B2512-TP
B2512-TP
    CJT(长江连接器)
    胶壳端子 22-28AWG
B2512-TP 数据手册
B2512 SERIES 2.50mm pitch board-in connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 1.60 1.65 REF. 1.60 1.65 REF. 6.70 6.60 6.70 3.85 E326732 Dual Row Single Row CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-18 B2512 SERIES B2512-T 2.50mm pitch board-in connector 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT B2512H-XP series Housing 2.75±0.25 1.70±0.20 1.70±0.20 C 5.80±0.20 C 1.30±0.20 B 10.00±0.25 B SEC:A-A 1.30 A 6.06±0.20 A 3.30±0.20 1.20±0.20 2.55±0.25 0.20 1.00±0.10 1.70±0.20 SEC:B-B 1.70±0.20 SEC:C-C Unit:mm Ordering information & Specifications: Wire Range Part NO. B2512-TB B2512-TP B2512-GB B2512-GP AWG#22-#28 AWG#22-#28 AWG#22-#28 AWG#22-#28 Insulation O.D. 1.70mm(max) 1.70mm(max) 1.70mm(max) 1.70mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested B2512H-XP 2.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2512-T series Terminal *Color:Natural(white) Ordering Information: B2512H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.50±0.10 2.50±0.10 +0.10 Ø1.000 Ordering Information & Dimensions: A±0.20 P.C.B LAYOUT PART NO. B±0.25 6.70±0.25 3.85±0.20 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.50 6.70 5.00 9.20 7.50 11.70 10.00 14.20 12.50 16.70 15.00 19.20 17.50 21.70 20.00 24.20 22.50 26.70 25.00 29.20 27.50 31.70 30.00 34.20 32.50 36.70 35.00 39.20 37.50 41.70 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-19 B2512 SERIES B2512H-2xXP 2.50mm pitch board-in connector 2.50mm pitch Dual Row Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2512-T series Terminal *Color:Natural(white) 2.50±0.10 2.50±0.10 2.50±0.10 Last Circuit Ordering Information: B2512H-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x5P 2x6P 2x7P 2x8P 2x9P 2x10P 2x11P 2x12P 2x13P 2x14P 2x15P 2x16P 2x17P 2x18P 2x19P 2x20P +0.10 Ø1.000 P.C.B LAYOUT Circuit 1 Circuit 2 B±0.25 A±0.20 6.60±0.20 6.60±0.25 2.50±0.10 Dimensions A B 2.50 5.08 5.00 9.10 7.50 11.60 10.00 14.10 12.50 16.60 15.00 19.10 17.50 21.60 20.00 24.10 22.50 26.60 25.00 29.10 27.50 31.60 30.00 34.10 32.50 36.60 35.00 39.10 37.50 41.60 40.00 44.10 42.50 46.60 45.00 49.10 47.50 51.60 PART NO. 21P 22P 23P 24P 25P 26P 27P 28P 29P 30P 31P 32P 33P 34P 35P 36P 37P 38P Dimensions A B 50.00 54.10 52.50 56.60 55.00 59.10 57.50 61.60 60.00 64.10 62.50 66.60 65.00 69.10 67.50 71.60 70.00 74.10 72.50 76.60 75.00 79.10 77.50 81.60 80.00 84.10 82.50 86.60 85.00 89.10 87.50 91.60 90.00 94.10 92.50 96.60 Unit: mm B2512WV-XP 7.00±0.30 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:PBT+15%GF, UL94V-0 *Accepts Cable:Top Coated Wire(AWG#24~#26) *Color:white Ordering Information: B2512WV-XP - * - *** 1 2 3 1.Part No. 2.Style: (blank):TYPE 1 2:TYPE 2 3.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 2.50 A±0.10 1.25 MAX Ø1.70 MAX 1.00 MAX 2.50mm pitch 180° Wafer 2.50±0.05 2.50±0.10 6.00±0.50 A±0.20 Ø0.90±0.05 CABLE DIM P.C.B LAYOUT B±0.30 2.05 +0.30 PART NO. 10.00-0.50 3.20±0.50 Ordering Information & Dimensions: 1.20±0.30 1.85 1.20 1.00±0.25 1.85 TYPE 1 TYPE 2 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 2.50 8.10 5.00 10.60 7.50 13.10 10.00 15.60 12.50 18.10 15.00 20.60 17.50 23.10 20.00 25.60 22.50 28.10 25.00 30.60 27.50 33.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-20
B2512-TP 价格&库存
很抱歉,暂时无法提供与“B2512-TP”相匹配的价格&库存,您可以联系我们找货
B2512-TP
