B3951H-4P
B3951H-4P
    CJT(长江连接器)
    Housings
    间距P=3.96mm 胶壳 4pin 300V 7A
B3951H-4P 数据手册
B3951 SERIES 3.96mm pitch board-in connector Specifications Current rating:7A AC,DC Voltage rating:300V AC,DC Temperature range:-40°C~+105°C Contact resistance:20m ΩMax. Insulation resistance:1000M ΩMin. Withstanding voltage:1500V AC/minute *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 3.85 REF. 1.60 7.65 5.00 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-28 B3951 SERIES B3951-T 3.96mm pitch board-in connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT B3951H-XP series Housing 0.25 1.38 3.80±0.25 3.60±0.25 A C 2.40 Ø1.65 2.30±0.25 C 0.75 2.20±0.25 2.70 B 4.75±0.20 B P.C.BLAYOUT SEC:A-A 10.30±0.25 A Ø1.80±0.05 2.07 SEC:C-C SEC:B-B Unit:mm Ordering information & Specifications: Part NO. B3951-TB B3951-TP B3951-GB B3951-GP Wire Range AWG#18-#22 AWG#18-#22 AWG#18-#22 AWG#18-#22 Insulation O.D. 3.00mm(max) 3.00mm(max) 3.00mm(max) 3.00mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 6,000 PCS 6,000 PCS 6,000 PCS 6,000 PCS Optional Gold plating available but MOQ requested B3951H-XP 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B3951-T series Terminal *Color:Natural(white) Ordering Information: B3951H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 5.00±0.25 A±0.20 3.96±0.20 Ø1.80 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. B±0.25 7.70±0.25 5.00±0.25 4.60±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.42 7.92 12.38 11.88 16.34 15.84 20.30 19.80 24.26 23.76 28.22 27.72 32.18 31.68 36.14 35.64 40.10 39.60 44.06 43.56 48.02 47.52 51.98 51.48 55.94 55.44 59.90 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-29
B3951H-4P
物料型号:B3951系列
器件简介:3.96mm间距板对板连接器
引脚分配:文档中未明确列出引脚分配,但提供了PCB布局的参考信息。
参数特性: - 电流额定值:7A AC/DC - 电压额定值:300V AC/DC - 温度范围:-40°C至+105°C - 接触电阻:最大20mΩ - 绝缘电阻:最小1000MΩ - 耐电压:1500V AC/分钟
功能详解:文档中未提供详细的功能解释,但提到了符合HF/无卤、GWT/灼热丝测试(IEC60335-1)的要求,需要定制。
应用信息:文档中未明确提供应用信息
封装信息:提供了B3951-T系列压接端子和B3951H-XP系列外壳的订购信息和规格,包括线规范围、绝缘外径、材料、表面处理和每卷数量。
B3951H-4P 价格&库存
很抱歉,暂时无法提供与“B3951H-4P”相匹配的价格&库存,您可以联系我们找货
B3951H-4P
    • 1+0.38630
    库存:270
