A5081H-6P
A5081H-6P
    CJT(长江连接器)
    Housings
    间距P=5.08mm 胶壳 6pin 250V 7A
A5081H-6P 数据手册
A5081 SERIES 5.08mm pitch wire to board connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 2.00 16.57 REF. 1.60 2.00 1.60 2.00 10.30 10.20 REF. 1.60 1.60 2.00 19.20 REF. 10.20 REF. 19.20 REF. 6.30 E326732 24.60 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-582 A5081 SERIES A5081H-XP 5.08mm pitch wire to board connector 5.08mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961-T(-1) series Terminal *Mates with CJT A5081WV,WR,WVA,WRA-XP(-A),A5081WVB-XP A5081WV-XP-R(-A),A5081WVA-XP-R(-A) series Wafer *Color:Natural Ordering Information: A5081H-XP - * - *** 1 2 3 1.Part No. 2.Style: (blank)-Type 1 2-Type 2 3.Material: (blank)-Nylon 66,UL94V-2(Natural) V0-Nylon 66,UL94V-0(White) GWT-Nylon 66,UL94V-0,GWT 750°C Circuit 1 5.08±0.10 A±0.20 7.70±0.25 16.00±0.25 B±0.25 A5081WV-XP 6.30±0.25 6.30±0.25 TYPE 1 TYPE 2 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.08 10.16 15.16 15.24 20.24 20.32 25.32 25.40 30.40 30.48 35.48 35.56 40.56 40.64 45.64 45.72 50.72 50.80 55.80 55.88 60.88 60.96 65.96 66.04 71.04 71.12 76.12 76.20 81.20 81.28 86.28 86.36 91.36 91.44 96.44 96.52 101.52 Unit: mm 5.08mm pitch 180° Wafer Ordering Information: A5081WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural Circuit 1 5.08±0.10 Ordering Information & Dimensions: PART NO. 5.08±0.10 ∅1.80±0.05 A±0.20 P.C.B LAYOUT B±0.25 3.20±0.20 3.60±0.20 17.50±0.25 12.30±0.25 5.60±0.25 10.20±0.25 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-583 A5081 SERIES A5081WR-XP 5.08mm pitch wire to board connector 5.08mm pitch 90° Wafer Ordering Information: A5081WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural Circuit 1 5.08±0.10 4 Ordering Information & Dimensions: PART NO. ∅1.80±0.05 5.08±0.10 P.C.B LAYOUT A±0.20 5.40 18.810±0.25 12.30±0.25 3.20±0.20 5.60±0.25 B±0.25 3.60±0.20 PIN 1.14 SQ A5081WVA-XP 10.20±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm 5.08mm pitch 180° Wafer Ordering Information: A5081WVA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.35±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural 5.08±0.10 Ordering Information & Dimensions: PART NO. 5.08±0.10 A±0.20 ∅1.80±0.05 P.C.B LAYOUT 3.20±0.25 3.60 17.50±0.25 B±0.25 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-584 A5081 SERIES A5081WRA-XP 5.08mm pitch wire to board connector 5.08mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural 6.35±0.25 Ordering Information: A5081WRA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Ordering Information & Dimensions: 5.08±0.10 PART NO. ∅1.80±0.05 5.08±0.10 P.C.B LAYOUT A±0.20 8.50±0.25 3.20±0.25 3.60±0.20 8.10±0.25 B±0.25 PIN 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm A5081WVB-XP 5.08mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural 6.40±0.25 Circuit 1 Ordering Information: A5081WVB-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 5.08±0.10 Ordering Information & Dimensions: PART NO. 5.08±0.10 A±0.20 ∅1.57±0.05 P.C.B LAYOUT PIN 1.14 ROUND 3.20±0.20 4.43±0.25 3.25±0.20 11.52±0.25 19.20±0.25 9.80±0.25 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 8.20 10.16 13.28 15.24 18.36 20.32 23.44 25.40 28.52 30.48 33.60 35.56 38.68 40.64 43.76 45.72 48.84 50.80 53.92 55.88 59.00 60.96 64.08 66.04 69.16 71.12 74.24 76.20 79.32 81.28 84.40 86.36 89.48 91.44 94.56 96.52 99.64 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-585 A5081 SERIES A5081WV-XP-R 5.08mm pitch wire to board connector 5.08mm pitch 180° Wafer Round Pin Ordering Information: A5081WV-XP-R - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural Circuit 1 5.08±0.10 Ordering Information & Dimensions: PART NO. ∅1.57±0.05 5.08±0.10 P.C.B LAYOUT A±0.20 5.60±0.25 3.20±0.25 3.60±0.20 17.50±0.25 12.30±0.25 B±0.25 10.20±0.25 PIN 1.14 ROUND A5081WVA-XP-R 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm 5.08mm pitch 180° Wafer Round Pin 6.35±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural Ordering Information: A5081WVA-XP-R - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 5.08±0.10 5.08±0.10 Ordering Information & Dimensions: PART NO. A±0.25 ∅1.57±0.05 P.C.B LAYOUT 3.20±0.25 3.60 17.50±0.25 B±0.25 PIN 1.14 ROUND 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 5.08 10.16 10.16 15.24 15.24 20.32 20.32 25.40 25.40 30.48 30.48 35.56 35.56 40.64 40.64 45.72 45.72 50.80 50.80 55.88 55.88 60.96 60.96 66.04 66.04 71.12 71.12 76.20 76.20 81.28 81.28 86.36 86.36 91.44 91.44 96.52 96.52 101.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-586 A5081 SERIES A5081WV-XP-A 5.08mm pitch wire to board connector 10.16mm pitch 180° Wafer Ordering Information: A5081WV-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2(Natural) V0:Nylon 66,UL94V-0(White) GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural Circuit 1 10.16±0.10 5.08±0.10 10.16±0.10 ∅1.80±0.05 A±0.20 P.C.B LAYOUT B±0.25 5.60±0.25 PART NO. 3.20±0.20 3.60±0.20 17.50±0.25 13.25±0.25 Ordering Information & Dimensions: 10.20±0.25 PIN 1.14 SQ Unit: mm A5081WR-XP-A Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A5081H-XP,A5082H-XP, A5082H-XP-A series Housing *Color:Natural 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 71.12 76.20 81.28 86.36 91.44 96.52 10.16mm pitch 90° Wafer Circuit 1 Ordering Information: A5081WR-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank)-Nylon 66,UL94V-2(Natural) V0-Nylon 66,UL94V-0(White) GWT-Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 10.16±0.10 5.08±0.10 10.16±0.10 ∅1.80±0.05 P.C.B LAYOUT A±0.20 5.60±0.25 B±0.25 3.20±0.20 PART NO. 5.40 18.810±0.25 12.30±0.25 Ordering Information & Dimensions: PIN 1.14 SQ 3.60±0.20 10.20±0.25 3P 5P 7P 9P 11P 13P 15P 17P 19P Dimensions A B 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 71.12 76.20 81.28 86.36 91.44 96.52 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-587
A5081H-6P 价格&库存
很抱歉,暂时无法提供与“A5081H-6P”相匹配的价格&库存,您可以联系我们找货
A5081H-6P
    • 1+1.44820
    库存:102
