MYD-Y6ULY2-256N256D-50-I
    MYIR(米尔科技)
MYD-Y6ULY2-256N256D-50-I 数据手册
MYD-Y6ULX Development Board          MYC-Y6ULX CPU Module as Controller Board 528Hz NXP i.MX 6UL/6ULL ARM Cortex-A7 Processors 1.0mm pitch 140-pin Stamp Hole Expansion Interface for Board-to-Board Connections 256MB DDR3 SDRAM, 256MB Nand Flash or 4GB eMMC Flash 2 x USB2.0 Host, 1 x USB2.0 OTG, 2 x 10/100 Mbps Ethernets , CAN, RS485, TF, LCD, Camera, Audio… Onboard SDIO based WiFi Module with External Antennas Mini-PCIe Slot for Optional USB based 4G LTE Module Optional 4.3 or 7 inch LCD/TSP and Camera Module Ready-to-Run Linux 4.1.15 Figure 1-1 MYD-Y6ULX Development Board Description The MYD-Y6ULX development board is a complete evaluation platform for NXP’s i.MX 6UltraLite / 6ULL processor family, which can operate at 528 MHz and features the most efficient ARM Cortex-A7 core, providing various memory interfaces and enhancing the flexibility and convenience of the board to connect peripheral devices. The board is ready to run Linux and supports industrial operating temperature range from -40 to +85 Celsius. The MYD-Y6ULX development board employs the MYC-Y6ULX CPU Module as the controller board by populating the CPU Module on its base board through 1.0mm pitch 140-pin stamp hole interface. The MYC-Y6ULX 1 / 11 CPU Module is mounted with a shield cover and integrated with core components including i.MX 6UltraLite / 6ULL processor, 256MB DDR3, 256MB Nand Flash or optional 4GB eMMC and Ethernet PHY. The base board has extended rich peripherals through connectors and headers like Serial ports, USB, Ethernet, CAN, Micro SD card, WiFi module, LCD/Touch screen, Camera, Audio as well as an optional Mini PCIe interface for USB based 4G LTE module. It is a versatile platform and solid reference design delivered with necessary cable accessories detailed documentations ideal for prototype and evaluation based on i.MX 6UL/6ULL solutions. MYIR offers three models of MYD-Y6ULX development boards with mainly different features as shown in below table. User can select model according to their own requirement. MYD-Y6ULX MYD-Y6ULG2-256N256D-50-I MYD-Y6ULY2-256N256D-50-C MYD-Y6ULY2-4E512D-50-C Processor MCIMX6G2CVM05AB MCIMX6Y2DVM05AA MCIMX6Y2DVM05AA MYC-Y6ULX RAM Flash WiFi Working Temp. MYC-Y6ULG2-256N256D-50-I 256MB DDR3 256MB Nand Flash Support -40 to +85 Celsius MYC-Y6ULY2-256N256D-50-C 256MB DDR3 256MB Nand Flash Support 0 to +70 Celsius WiFi Module can only support -20 to +65 Celsius. MYC-Y6ULY2-4E512D-50-C 512MB DDR3 4GB eMMC Cannot support Reuse SDIO with eMMC 0 to +70 Celsius Table 1-1 Three Models of MYD-6ULX (default configurations) 2 / 11 Hardware Specification The MYC-Y6ULX CPU Module is using the 14 x 14mm, 0.8 mm ball pitch, 289 MAPBGA package 528 MHz i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 application processor which provides multiple compatible options of G0, G1, G2, G3, Y0, Y1 and Y2 sub family. The MCIMX6G2CVM05AB and MCIMX6Y2DVM05AA are optional as the default part with the board. Expanding the i.MX 6 series, the i.MX 6UltraLite is a high performance, ultra-efficient processor family featuring an advanced implementation of a single ARM® Cortex®-A7 core, which operates at speeds up to 696 MHz. The i.MX 6UltraLite applications processor includes an integrated power management module that reduces the complexity of external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth™, GPS, displays and camera sensors. Feature MCIMX6G0 MCIMX6G1 MCIMX6G2 MCIMX6G3 Speed 528 MHz 528 MHz, 696 MHz 528 MHz, 696 MHz 528 MHz 128 KB L2 128 KB L2 Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Security Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI S/PDIF Timer/PWM 12-bit ADC 3 / 11 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 128 KB 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 512-bit 1024-bit 1536-bit 2048-bit DDR3/DDR3L Yes DDR3/DDR4L Yes Yes Yes DDR3/DDR5L Yes Yes DDR3/DDR6L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 10/100-Mbit/s x 2 0 1 2 2 OTG, HS/FS x 1 Basic OTG, HS/FS x 2 OTG, HS/FS x 2 TRNG, Crypto Engine TRNG, Crypto Engine Secure Boot Secure Boot (AES/TDES/SHA), (AES/TDES/SHA), TRNG, Crypto Engine (AES with DPA/TDES/SHA/RSA), Secure Boot, tamper monitor, PCI4.0 pre-certification, OTF DRAM encryption None None None None 24-bit Parallel LCD 24-bit Parallel LCD 2 2 2 None None 1 1 2 4 8 2 4 2 4 1 1 3 Timer x 2, PWM x 4 1 x 10-ch. 1 Timer x 4, PWM x 8 1 x 10-ch. PxP OTG, HS/FS x 2 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. Table 1-2 i.MX 6UltraLite Device Options PxP 24-bit Parallel CSI 1 8 4 4 3 1 Timer x 4, PWM x 8 2 x 10-ch. The i.MX 6ULL is a power efficient and cost optimized applications processor family featuring an advanced implementation of a single ARM Cortex-A7 core, which operates at speeds up to 900 MHz. The i.MX 6ULL applications processor includes an integrated power management module that reduces the complexity of an external power supply and simplifies power sequencing. Each processor in this family provides various memory interfaces, including 16-bit LPDDR2, DDR3, DDR3L, raw and managed NAND flash, NOR flash, eMMC, Quad SPI and a wide range of other interfaces for connecting peripherals such as WLAN, Bluetooth®, GPS, displays and camera sensors. Feature MCIMX6Y0 MCIMX6Y1 MCIMX6Y2 Core ARM® Cortex-A7 ARM® Cortex-A7 ARM® Cortex-A7 32 KB-I, 32 KB-D 32 KB-I, 32 KB-D 128 KB 128 KB Speed Cache OCRAM DRAM eFuse NAND (BCH40) EBI Ethernet USB CAN Graphic CSI LCD Quad SPI SDIO UART I2C SPI I2S/SAI ESAI S/PDIF Timer/PWM 12-bit ADC Security Temperature 528 MHz 32 KB-I, 32 KB-D 128 KB 528 MHz 128 KB L2 128 KB L2 16-bit LP-DDR2, 16-bit LP-DDR2, 16-bit LP-DDR2, 256-bit 256-bit 256-bit DDR3/DDR3L Yes Yes DDR3/DDR4L Yes Yes DDR3/DDR5L Yes Yes 10/100-Mbit/s x 1 10/100-Mbit/s x 1 10/100-Mbit/s x 2 0 1 2 OTG, HS/FS x 1 OTG, HS/FS x 2 OTG, HS/FS x 2 None None None None 24-bit Parallel LCD 2 2 None 1 2 4 2 2 1 1 1 None 1 8 4 4 3 1 1 PxP 16-bit Parallel CSI 1 8 4 4 3 1 1 Timer x 2, PWM x 4 Timer x 4, PWM x 8 Timer x 4, PWM x 8 None AES-128, HAB AES-128, HAB 1 x 10-ch. -40°C to 105°C (Tj) 1 x 10-ch. -40°C to 105°C (Tj) Table 1-3 i.MX 6ULL Device Options 4 / 11 528 MHz 2 x 10-ch. 0°C to 90°C (Tj) Mechanical Parameters • Dimensions: 105mm x 140mm (base board), 37mm x 39mm (CPU Module) • PCB Layers: 4-layer design (base board), 8-layer design (CPU Module) • Power supply: +12V/1.5A (base board), +3.3V/0.3A (CPU Module) • Working temperature: 0~70 Celsius (commercial grade) or -40~85 Celsius (industrial grade) The MYD-Y6ULX Controller Board (MYC-Y6ULX CPU Module) Figure 1-2 MYC-Y6ULX CPU Module (delivered with shield cover) Processor • 528MHz NXP i.MX 6UltraLite / i.MX 6ULL ARM Cortex-A7 processor (MCIMX6G2CVM05AB or MCIMX6Y2DVM05AA by default) Memory • • 256MB DDR3 SDRAM (supports up to 1GB) 256MB Nand Flash (4GB eMMC Flash is optional) Peripherals and Signals Routed to Pins MYC-Y6ULX Pinouts Description • One 10/100M Ethernet PHY • 1.0mm pitch 140-pin stamp hole expansion interface - 2 x 10/100Mbps Ethernet - 8 x Serial ports - 4 x I2C - 2 x CAN - 4 x SPI - 8 x ADC - 8 x PWM - 3 x I2S - 1 x Parallel Camera Sensor Interface 5 / 11 - 1 x JTAG - 1 x 24-bit LCD interface - Up to 97 x GPIOs Note: the peripheral signals brought out to the expansion interface are listed in maximum number. Some signals are reused. Please refer to the processor datasheet. The MYD-Y6ULX Base Board Figure 1-3 MYD-Y6ULX Base Board • • • • • • • • • • • • • • 6 / 11 Serial ports - 1 x Debug serial port (TTL) - 1 x RS485 serial port (with isolation) - 1 x 3-wire RS232 serial port (with isolation) USB - 2 x USB2.0 Host ports - 1 x Micro USB2.0 OTG ports 1 x Mini PCIe interface (for optional USB based 4G LTE module) 1 x SIM card socket 1 x SDIO based WiFi module 2 x External antenna interfaces (one for WiFi module and one for 4G LTE module) 2 x 10/100 Mbps Ethernet interfaces 1 x Camera interface 1 x CAN interface (with isolation) 1 x Micro SD card slot 1 x LCD interface (16-bit true color, supports optional 4.3-inch and 7-inch TFT LCD) Battery backed RTC Audio input/output port (3.5mm jack) 3 x Buttons (1 x Reset button, 1 x User button, 1 x ON/OFF button) • • 2 x LEDs (1 x power indicator LED, 1 x user-defined LED) 1 x 2.0mm 20-pin male expansion connector - 1 x SPI - 1 x I2C - 2 x UART - 10 x GPIO Figure 1-4 MYD-Y6ULX Development Board 7 / 11 Function Block Diagram Figure 1-5 MYC-Y6ULX Function Block Diagram Figure 1-6 MYD-Y6ULX Function Block Diagram 8 / 11 Dimension Chart of MYD-Y6ULX Figure 1-7 Dimension Chart of MYD-Y6ULX 9 / 11 Software Features The MYD-Y6ULX development board supports running Linux Operating System and is provided with software packages. Software features are summarized as below: Item Bootstrap program Kernel Features Description u-boot The primary bootstrap (source code) USB HOST and OTG driver (source code) Version Linux 4.1.15 (source code, based on official imx_4.1.15_2.0.0_ga version) Ethernet Ethernet driver (source code) MMC MMC/eMMC/TF card driver (source code) NandFlash Nand Flash driver (source code) eMMC eMMC driver (source code) WiFi WiFi Module driver (SDIO signal, source code) 4G LTE Camera Linux Drivers LCD Controller Touch Panel RTC GPIO Button GPIO LED GPIO KEY UART LCD driver (source code, supports MYIR’s 4.3- and 7- inch LCD) Resistive and Capacitive touch screen driver (source code) RTC driver (source code) Button driver (source code) LED driver (source code) KEY driver (source code) CAN driver (source code) RS485 RS485 driver (source code) Audio Audio (wm8904) driver (source code) UART Compiler Tool Chain Camera driver (source code, supports MYIR’s MY-CAM011B) UART driver (source code) CAN File System 4G LTE Module driver (USB signal, source code) UART driver (source code) SPI SPI driver (source code) I2C Yocto Linaro GCC 4.9 hf MetaToolchain Applications Tool Chain I2C driver (source code) Including QT5.6 (source code) Binary file Built by Yocto, GCC 5.3 (Binary file) Built by Yocto, GCC 5.3 (Binary file) Table 1-4 Software Features of MYD-Y6ULX 10 / 11 Order Information Product Item MYD-Y6ULX Development Board MYC-Y6ULX CPU Module MY-LCD43TP 4.3-inch LCD Module with resistive touch screen MY-LCD70TP 7-inch LCD Module with resistive touch screen MY-LCD70TP-C 7-inch LCD Module with capacitive touch screen MY-CAM011B Camera Module Part No. Packing List MYD-Y6ULG2-256N256D-50-I  One MYD-Y6ULX Development Board  One 12V/1.5A Power adapter  One USB cable  One Ethernet cable  One 4G LTE antenna  One WiFi antenna (MYC-Y6ULY2-4E512D-50-C has none.)  One Product Disk (including user manual, datasheet, base board schematic, CPU module pinouts and software packages) MYD-Y6ULY2-256N256D-50-C MYD-Y6ULY2-4E512D-50-C MYC-Y6ULG2-256N256D-50-I MYC-Y6ULY2-256N256D-50-C MYC-Y6ULY2-4E512D-50-C MY-TFT043RV2 MY-TFT070RV2 MY-TFT070CV2 MY-CAM011B MYIR Tech Limited Room 04, 6th Floor, Building No.2, Fada Road, Yunli Intelligent Park, Bantian, Longgang District, Shenzhen, Guangdong, China 518129 E-mail: sales@myirtech.com Phone: +86-755-22984836 Fax: +86-755-25532724 Website: http://www.myirtech.com 11 / 11 Add-on Options  MYC-Y6ULX CPU Module  MY-LCD43TP 4.3-inch LCD Module  MY-LCD70TP 7-inch LCD Module  MY-LCD70TP-C 7-inch LCD Module  MY-CAM011B Camera Module
MYD-Y6ULY2-256N256D-50-I 价格&库存
很抱歉,暂时无法提供与“MYD-Y6ULY2-256N256D-50-I”相匹配的价格&库存,您可以联系我们找货
