B1251H-13P
B1251H-13P
    CJT(长江连接器)
    Housings
    间距P=1.25mm 胶壳 13pin 125V 1A
B1251H-13P 数据手册
B1251 SERIES 1.25mm pitch board-in connector Specifications Current rating:1A AC,DC Voltage rating:125V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:250V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 1.65 REF. 0.80 3.50 2.20 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-6 B1251 SERIES B1251-T 1.25mm pitch board-in connector 1.25mm pitch Crimp Terminal 1.70±0.10 Reference Informations: *Used in CJT B1251H-XP series Housing 0.15 1.37±0.10 (3.13) 0.70±0.10 B 2.80±0.10 B 0.30 1.07±0.10 SEC:B-B 0.90±0.05 A 5.60±0.25 A 1.06±0.10 0.50 SEC:A-A 0.80±0.05 0.35±0.05 0.55±0.05 0.45 Ordering information & Specifications: Unit:mm Part NO. Wire Range Insulation O.D. Material Finish Qty/reel B1251-TP AWG#28-#32 1.00mm(max) Phosphor Bronze Tin over Nickel 15,000 PCS B1251-GP AWG#28-#32 1.00mm(max) Phosphor Bronze Gold over Nickel 15,000 PCS Optional Gold plating available but MOQ requested B1251H-XP Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B1251-T series Terminal *Color:White 1.25mm pitch Housing Ordering Information: B1251H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 1.25±0.10 ∅0.50±0.05 Circuit 1 1.25±0.10 P.C.B LAYOUT A±0.20 Ordering Information & Dimensions: B±0.25 2.20±0.20 1.25±0.20 3.50±0.25 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 1.25 3.05 2.50 4.30 3.75 5.55 5.00 6.80 6.25 8.05 7.50 9.30 8.75 10.55 10.00 11.80 11.25 13.05 12.50 14.30 13.75 15.55 15.00 16.80 16.25 18.05 17.50 19.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-7
B1251H-13P 价格&库存
很抱歉,暂时无法提供与“B1251H-13P”相匹配的价格&库存,您可以联系我们找货
