C2521HM-8P
C2521HM-8P
    CJT(长江连接器)
    Housings
    间距P=2.50mm 胶壳 8pin 250V 3A
C2521HM-8P 数据手册
C2521 SERIES 2.50mm pitch wire to wire connector Specifications Current rating:3A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩ Max. Insulation resistance:500MΩ Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,need to customize* *Contact CJT for details* Standards E326732 9.47 E326732 15.10 23.20 REF. 23.30 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-63 C2521 SERIES 5.15+0.15 0 4.15+0.15 0 2P~12P circuits 1.60 4.00+0.15 0 2.50mm pitch wire to wire connector A Panel thickness(mm) B 1.40 PART NO. +0.15 C2521HF-2P C2521HF-3P C2521HF-4P C2521HF-5P C2521HF-6P C2521HF-7P C2521HF-8P C2521HF-9P C2521HF-10P C2521HF-11P C2521HF-12P C2521HF-2x9P 10.150 7.150 2x9P circuits +0.15 7.00 A B 0.50~0.90 A B 5.70 9.60 8.20 12.10 10.70 14.60 13.20 17.10 15.70 19.60 18.20 22.10 20.70 24.60 23.20 27.10 25.70 29.60 28.20 32.10 30.70 34.60 23.20 27.20 1.00~1.50 A B 5.70 9.80 8.20 12.30 10.70 14.80 13.20 17.30 15.70 19.80 18.20 22.30 20.70 24.80 23.20 27.30 25.70 29.80 28.20 32.30 30.70 34.80 23.20 27.40 1.50~2.00 A B 5.70 10.00 8.20 12.50 10.70 15.00 13.20 17.50 15.70 20.00 18.20 22.50 20.70 24.00 23.20 27.50 25.70 30.00 28.20 32.50 30.70 35.00 23.20 27.60 Unit:mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-64 C2521 SERIES C2521F-T 2.50mm pitch wire to wire connector 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT A2504H-XP,C2521HF-XP,C2521HF-2x9P series Housing 3.00±0.25 B 3.00±0.25 1.00 2.00±0.25 3.90±0.25 3.00±0.10 1.20 1.90 2.10±0.25 B SEC:A-A 2.30 A 1.70 A 9.00±0.25 1.10 0.20 SEC:B-B 0.75±0.05 Unit:mm Ordering information & Specifications: Part NO. C2521F-TP C2521F-GP Wire Range Material Phosphor Bronze Phosphor Bronze Insulation O.D. 1.80mm(max) 1.80mm(max) AWG#22-#28 AWG#22-#28 Qty/reel 7,000 PCS 7,000 PCS Finish Tin over Nickel Gold over Nickel Optional Gold plating available but MOQ requested C2521M-T 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT C2501HM-2P,C2521HM-XP,C2521HM-2x9P series Housing A B 0.80 SEC:A-A 9.70±0.20 4.30 16.00±0.25 B 2.10±0.25 A 2.80±0.25 1.70 1.20 2.65±0.25 0.25 2.10±0.25 SEC:B-B 1.10 Unit:mm Ordering information & Specifications: Part NO. C2521M-TP C2521M-GP Wire Range AWG#22-#28 AWG#22-#28 Insulation O.D. 1.80mm(max) 1.80mm(max) Material Phosphor Bronze Phosphor Bronze Finish Tin over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-65 C2521 SERIES C2521F-T-B 2.50mm pitch wire to wire connector 2.50mm pitch Crimp Terminal 0.20 SEC:A-A 1.55±0.25 B 2.40±0.25 1.70±0.20 B 0.70 A 7.25±0.25 A 2.50±0.25 Reference Informations: *Used in CJT C2521HFB-XP series Housing 2.75±0.25 1.85±0.25 3.30±0.25 SEC:B-B 0.85±0.20 Unit:mm Ordering information & Specifications: Wire Range Part NO. C2521F-TP-B C2521F-GP-B Material Phosphor Bronze Phosphor Bronze Insulation O.D. 1.80mm(max) 1.80mm(max) AWG#22-#26 AWG#22-#26 Qty/reel 7,000 PCS 7,000 PCS Finish Tin over Nickel Gold over Nickel Optional Gold plating available but MOQ requested C2521M-T-B 2.50mm pitch Crimp Terminal Reference Informations: *Used in CJT C2521HMB-XP series Housing 0.80 2.40±0.25 0.20 13.70±0.25 SEC:A-A 1.30±0.25 1.60±0.25 B 3.20±0.25 B 1.80 A 2.20±0.25 A 2.30±0.25 1.60±0.25 0.65±0.10 2.60±0.25 SEC:B-B 0.80±0.20 1.80±0.25 Unit:mm Ordering information & Specifications: Part NO. C2521M-TP-B Wire Range AWG#22-#28 C2521M-GP-B AWG#22-#28 Insulation O.D. 1.80mm(max) 1.80mm(max) Material Phosphor Bronze Phosphor Bronze Finish Tin over Nickel Gold over Nickel Qty/reel 10,000 PCS 10,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-66 C2521 SERIES C2521HF-2x9P 2.50mm pitch wire to wire connector 2.50mm Pitch Dual Row Housing Ordering Information: C2521HF-2x9P - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Black WH:White 12.40±0.20 7.00 Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2521F-T series Terminal *Mates with CJT C2521HM-2x9P series Housing *Color:Black 2.50±0.10 Circuit 1 20.00±0.20 10.00±0.20 1.50 12.00±0.20 23.00±0.20 29.00±0.25 C2521HM-2x9P Unit: mm 2.50mm Pitch Dual Row Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT C2521M-T series Terminal *Mates with CJT C2521HF-2x9P series Housing *Color:Black Ordering Information: C2521HM-2x9P - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (blank):Black WH:White 12.50±0.20 20.00±0.20 7.60 15.20±0.20 25.50±0.20 23.00±0.20 19.00±0.25 2.50±0.10 10.00 Circuit 1 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-69 C2521 SERIES C2521HMI-XP 2.50mm pitch wire to wire connector 2.50mm Pitch Retainer Reference Informations: *Material:Nylon 66,UL94V-2 *Mates with CJT C2521HM-XP series Housing *Color:White Ordering Information: C2521HMI-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2 V0:Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 8.20±0.20 3.60 4.20 2P 3P 2.20±0.10 17.60±0.20 9.50±0.20 7.60±0.20 1.10 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-71
C2521HM-8P 价格&库存
很抱歉,暂时无法提供与“C2521HM-8P”相匹配的价格&库存,您可以联系我们找货
C2521HM-8P
    • 1000+0.44880
    库存:2000
