B3952H-2P
B3952H-2P
    CJT(长江连接器)
    P=3.96mm
    胶壳 间距P=3.96mm 2Pin(1x2)
B3952H-2P 数据手册
B3952 SERIES 3.96mm pitch board-in connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 1.60 1.70 REF. 1.60 2.28 REF. 7.00 8.00 6.20 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-30 B3952 SERIES B3952-T 3.96mm pitch board-in connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT B3952H-XP,B3952H-F-XP series Housing 4.00±0.25 1.08±0.20 4.10±0.25 0.25 SEC:A-A A 2.45±0.20 4.80±0.25 2.20±0.10 0.78 2.60±0.20 1.15 B 1.44±0.20 B 0.70±0.10 10.00±0.25 A SEC:B-B 1.25±0.20 1.28±0.10 2.20±0.20 Unit:mm Ordering information & Specifications: Wire Range Part NO. B3952-TB B3952-TP B3952-GB B3952-GP Insulation O.D. 3.00mm(max) 3.00mm(max) 3.00mm(max) 3.00mm(max) AWG#18-#22 AWG#18-#22 AWG#18-#22 AWG#18-#22 Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS Optional Gold plating available but MOQ requested B3952-T-A 4.00mm pitch Crimp Terminal Reference Informations: *Used in CJT B3952HA-XP series Housing 3.20±0.25 1.30 3.30±0.25 0.20 SEC:A-A 1.00±0.15 2.10±0.25 SEC:B-B 0.70±0.15 0.80±0.15 Unit:mm Ordering information & Specifications: Part NO. B3952-TB-A B3952-TP-A B3952-GB-A B3952-GP-A Wire Range AWG#18-#22 AWG#18-#22 AWG#18-#22 AWG#18-#22 2.30±0.25 2.20±0.20 1.60±0.20 1.80±0.20 B 1.00 B 2.00 A 9.90±0.30 A Insulation O.D. 2.60mm(max) 2.60mm(max) 2.60mm(max) 2.60mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-31 B3952 SERIES B3952H-XP 3.96mm pitch board-in connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B3952-T series Terminal *Color:Natural(white) Ordering Information: B3952H-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Circuit 1 3.96±0.05 Ø1.55±0.05 3.96±0.10 P.C.B LAYOUT A±0.20 PART NO. B±0.25 6.20±0.25 2 3 4 7.00±0.25 1 Ordering Information & Dimensions: 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.96 7.92 12.92 11.88 16.88 15.84 20.84 19.80 24.80 23.76 28.76 32.72 27.72 31.68 36.68 35.64 40.64 39.60 44.60 43.56 48.56 47.52 52.52 51.48 56.48 55.44 60.44 Unit: mm B3952H-F-XP 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B3952-T series Terminal *Color:Natural(white) Ordering Information: B3952H-F-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.70±0.05 Circuit 1 3.96±0.05 1.98±0.05 +0.10 Ø1.50-0.00 3.96±0.10 Ø1.55±0.05 A±0.20 P.C.B LAYOUT B±0.25 2 3 1.98±0.10 4 7.00±0.25 1 6.20±0.25 1.20±0.10 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.96 7.92 12.92 11.88 16.88 15.84 20.84 19.80 24.80 23.76 28.76 27.72 32.72 31.68 36.68 35.64 40.64 39.60 44.60 43.56 48.56 47.52 52.52 51.48 56.48 55.44 60.44 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-32 B3952 SERIES B3952HA-XP 3.96mm pitch board-in connector 4.00mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT B3952-T-A series Terminal *Color:Natural(white) Ordering Information: B3952HA-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Circuit 1 4.00±0.05 B±0.25 4.50±0.25 Ø1.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. A±0.20 3.50±0.25 8.00±0.25 7.00±0.25 4.00±0.10 3.30±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 4.00 8.00 8.00 12.00 12.00 16.00 16.00 20.00 20.00 24.00 24.00 28.00 28.00 32.00 32.00 36.00 36.00 40.00 40.00 44.00 44.00 48.00 48.00 52.00 52.00 56.00 56.00 60.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn B-33
B3952H-2P 价格&库存
很抱歉,暂时无法提供与“B3952H-2P”相匹配的价格&库存,您可以联系我们找货
