A3965H-2P
A3965H-2P
    CJT(长江连接器)
    P=3.96mm
    胶壳 间距P=3.96mm 2Pin(1x2)
A3965H-2P 数据手册
A3965 SERIES 3.96~7.92mm pitch wire to board connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 1.60 1.81 1.60 2.05 10.00 16.00 REF. 10.00 20.00 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-560 A3965 SERIES A3965-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3965H-XP,A3965HA-XP-GWT,A3502H-XP series Housing 0.20 1.35 4.00±0.25 3.90±0.25 A SEC:A-A 2.50±0.25 2.20±0.25 B 4.85±0.25 B 10.90±0.25 2.25 A SEC:B-B 1.90 4.00±0.25 2.80 Unit:mm Ordering information & Specifications: Wire Range Part NO. A3965-TB A3965-TP A3965-GB A3965-GP Insulation O.D. 3.20mm(max) 3.20mm(max) 3.20mm(max) 3.20mm(max) AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 3,000 PCS 3,000 PCS 3,000 PCS 3,000 PCS Optional Gold plating available but MOQ requested A3965H-XP 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3965-T series Terminal *Mates with CJT A3965HM-XP series Housing and A3965WV,WR-XP(-A),A3965WV-F-XP(-A)-GWT series Wafer *Color:White Ordering Information: A3965H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.96±0.10 Circuit 1 Ordering Information & Dimensions: A±0.20 8.30±0.25 PART NO. 6.00±0.25 12.50±0.25 13.30±0.25 CJTCONN 35156 5.98 C±0.25 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 Dimensions B 10.58 14.54 18.50 22.46 26.42 30.38 34.34 38.30 42.26 46.22 50.18 54.14 58.10 62.06 C 8.88 12.84 16.80 20.76 24.72 28.68 32.64 36.60 40.56 44.52 48.48 52.44 56.40 60.36 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-561 A3965 SERIES A3965HA-XP-GWT 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0,GWT 750°C *Suitable CJT A3965-T series Terminal *Mates with CJT A3965HM-XP series Housing and A3965WV,WR-XP(-A),A3965WV-F-XP(-A)-GWT series Wafer and A3965S-XP-GWT series Retainer *Color:Ivory 4P~8P 9P~15P 3.96±0.10 Circuit 1 A±0.20 8.30±0.25 Ordering Information & Dimensions: 6.00±0.20 C±0.25 12.50±0.25 5.98 CJTCONN 35156 13.30±0.25 PART NO. B±0.25 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 Dimensions B 18.50 22.46 26.42 30.38 34.34 38.30 42.26 46.22 50.18 54.14 58.10 62.06 C 16.80 20.76 24.72 28.68 32.64 36.60 40.56 44.52 48.48 52.44 56.40 60.36 Unit: mm A3965S-XP-GWT 3.96mm pitch Retainer Reference Informations: *Material: Nylon 66,UL94V-0,GWT 750°C *Used in CJT A3965HA-XP-GWT series Housing *Color:Brick Red B±0.30 1.50 6.00 6.00 B±0.30 10.50 1.00 2.21 4.00 8.95 10.50 2.21 A±0.20 A±0.20 2P 1.21 3P~4P PART NO. 12.84 2.21 1.50 0.75 B±0.30 7.25 4.00 8.95 3.95 2.95 B±0.30 7.00 Ordering Information & Dimensions: 1.21 12.84 A±0.20 23.76 5P~8P A±0.20 9P~15P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.02 7.92 11.98 11.88 15.94 15.84 19.90 19.80 23.86 23.76 27.82 27.72 31.78 31.68 35.74 35.64 39.70 39.60 43.66 43.56 47.62 47.52 51.58 51.48 55.54 55.44 59.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-562 A3965 SERIES A3965HM-XP-GWT 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0,GWT 750°C *Suitable CJT A3965M-T series Terminal *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:White Circuit 1 3.96±0.10 A±0.20 Ordering Information & Dimensions: B±0.30 7.90±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 24.60±0.30 10.00±0.25 PART NO. 5.90±0.25 C±0.25 A 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 Dimensions B 11.22 15.18 19.14 23.10 27.06 31.02 34.98 38.94 42.90 46.86 50.82 54.78 58.74 62.70 C 9.65 13.52 17.39 21.26 25.13 29.00 32.87 36.74 40.61 44.48 48.35 52.22 56.09 59.96 Unit: mm A3965WV(-F)-XP 3.96mm pitch 180° Wafer Ordering Information: A3965WV(-F)-XP - ** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 (A3965WV-XP) GWT:Nylon 66,UL94V-0,GWT 750°C (A3965WV(-F)-XP) 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0,Nylon 66,UL94V-0 GWT 750°C *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:Ivory A3965WV-F-XP-GWT Circuit 1 3.96±0.10 3.96±0.10 A±0.20 +0.10 Ø1.650 3.40±0.10 7.80±0.25 +0.10 Ø1.400 1.50±0.10 Ordering Information & Dimensions: P.C.B LAYOUT B±0.25 3.65 1.50 10.00±0.25 8.45±0.25 Ø1.14 1.50 PIN 1.14 SQ A3965WV-F-XP-GWT 3.40±0.20 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 10.58 7.92 14.54 11.88 18.50 15.84 22.46 19.80 26.42 23.76 30.38 27.72 34.34 31.68 38.30 35.64 42.26 39.60 46.22 43.56 50.18 47.52 54.14 51.48 58.10 55.44 62.06 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-563 A3965 SERIES A3965WR-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:White 7.80±0.25 Circuit 1 Ordering Information: A3965WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750 ℃ 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.10 3.96±0.10 Ordering Information & Dimensions: ∅1.80±0.10 A±0.20 B±0.25 Dimensions A B 3.96 10.58 7.92 14.54 11.88 18.50 15.84 22.46 19.80 26.42 23.76 30.38 27.72 34.34 31.68 38.30 35.64 42.26 39.60 46.22 43.56 50.18 47.52 54.14 51.48 58.10 55.44 62.06 PART NO. P.C.B LAYOUT 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 4.00 10.00±0.25 8.45±0.25 PIN 1.14 SQ Unit: mm A3965WV-XP-A 7.92mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66, UL94V-0 *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:White A±0.20 Circuit 1 Ordering Information: A3965WV-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.92±0.10 7.80±0.25 7.92±0.10 ∅1.80±0.10 P.C.B LAYOUT C±0.25 B±0.25 8.45±0.25 3.65 10.00±0.25 Ordering Information & Dimensions: PIN 1.14 SQ PART NO. 3P 5P 7P 9P 11P 13P 15P A 7.92 15.84 23.76 31.68 39.60 47.52 55.44 Dimensions B 14.74 22.66 30.58 38.50 46.42 54.34 62.26 C 13.14 21.06 28.98 36.90 44.82 52.74 60.66 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-564 A3965 SERIES A3965WR-XP-A 3.96mm pitch wire to board connector 7.92mm pitch 90° Wafer Ordering Information: A3965WR-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:White 7.80±0.25 Circuit 1 7.92±0.10 7.92±0.10 Ø1.80±0.10 P.C.B LAYOUT A±0.20 C±0.25 B±0.25 8.45±0.25 10.00±0.25 Ordering Information & Dimensions: PART NO. 4.00 3P 5P 7P 9P 11P 13P 15P PIN 1.14 SQ A 7.92 15.84 23.76 31.68 39.60 47.52 55.44 Dimensions B 14.74 22.66 30.58 38.50 46.42 54.34 62.26 C 13.14 21.06 28.98 36.90 44.82 52.74 60.66 Unit: mm A3965WV-F-XP-A-GWT 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0,GWT 750°C *Mates with CJT A3965H-XP,A3965HA-XP-GWT series Housing *Color:Ivory +0.10 Ordering Information: A3965WV-F-XP-A-GWT - ** 1 2 1.Part No. 2.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.92±0.10 Ø1.400 Circuit 1 7.92±0.10 3.40±0.10 7.80±0.25 +0.10 Ø1.650 1.50±0.10 P.C.B LAYOUT A±0.20 B±0.25 3.65 1.50 10.00±0.25 8.45±0.25 Ø1.14 PIN 1.14 SQ 3.40±0.20 1.50 Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 14.54 15.84 22.46 23.76 30.38 31.68 38.30 39.60 46.22 47.52 54.14 55.44 62.06 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-565
A3965H-2P
物料型号:A3965系列
器件简介:这是一系列3.96~7.92mm间距的线对板连接器,具有多种型号和配置。
引脚分配:文档中提供了不同型号的引脚分配和尺寸信息,例如2P至15P的配置。
参数特性: - 电流额定值:7A AC/DC - 电压额定值:250V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大10mΩ - 绝缘电阻:最小1000MΩ - 耐电压:1500V AC/分钟
功能详解:文档中提到了符合RoHS和REACH标准,以及满足HF/Halogen Free和GWT/Glow wire Test (IEC60335-1)的要求,但需要定制。
应用信息:文档中没有提供具体的应用信息,但根据其特性,这些连接器可能适用于需要高电流和高电压额定值的应用。
封装信息:提供了多种材料和表面处理选项,例如黄铜镀锡镍、磷青铜镀锡镍、黄铜镀金镍和磷青铜镀金镍。还提供了可选的金镀层,但需要最小订单量。
订购信息:文档列出了详细的订购信息和尺寸,包括部件编号、线径范围、绝缘外径、材料、表面处理和每卷数量。
A3965H-2P 价格&库存
很抱歉,暂时无法提供与“A3965H-2P”相匹配的价格&库存,您可以联系我们找货
