A3964H-6P
A3964H-6P
    CJT(长江连接器)
    Housings
    间距P=3.96mm 胶壳 6pin 250V 7A
A3964H-6P 数据手册
A3964 SERIES 3.96~7.92mm pitch wire to board connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 2.00 16.57 REF. 1.60 2.00 1.60 2.00 10.80 10.20 REF. 1.60 1.60 2.00 19.20 REF. 10.20 REF. 19.20 REF. 9.32 24.60 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-556 A3964 SERIES A3964-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3964H-XP,A3964H-XP-A,A3964H-XP-B,A3964H-XP-C, A5082H-XP,A5082H-XP-A,A7501H-XP series Housing 1.55 3.20±0.20 2.40±0.20 SEC:A-A 2.20±0.20 1.92±0.20 B 6.10±0.20 B 2.00 A 12.50±0.25 A 3.60±0.20 0.25 4.30±0.20 1.90±0.20 SEC:B-B 1.20±0.20 Unit:mm Ordering information & Specifications: Part NO. A3964-TB A3964-TP A3964-GB A3964-GP Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Insulation O.D. 3.20mm(max) 3.20mm(max) 3.20mm(max) 3.20mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS Optional Gold plating available but MOQ requested A3964-T-L 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3964H-XP,A3964H-XP-A,A3964H-XP-B,A3964H-XP-C, A5082H-XP,A5082H-XP-A,A7501H-XP series Housing 3.20±0.20 1.92±0.20 SEC:A-A 1.80±0.20 B 6.10±0.20 B 2.00 A 12.50±0.25 A 2.95±0.20 1.55 0.25 2.20±0.20 4.30±0.20 1.90±0.20 SEC:B-B 1.20±0.20 Unit:mm Ordering information & Specifications: Part NO. A3964-TB-L A3964-TP-L A3964-GB-L A3964-GP-L Wire Range AWG#22-#28 AWG#22-#28 AWG#22-#28 AWG#22-#28 Insulation O.D. 2.60mm(max) 2.60mm(max) 2.60mm(max) 2.60mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-557 A3964 SERIES A3964H-XP 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3964-T(-L)series Terminal *Mates with CJT A3961WV,WR,WVA,WRA-XP(-A), A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB,WVC,WRC-XP series Wafer *Color:Natural Circuit 1 Ordering Information: A3964H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.96±0.10 A±0.20 Ordering Information & Dimensions: B±0.25 1.50 16.00±0.25 7.35±0.25 8.10±0.25 A3964H-XP-A PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 3.96 9.06 7.92 13.02 11.88 16.98 15.84 20.94 19.80 24.90 23.76 28.86 27.72 32.82 31.68 36.78 35.64 40.74 39.60 44.70 43.56 48.66 Unit: mm 7.92~3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3964-T(-L) series Terminal *Mates with CJT A3961WV,WR,WVA,WRA-XP(-A), A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB,WVC,WRC-XP series Wafer *Color:Natural Circuit 1 Ordering Information: A3964H-XP-A - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 7.92±0.10 3.96±0.10 A±0.20 B±0.25 7.35±0.25 Ordering Information & Dimensions: 1.50 16.00±0.25 PART NO. 8.10±0.25 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 7.92 13.02 11.88 16.98 15.84 20.94 19.80 24.90 23.76 28.86 27.72 32.82 31.68 36.78 35.64 40.74 39.60 44.70 43.56 48.66 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-558 A3964 SERIES A3964H-XP-B 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3964-T(-L) series Terminal *Mates with CJT A3961WVA,WRA-XP(-A), A3961WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB-XP,A3961WRB-F-L-XP series Wafer *Color:White Ordering Information: A3964H-XP-B - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):White BK:Black Circuit 1 3.96±0.10 A±0.20 10.05±0.20 B±0.25 Ordering Information & Dimensions: 16.00±0.25 2.50±0.20 PART NO. 6.55±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 3.96 9.06 7.92 13.02 11.88 16.98 15.84 20.94 19.80 24.90 23.76 28.86 27.72 32.82 31.68 36.78 35.64 40.74 39.60 44.70 43.56 48.66 Unit: mm A3964H-XP-C 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3964-T(-L) series Terminal *Mates with CJT A3961WV,WR,WVA,WRA-XP(-A), A3961WV,WVA-XP-R(-A),A3961WVB-F,WRB-F-XP, A3961WVB,WRB,WVC,WRC-XP series Wafer *Color:White Ordering Information: A3964H-XP-C - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):White BK:Black Circuit 1 3.96±0.10 A±0.20 6.55±0.20 B±0.25 Ordering Information & Dimensions: PART NO. 16.00±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 3.96 9.06 7.92 13.02 11.88 16.98 15.84 20.94 19.80 24.90 23.76 28.86 27.72 32.82 31.68 36.78 35.64 40.74 39.60 44.70 43.56 48.66 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-559
A3964H-6P 价格&库存
很抱歉,暂时无法提供与“A3964H-6P”相匹配的价格&库存,您可以联系我们找货
