C2003HF-11P
C2003HF-11P
    CJT(长江连接器)
    Housings
    间距P=2.00mm 胶壳 11pin 125V 2A
C2003HF-11P 数据手册
C2003 SERIES 2.00mm pitch wire to wire connector Specifications Current rating:2A AC,DC Voltage rating:125V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 14.80 REF. 21.35 REF 2.70 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-36 C2003 SERIES C2003F-T 2.00mm pitch wire to wire connector 2.00mm pitch Crimp Terminal Reference Informations: *Used in CJT C2003HF-XP series Housing 1.90±0.25 2.00±0.25 0.20 0.65 SEC:A-A 1.45±0.25 A 1.60±0.25 C SEC:B-B 3.65±0.20 C 0.50 4.85±0.20 B 0.85 B 8.35±0.25 A 1.15±0.20 1.00 1.50±0.25 SEC:C-C 0.80 1.50 Unit:mm Ordering information & Specifications: Wire Range Part NO. C2003F-TP C2003F-GP AWG#24-#28 AWG#24-#28 Material Phosphor Bronze Phosphor Bronze Insulation O.D. 1.15mm(max) 1.15mm(max) Qty/reel 10,000 PCS 10,000 PCS Finish Tin over Nickel Gold over Nickel Optional Gold plating available but MOQ requested C2003M-T 2.00mm pitch Crimp Terminal SEC:A-A 0.65 0.20 2.00±0.25 1.90±0.25 Reference Informations: *Used in CJT C2003HM-XP series Housing 1.50±0.25 C 0.72 SEC:B-B 1.60±0.25 C 5.54±0.20 B 1.30 B 0.84 A 8.73±0.25 A 0.50 1.50±0.25 1.00 SEC:C-C Unit:mm Ordering information & Specifications: Part NO. C2003M-TP C2003M-GP Wire Range AWG#24-#28 AWG#24-#28 1.25±0.25 0.40 Insulation O.D. 1.15mm(max) 1.15mm(max) Material Phosphor Bronze Phosphor Bronze Finish Tin over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-37 C2003 SERIES C2003FB-T 2.00mm pitch wire to wire connector 2.00mm pitch Crimp Terminal Reference Informations: *Used in CJT C2003HFB-XP series Housing 2.68±0.25 0.20 A 1.50±0.25 B SEC:A-A 1.30 B 7.50±0.25 A 3.00±0.25 0.80 2.40±0.25 1.60±0.25 1.90±0.25 1.50±0.20 2.00±0.20 SEC:B-B 0.60±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. C2003FB-TP C2003FB-GP AWG#22-#26 AWG#22-#26 Insulation O.D. 1.50mm(max) 1.50mm(max) Material Phosphor Bronze Phosphor Bronze Finish Tin over Nickel Gold over Nickel Qty/reel 8,000 PCS 8,000 PCS Optional Gold plating available but MOQ requested C2003MB-T 2.00mm pitch Crimp Terminal 0.20 2.55±0.25 Reference Informations: *Used in CJT C2003HMB-XP series Housing 2.10±0.25 SEC:A-A C C 1.55±0.25 SEC:B-B 2.45±0.25 B 4.40±0.25 B 1.45±0.25 A 13.50±0.25 A 1.60±0.25 0.54±0.05 0.48±0.05 SEC:C-C Unit:mm Ordering information & Specifications: Part NO. C2003MB-TP C2003MB-GP Wire Range AWG#22-#26 AWG#22-#26 Insulation O.D. 1.50mm(max) 1.50mm(max) Material Phosphor Bronze Phosphor Bronze Finish Tin over Nickel Gold over Nickel Qty/reel 8,000 PCS 8,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-38 C2003 SERIES C2003HF-XP 2.00mm pitch wire to wire connector 2.00mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2003F-T series Terminal *Mates with CJT C2003HM-XP series Housing *Color:White Circuit 1 2.00±0.10 Ordering Information: C2003HF-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 1.00 A±0.20 2.10±0.20 B±0.25 PART NO. 9.20±0.25 5.20±0.20 Ordering Information & Dimensions: C±0.25 2.70±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 Dimensions B 6.60 8.60 10.60 12.60 14.60 16.60 18.60 20.60 22.60 24.60 26.60 28.60 C 4.60 6.60 8.60 10.60 12.60 14.60 16.60 18.60 20.60 22.60 24.60 26.60 Unit: mm C2003HM-XP 2.00mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2003M-T series Terminal *Mates with CJT C2003HF-XP series Housing *Color:White Circuit 1 Ordering Information: C2003HM-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.00±0.10 A±0.20 2.50±0.20 B±0.25 C±0.25 PART NO. 10.80±0.25 5.20±0.20 Ordering Information & Dimensions: 2.80±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P A 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 Dimensions B 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 C 4.60 6.60 8.60 10.60 12.60 14.60 16.60 18.60 20.60 22.60 24.60 26.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-39 C2003 SERIES C2003HFB-XP 2.00mm pitch wire to wire connector 2.00mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2003FB-T series Terminal *Mates with CJT C2003HMB-XP series Housing and C2003SB-XP series Seal *Color:White Ordering Information: C2003HFB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C A±0.20 A±0.20 2.00±0.10 Circuit 1 Circuit 1 B±0.25 B±0.25 6.45±0.25 10.05±0.25 Ordering Information & Dimensions: 2P 3P~6P,8P,10P PART NO. 2P 3P 4P 5P 6P 8P 10P Dimensions A B 2.00 5.70 4.00 7.70 6.00 9.70 8.00 11.70 10.00 13.70 14.00 17.70 18.00 21.70 Unit: mm C2003HMB-XP Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2003MB-T series Terminal *Mates with CJT C2003HFB-XP series Housing and C2003SB-XP series Seal *Color:White A±0.20 2.00mm Pitch Housing Ordering Information: C2003HMB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.00±0.10 5.90±0.25 19.30±0.25 Circuit 1 B±0.25 3.20 7.60±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 8P 10P Dimensions A B 2.00 6.00 4.00 8.00 6.00 10.00 8.00 12.00 10.00 14.00 14.00 18.00 18.00 22.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-40 C2003 SERIES C2003SB-XP Reference Informations: *Material:Nylon 66,UL94V-2 *Mates with CJT C2003HFB,HMB-XP series Housing *Color:White 2.00mm pitch wire to wire connector 2.00mm Pitch SeaL Ordering Information: C2003SB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C A±0.20 2.00±0.10 B±0.25 7.05±0.25 5.60±0.25 2.25±0.25 Ordering Information & Dimensions: PART NO. 2P 4P 6P 8P 10P Dimensions A B 2.00 6.30 4.00 10.30 6.00 14.30 8.00 18.30 10.00 22.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-41
C2003HF-11P
物料型号: - C2003F-TP/GP:2.00mm间距压接端子,适用于C2003HF-XP系列塑壳 - C2003M-TP/GP:2.00mm间距压接端子,适用于C2003HM-XP系列塑壳 - C2003FB-TP/GP:2.00mm间距压接端子,适用于C2003HFB-XP系列塑壳 - C2003MB-TP/GP:2.00mm间距压接端子,适用于C2003HMB-XP系列塑壳 - C2003HF-XP/HM-XP/HFB-XP/HMB-XP/SB-XP:2.00mm间距塑壳,不同系列对应不同端子和密封
器件简介: C2003系列提供了多种2.00mm间距的线对线连接器,包括压接端子和塑壳,适用于不同的应用需求。
引脚分配: 文档中未明确提供引脚分配图,但提供了不同电路配置的尺寸信息。
参数特性: - 电流额定值:2A AC/DC - 电压额定值:125V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大20mΩ - 最小绝缘电阻:1000MΩ - 耐电压:500V AC/分钟
功能详解: - 符合RoHS和REACH标准 - 提供HF/无卤素选项,需要定制 - 提供不同材料和表面处理的端子,如磷青铜镀锡/镀金
应用信息: 适用于需要2.00mm间距连接器的各种电子设备和应用。
封装信息: - 塑壳材料:尼龙66,UL94V-0或UL94V-2 - 颜色:白色 - 提供不同电路配置的塑壳,如2至10极
C2003HF-11P 价格&库存
很抱歉,暂时无法提供与“C2003HF-11P”相匹配的价格&库存,您可以联系我们找货
