B2541BW-2P
B2541BW-2P
    CJT(长江连接器)
    插件,P=2.54mm
    线对板针座 1x2P 直插 间距:2.54mm
B2541BW-2P 数据手册
B2541 SERIES 2.54mm pitch board to board connector Specifications Current rating:2.5A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩMax. Insulation resistance:100MΩMin. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free need to customize* *Contact CJT for details* Standards E326732 E326732 8.00 8.00 1.60 1.60REF. 2.00REF. 1.60 1.80 REF. 1.60 8.00 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-25 B2541 SERIES B2541AW-XP 2.54mm pitch board to board connector 2.54mm Pitch PC Board Connector-Ringnt Angle Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2541WV,WR,WVA,WRA-XP, A2543WV,WR,WVA,WRA-XP series Wafer *Color:White 4.70±0.20 2.54±0.10 2.54±0.10 Ø1.07±0.05 P.C.B LAYOUT 5.33±0.10 A±0.20 Ordering Information: B2541AW-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P B±0.25 8.00±0.20 8.00±0.25 0.82 3.00±0.20 Dimensions A B 2.54 4.98 5.08 7.52 7.62 10.06 10.16 12.60 12.70 15.14 15.24 17.68 17.78 20.22 20.32 22.76 25.30 22.86 25.40 27.84 27.94 30.38 30.48 32.92 33.02 35.46 35.56 38.00 38.10 40.54 Unit: mm B2541BW-XP 2.54mm Pitch PC Board Connertor-Bottom Entry Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2541WV,WR,WVA,WRA-XP, A2543WV,WR,WVA,WRA-XP series Wafer *Color:White 4.70±0.20 A±0.20 2.54±0.10 2.54±0.10 3.81±0.10 Ordering Information: B2541BW-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Ø1.78±0.25 Ø1.07±0.05 Ordering Information & Dimensions: P.C.B LAYOUT 3.00±0.20 8.00±0.20 B±0.25 8.00±0.25 0.82 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.54 4.98 5.08 7.52 7.62 10.06 10.16 12.60 12.70 15.14 15.24 17.68 17.78 20.22 20.32 22.76 22.86 25.30 25.40 27.84 27.94 30.38 30.48 32.92 33.02 35.46 35.56 38.00 38.10 40.54 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-26 B2541 SERIES 2.54mm Pitch PC Board Connector-Top Entry Ordering Information: B2541CW-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C A±0.20 2.54±0.10 4.70±0.20 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A2541WV,WR,WVA,WRA-XP, A2543WV,WR,WVA,WRA-XP series Wafer *Color:White 2.54±0.10 B2541CW-XP 2.54mm pitch board to board connector 2.54±0.10 Ø1.07±0.05 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. 8.00±0.25 3.00±0.20 8.00±0.20 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P Dimensions A B 2.54 4.98 5.08 7.52 7.62 10.06 10.16 12.60 12.70 15.14 15.24 17.68 17.78 20.22 20.32 22.76 25.30 22.86 25.40 27.84 27.94 30.38 30.48 32.92 33.02 35.46 35.56 38.00 38.10 40.54 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-27
B2541BW-2P 价格&库存
很抱歉,暂时无法提供与“B2541BW-2P”相匹配的价格&库存,您可以联系我们找货
