C2363HM-3x4P
C2363HM-3x4P
    CJT(长江连接器)
    P=6.7mm
    胶壳 间距P=6.70mm 12Pin(3x4)
C2363HM-3x4P 数据手册
C2363 SERIES 6.70mm pitch wire to wire and wire to board connector Specifications Current rating:12A AC,DC Voltage rating:600V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 14.70 47.80 REF. 19.30 26.00 21.60 47.80 REF. 1.60 47.80 REF. 28.10 32.80 REF. 1.60 32.80 REF. 1.60 32.80 REF. 12.60 wire to board wire to wire A±0.10 PART NO. B±0.10 C2363HM-1P C2363HM-2P C2363HM-3P C2363HM-4P C2363HM-2x3P C2363HM-3x3P C2363HM-3x4P C2363HM-3x5P Dimensions A 14.20 20.90 27.20 34.30 27.90 28.40 35.40 41.90 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-48 B 9.80 10.00 10.00 10.00 17.30 23.70 23.70 23.70 Unit:mm C2363 SERIES C2363H 6.70mm pitch wire to wire and wire to board connector 6.70mm Pitch Housing Ordering Information: C2363HF-XP - *** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C2363HM(Suitable Terminal: C5030M-T(-H),C5030ML-T(-H) ) *C2363HF(Suitable Terminal: C5030F-T(-H) ) *Color:Natural Ordering Information: C2363HM-XP - *** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C2363HF C2363HM C2363HM-1P C2363HMA-1P(WITHOUT EARS) 8.10±0.20 18.00±0.20 7.60±0.20 30.00±0.25 30.00±0.25 8.10±0.25 7.80±0.25 10.60±0.25 11.20±0.25 C2363HF-1P C2363HM-2P C2363HMA-2P(WITHOUT EARS) 8.20±0.20 Circuit 1 7.60±0.20 14.70±0.25 6.70±0.20 6.70±0.10 14.30±0.25 18.00±0.20 13.20±0.35 12.60±0.25 C2363HF-2P Circuit 1 30.00±0.35 30.00±0.35 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-49 C2363 SERIES C2363H 6.70mm pitch wire to wire and wire to board connector 6.70mm Pitch Housing Unit: mm C2363HF C2363HM 12.60±0.25 13.20±0.25 C2363HM-3P C2363HMA-3P(WITHOUT EARS) C2363HF-3P 18.00±0.20 Circuit 1 21.40±0.25 13.40±0.20 13.40±0.10 21.00±0.35 6.70±0.10 6.70±0.10 8.20±0.20 Circuit 1 7.60±0.20 30.00±0.35 30.00±0.35 12.60±0.25 13.20±0.25 C2363HM-4P C2363HMA-4P(WITHOUT EARS) C2363HF-4P 18.00±0.20 Circuit 1 7.60±0.20 28.10±0.35 20.10±0.20 6.70±0.10 20.10±0.10 27.70±0.35 6.70±0.10 8.20±0.20 Circuit 1 30.00±0.35 30.00±0.35 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-50 C2363 SERIES C2363H 6.70mm pitch wire to wire and wire to board connector 6.70mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 or UL94V-0 *C2363HM(Suitable Terminal: C5030M-T(-H,C5030ML-T(-H) ) ) *C2363HF(Suitable Terminal: C5030F-T(-H) ) *Color:Natural Ordering Information: C2363HF-2xXP - ** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C2363HM-2xXP - ** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C2363HF-3xXP - ** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information: C2363HM-3xXP - ** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Unit: mm C2363HF C2363HM C2363HM-2x3P C2363HMA-2x3P(WITHOUT EARS) Circuit 3 Last Circuit 18.00±0.20 13.40±0.20 13.40±0.10 21.00±0.35 14.30±0.25 6.70±0.10 14.90±0.20 Circuit 1 6.70±0.10 30.00±0.35 21.40±0.25 Circuit 3 6.70±0.10 Last Circuit 19.90±0.25 19.30±0.35 C2363HF-2x3P Circuit 1 30.00±0.25 6.70±0.10 C2363HM-3x3P C2363HMA-3x3P(WITHOUT EARS) 21.60±0.20 Last Circuit 13.40±0.20 Circuit 3 13.40±0.10 21.00±0.25 21.00±0.25 6.70±0.10 Circuit 3 6.70±0.10 18.00±0.20 13.40±0.10 30.00±0.25 21.40±0.25 Last Circuit 6.70±0.10 26.00±0.25 26.60±0.25 C2363HF-3x3P Circuit 1 Circuit 1 6.70±0.10 30.00±0.35 13.40±0.10 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-51 C2363 SERIES C2363H 6.70mm pitch wire to wire and wire to board connector 6.70mm Pitch Housing Unit: mm C2363HF C2363HM C2363HM-3x4P C2363HMA-3x4P(WITHOUT EARS) 26.00±0.35 26.60±0.35 C2363HF-3x4P 21.00±0.35 21.60±0.20 Last Circuit 6.70±0.10 Circuit 4 6.70±0.10 27.70±0.35 20.10±0.10 20.10±0.20 Circuit 4 Circuit 1 6.70±0.10 18.00±0.20 30.00±0.35 28.10±0.35 Last Circuit Circuit 1 6.70±0.10 13.40±0.10 30.00±0.35 13.40±0.10 C2363HM-3x5P C2363HMA-3x5P(WITHOUT EARS) 26.60±0.35 26.00±0.35 C2363HF-3x5P 21.60±0.30 21.00±0.35 Last Circuit 34.80±0.35 26.80±0.20 6.70±0.10 Circuit 1 6.70±0.10 18.00±0.20 30.00±0.25 Circuit 5 26.80±0.20 34.40±0.35 Circuit 5 6.70±0.10 Last Circuit Circuit 1 6.70±0.10 13.40±0.20 30.00±0.30 13.40±0.10 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-52 C2363 SERIES C2363WV 6.70mm pitch wire to wire and wire to board connector 6.70mm Pitch 180° Wafer Ordering Information: C2363WV-XP - *** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT C2363HF-XP series single row Housing *Color:Natural 13.40±0.20 3.80±0.20 3.30±0.20 8.20±0.25 3.30±0.20 21.60±0.25 15.00±0.25 14.90±0.25 15.00±0.25 2.00±0.20 Circuit 1 3.00±0.20 1.30±0.20 2.00±0.20 Circuit 1 6.00±0.20 6.70±0.10 6.00±0.20 1.30±0.20 6.70±0.10 ∅1.80 ∅1.80 C2363WV-3P C2363WV-2P 6.00±0.10 20.10±0.20 ∅3.00±0.05 6.70±0.10 6.00±0.20 ∅2.20±0.05 Circuit 1 2.00±0.20 28.30±0.25 3.80±0.20 3.30±0.20 15.00±0.25 8.20±0.25 3.00±0.20 1.30±0.20 P.C.B LAYOUT 1.10±0.05 6.70±0.10 C2363WV-4P CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-53 C2363 SERIES C2363WV-2x3P 6.70mm Pitch 180° Dual Row Wafer Ordering Information: C2363WV-2x3P - *** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT C2363HF-2x3P series Dual Row Housing *Color:Natural Circuit 1 6.00±0.20 6.70mm pitch wire to wire and wire to board connector 6.70±0.20 6.70±0.10 13.40±0.20 6.70±0.10 Circuit 3 Last Circuit ∅2.20±0.05 P.C.B LAYOUT 3.30±0.20 3.80±0.20 15.00±0.25 21.60±0.25 6.00±0.10 3.00±0.20 6.70±0.20 18.50±0.25 3.35±0.10 14.90±0.25 ∅3.00±0.05 ∅1.80 2.00±0.20 6.70mm Pitch 180° Triple Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT C2363HF-3x3P series Triple Row Housing *Color:Natural 13.40±0.20 6.70±0.10 ∅3.00±0.05 6.70±0.20 13.40±0.20 21.60±0.25 6.70±0.20 Circuit 3 6.90±0.20 ∅2.20±0.05 6.00±0.10 3.00±0.10 Circuit 1 6.00±0.20 Ordering Information: C2363WV-3x3P - *** 1 2 1.Part No. 2.Material/Color: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Last Circuit P.C.B LAYOUT 3.30±0.20 15.00±0.25 21.60±0.25 3.80±0.20 6.70±0.10 C2363WV-3x3P 2.00±0.20 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-54
C2363HM-3x4P
物料型号: - C2363HM-1P - C2363HM-2P - C2363HM-3P - C2363HM-4P - C2363HM-2x3P - C2363HM-3x3P - C2363HM-3x4P - C2363HM-3x5P
器件简介: CJT C2363系列是6.70mm间距的线对线和线对板连接器。
引脚分配: 文档中提供了不同型号的引脚分配和尺寸信息,例如C2363HM-1P具有10.60mm的A尺寸和18.00mm的B尺寸。
参数特性: - 电流额定值:12A AC/DC - 电压额定值:600V AC/DC - 温度范围:-40°C~+105°C - 接触电阻:10mΩ Max - 最小绝缘电阻:1000MΩ Min - 耐电压:1500V AC/分钟
功能详解: 文档中提供了详细的组装布局和面板孔布局信息,以及不同型号的尺寸和电路信息。
应用信息: 文档中提到了符合RoHS和REACH标准,以及满足HF/Halogen Free, GWT/Glow wire Test (IEC60335-1)的请求,但需要定制。
封装信息: 提供了不同型号的封装尺寸和材料信息,例如材料为Nylon 66,UL94V-2或UL94V-0,颜色为自然色。
C2363HM-3x4P 价格&库存
很抱歉,暂时无法提供与“C2363HM-3x4P”相匹配的价格&库存,您可以联系我们找货
