C1581F-TB
C1581F-TB
    CJT(长江连接器)
    胶壳端子 20-24AWG
C1581F-TB 数据手册
C1581 SERIES 3.68mm pitch wire to wire connector Specifications Current rating:5A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 15.20 7.50 30.40 REF. 31.40 REF. C±0.10 PART NO. D±0.10 B±0.10 A±0.10 C1581HFB-2P C1581HFB-3P C1581HFB-4P C1581HFB-2x2P C1581HFB-2x3P C1581HFB-3x3P C1581HFB-3x4P C1581HFB-3x5P Dimensions A 12.83 16.51 19.94 12.85 12.83 16.51 20.19 23.62 B 6.73 6.73 6.60 10.16 14.02 14.02 14.30 14.45 PART NO. C1581HMB-2P C1581HMB-3P C1581HMB-4P C1581HMB-2x2P C1581HMB-2x3P C1581HMB-3x3P C1581HMB-3x4P C1581HMB-3x5P Dimensions C 15.47 19.15 21.97 15.62 15.42 19.10 22.94 26.21 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-12 D 8.08 8.08 7.92 11.81 15.62 15.62 15.60 15.75 Unit:mm C1581 SERIES C1581F-T 3.68mm pitch wire to wire connector 3.68mm pitch Crimp Terminal Reference Informations: *Used in CJT C1581HFB,C1581HFC series Housing 0.20 2.00 ∅2.00 3.41±0.25 A 2.30±0.25 7.40±0.25 3.20±0.20 SEC:A-A 2.10±0.25 B 16.95±0.25 B 2.05 A 3.29±0.25 9.50±0.25 SEC:B-B ∅1.60±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. C1581F-TB C1581F-TP C1581F-GB C1581F-GP Material Brass Phosphor Bronze Insulation O.D. 1.85mm(max) 1.85mm(max) 1.85mm(max) 1.85mm(max) AWG#20-#24 AWG#20-#24 AWG#20-#24 AWG#20-#24 Brass Phosphor Bronze Qty/reel 8,000 PCS 8,000 PCS 8,000 PCS 8,000 PCS Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Optional Gold plating available but MOQ requested C1581M-T 3.68mm pitch Crimp Terminal 9.50±0.25 3.29±0.25 Reference Informations: *Used in CJT C1581HMB,C1581HMC series Housing 0.20 2.00 3.41±0.25 A 2.30±0.25 7.40±0.25 2.85±0.20 2.10±0.25 B 16.95±0.25 B SEC:A-A 2.05 A SEC:B-B ∅1.56±0.10 Unit:mm Ordering information & Specifications: Part NO. C1581M-TB C1581M-TP C1581M-GB C1581M-GP Wire Range AWG#20-#24 AWG#20-#24 AWG#20-#24 AWG#20-#24 Insulation O.D. 1.85mm(max) 1.85mm(max) 1.85mm(max) 1.85mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 8,000 PCS 8,000 PCS 8,000 PCS 8,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-13 C1581 SERIES C1581F-T-L 3.68mm pitch wire to wire connector 3.68mm pitch Crimp Terminal Reference Informations: *Used in CJT C1581HFB,C1581HFC series Housing 9.50±0.25 2.00 1.90±0.25 0.20 A 1.76±0.25 16.95±0.25 B SEC:A-A 7.40±0.25 B 2.05 A 1.90±0.25 3.20±0.20 1.82±0.25 SEC:B-B ∅1.60±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. C1581F-TB-L C1581F-TP-L C1581F-GB-L C1581F-GP-L Material Brass Phosphor Bronze Insulation O.D. 1.57mm(max) 1.57mm(max) 1.57mm(max) 1.57mm(max) AWG#24-#30 AWG#24-#30 AWG#24-#30 AWG#24-#30 Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 8,000 PCS 8,000 PCS 8,000 PCS 8,000 PCS Optional Gold plating available but MOQ requested C1581M-T-L 3.68mm pitch Crimp Terminal Reference Informations: *Used in CJT C1581HMB,C1581HMC series Housing 9.50±0.25 2.00 1.90±0.25 16.95±0.25 B 2.85±0.20 1.82±0.25 7.40±0.20 B SEC:A-A 1.76±0.25 A 2.05 A 1.90±0.25 0.20 SEC:B-B ∅1.56±0.10 Unit:mm Ordering information & Specifications: Part NO. C1581M-TB-L C1581M-TP-L C1581M-GB-L C1581M-GP-L Wire Range AWG#24-#30 AWG#24-#30 AWG#24-#30 AWG#24-#30 Insulation O.D. 1.57mm(max) 1.57mm(max) 1.57mm(max) 1.57mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 8,000 PCS 8,000 PCS 8,000 PCS 8,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-14 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMB(Suitable Terminal:C1581M-T(-L)) *C1581HFB(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HMB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C1581HFB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C1581HMB C1581HFB 5.10±0.15 4.95±0.20 9.50±0.20 22.20±0.25 6.20±0.20 22.20±0.25 C1581HM-1P C1581HF-1P 9.75±0.25 7.36±0.20 12.30±0.25 Circuit 1 3.68±0.10 3.68 9.90±0.25 7.36±0.20 Circuit 1 3.68±0.10 12.40±0.25 15.00±0.25 Circuit 1 3.68±0.10 9.75±0.20 C1581HFB-2P 7.36±0.20 C1581HMB-2P 19.10±0.25 11.04±0.20 9.90±0.25 15.98±0.25 Circuit 1 3.68±0.10 18.68±0.25 Circuit 1 11.04±0.20 9.75±0.20 19.80±0.25 C1581HFB-3P 3.68±0.10 C1581HMB-3P 16.08±0.25 19.80±0.25 12.30±0.25 11.32±0.25 8.72±0.25 Circuit 1 19.10±0.25 9.90±0.25 19.10±0.25 C1581HMB-4P 19.80±0.25 C1581HFB-4P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-15 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Ordering Information: C1581HMB-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMB(Suitable Terminal:C1581M-T(-L)) *C1581HFB(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HFB-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C1581HMB C1581HFB 9.90±0.25 Circuit 1 3.68±0.10 8.78±0.20 11.20±0.25 Circuit 1 Circuit 2 Last Circuit C1581HFB-2x2P 7.36±0.20 14.96±0.25 3.68±0.10 Circuit 3 Circuit 1 3.68±0.10 Last Circuit Last Circuit 3.68±0.10 Circuit 3 14.96±0.25 7.36±0.20 Circuit 3 3.68±0.10 Circuit 1 Circuit 1 Circuit 3 12.46±0.25 Last Circuit C1581HM-3x3P 7.36±0.20 3.68±0.10 7.36±0.20 3.68±0.10 12.40±0.25 Last Circuit 19.10±0.25 9.90±0.25 C1581HFB-3x2P 15.00±0.25 3.68±0.10 C1581HMB-3x2P 19.80±0.25 Circuit 1 12.46±0.20 7.36±0.20 7.36±0.20 8.62±0.20 8.72±0.20 11.32±0.25 C1581HMB-2x2P 19.10±0.25 9.90±0.25 3.68±0.10 3.68±0.10 12.30±0.25 19.10±0.25 Last Circuit 19.80±0.25 Circuit 1 3.68±0.10 3.68±0.10 8.72±0.20 Circuit 2 C1581HFB-5P 8.62±0.20 C1581HMB-5P 3.68±0.10 19.10±0.25 11.32±0.25 19.66±0.25 14.72±0.20 14.72±0.20 22.36±0.25 Circuit 1 19.76±0.25 19.80±0.25 3.68±0.10 9.75±0.20 9.90±0.20 19.80±0.25 C1581HFB-3x3P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-16 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Ordering Information: C1581HMB-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMB(Suitable Terminal:C1581M-T(-L)) *C1581HFB(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HFB-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm 3.68±0.10 C1581HFB 14.96±0.25 7.36±0.20 Circuit 3 Circuit 1 Circuit 3 15.98±0.25 12.46±0.25 11.04±0.20 3.68±0.10 7.36±0.20 7.36±0.10 16.08±0.25 Last Circuit 19.10±0.25 9.90±0.20 3.68±0.10 Circuit 1 18.68±0.25 11.04±0.20 C1581HMB 19.80±0.25 Last Circuit 7.36±0.20 14.96±0.25 Circuit 1 Circuit 1 Circuit 3 14.72±0.20 3.68±0.10 12.46±0.25 7.36±0.20 11.04±0.10 Last Circuit 19.10±0.25 9.90±0.20 3.68±0.10 Circuit 3 19.66±0.25 3.68±0.10 C1581HFB-3x4P 22.36±0.25 19.76±0.25 14.72±0.20 C1581HMB-3x4P 19.80±0.25 Last Circuit C1581HMB-3x5P C1581HFB-3x5P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-17 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMC(Suitable Terminal:C1581M-T(-L)) *C1581HFC(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HMC-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C1581HFC-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C1581HFC 5.10±0.20 Circuit 1 3.68±0.10 C1581HMC-2P C1581HFC-2P 5.10±0.20 7.36±0.20 3.68±0.10 7.60±0.20 7.36±0.20 Circuit 1 3.68±0.10 12.40±0.25 15.00±0.25 Circuit 1 19.10±0.25 C1581HMC-3P 19.80±0.25 9.10±0.20 5.10±0.20 Circuit 1 15.98±0.25 11.04±0.20 3.68±0.10 11.04±0.20 3.68±0.10 16.08±0.25 18.68±0.25 7.60±0.20 C1581HMC-4P 19.80±0.25 C1581HFC-4P 9.10±0.20 5.10±0.20 19.66±0.25 3.68±0.10 7.60±0.20 14.72±0.20 14.72±0.20 Circuit 1 3.68±0.10 19.76±0.25 22.36±0.25 Circuit 1 19.10±0.25 9.10±0.20 C1581HFC-3P Circuit 1 19.10±0.25 9.10±0.25 19.80±0.25 12.30±0.25 7.60±0.20 3.68±0.10 19.10±0.25 11.32±0.25 8.72±0.25 Circuit 1 8.62±0.25 C1581HMC C1581HMC-5P 19.80±0.25 C1581HFC-5P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-18 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Ordering Information: C1581HMC-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMC(Suitable Terminal:C1581M-T(-L)) *C1581HFC(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HFC-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm 3.68±0.10 Last Circuit Last Circuit 3.68±0.10 Circuit 2 11.30±0.25 7.36±0.20 3.68±0.10 Circuit 1 3.68±0.10 Last Circuit 3.68±0.10 7.36±0.20 Circuit 2 19.80±0.25 Last Circuit C1581HMC-3x2P C1581HFC-3x2P 7.36±0.20 12.40±0.25 3.68±0.10 7.36±0.20 Last Circuit C1581HMC-3x3P Circuit 3 7.36±0.20 14.96±0.25 7.36±0.20 3.68±0.10 Last Circuit Circuit 1 Circuit 1 15.00±0.25 Circuit 3 12.46±0.25 3.68±0.10 3.68±0.10 19.10±0.25 9.10±0.20 Circuit 1 12.46±0.25 12.30±0.25 11.32±0.25 8.72±0.20 Circuit 3 8.62±0.25 C1581HFC-2x2P 14.96±0.25 19.10±0.25 Circuit 1 8.78±0.25 C1581HMC-2x2P 9.75±0.25 19.80±0.25 8.62±0.25 Circuit 1 3.68±0.10 Circuit 2 3.68±0.10 11.32±0.25 8.72±0.20 9.75±0.25 19.10±0.25 C1581HFC 3.68±0.10 C1581HMC 19.80±0.25 9.10±0.20 C1581HFC-3x3P 7.36±0.20 3.68±0.10 Circuit 1 12.46±0.25 Circuit 1 19.80±0.25 Circuit 3 15.98±0.25 7.36±0.20 Last Circuit C1581HMC-3x4P 11.04±0.20 3.68±0.10 Last Circuit 14.96±0.25 3.68±0.10 11.04±0.20 19.10±0.25 3.68±0.10 16.08±0.25 18.68±0.25 Circuit 3 9.10±0.20 C1581HFC-3x4P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-19 C1581 SERIES C1581H 3.68mm pitch wire to wire connector 3.68mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *C1581HMC(Suitable Terminal:C1581M-T(-L)) *C1581HFC(Suitable Terminal:C1581F-T(-L)) *Color:Natural Ordering Information: C1581HMC-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C1581HFC-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C1581HMC C1581HFC 7.36±0.20 Circuit 1 Circuit 1 19.80±0.25 Circuit 3 3.68±0.10 Last Circuit 7.36±0.20 14.96±0.25 Last Circuit C1581HMC-3x5P 3.68±0.10 14.72±0.20 19.10±0.25 3.68±0.10 19.76±0.25 22.36±0.25 14.72±0.20 Circuit 3 12.46±0.25 19.66±0.25 3.68±0.10 9.10±0.20 C1581HFC-3x5P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-20
C1581F-TB 价格&库存
很抱歉,暂时无法提供与“C1581F-TB”相匹配的价格&库存,您可以联系我们找货
C1581F-TB
