C6201M-TP
C6201M-TP
    CJT(长江连接器)
    胶壳端子 14-20AWG
C6201M-TP 数据手册
C6201 SERIES 6.20mm pitch wire to wire and wire to board connector Specifications Current rating:23A AC,DC Voltage rating:600V AC,DC Temperature range:-40°C~+105°C Contact resistance:7mΩ Max. Insulation resistance:1000MΩ Min. Withstanding voltage:2000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 1.60 29.20 27.40REF 12.20 Inner-housing lock 14.60 21.60 Outer-housing lock wire to board type CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-197 44.10(including retainer) 40.50.REF 44.10(including retainer) 40.50.REF 40.50.REF 19.20 44.10(including retainer) 44.10(including retainer) 40.50.REF 1.60 19.20 29.40 27.40REF 12.20 C6201 SERIES 6.20mm pitch wire to wire and wire to board connector 14.60 Inner-housing lock 29.20 REF. 29.20 REF. 29.20 REF. 21.60 29.20 REF. 19.20 13.20 Outer-housing lock A D E C D 0.50±0.10 12.20±0.10 C E 4.20±0.10 B A B ShapeⅠ PART NO. C6201HM-2P C6201HM-3P C6201HM-4P C6201HM-2X2P C6201HM-2X3P C6201HM-2X4P C6201HM-2X6P ShapeⅡ Panel hole shape Ⅰ Ⅰ Ⅰ Ⅱ Ⅱ Ⅱ Ⅱ Panel hole Dimensions A B C D E 13.80 20.60 5.70 8.50 1.40 20.00 26.80 5.70 8.50 1.40 26.20 33.00 5.70 8.50 1.40 13.80 20.60 7.00 15.40 4.20 20.00 26.80 7.00 15.40 4.20 26.20 33.00 7.00 15.40 4.20 38.90 45.40 7.00 15.40 4.20 applicable panel thickness (mm) 0.5-2.0 Note:1.Punch holes in the panel according to the sketch and table shown above.Burrs must be removed 2.The strength of the panel must be considered when punching two or more holes. 3.The connector must be inserted from the same side as the hole is punched CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-198 18.60±0.10 9.80±0.10 9.80±0.10 C6201 SERIES C6201F-T 6.20mm pitch wire to wire and wire to board connector 6.20mm pitch Crimp Terminal Reference Informations: *Used in CJT C6201HF,HFA series Housing 6.00±0.25 3.45±0.25 B 7.71±0.20 B SEC:A-A 3.60 A 16.70±0.25 A 7.30±0.20 5.50±0.25 0.25 3.80±0.25 SEC:B-B 4.10±0.10 3.10±0.20 Unit:mm Ordering information & Specifications: Wire Range Insulation O.D. Material Finish Qty/reel C6201F-TP AWG#14-#20 4.10mm(max) Phosphor Bronze Tin over Nickel 2,000 PCS C6201F-GP AWG#14-#20 4.10mm(max) Phosphor Bronze Gold over Nickel 2,000 PCS Part NO. Optional Gold plating available but MOQ requested C6201M-T 6.20mm pitch Crimp Terminal Reference Informations: *Used in CJT C6201HM,HMA series Housing 0.25 SEC:A-A 3.45±0.25 10.50±0.20 4.10±0.10 2.10 B 22.20±0.25 B 5.50±0.25 A 3.60 A 7.30±0.20 6.00±0.25 3.80±0.25 SEC:B-B 3.20±0.10 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel C6201M-TP AWG#14-#20 4.10mm(max) Phosphor Bronze Tin over Nickel 2,000 PCS C6201M-GP AWG#14-#20 4.10mm(max) Phosphor Bronze Gold over Nickel 2,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-199 C6201 SERIES C6201H 6.20mm pitch wire to wire and wire to board connector 6.20mm Pitch Housing Ordering Information: C6201HF/HFA-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0/White V2:Nylon 66,UL94V-2/Natural GWT:Nylon 66,UL94V-0,GWT 750°C C6201HM C6201S-1P 11.40±0.25 11.20±0.25 C6201HF-1P 5.90 26.90±0.25 3.80 5.40±0.10 7.20±0.25 7.20±0.20 12.20±0.25 Ordering Information: C6201S-XP - ** 1 2 1.Part No. 2.Color: (blank):Blue IV:Ivory Retainer C6201HF 8.40±0.20 C6201HM-1P Ordering Information: C6201HM/HMA-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0/White V2:Nylon 66,UL94V-2/Natural GWT:Nylon 66,UL94V-0,GWT 750°C 9.70 6.15 5.20 Reference Informations: *Material:Housing:Nylon 66,UL94V-0 Retainer:Nylon 66,UL94V-0 *C6201HM(Suitable Terminal: C6201M-T) *C6201HF(Suitable Terminal: C6201F-T) *Color:White 24.00±0.25 12.90±0.20 6.20±0.10 12.20±0.25 9.40±0.20 16.80±0.20 10.20±0.20 8.20±0.20 C6201HF-2P 9.40±0.20 24.00±0.25 11.00±0.20 13.40±0.25 3.40±0.20 5.90 3.80 9.70 6.15 5.80 Circuit 1 29.50±0.25 14.60±0.25 13.60±0.20 8.20±0.20 C6201HFA-2P 11.20±0.25 C6201HMA-2P C6201S-2P 11.00±0.20 15.00±0.25 6.20±0.10 9.40±0.20 Circuit 1 15.00±0.25 13.40±0.25 6.20±0.10 24.00±0.25 8.40±0.25 Circuit 1 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-200 11.40 Circuit 1 29.50±0.25 13.40±0.25 6.20±0.10 C6201HM-2P 11.20±0.25 29.50±0.25 C6201 SERIES 9.40±0.20 19.60±0.25 10.20±0.25 6.20±0.10 12.40±0.20 11.00±0.20 3.80 5.90 9.70 6.15 17.60 24.00±0.25 8.40±0.25 15.00±0.25 11.00±0.20 19.60±0.25 6.20±0.10 13.60±0.20 14.60±0.25 29.50±0.25 12.40±0.20 8.20±0.20 11.20±0.25 C6201HFA-3P 9.40±0.20 6.20±0.10 19.60±0.25 12.40±0.20 24.00±0.25 Circuit 1 C6201HMA-3P Circuit 1 C6201S-3P 12.20±0.25 C6201HF-3P 16.80±0.20 9.40±0.20 8.20±0.20 29.50±0.25 3.40±0.20 19.60±0.25 Circuit 1 6.20mm Pitch Housing 12.40±0.20 6.20±0.10 C6201HM-3P 11.20±0.25 C6201H 6.20mm pitch wire to wire and wire to board connector Circuit 1 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-201 C6201 SERIES 8.20±0.20 6.20mm Pitch Housing 29.50±0.25 C6201HFA-4P C6201S-4P 16.80±0.20 13.60±0.20 14.60±0.25 9.40±0.20 Circuit 1 18.60±0.20 25.80±0.25 6.20±0.10 C6201HM-4P 11.20±0.25 C6201H 6.20mm pitch wire to wire and wire to board connector 5.90 9.70 6.15 24.00±0.25 8.40±0.25 11.00±0.20 10.40 23.80 3.40 6.20±0.10 3.80 25.80±0.25 15.00±0.25 29.50±0.25 18.60±0.20 8.20±0.20 11.20±0.25 C6201HMA-4P 25.80±0.25 9.40±0.20 Circuit 1 18.60±0.20 6.20±0.10 Circuit 1 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-202 C6201 SERIES C6201H 6.20mm Pitch Housing 29.50±0.25 C6201HF-2x2P C6201S-2P 15.40±0.20 18.20±0.25 10.20±0.20 13.40±0.25 13.40±0.25 5.90 3.80 5.80 3.40±0.20 9.70 6.15 6.20±0.10 24.00±0.25 11.00±0.20 13.40±0.25 15.00±0.25 Circuit 4 20.60±0.20 15.40±0.20 C6201HFA-2x2P 3.00±0.25 15.00±0.20 9.40±0.20 6.20±0.10 Circuit 1 11.00±0.20 29.50±0.25 C6201HMA-2x2P Circuit 2 24.00±0.25 Circuit 2 Circuit 1 9.40±0.20 Circuit 4 Circuit 4 10.20±0.20 6.20±0.10 Circuit 1 Circuit 2 6.20±0.10 3.00±0.25 15.00±0.20 16.80±0.20 11.40 C6201HM-2x2P 6.20mm pitch wire to wire and wire to board connector Circuit 2 Circuit 1 Circuit 4 3.40±0.20 19.60±0.25 3.80 5.90 9.70 6.15 15.40±0.20 Circuit 2 Circuit 1 3.00±0.25 20.60±0.25 29.50±0.25 19.60±0.25 24.00±0.25 11.00±0.20 Circuit 6 15.00±0.20 19.60±0.25 6.20±0.10 15.40±0.25 12.40±0.20 9.40±0.20 15.00±0.20 12.40±0.20 6.20±0.10 Circuit 1 11.00±0.20 C6201HFA-2x3P C6201HMA-2x3P Circuit 2 24.00±0.25 17.60 9.40±0.20 Circuit 6 C6201S-3P 19.60±0.25 Circuit 6 10.20±0.20 Circuit 1 Circuit 2 6.20±0.10 12.40±0.20 3.00±0.25 15.00±0.20 12.40±0.20 6.20±0.10 C6201HF-2x3P 16.80±0.20 18.20±0.25 29.50±0.25 C6201HM-2x3P Circuit 2 Circuit 1 Circuit 6 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-203 C6201 SERIES C6201H 6.20mm Pitch Housing 29.50±0.25 16.80±0.20 18.20±0.25 15.40±0.20 9.40±0.20 10.20±0.20 11.00±0.20 25.80±0.25 18.60±0.20 24.00±0.25 5.90 Circuit 2 3.80 9.70 6.15 10.40 23.80 C6201HFA-2x4P 15.00±0.20 25.80±0.25 24.00±0.25 11.00±0.20 Circuit 8 25.80±0.25 9.40±0.20 15.40±0.25 6.20±0.10 18.60±0.20 3.00±0.25 15.00±0.20 20.60±0.25 29.50±0.25 Circuit 1 18.60±0.20 C6201S-4P Circuit 1 C6201HMA-2x4P Circuit 2 Circuit 8 3.40±0.20 25.80±0.25 Circuit 2 6.20±0.10 18.60±0.20 15.00±0.20 6.20±0.10 Circuit 1 Circuit 8 6.20±0.10 C6201HF-2x4P 3.00±0.25 C6201HM-2x4P 6.20mm pitch wire to wire and wire to board connector Circuit 2 Circuit 1 Circuit 8 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-204 C6201 SERIES C6201H C6201HM-2x6P 6.20mm pitch wire to wire and wire to board connector 6.20mm Pitch Housing C6201HF-2x6P 29.50±0.25 C6201S-6P 24.00±0.25 11.00±0.20 9.40±0.20 38.20±0.25 31.00±0.20 6.20±0.10 3.40±0.20 38.20±0.25 Circuit 12 31.00±0.20 18.20±0.25 15.40±0.20 3.00±0.25 Circuit 1 Circuit 2 10.20±0.20 6.20±0.10 15.00±0.20 16.80±0.20 5.90 3.80 9.70 6.15 Circuit 2 Circuit 1 C6201HMA-2x6P C6201HFA-2x6P 20.60±0.25 3.00±0.25 Circuit 1 Circuit 2 15.40±0.25 31.00±0.20 6.20±0.10 38.20±0.25 9.40±0.20 38.20±0.25 24.00±0.25 11.00±0.20 Circuit 12 15.00±0.20 15.00±0.20 29.50±0.25 31.00±0.20 6.20±0.10 22.80 36.20 Circuit 12 Circuit 2 Circuit 1 Circuit 12 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-205 C6201 SERIES C6201WV-XP 6.20mm pitch 180° Single Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C6201HF,HFA-XP series Housing *Color:White A±0.10 3.60 6.20±0.05 Circuit 1 Circuit 1 6.84 Ordering Information: ∅2.10±0.05 C6201WV-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0/White V2:Nylon 66,UL94V-2/Natural GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.20±0.10 A±0.20 6.20mm pitch wire to wire and wire to board connector P.C.B LAYOUT A±0.20 11.20±0.20 B±0.25 B±0.25 12.00±0.20 16.40±0.25 16.40±0.25 8.20±0.20 Ordering Information & Dimensions: 1.80±0.05 1.80±0.05 2P PART NO. 3.30 3.30 2.00 1.60±0.05 2P 3P 4P 3P~4P Dimensions A B 6.20 13.40 12.40 19.60 18.60 25.80 Unit: mm C6201WV-2xXP 6.20mm pitch 180° Dual Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT C6201HF,HFA-2xXP series Housing *Color:White Ordering Information: C6201WV-2xXP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0/White V2:Nylon 66,UL94V-2/Natural GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Last Circuit A±0.10 ∅2.10±0.05 6.20±0.05 3.60 Circuit 1 18.00±0.20 B±0.25 1.80±0.05 3.30 P.C.B LAYOUT 12.00±0.20 16.40±0.25 15.00±0.20 8.28±0.05 A±0.20 3.40 6.20±0.10 Circuit 2 Ordering Information & Dimensions: PART NO. 2x2P 2x3P 2x4P 2x6P 1.60±0.05 8.28±0.20 Dimensions A B 6.20 13.40 12.40 19.60 18.60 25.80 31.00 38.20 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-206 C6201 SERIES C6201F-TCA 6.20mm pitch wire to wire and wire to board connector 5.70mm pitch Crimp Terminal Reference Informations: *Used in CJT C6201HFB-2xXP series Housing 0.30 A 2.50±0.25 3.50±0.25 2.58±0.20 9.00±0.25 3.55±0.25 SEC:A-A 11.08±0.25 18.65±0.30 A 3.55±0.30 3.40±0.30 2.08±0.20 2.30±0.20 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel C6201FB-TCA AWG#14-#16 3.75mm(max) Brass Tin over Nickel 2,000 PCS C6201FP-TCA AWG#14-#16 3.75mm(max) Phosphor Bronze Tin over Nickel 2,000 PCS C6201FB-GCA AWG#14-#16 3.75mm(max) Brass Gold over Nickel 2,000 PCS C6201FP-GCA AWG#14-#16 3.75mm(max) Phosphor Bronze Gold over Nickel 2,000 PCS Optional Gold plating available but MOQ requested C6201F-TCA-H 5.70mm pitch Crimp Terminal Reference Informations: *Used in CJT C6201HFB-2xXP series Housing 0.30 A 2.50±0.25 3.50±0.25 SEC:A-A 2.58±0.20 9.00±0.25 3.55±0.25 11.08±0.25 18.65±0.30 A 4.80±0.30 5.00±0.30 2.08±0.20 2.30±0.20 Unit:mm Ordering information & Specifications: Part NO. Wire Range Insulation O.D. Material Finish Qty/reel C6201FB-TCA-H AWG#12 4.35mm(max) Brass Tin over Nickel 2,000 PCS Phosphor Bronze C6201FP-TCA-H AWG#12 4.35mm(max) Tin over Nickel 2,000 PCS C6201FB-GCA-H AWG#12 4.35mm(max) Brass Gold over Nickel 2,000 PCS C6201FP-GCA-H AWG#12 4.35mm(max) Phosphor Bronze Gold over Nickel 2,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-207 C6201 SERIES C6201WRB-F-2xXP 6.20mm pitch wire to wire and wire to board connector 5.70mm pitch 90° Dual Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:LCP,UL94V-0 *Mates with CJT C6201HFB-2xXP series Housing *Color:Black Ordering Information: C6201WRB-F-2xXP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):LCP,UL94V-0 GWT:LCP,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 5.70±0.10 B±0.25 3.60±0.20 14.80±0.25 12.93±0.25 A±0.20 5.70±0.10 Last Circuit 2x1P 2x2P 2x3P Circuit 1 2x5P 2x4P 3.00 2.85 Circuit 2 2.90 7.30 5.50 Ordering Information & Dimensions: 5.70 ∅1.80 5.50 5.50 A 5.70 PART NO. ∅1.80 ∅3.00 2x1P 2x2P 2x3P 2x4P 2x5P 2x6P 7.30 ∅3.00 7.30 7.30 ∅1.80 ∅3.00 2x2P 2x3P~2x6P 2x6P 2x1P Dimensions A B 8.35 ----5.70 12.05 11.40 17.75 17.10 23.45 22.80 29.15 28.50 34.85 P.C.B LAYOUT C6201WVC-XP Unit: mm 6.50mm pitch 180° Single Row Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66+GF,UL94V-0 *Color:Ivory 10.80±0.20 1.50 15.50±0.25 B±0.25 1.50 15.50±0.25 B±0.25 Ordering Information: C6201WVC-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66+GF,UL94V-0/Ivory PBT:PBT+GF,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C/Ivory 3.Color: (blank):Ivory RD:Red BK:Black BL:Blue YL:Yellow GN:Green 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 4.50±0.05 A±0.20 6.50±0.05 2.00 6.50±0.10 0.45 1.20±0.05 3.80±0.20 3.80±0.20 1.20±0.05 2.00 4.50 ∅1.40±0.05 6.50±0.10 ∅1.40±0.05 2.00±0.05 P.C.B LAYOUT Ordering Information & Dimensions: A±0.20 A±0.20 2P 3P~4P PART NO. 2P 3P 4P Dimensions A B 6.50 12.30 13.00 18.80 19.50 25.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-209 C6201 SERIES C6201WVC-2xXP 6.20mm pitch wire to wire and wire to board connector 6.50mm pitch 180° Dual Row Wafer Ordering Information: C6201WVC-2xXP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66+GF,UL94V-0/Ivory PBT:PBT+GF,UL94V-0/White GWT:Nylon 66,UL94V-0,GWT 750°C/Ivory 3.Color: (blank):Ivory RD:Red BK:Black BL:Blue YL:Yellow GN:Green 4.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66+GF,UL94V-0 *Color:Ivory B±0.25 3.80±0.20 1.20±0.05 2.00 6.50±0.10 1.50 15.50±0.25 16.40±0.25 1.20±0.05 3.80±0.20 1.40 15.50±0.25 B±0.25 0.45 4.50 2.00 6.50±0.05 6.50±0.10 A±0.20 6.50±0.05 A±0.20 ∅1.40±0.05 2.00±0.05 2x2P 2x3P P.C.B LAYOUT 6.50±0.05 A±0.20 4.50±0.05 ∅1.40±0.05 Ordering Information & Dimensions: PART NO. 2x2P 2x3P Dimensions A B 6.50 12.30 13.00 18.80 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn C-210
C6201M-TP 价格&库存
很抱歉,暂时无法提供与“C6201M-TP”相匹配的价格&库存,您可以联系我们找货
C6201M-TP
    • 10+0.24450
    • 100+0.22950
    • 500+0.21450
    • 2000+0.19950
    • 5000+0.18900
    • 10000+0.18450
    库存:2025
