B3952 SERIES
3.96mm pitch board-in connector
Specifications
Current rating:7A AC,DC
Voltage rating:250V AC,DC
Temperature range:-40°C~+105°C
Contact resistance:10mΩMax.
Insulation resistance:1000MΩMin.
Withstanding voltage:1500V AC/minute
*Compliant with RoHS and REACH*
*Meet the HF/Halogen Free,GWT/Glow wire
Test (IEC60335-1) request,need to
customize*
*Contact CJT for details*
Standards
E326732
E326732
1.60
1.70 REF.
1.60
2.28 REF.
7.00
8.00
6.20
CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn
B-30
B3952 SERIES
B3952-T
3.96mm pitch Crimp Terminal
Reference Informations:
*Used in CJT B3952H-XP,B3952H-F-XP series Housing
4.00±0.25
1.08±0.20
4.10±0.25
0.25
SEC:A-A
A
2.45±0.20
4.80±0.25
2.20±0.10
0.78
2.60±0.20
1.15
B
1.44±0.20
B
0.70±0.10
10.00±0.25
A
SEC:B-B
1.25±0.20
1.28±0.10
2.20±0.20
Unit:mm
Ordering information & Specifications:
Wire Range
Part NO.
B3952-TB
B3952-TP
B3952-GB
B3952-GP
Insulation O.D.
3.00mm(max)
3.00mm(max)
3.00mm(max)
3.00mm(max)
AWG#18-#22
AWG#18-#22
AWG#18-#22
AWG#18-#22
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
5,000 PCS
5,000 PCS
5,000 PCS
5,000 PCS
Optional Gold plating available but MOQ requested
B3952-T-A
4.00mm pitch Crimp Terminal
*Used in CJT B3952HA-XP series Housing
3.20±0.25
1.30
3.30±0.25
0.20
SEC:A-A
1.00±0.15
2.10±0.25
SEC:B-B
0.70±0.15
0.80±0.15
Unit:mm
Part NO.
B3952-TB-A
B3952-TP-A
B3952-GB-A
B3952-GP-A
Wire Range
AWG#18-#22
AWG#18-#22
AWG#18-#22
AWG#18-#22
2.30±0.25
2.20±0.20
1.60±0.20
1.80±0.20
B
1.00
B
2.00
A
9.90±0.30
A
Insulation O.D.
2.60mm(max)
2.60mm(max)
2.60mm(max)
2.60mm(max)
Material
Brass
Phosphor Bronze
Brass
Phosphor Bronze
Finish
Tin over Nickel
Tin over Nickel
Gold over Nickel
Gold over Nickel
Qty/reel
5,000 PCS
5,000 PCS
5,000 PCS
5,000 PCS
B-31
B3952 SERIES
B3952H-XP
3.96mm pitch Housing
*Material:Nylon 66,UL94V-0
*Suitable CJT B3952-T series Terminal
*Color:Natural(white)
Ordering Information:
B3952H-XP - ***
1
2
1.Part No.
2.Material:
(blank):Nylon 66,UL94V-0
GWT:Nylon 66,UL94V-0,GWT 750°C
Circuit 1
3.96±0.05
Ø1.55±0.05
3.96±0.10
P.C.B LAYOUT
A±0.20
PART NO.
B±0.25
6.20±0.25
2
3
4
7.00±0.25
1
Ordering Information & Dimensions:
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
3.96
8.96
7.92
12.92
11.88
16.88
15.84
20.84
19.80
24.80
23.76
28.76
32.72
27.72
31.68
36.68
35.64
40.64
39.60
44.60
43.56
48.56
47.52
52.52
51.48
56.48
55.44
60.44
Unit: mm
B3952H-F-XP
B3952H-F-XP - ***
1
2
1.Part No.
2.Material:
2.70±0.05
Circuit 1
3.96±0.05
1.98±0.05
+0.10
Ø1.50-0.00
3.96±0.10
Ø1.55±0.05
A±0.20
P.C.B LAYOUT
B±0.25
2
3
1.98±0.10
4
7.00±0.25
1
6.20±0.25
1.20±0.10
PART NO.
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
3.96
8.96
7.92
12.92
11.88
16.88
15.84
20.84
19.80
24.80
23.76
28.76
27.72
32.72
31.68
36.68
35.64
40.64
39.60
44.60
43.56
48.56
47.52
52.52
51.48
56.48
55.44
60.44
Unit: mm
B-32
B3952 SERIES
B3952HA-XP
4.00mm pitch Housing
*Suitable CJT B3952-T-A series Terminal
B3952HA-XP - ***
1
2
1.Part No.
2.Material:
Circuit 1
4.00±0.05
B±0.25
4.50±0.25
Ø1.00±0.05
P.C.B LAYOUT
PART NO.
A±0.20
3.50±0.25
8.00±0.25
7.00±0.25
4.00±0.10
3.30±0.25
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
12P
13P
14P
15P
Dimensions
A
B
4.00
8.00
8.00
12.00
12.00
16.00
16.00
20.00
20.00
24.00
24.00
28.00
28.00
32.00
32.00
36.00
36.00
40.00
40.00
44.00
44.00
48.00
48.00
52.00
52.00
56.00
56.00
60.00
Unit: mm
B-33
很抱歉,暂时无法提供与“B3952H-10P”相匹配的价格&库存,您可以联系我们找货
