wafer 7.20±0.20 10.20±0.20 4.24±0.10 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:White 3.96±0.10 Ø1.80±0.05 Ordering Information & Dimensions: PART NO. Ø1.63±0.05 1.98±0.05 3.96±0.10 Circuit 1 A±0.20 Ordering Information: A3961WVB-F-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel P.C.B LAYOUT 5.60±0.20 B±0.25 3.56±0.20 2.60±0.20 3.20±0.20 +0 11.43-0.25 1.60±0.20 4.20±0.20 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 55.44 51.48 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 Unit: mm A3961WRB-XP 3.96mm pitch 90° Wafer 3.96±0.10 Ordering Information: A3961WRB-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):White BK:Black 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 10.20±0.20 7.20±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:White Circuit 1 3.96±0.10 A±0.20 5.60±0.20 1.60±0.20 +0 11.43-0.25 5.41±0.20 3.20±0.20 B±0.25 PIN 1.14 SQ 3.96±0.20 Ø1.80±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 83.16 79.20 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-536 A3961 SERIES A3961WRB-F-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer 10.20±0.20 Circuit 1 Ordering Information: A3961WRB-F-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Ordering Information & Dimensions: PART NO. 3.96±0.10 Ø1.80±0.05 6.07±0.10 7.20±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:White 3.96±0.10 1.98±0.05 P.C.B LAYOUT A±0.20 5.60±0.20 1.60±0.20 6.07±0.20 5.41±0.25 3.20±0.20 +0 11.43-0.25 B±0.25 Ø1.63±0.05 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P 3.96±0.20 A3961WRB-F-L-XP Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 79.20 83.16 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm 3.96mm pitch 90° Wafer Ordering Information: A3961WRB-F-L-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.10 Ø1.80±0.05 Circuit 1 1.98±0.05 3.96±0.10 Ø1.63±0.05 P.C.B LAYOUT A±0.20 +0 3.68±0.25 4.34±0.20 3.20±0.20 11.43-0.25 5.60±0.20 B±0.25 PIN 1.14 SQ Ordering Information & Dimensions: PART NO. 4.34±0.10 10.20±0.20 7.20±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2/-3) or A3964H-XP, A3964H-XP-A,A3964H-XP-B,A3964H-XP-C series Housing *Color:White 3.96±0.20 1.60±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 59.40 63.36 63.36 67.32 67.32 71.28 71.28 75.24 75.24 79.20 83.16 79.20 83.16 87.12 87.12 91.08 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-537 A3961 SERIES A3961WVC-XP 3.96mm pitch 180° Wafer Ordering Information: A3961WVC-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 V2:Nylon 66,UL94V-2 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish (blank):Tin over Nickel G:Gold over Nickel (1u") G15:Gold over Nickel(15u") G20:Gold over Nickel(20u") G30:Gold over Nickel(30u") 4.Size(P,M):See ① Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Black Optional Voided CKT 3.96mm pitch wire to board connector Circuit 1 3.96±0.10 A±0.20 12.70±0.25 Gold over Nickel M(11.43±0.25) 3.25 P(4.37±0.20) 9.07±0.25 PIN 1.14 SQ 3.80±0.20 B±0.25 A 3.96±0.10 ∅1.70 Note: ① M(mm) PART NO. P(mm) P44M114 4.37 11.43 P115M114 11.53 11.43 P32M114 3.18 11.43 P32M133 3.18 13.28 P25M133 2.51 13.28 P74M114 7.42 11.43 P44M122 4.37 12.19 P123M122 12.34 12.19 PART NO. P(mm) M(mm) P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.16 7.92 11.12 11.88 15.08 15.84 19.04 19.80 23.00 23.76 26.96 30.92 27.72 31.68 34.88 35.64 38.84 39.60 42.80 43.56 46.76 47.52 50.72 51.48 54.68 55.44 58.64 59.40 62.60 63.36 66.56 67.32 70.52 71.28 74.48 75.24 78.44 79.20 82.40 83.16 86.36 87.12 90.32 91.08 94.28 Unit: mm A3961WRC-XP 3.96mm pitch 90° Wafer Ordering Information: A3961WRC-XP - *** - *** - *** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 V2:Nylon 66,UL94V-2 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish (blank):Tin over Nickel G:Gold over Nickel (1u") G15:Gold over Nickel(15u") G20:Gold over Nickel(20u") G30:Gold over Nickel(30u") 4.Size(P,M,Y):See ① Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961H-XP(-2) or A3964H-XP, A3964H-XP-A,A3964H-XP-C series Housing *Color:Black Optional Voided CKT Circuit 1 3.96±0.10 A±0.20 12.70±0.25 Gold over Nickel M(11.43±0.20) Y(5.41±0.25) 3.25 9.07±0.25 P(5.38±0.25) PIN 1.14 SQ B±0.25 Note: ① PART NO. P(mm) M(mm) Y(mm) PART NO. P(mm) M(mm) P54M114Y54 5.38 11.43 5.41 P35M114Y56 3.45 11.43 5.61 P35M133Y54 3.45 13.28 5.41 P35M114Y54 3.45 11.43 5.41 P54M133Y55 5.38 13.28 5.51 P47M114Y54 4.69 11.43 5.41 P150M127Y54 15.04 12.67 5.41 Y(mm) A 3.96±0.10 ∅1.70 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P 21P 22P 23P 24P Dimensions A B 3.96 7.16 7.92 11.12 11.88 15.08 15.84 19.04 19.80 23.00 23.76 26.96 30.92 27.72 31.68 34.88 35.64 38.84 39.60 42.80 43.56 46.76 47.52 50.72 51.48 54.68 55.44 58.64 59.40 62.60 63.36 66.56 67.32 70.52 71.28 74.48 75.24 78.44 79.20 82.40 83.16 86.36 87.12 90.32 91.08 94.28 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-538
A3961WV-10P
物料型号:A3961系列
器件简介: - A3961系列提供3.96mm间距的线对板连接器解决方案。 - 产品符合RoHS和REACH标准,支持无卤素、GWT/Glow Wire Test (IEC60335-1)的定制需求。
引脚分配: - 提供2至24个电路的配置选项。
参数特性: - 电流额定值:7A AC/DC - 电压额定值:250V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大10mΩ - 绝缘电阻:最小1000MΩ - 耐电压:1500V AC/分钟
功能详解: - 提供直插式和贴装式选项。 - 支持多种材料和表面处理工艺,如黄铜镀锡、磷青铜镀锡、黄铜镀金、磷青铜镀金等。 - 可选择的金层厚度包括1u"、15u"、20u"、30u"。
应用信息: - 适用于CJT A3961H-XP、A3961H-XP-2、A3961H-XP-3、A5081H-XP系列外壳。
封装信息: - 提供多种尺寸和形状的封装选项,以满足不同应用场景的需求。
订购信息: - 包括部件编号、线规范围、绝缘外径、材料、表面处理和每卷数量等详细信息。
联系方式: - 长河连接器(CHANGJIANG CONNECTORS) - 电话:+86-755-29959119 29959129 - 传真:+86-755-29959139 - 网址:[Http://www.CJT.cn](Http://www.CJT.cn)
A3961WV-10P 价格&库存
很抱歉,暂时无法提供与“A3961WV-10P”相匹配的价格&库存,您可以联系我们找货
