C5030F-TB
C5030F-TB
    CJT(长江连接器)
    胶壳端子 18-24AWG
C5030F-TB 数据手册
C5030 SERIES 5.03mm pitch wire to wire and wire to board connector Specifications Current rating:12A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 16.00 29.60 REF. 41.80 REF. 16.00 wire to wire wire to board CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-180 C5030 SERIES C5030F-T(-H) 5.03mm pitch wire to wire and wire to board connector 5.03mm pitch Crimp Terminal Reference Informations: *Used in CJT C2363HF;C5030HFB,HMB,HFC,HMC series Housing C SEC:A-A A B F 11.20±0.20 ∅2.80±0.10 SEC:B-B 1.30±0.25 C 4.40±0.20 8.20±0.20 C E 22.20±0.25 B 3.15 A D 2.20 0.25 3.80±0.25 Ø3.05±0.10 SEC:C-C Unit:mm Ordering information & Specifications: Part NO. C5030F-TB C5030F-TP C5030F-GB C5030F-GP C5030F-TB-H C5030F-TP-H C5030F-GB-H C5030F-GP-H Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#14-#20 AWG#14-#20 AWG#14-#20 AWG#14-#20 Insulation O.D. 3.10mm(max) 3.10mm(max) 3.10mm(max) 3.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel C 3.60 3.60 3.60 3.60 4.70 4.70 4.70 4.70 D 3.60 3.60 3.60 3.60 4.80 4.80 4.80 4.80 E 3.30 3.30 3.30 3.30 3.00 3.00 3.00 3.00 F 3.30 3.30 3.30 3.30 3.40 3.40 3.40 3.40 Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS Optional Gold plating available but MOQ requested C5030M-T(-H) 5.03mm pitch Crimp Terminal Reference Informations: *Used in CJT C2363HM,HMA;C5030HMB,HFB,HMC,HFC series Housing 2.15 0.30 C SEC:A-A E F 4.40±0.20 8.50±0.20 21.90±0.25 B D 3.00 A B 11.30±0.25 A SEC:B-B 2.36±0.10 Unit:mm Ordering information & Specifications: Part NO. C5030M-TB C5030M-TP C5030M-GB C5030M-GP C5030M-TB-H C5030M-TP-H C5030M-GB-H C5030M-GP-H Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#14-#20 AWG#14-#20 AWG#14-#20 AWG#14-#20 Insulation O.D. 3.10mm(max) 3.10mm(max) 3.10mm(max) 3.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel C 3.50 3.50 3.50 3.50 5.40 5.40 5.40 5.40 D 3.70 3.70 3.70 3.70 4.90 4.90 4.90 4.90 E 2.90 2.90 2.90 2.90 3.20 3.20 3.20 3.20 F 3.30 3.30 3.30 3.30 3.30 3.30 3.30 3.30 Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-181 C5030 SERIES C5030ML-T(-H) 5.03mm pitch wire to wire and wire to board connector 5.03mm pitch Crimp Terminal 2.15 Reference Informations: *Used in CJT C2363HM,HMA;C5030HMB,HFB,HMC,HFC series Housing C D B 11.40±0.20 4.40±0.20 SEC:A-A E F 24.80±0.25 B 3.00 A 14.20±0.25 A 0.30 SEC:B-B 2.36±0.10 Unit:mm Ordering information & Specifications: Part NO. C5030ML-TB C5030ML-TP C5030ML-GB C5030ML-GP C5030ML-TB-H C5030ML-TP-H C5030ML-GB-H C5030ML-GP-H Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#14-#20 AWG#14-#20 AWG#14-#20 AWG#14-#20 Insulation O.D. 3.10mm(max) 3.10mm(max) 3.10mm(max) 3.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) 4.10mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel Tin over Nickel Gold over Nickel C 3.50 3.50 3.50 3.50 5.40 5.40 5.40 5.40 D 3.70 3.70 3.70 3.70 4.90 4.90 4.90 4.90 E 2.90 2.90 2.90 2.90 3.20 3.20 3.20 3.20 F 3.30 3.30 3.30 3.30 3.30 3.30 3.30 3.30 Qty/reel 5,000 PCS 5,000 PCS 5,000 PCS 5,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-182 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFB/HMB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMB(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFB(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFB Unit: mm C5030HMB 24.50±0.25 Ø6.10±0.20 Ø9.10±0.25 26.70±0.25 7.56±0.20 C5030HM-1P Ø5.96±0.20 C5030HF-1P 9.60±0.20 C5030HFB-2P C5030HMB-2P 6.40±0.20 26.20±0.20 25.40±0.25 8.80±0.25 C5030HFB-3P 13.60±0.25 16.30±0.25 Circuit 1 6.30±0.10 13.70±0.25 Circuit 1 10.70±0.20 6.30±0.10 11.20±0.20 C5030HMB-3P 11.20±0.20 Circuit 1 6.10±0.20 26.20±0.25 C5030HFB-4P 8.50±0.20 17.04±0.25 19.64±0.25 5.03±0.10 10.06±0.20 5.03±0.10 17.17±0.25 Circuit 1 10.06±0.20 10.70±0.20 25.50±0.25 C5030HMB-4P 10.70±0.20 26.20±0.25 6.10±0.20 8.50±0.20 Circuit 1 22.07±0.25 24.67±0.25 5.03±0.10 15.09±0.20 15.09±0.20 22.20±0.25 Circuit 1 5.03±0.10 11.20±0.20 25.50±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-183 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFB/HMB-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMB(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFB(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFB C5030HMB C5030HFB-5P C5030HMB-5P 10.70±0.20 11.20±0.20 Circuit 1 26.20±0.25 27.10±0.25 8.50±0.20 25.50±0.25 C5030HMB-2x2P 5.03±0.10 Last circuit Circuit 2 Circuit 1 Circuit 1 26.20±0.25 11.84±0.20 Last Circuit 10.70±0.20 5.03±0.10 5.03±0.10 5.03±0.10 14.64±0.25 11.25±0.20 Circuit 2 13.53±0.25 C5030HFB-3x2P C5030HMB-3x2P 10.06±0.20 5.03±0.10 10.06±0.20 5.03±0.10 Circuit 3 Circuit 1 10.70±0.20 14.50±0.25 5.03±0.20 5.03±0.10 11.25±0.20 25.40±0.25 Circuit 3 Circuit 1 Last Circuit Last circuit C5030HFB-3x3P C5030HMB-3x3P 10.06±0.20 5.03±0.10 10.70±0.20 Circuit 1 19.53±0.25 5.03±0.10 Circuit 3 Circuit 3 Circuit 1 Last Circuit 26.20±0.25 10.06±0.20 5.03±0.10 5.03±0.10 17.17±0.25 10.06±0.20 11.25±0.20 25.40±0.25 18.54±0.25 16.87±0.25 16.16±0.25 10.06±0.20 26.20±0.25 11.84±0.25 C5030HFB-2x2P 12.14±0.20 29.70±0.25 20.12±0.20 6.10±0.20 5.03±0.10 5.03±0.10 20.12±0.20 27.23±0.25 Circuit 1 12.14±0.25 Unit: mm Last circuit 16.16±0.25 18.54±0.25 25.40±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-184 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFB/HMB-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMB(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFB(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFB Unit: mm C5030HMB C5030HMB-3x4P Circuit 3 Circuit 3 Circuit 1 Last Circuit 26.20±0.25 21.90±0.25 Circuit 1 10.70±0.20 24.56±0.25 22.20±0.25 5.03±0.10 5.03±0.10 11.25±0.20 15.09±0.20 10.06±0.20 5.03±0.10 10.06±0.20 5.03±0.10 15.09±0.20 C5030HFB-3x4P Last circuit 16.16±0.25 C5030HFB-3x5P C5030HMB-3x5P 10.06±0.20 5.03±0.10 10.06±0.20 5.03±0.10 10.70±0.20 Last Circuit 26.20±0.25 26.93±0.25 Circuit 1 29.59±0.25 Circuit 3 Circuit 1 20.12±0.20 Circuit 3 5.03±0.10 20.12±0.20 27.23±0.25 5.03±0.10 11.25±0.20 25.40±0.25 18.54±0.25 Last circuit 16.16±0.25 18.54±0.25 25.40±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-185 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFC/HMC-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMC(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFC(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFC Unit: mm C5030HMC C5030HMC-2P 6.30±0.10 C5030HFC-2P 6.40±0.20 26.20±0.25 8.80±0.20 13.70±0.25 16.30±0.25 Circuit 1 6.30±0.10 13.70±0.25 Circuit 1 10.70±0.20 25.40±0.25 6.10±0.25 26.20±0.25 16.87±0.25 19.64±0.25 5.03±0.10 10.06±0.20 Circuit 1 17.17±0.25 Circuit 1 10.06±0.20 C5030HMC-3P 5.03±0.10 C5030HFC-3P 10.70±0.20 8.50±0.20 25.40±0.25 C5030HMC-4P 6.10±0.25 26.20±0.25 10.70±0.20 C5030HFC-5P 8.50±0.20 21.90±0.25 24.67±0.25 Circuit 1 15.09±0.20 5.03±0.10 15.09±0.20 22.20±0.25 Circuit 1 5.03±0.10 C5030HFC-4P 25.40±0.25 C5030HMC-5P 8.50±0.20 26.93±0.25 20.12±0.20 6.10±0.25 5.03±0.10 20.12±0.20 5.03±0.10 27.23±0.25 26.20±0.25 29.70±0.25 Circuit 1 Circuit 1 10.70±0.20 25.40±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-186 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFC/HMC-2xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMC(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFC(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFC C5030HMC C5030HFC-2x2P C5030HMC-2x2P 25.40±0.25 Circuit 1 Circuit 2 Circuit 1 11.13±0.25 Last circuit 10.70±0.20 5.03±0.10 25.40±0.25 5.03±0.10 Circuit 3 Circuit 1 10.06±0.20 5.03±0.10 10.70±0.20 14.64±0.25 5.03±0.20 10.06±0.20 11.84±0.25 C5030HMC-3x2P 5.03±0.20 C5030HFC-3x2P 11.84±0.25 14.64±0.25 Last circuit 26.20±0.25 12.14±0.25 Circuit 2 5.03±0.10 12.14±0.20 5.03±0.10 13.53±0.20 5.03±0.10 Circuit 3 Circuit 1 Last Circuit 26.20±0.25 16.16±0.25 18.56±0.25 25.40±0.25 10.70±0.20 Circuit 3 Circuit 1 16.87±0.25 Circuit 3 Circuit 1 5.03±0.10 19.67±0.25 17.17±0.25 5.03±0.10 10.06±0.20 5.03±0.10 5.03±0.10 10.06±0.20 10.06±0.20 C5030HMC-3x3P 10.06±0.20 C5030HFC-3x3P Last Circuit Last Circuit 26.20±0.25 16.16±0.25 18.56±0.25 10.06±0.20 5.03±0.10 15.09±0.20 22.20±0.25 Circuit 3 Circuit 1 Last Circuit 16.16±0.25 10.70±0.20 18.56±0.25 21.90±0.25 5.03±0.10 5.03±0.10 24.70±0.25 5.03±0.10 10.06±0.20 Circuit 3 Circuit 1 26.20±0.25 25.40±0.25 C5030HMC-3x4P 15.09±0.20 C5030HFC-3x4P Last Circuit Last Circuit 25.40±0.25 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-187 C5030 SERIES C5030H 5.03mm pitch wire to wire and wire to board connector 5.03mm Pitch Housing Ordering Information: C5030HFC/HMC-3xXP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-2 *C5030HMC(Suitable Terminal: C5030M(F)-T(-H) ) *C5030HFC(Suitable Terminal: C5030F(M)-T(-H) ) *Color:Natural C5030HFC C5030HMC C5030HMC-3x5P Circuit 3 Circuit 1 Last Circuit 26.20±0.25 16.16±0.25 C5030WV-3x2P 18.56±0.25 Last Circuit 25.40±0.25 Ordering Information: C5030WV-3x2P - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-2/Natural V0:Nylon 66,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C 5.03±0.10 5.03±0.10 5.03±0.10 Last Circuit 5.03mm Pitch Triple Row Wafer Reference Informations: *Material:Pin:Brass/Gold over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT C5030HFB-3x2P,C5030HFC-3x2P Housing *Color:Natural Circuit 1 26.93±0.25 Circuit 1 10.70±0.20 5.03±0.10 20.12±0.20 5.03±0.10 Circuit 3 5.03±0.10 29.73±0.25 5.03±0.10 10.06±0.20 20.12±0.20 10.06±0.20 5.03±0.10 C5030HFC-3x5P 27.23±0.25 Unit: mm Circuit 3 10.06±0.20 +0.10 Ø1.700 P.C.B LAYOUT 18.75±0.25 13.60±0.20 Ø1.60 3.70±0.20 0.90 11.50±0.20 Ø2.28 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-188
C5030F-TB
物料型号:C5030系列,包括多种型号如C5030F-TB、C5030F-TP、C5030F-GB、C5030F-GP等,以及它们的高电流版本(-H型号)。
器件简介:C5030系列是5.03mm间距的线对线和线对板连接器,具有多种不同的端子和外壳配置。
引脚分配:文档中提供了详细的装配布局和尺寸图,展示了不同型号的引脚分配
参数特性: - 电流额定值:12A AC/DC - 电压额定值:250V AC/DC - 工作温度范围:-40°C至+105°C - 接触电阻:最大10mΩ - 最小绝缘电阻:1000MΩ - 耐受电压:1500V AC/分钟
功能详解:C5030系列连接器符合RoHS和REACH标准,可提供无卤/无卤素、GWT/Glow Wire Test(IEC60335-1)的定制选项。
应用信息:适用于需要高电流和高电压额定的线对线或线对板连接。
封装信息:提供多种材料和表面处理选项,如黄铜镀锡、磷青铜镀金等。还提供了不同线径的适用性,从AWG#14至AWG#24不等。
C5030F-TB 价格&库存
很抱歉,暂时无法提供与“C5030F-TB”相匹配的价格&库存,您可以联系我们找货
C5030F-TB
