B2012H-12P
B2012H-12P
    CJT(长江连接器)
    P=2mm
    胶壳 间距P=2.00mm 12Pin(1x12)
B2012H-12P 数据手册
B2012 SERIES 2.00mm pitch board-in connector Specifications Current rating:2A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:800V AC/minute *Contact CJT for details* Standards E326732 E326732 3.70 REF. 1.55 REF. 1.60 3.50 6.20 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-16 B2012 SERIES B2012-T 2.00mm pitch board-in connector 2.00mm pitch Crimp Terminal 2.00±0.25 0.70±0.20 0.20 1.76±0.25 Reference Informations: *Used in CJT B2012H-XP series Housing 1.49±0.25 SEC:A-A C 0.90 B 4.92±0.25 0.80 0.90±0.20 B 5.10±0.25 A A C Wire Range Part NO. Insulation O.D. 1.30mm(max) AWG#24-#30 B2012-TB 1.30mm(max) B2012-TP AWG#24-#30 1.30mm(max) B2012-GB AWG#24-#30 1.30mm(max) B2012-GP AWG#24-#30 Optional Gold plating available but MOQ requested B2012H-XP 1.50±0.20 SEC:C-C SEC:D-D Ordering information & Specifications: Material Brass Phosphor Bronze Brass Phosphor Bronze 1.30±0.20 D 1.60±0.20 D 1.10±0.20 SEC:B-B Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Unit:mm Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS 2.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2012-T series Terminal *Color:Natural(white) Ordering Information: B2012H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.00±0.10 2.00±0.10 Ø0.80±0.05 A±0.20 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. B±0.25 5.80±0.20 6.20±0.25 3.50±0.25 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.00 5.20 4.00 7.20 6.00 9.20 8.00 11.20 10.00 13.20 12.00 15.20 14.00 17.20 16.00 19.20 18.00 21.20 20.00 23.20 22.00 25.20 24.00 27.20 26.00 29.20 28.00 31.20 30.00 33.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-17
B2012H-12P 价格&库存
很抱歉,暂时无法提供与“B2012H-12P”相匹配的价格&库存,您可以联系我们找货
