B2513H-12P
B2513H-12P
    CJT(长江连接器)
    P=2.5mm
    胶壳 间距P=2.50mm 12Pin(1x12)
B2513H-12P 数据手册
B2513 SERIES 2.50mm pitch board-in connector Specifications Current rating:3A AC,DC Voltage rating:125V AC,DC Temperature range:-40°C~+105°C Contact resistance:5mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 1.60 3.95 6.75 2.30 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-21 B2513 SERIES B2513-T 2.50mm pitch board-in connector 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT B2513H-XP series Housing 2.70±0.25 0.67 2.60±0.25 0.20 1.45±0.20 1.45 5.70±0.25 0.38±0.10 1.80±0.20 D SEC:C-C 1.80±0.20 D 1.65±0.20 1.10 B C 2.70±0.20 B C 6.10±0.25 A 1.10±0.20 4.60±0.25 1.00±0.20 1.04±0.10 A SEC:A-A 1.85±0.20 SEC:D-D SEC:B-B Unit:mm Ordering information & Specifications: Wire Range Part NO. B2513-TB B2513-TP B2513-GB B2513-GP AWG#22-#28 AWG#22-#28 AWG#22-#28 AWG#22-#28 Insulation O.D. 1.70mm(max) 1.70mm(max) 1.70mm(max) 1.70mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested B2513H-XP 2.50mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B2513-T series Terminal *Color:Natural(white) Ordering Information: B2513H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.50±0.10 2.50±0.10 +0.10 Ordering Information & Dimensions: Ø1.000 A±0.20 P.C.B LAYOUT B±0.25 PART NO. 6.70±0.25 3.85±0.20 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.50 6.65 5.00 9.15 7.50 11.65 10.00 14.15 12.50 16.65 15.00 19.15 17.50 21.65 20.00 24.15 22.50 26.65 25.00 29.15 27.50 31.65 30.00 34.15 32.50 36.65 35.00 39.15 37.50 41.65 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-22
B2513H-12P 价格&库存
很抱歉,暂时无法提供与“B2513H-12P”相匹配的价格&库存,您可以联系我们找货
