C2504WV-10P
C2504WV-10P
    CJT(长江连接器)
    插件,P=2.5mm
    线对板连接器 10Pin(1x10P) P=2.50mm 直插
C2504WV-10P 数据手册
C2504 SERIES 2.50mm pitch wire to wire and wire to board connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:20mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 E326732 6.70 17.06 REF. 13.30 REF. 1.60 9.23 1.60 11.70 REF. 6.32 PART NO. 8.50±0.10 A±0.10 C2504HM-2P C2504HM-3P C2504HM-4P C2504HM-5P C2504HM-6P C2504HM-7P C2504HM-8P C2504HM-9P C2504HM-10P C2504HM-11P C2504HM-12P Dimensions A 12.40 14.90 17.40 19.90 22.40 24.90 27.40 29.90 32.40 34.90 37.40 Unit:mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-58 C2504 SERIES C2504HFA-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2509-T-A series Terminal *Mates with CJT C2504HM,HMA,HMB-XP series Housing or C2504WV,WR-XP,C2504WVR-XP series Wafer *Color:Beige 1.10 1.30 Circuit 1 2.50±0.10 A±0.20 Ordering Information: C2504HFA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 6.55±0.25 1.00 0.95 10.00±0.25 4.80±0.20 7.40±0.20 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.60 5.00 8.10 7.50 10.60 10.00 13.10 12.50 15.60 15.00 18.10 17.50 20.60 23.10 20.00 22.50 25.60 25.00 28.10 27.50 30.60 30.00 33.10 32.50 35.60 35.00 38.10 37.50 40.60 40.00 43.10 42.50 45.60 45.00 48.10 47.50 50.60 Unit: mm C2504AH-XP 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A2543-T series Terminal *Mates with CJT C2504WV,WR-XP, C2504WVR-XP series Wafer *Color:Beige Circuit 1 2.50±0.10 A±0.20 Ordering Information: C2504AH-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 6.30±0.25 4.85±0.20 12.70±0.25 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.50 5.00 8.00 7.50 10.50 10.00 13.00 12.50 15.50 15.00 18.00 17.50 20.50 20.00 23.00 22.50 25.50 25.00 28.00 27.50 30.50 30.00 33.00 32.50 35.50 35.00 38.00 37.50 40.50 40.00 43.00 42.50 45.50 45.00 48.00 47.50 50.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-59 C2504 SERIES C2504HM-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:Beige Ordering Information: C2504HM-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 5.00±0.20 Circuit 1 2.50±0.10 A±0.20 B±0.25 7.90±0.25 A Ordering Information & Dimensions: 18.50±0.25 PART NO. A 5.00±0.20 C±0.25 SEC:A-A C2504HMA-XP Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:Beige B±0.25 A±0.20 2.50±0.10 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P A 2.50 5.00 7.50 10.00 12.50 15.00 17.50 20.00 22.50 25.00 27.50 Dimensions B 8.60 11.10 13.60 16.10 18.60 21.10 23.60 26.10 28.60 31.10 33.60 C 5.80 8.30 10.80 13.30 15.80 18.30 20.80 23.30 25.80 28.30 30.80 Unit: mm 2.50mm Pitch Housing Ordering Information: C2504HMA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Beige WH:White 7.90±0.25 Circuit 1 Ordering Information & Dimensions: 18.70±0.25 PART NO. C±0.25 5.00±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P A 2.50 5.00 7.50 10.00 12.50 15.00 17.50 20.00 22.50 25.00 27.50 Dimensions B 8.60 11.10 13.60 16.10 18.60 21.10 23.60 26.10 28.60 31.10 33.60 C 5.80 8.30 10.80 13.30 15.80 18.30 20.80 23.30 25.80 28.30 30.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-60 C2504 SERIES C2504HMB-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch Housing Ordering Information: C2504HMB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66, UL94V-0 *Suitable CJT A2501M-T series Terminal *Mates with CJT C2504HFA-XP series Housing *Color:White 5.00±0.20 8.95±0.25 2.50±0.10 2.50±0.10 Circuit 1 Circuit 1 18.75±0.25 4.25±0.25 6.36±0.25 6.05±0.20 18.70±0.25 8.05±0.20 11.50±0.25 8.50±0.25 2P 8.05±0.20 6.05±0.20 4.25±0.25 3P C2504WV-XP 2.50mm Pitch 180° Wafer Ordering Information: C2504WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige Circuit 1 2.50±0.10 Ordering Information & Dimensions: PART NO. Ø1.20±0.05 2.50±0.10 P.C.B LAYOUT A±0.20 5.80±0.20 B±0.25 PIN 0.64 SQ 11.70±0.25 7.50±0.20 3.40±0.20 3.30±0.20 3.20 4.90±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-61 C2504 SERIES C2504WR-XP 2.50mm pitch wire to wire and wire to board connector 2.50mm Pitch 90° Wafer Ordering Information: C2504WR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 2.50±0.10 13.30±0.25 4.90±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige Ordering Information & Dimensions: PART NO. Ø1.20±0.05 P.C.B LAYOUT 2.50±0.10 Circuit 1 A±0.20 7.50±0.25 6.00±0.20 3.40±0.20 6.30±0.25 B±0.25 3.20±0.20 PIN 0.64 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm C2504WVR-XP 2.50mm Pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C2504HFA,AH-XP series Housing *Color:Beige PIN 0.64 SQ Ordering Information: C2504WVR-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 2.50±0.10 Circuit 1 Ordering Information & Dimensions: Ø1.20±0.05 PART NO. P.C.B LAYOUT 2.50±0.10 A±0.20 5.80±0.20 B±0.25 7.30±0.20 11.50±0.25 3.30±0.20 3.20 5.10±0.20 3.40±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 16P 17P 18P 19P 20P Dimensions A B 2.50 5.00 5.00 7.50 7.50 10.00 10.00 12.50 12.50 15.00 15.00 17.50 17.50 20.00 20.00 22.50 22.50 25.00 25.00 27.50 27.50 30.00 30.00 32.50 32.50 35.00 35.00 37.50 37.50 40.00 40.00 42.50 42.50 45.00 45.00 47.50 47.50 50.00 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-62
C2504WV-10P
物料型号: - C2504HM-2P至C2504HM-12P:不同引脚数量的型号,从2P到12P。 - C2504HFA-XP、C2504AH-XP、C2504HM-XP:不同系列的外壳型号。 - C2504HMA-XP、C2504HMB-XP:不同颜色和材料的外壳型号。 - C2504WV-XP、C2504WR-XP、C2504WVR-XP:不同角度的焊片型号。
器件简介: - 这些连接器适用于2.50mm间距的线对线和线对板连接。 - 材料为尼龙66,符合UL94V-0标准。 - 颜色通常为米色,但C2504HMB-XP系列为白色。
引脚分配: - 提供了不同引脚数量的型号,从2P到20P。 - 引脚间距为2.50mm±0.10mm。
参数特性: - 电流额定值:3A AC/DC - 电压额定值:250V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大20mΩ - 最小绝缘电阻:1000MΩ - 耐电压:1000V AC/分钟 - 符合RoHS和REACH标准 - 提供无卤/无卤素产品,需定制
功能详解: - 连接器适用于各种电子设备中的电气连接。 - 提供了不同系列的外壳和焊片,以适应不同的应用需求。
应用信息: - 适用于需要电气连接的场合,如电子设备、家用电器等。
封装信息: - 提供了详细的组装布局和面板孔布局的尺寸信息。 - 列出了不同型号的尺寸参数,包括A和B的尺寸。
订购信息: - 提供了订购时需要提供的信息,如部件编号、材料、颜色和表面处理。
参考信息: - 提供了与CJT A2509-T-A系列端子、CJT A2543-T系列端子和CJT A2501M-T系列端子兼容的型号。
联系方式: - 提供了长江连接器的联系电话、传真和官方网站。
C2504WV-10P 价格&库存
很抱歉,暂时无法提供与“C2504WV-10P”相匹配的价格&库存,您可以联系我们找货
