C2501HF-2P
C2501HF-2P
    CJT(长江连接器)
    P=2.5mm
    胶壳 间距P=2.50mm 2Pin(1x2)
C2501HF-2P 数据手册
C2501 SERIES 2.50mm pitch wire to wire connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩ Max. Insulation resistance:500MΩ Min. Withstanding voltage:5000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 4.00 E326732 23.42 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-55 C2501 SERIES C2501F-T 2.50mm pitch wire to wire connector 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT C2501HF-2P series Housing 0.20 SEC:A-A A 1.82 A 2.60±0.20 1.40±0.20 3.05±0.20 3.40±0.20 SEC:B-B 1.20±0.20 1.65±0.20 1.85±0.20 Unit:mm Ordering information & Specifications: Part NO. C2501F-TB C2501F-TP C2501F-GB C2501F-GP Wire Range AWG#22-#28 AWG#22-#28 AWG#22-#28 AWG#22-#28 1.90±0.20 1.80±0.20 0.55 5.75±0.20 B 11.70±0.25 B Insulation O.D. 1.80mm(max) 1.80mm(max) 1.80mm(max) 1.80mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 7,000 PCS 7,000 PCS 7,000 PCS 7,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-56 C2501 SERIES C2501HF-2P 2.50mm pitch wire to wire connector 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 or UL94V-0 *Suitable CJT C2501F-T series Terminal *Mates with CJT C2501HM-2P series Housing *Color:Red 6.25±0.20 2.50±0.10 1 2 5.30±0.20 3.20±0.20 Ordering Information: C2501HF-2P - *** 1 2 1.Part No. 2.Color and Material: (blank):Red/Nylon 66,UL94V-2 WH:White/Nylon 66,UL94V-0 BK:Black/Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 4.20±0.20 Circuit 1 13.20±0.25 Unit: mm C2501HM-2P 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 or UL94V-0 *Suitable CJT C2521M-T series Terminal *Mates with CJT C2501HF-2P series Housing *Color:Red 4.00±0.20 Ordering Information: C2501HM-2P - *** 1 2 1.Part No. 2.Color and Material: (blank):Red/Nylon 66,UL94V-2 WH:White/Nylon 66,UL94V-0 BK:Black/Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 2.50±0.10 7.00±0.20 6.00±0.20 2 1 Circuit 1 9.50±0.20 19.20±0.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-57
C2501HF-2P 价格&库存
很抱歉,暂时无法提供与“C2501HF-2P”相匹配的价格&库存,您可以联系我们找货
