B2512 SERIES
2.50mm pitch board-in connector
Specifications
Current rating:3A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:10mΩMax.
Insulation resistance:1000MΩMin.
Withstanding voltage:1000V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,need to
customize*
*Contact CJT for details*
Standards
E326732
1.60
1.65 REF.
1.60
1.65 REF.
6.70
6.60
6.70
3.85
E326732
Dual Row
Single Row
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
B-18
B2512 SERIES
B2512-T
2.50mm pitch Crimp Terminal
Reference Informations:
*Used in CJT B2512H-XP series Housing
2.75±0.25
1.70±0.20
1.70±0.20
C
5.80±0.20
C
1.30±0.20
B
10.00±0.25
B
SEC:A-A
1.30
A
6.06±0.20
A
3.30±0.20
1.20±0.20
2.55±0.25
0.20
1.00±0.10
1.70±0.20
SEC:B-B
1.70±0.20
SEC:C-C
Unit:mm
Ordering information & Specifications:
Wire Range
Part NO.
B2512-TB
B2512-TP
B2512-GB
B2512-GP
AWG#22-#28
AWG#22-#28
AWG#22-#28
AWG#22-#28
Insulation O.D.
1.70mm(max)
1.70mm(max)
1.70mm(max)
1.70mm(max)
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
10,000 PCS
10,000 PCS
10,000 PCS
10,000 PCS
Optional Gold plating available but MOQ requested
B2512H-XP
2.50mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT B2512-T series Terminal
*Color:Natural(white)
Ordering Information:
B2512H-XP - ***
1
2
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750°C
2.50±0.10
2.50±0.10
+0.10
Ø1.000
Ordering Information & Dimensions:
A±0.20
P.C.B LAYOUT
PART NO.
B±0.25
6.70±0.25
3.85±0.20
Circuit 1
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
16P
Dimensions
A
B
2.50
6.70
5.00
9.20
7.50
11.70
10.00
14.20
12.50
16.70
15.00
19.20
17.50
21.70
20.00
24.20
22.50
26.70
25.00
29.20
27.50
31.70
30.00
34.20
32.50
36.70
35.00
39.20
37.50
41.70
Unit: mm
B-19
B2512 SERIES
B2512H-2xXP
2.50mm pitch Dual Row Housing
2.50±0.10
2.50±0.10
2.50±0.10
Last Circuit
B2512H-2xXP - ***
1
2
1.Part No.
2.Material:
PART NO.
2x2P
2x3P
2x4P
2x5P
2x6P
2x7P
2x8P
2x9P
2x10P
2x11P
2x12P
2x13P
2x14P
2x15P
2x16P
2x17P
2x18P
2x19P
2x20P
+0.10
Ø1.000
P.C.B LAYOUT
Circuit 1
Circuit 2
B±0.25
A±0.20
6.60±0.20
6.60±0.25
2.50±0.10
Dimensions
A
B
2.50
5.08
5.00
9.10
7.50
11.60
10.00
14.10
12.50
16.60
15.00
19.10
17.50
21.60
20.00
24.10
22.50
26.60
25.00
29.10
27.50
31.60
30.00
34.10
32.50
36.60
35.00
39.10
37.50
41.60
40.00
44.10
42.50
46.60
45.00
49.10
47.50
51.60
PART NO.
21P
22P
23P
24P
25P
26P
27P
28P
29P
30P
31P
32P
33P
34P
35P
36P
37P
38P
Dimensions
A
B
50.00
54.10
52.50
56.60
55.00
59.10
57.50
61.60
60.00
64.10
62.50
66.60
65.00
69.10
67.50
71.60
70.00
74.10
72.50
76.60
75.00
79.10
77.50
81.60
80.00
84.10
82.50
86.60
85.00
89.10
87.50
91.60
90.00
94.10
92.50
96.60
Unit: mm
B2512WV-XP
7.00±0.30
*Material:Pin:Phosphor Bronze/Tin over Nickel
Insulator:PBT+15%GF, UL94V-0
*Accepts Cable:Top Coated Wire(AWG#24~#26)
*Color:white
B2512WV-XP - * - ***
1
2 3
1.Part No.
2.Style:
(blank):TYPE 1
2:TYPE 2
3.Material:
(blank):PBT,UL94V-0
GWT:PBT,UL94V-0,GWT 750°C
2.50
A±0.10
1.25 MAX
Ø1.70 MAX
1.00 MAX
2.50mm pitch 180° Wafer
2.50±0.05
2.50±0.10
6.00±0.50
A±0.20
Ø0.90±0.05
CABLE DIM
P.C.B LAYOUT
B±0.30
2.05
+0.30
PART NO.
10.00-0.50
3.20±0.50
1.20±0.30
1.85
1.20
1.00±0.25
1.85
TYPE 1
TYPE 2
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
Dimensions
A
B
2.50
8.10
5.00
10.60
7.50
13.10
10.00
15.60
12.50
18.10
15.00
20.60
17.50
23.10
20.00
25.60
22.50
28.10
25.00
30.60
27.50
33.10
Unit: mm
B-20
很抱歉,暂时无法提供与“B2512H-11P”相匹配的价格&库存,您可以联系我们找货
