A3964 SERIES
3.96~7.92mm pitch wire to board connector
Specifications
Current rating:7A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:10mΩMax.
Insulation resistance:1000MΩMin.
Withstanding voltage:1500V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,GWT/Glow wire
Test (IEC60335-1) request,need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
2.00
16.57 REF.
1.60
2.00
1.60
2.00
10.80
10.20 REF.
1.60
1.60
2.00
19.20 REF.
10.20 REF.
19.20 REF.
9.32
24.60 REF.
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
A-556
A3964 SERIES
A3964-T
3.96mm pitch wire to board connector
3.96mm pitch Crimp Terminal
Reference Informations:
*Used in CJT A3964H-XP,A3964H-XP-A,A3964H-XP-B,A3964H-XP-C,
A5082H-XP,A5082H-XP-A,A7501H-XP series Housing
1.55
3.20±0.20
2.40±0.20
SEC:A-A
2.20±0.20
1.92±0.20
B
6.10±0.20
B
2.00
A
12.50±0.25
A
3.60±0.20
0.25
4.30±0.20
1.90±0.20
SEC:B-B
1.20±0.20
Unit:mm
Ordering information & Specifications:
Part NO.
A3964-TB
A3964-TP
A3964-GB
A3964-GP
Wire Range
AWG#18-#24
AWG#18-#24
AWG#18-#24
AWG#18-#24
Insulation O.D.
3.20mm(max)
3.20mm(max)
3.20mm(max)
3.20mm(max)
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
5,000 PCS
5,000 PCS
5,000 PCS
5,000 PCS
Optional Gold plating available but MOQ requested
A3964-T-L
3.20±0.20
1.92±0.20
SEC:A-A
1.80±0.20
B
6.10±0.20
B
2.00
A
12.50±0.25
A
2.95±0.20
1.55
0.25
2.20±0.20
4.30±0.20
1.90±0.20
SEC:B-B
1.20±0.20
Unit:mm
Part NO.
A3964-TB-L
A3964-TP-L
A3964-GB-L
A3964-GP-L
Wire Range
AWG#22-#28
AWG#22-#28
AWG#22-#28
AWG#22-#28
Insulation O.D.
2.60mm(max)
2.60mm(max)
2.60mm(max)
2.60mm(max)
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
5,000 PCS
5,000 PCS
5,000 PCS
5,000 PCS
A-557
A3964 SERIES
A3964H-XP
3.96mm pitch Housing
*Material:Nylon 66,UL94V-2
*Suitable CJT A3964-T(-L)series Terminal
*Mates with CJT A3961WV,WR,WVA,WRA-XP(-A),
A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP,
A3961WVB,WRB,WVC,WRC-XP series Wafer
*Color:Natural
Circuit 1
Ordering Information:
A3964H-XP - ***
1
2
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-2
V0:Nylon 66,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750°C
3.96±0.10
A±0.20
Ordering Information & Dimensions:
B±0.25
1.50
16.00±0.25
7.35±0.25
8.10±0.25
A3964H-XP-A
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.96
9.06
7.92
13.02
11.88
16.98
15.84
20.94
19.80
24.90
23.76
28.86
27.72
32.82
31.68
36.78
35.64
40.74
39.60
44.70
43.56
48.66
Unit: mm
7.92~3.96mm pitch Housing
*Suitable CJT A3964-T(-L) series Terminal
*Color:Natural
Circuit 1
A3964H-XP-A - ***
1
2
1.Part No.
2.Material:
V0:Nylon 66,UL94V-0
7.92±0.10
3.96±0.10
A±0.20
B±0.25
7.35±0.25
1.50
16.00±0.25
PART NO.
8.10±0.25
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
7.92
13.02
11.88
16.98
15.84
20.94
19.80
24.90
23.76
28.86
27.72
32.82
31.68
36.78
35.64
40.74
39.60
44.70
43.56
48.66
Unit: mm
A-558
A3964 SERIES
A3964H-XP-B
*Material:Nylon 66,UL94V-0
*Mates with CJT A3961WVA,WRA-XP(-A),
A3961WVA-XP-R(-A),A3961WVB-F,WRB-F-XP,
A3961WVB,WRB-XP,A3961WRB-F-L-XP series Wafer
*Color:White
A3964H-XP-B - *** - **
1
2 3
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-0
3.Color:
(blank):White
BK:Black
Circuit 1
3.96±0.10
A±0.20
10.05±0.20
B±0.25
16.00±0.25
2.50±0.20
PART NO.
6.55±0.20
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.96
9.06
7.92
13.02
11.88
16.98
15.84
20.94
19.80
24.90
23.76
28.86
27.72
32.82
31.68
36.78
35.64
40.74
39.60
44.70
43.56
48.66
Unit: mm
A3964H-XP-C
*Color:White
A3964H-XP-C - *** - **
1
2 3
1.Part No.
2.Material:
3.Color:
(blank):White
BK:Black
Circuit 1
3.96±0.10
A±0.20
6.55±0.20
B±0.25
PART NO.
16.00±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
3.96
9.06
7.92
13.02
11.88
16.98
15.84
20.94
19.80
24.90
23.76
28.86
27.72
32.82
31.68
36.78
35.64
40.74
39.60
44.70
43.56
48.66
Unit: mm
A-559
